Solving Kirsch's problem using the release nodal force approach: run with MPI parallel computing
import gmsh
Run “Solving Kirsch’s problem using the release nodal force approach” with MPI parallel computing
if not out_dir.exists():
    out_dir.mkdir(parents=True)
1. Mesh generation
if not gmsh.isInitialized():… (click to toggle)
    gmsh.initialize()
gmsh.model.add("Mesh")
gmsh.finalize()
Info    : Meshing 1D...
Info    : Done meshing 1D (Wall 0.00312779s, CPU 0.003312s)
Info    : Meshing 2D...
Info    : Done meshing 2D (Wall 0.00695529s, CPU 0.006924s)
Info    : 1469 nodes 2051 elements
Info    : Writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.msh'...
Info    : Done writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.msh'
INFO:ogstools.meshes.gmsh_converter:Detected domain dimension of 2
INFO:ogstools.meshes.gmsh_converter:Found material IDs: [1]
INFO:ogstools.meshes.gmsh_converter:Renumbered to: [0]
INFO:ogstools.meshes.gmsh_converter:domain: UnstructuredGrid (0x7fab0b57a620)
  N Cells:    1674
  N Points:   1391
  X Bounds:   0.000e+00, 7.000e+01
  Y Bounds:   -8.570e+02, -7.870e+02
  N Arrays:   1
[0] info: Reordering nodes...
[0] info: Corrected 1674 elements.
[0] info: VTU file written.
INFO:ogstools.meshes.gmsh_converter:arc: UnstructuredGrid (0x7fab0b57a9e0)
  N Cells:    19
  N Points:   20
  X Bounds:   0.000e+00, 6.500e+00
  Y Bounds:   -8.570e+02, -8.505e+02
  N Arrays:   2
INFO:ogstools.meshes.gmsh_converter:left: UnstructuredGrid (0x7fab05ef8520)
  N Cells:    64
  N Points:   65
  X Bounds:   0.000e+00, 0.000e+00
  Y Bounds:   -8.505e+02, -7.870e+02
  N Arrays:   2
INFO:ogstools.meshes.gmsh_converter:bottom: UnstructuredGrid (0x7fab05ef8a60)
  N Cells:    64
  N Points:   65
  X Bounds:   6.500e+00, 7.000e+01
  Y Bounds:   -8.570e+02, -8.570e+02
  N Arrays:   2
INFO:ogstools.meshes.gmsh_converter:top: UnstructuredGrid (0x7fab05ef8c40)
  N Cells:    14
  N Points:   15
  Y Bounds:   -7.870e+02, -7.870e+02
  N Arrays:   2
INFO:ogstools.meshes.gmsh_converter:right: UnstructuredGrid (0x7fab05ef8e20)
  N Cells:    14
  N Points:   15
  X Bounds:   7.000e+01, 7.000e+01
  N Arrays:   2
INFO:ogstools.meshes.gmsh_converter:Conversion complete.
domain: 1674 cells
arc: 19 cells
left: 64 cells
bottom: 64 cells
top: 14 cells
right: 14 cells
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.vtu
[0] info: Create a quadratic order mesh
[0] info: Save the new mesh into a file
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top.vtu
[0] info: Mesh reading time: 0.0119992 s
[0] info: MeshNodeSearcher construction time: 0.000179236 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 0.000338202 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000810798 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.13e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000150465 s
[0] info: There is already a 'bulk_element_ids' property present in the subdomain mesh 'arc' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.0101e-05 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000162155 s
[0] info: There is already a 'bulk_element_ids' property present in the subdomain mesh 'left' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.0891e-05 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000160935 s
[0] info: There is already a 'bulk_element_ids' property present in the subdomain mesh 'bottom' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.88e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00395072 s
[0] info: There is already a 'bulk_element_ids' property present in the subdomain mesh 'top' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.86e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000153875 s
[0] info: There is already a 'bulk_element_ids' property present in the subdomain mesh 'right' and it is equal to the newly computed values.
[0] info: identifySubdomains time: 0.00583332 s
[0] info: writing time: 0.0208825 s
[0] info: Entire run time: -1.83263e+07 s
2. Partitioning meshes
bulk_mesh = Path(mesh_dir, "domain.vtu")… (click to toggle)
num_parts = 3
ot.cli().partmesh("-s", "-i", bulk_mesh, "-o", mesh_dir)
ot.cli().partmesh(
    "-m",
    "-n",
    str(num_parts),
    "-i",
    bulk_mesh,
    "-o",
    mesh_dir,
    Path(mesh_dir, "left.vtu"),
    Path(mesh_dir, "right.vtu"),
    Path(mesh_dir, "top.vtu"),
    Path(mesh_dir, "bottom.vtu"),
    Path(mesh_dir, "arc.vtu"),
[0] info: Mesh 'domain' read: 4455 nodes, 1674 elements.
[0] info: Property global_node_ids is added to mesh domain
[0] info: Property global_element_ids is added to mesh domain
[0] info: Write the mesh into METIS input file.
[0] info: Total runtime: 0.00472962 s.
[0] info: Total CPU time: 0.004722 s.
[0] info: METIS is running ...
[0] info: Path to mpmetis is:
[0] info: Running: mpmetis -gtype=nodal "/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.mesh" 3
METIS 5.2.1 Copyright 1998-22, Regents of the University of Minnesota
 (HEAD: unknown, Built on: Mar 31 2026, 09:31:44)
 size of idx_t: 64bits, real_t: 32bits, idx_t *: 64bits
Mesh Information ------------------------------------------------------------
 Name: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.mesh, #Elements: 1674, #Nodes: 4455, #Parts: 3
Options ---------------------------------------------------------------------
 ptype=kway, objtype=cut, ctype=shem, rtype=greedy, iptype=metisrb
 dbglvl=0, ufactor=1.030, minconn=NO, contig=NO, nooutput=NO
 seed=-1, niter=10, ncuts=1
 gtype=nodal, ncommon=1, niter=10, ncuts=1
Direct k-way Partitioning ---------------------------------------------------
 - Edgecut: 479.
Timing Information ----------------------------------------------------------
  I/O:          		   0.001 sec
  Partitioning: 		   0.003 sec   (METIS time)
  Reporting:    		   0.000 sec
Memory Information ----------------------------------------------------------
  Max memory used:		   1.725 MB
  rusage.ru_maxrss:		 111.266 MB
  proc/self/stat/VmPeak:	  28.211 MB
[0] info: Partitioning the mesh in the node wise way ...
[0] info: partitionMesh(): Partition IDs per element computed in 5.6622e-05 s
[0] info: partitionMesh(): distribute nodes to partitions took 2.237e-05 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 0.000119624 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 0.000122464 s
[0] info: partitionMesh(): distribute elements into partitions took 5.0591e-05 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.358e-05 s
[0] info: partitionMesh(): markDuplicateGhostCells took 7.4e-07 s
[0] info: Partitioning other meshes according to the main mesh partitions.
[0] info: Mesh 'left' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left.vtu' read: 129 nodes, 64 elements.
[0] info: Property global_node_ids is added to mesh left
[0] info: Property global_element_ids is added to mesh left
[0] info: partitionMesh(): Partition IDs per element computed in 1.66e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.46e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 2.37e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.29e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 2.02e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 1.3e-06 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.2e-07 s
[0] info: Mesh 'right' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right.vtu' read: 29 nodes, 14 elements.
[0] info: Property global_node_ids is added to mesh right
[0] info: Property global_element_ids is added to mesh right
[0] info: partitionMesh(): Partition IDs per element computed in 3.8e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 3.5e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 8.7e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 3.5e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 6.1e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.9e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.2e-07 s
[0] info: Mesh 'top' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top.vtu' read: 29 nodes, 14 elements.
[0] info: Property global_node_ids is added to mesh top
[0] info: Property global_element_ids is added to mesh top
[0] info: partitionMesh(): Partition IDs per element computed in 4.41e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 3.7e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 8.6e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 3.9e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 5.9e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.7e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.1e-07 s
[0] info: Mesh 'bottom' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom.vtu' read: 129 nodes, 64 elements.
[0] info: Property global_node_ids is added to mesh bottom
[0] info: Property global_element_ids is added to mesh bottom
[0] info: partitionMesh(): Partition IDs per element computed in 1.83e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.24e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 2.45e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.33e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 1.94e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 1.19e-06 s
[0] info: Mesh 'arc' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc.vtu' read: 39 nodes, 19 elements.
[0] info: Property global_node_ids is added to mesh arc
[0] info: Property global_element_ids is added to mesh arc
[0] info: partitionMesh(): Partition IDs per element computed in 4.2e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 4.7e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 9.2e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 4.3e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 7.4e-07 s
[0] info: Writing the partitions data into binary files took 0.000845928 s
[0] info: Total runtime: 0.0651597 s.
[0] info: Total CPU time: 0.010445 s.
0
3. Parallel computing
output_prefix = "kirsch_mpi"… (click to toggle)
temporary_project = Path(out_dir, f"{output_prefix}.prj")
prj = ot.Project(
    input_file="kirsch.prj",
    output_file=temporary_project,
prj.replace_text(
    output_prefix,
prj.write_input()
run(
    f"mpirun -np {num_parts} ogs {temporary_project} -m {mesh_dir} -o {out_dir}",
    shell=True,
    check=True,
[0] info: OGS started on 2026-05-18 15:56:17+0200 with MPI. MPI processes: 3.
[0] info: This is OpenGeoSys-6 version 6.5.8. Log version: 2, Log level: info.
[0] info: Using virtual environment site-packages: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/.venv/lib/python3.13/site-packages
[0] info: Reading project file ../../../../../build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.prj.
[0] info: Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain ...
[0] warning: Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain_partitioned_integration_point_properties_cfg3.bin'.
	You can ignore this warning if the mesh does not contain integration_point-wise property data.
[0] info: [time] Reading the mesh took 0.258160 s.
[0] info: Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left ...
[0] warning: Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left_partitioned_integration_point_properties_cfg3.bin'.
[0] info: [time] Reading the mesh took 0.221658 s.
[0] info: Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right ...
[0] warning: Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right_partitioned_integration_point_properties_cfg3.bin'.
[0] info: [time] Reading the mesh took 0.079993 s.
[0] info: Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top ...
[0] warning: Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top_partitioned_integration_point_properties_cfg3.bin'.
[0] info: [time] Reading the mesh took 0.117996 s.
[0] info: Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom ...
[0] warning: Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom_partitioned_integration_point_properties_cfg3.bin'.
[0] info: [time] Reading the mesh took 0.171739 s.
[0] info: Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc ...
[0] warning: Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc_partitioned_integration_point_properties_cfg3.bin'.
[0] info: [time] Reading the mesh took 0.145984 s.
[0] info: readRasters ...
[0] info: readRasters done
[0] info: ConstantParameter: E
[0] info: ConstantParameter: nu
[0] info: ConstantParameter: zero
[0] info: ConstantParameter: initial_displacement
[0] info: FunctionParameter: sigma0
[0] info: ConstantParameter: sigma_top
[0] info: FunctionParameter: decay_function
[0] info: Configure mesh 'left' for boundary condition or source term.
[0] info: Configure mesh 'bottom' for boundary condition or source term.
[0] info: Configure mesh 'top' for boundary condition or source term.
[0] info: Configure mesh 'arc' for boundary condition or source term.
[0] info: No source terms for process variable 'displacement' found.
[0] info: Threads used for ParallelVectorMatrixAssembler: 1.
[0] info: SmallDeformation process initializeSubmeshOutput().
[0] info: Initialize processes.
[0] info: Checking correct model evaluation order in the constitutive setting.
[0] info: Model evaluation order is correct.
[0] info: Time step #0 started. Time: 0. Step size: 0.
[0] info: [time] Output of timestep 0 took 0.204419 s.
[0] info: Calculate non-equilibrium initial residuum.
[0] info: Number of threads: 1
[0] info: Time step #0 took 0.754997 s.
[0] info: Solve processes.
[0] info: Time step #1 started. Time: 10000. Step size: 10000.
[0] info: Solving process #0 started.
[0] info: Iteration #1 started.
[0] info: [time] Assembly took 0.180466 s.
[0] info: [time] Applying Dirichlet BCs took 0.00476698 s.
Linear solver bcgs with bjacobi preconditioner using PRECONDITIONED
converged in 425 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 5.82074 s.
[0] info: Convergence criterion, component 0: |dx|=2.1980e-02, |x|=2.1980e-02, |dx|/|x|=1.0000e+00
[0] info: Convergence criterion, component 1: |dx|=5.3739e-02, |x|=5.3739e-02, |dx|/|x|=1.0000e+00
[0] info: [time] Iteration #1 took 6.08295 s.
[0] info: Iteration #2 started.
[0] info: [time] Assembly took 0.18331 s.
[0] info: [time] Applying Dirichlet BCs took 0.0930076 s.
converged in 55 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.929998 s.
[0] info: Convergence criterion, component 0: |dx|=6.5195e-16, |x|=2.1980e-02, |dx|/|x|=2.9661e-14
[0] info: Convergence criterion, component 1: |dx|=1.1208e-15, |x|=5.3739e-02, |dx|/|x|=2.0857e-14
[0] info: [time] Iteration #2 took 1.35 s.
[0] info: [time] Solving process #0 took 7.47492 s in time step #1
[0] info: [time] Time step #1 took 7.58596 s.
[0] info: [time] Output of timestep 1 took 0.397245 s.
[0] info: Time step #2 started. Time: 25000. Step size: 15000.
[0] info: [time] Assembly took 0.156622 s.
[0] info: [time] Applying Dirichlet BCs took 0.000183096 s.
converged in 430 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 5.89519 s.
[0] info: Convergence criterion, component 0: |dx|=3.2971e-02, |x|=5.4951e-02, |dx|/|x|=6.0000e-01
[0] info: Convergence criterion, component 1: |dx|=8.0608e-02, |x|=1.3435e-01, |dx|/|x|=6.0000e-01
[0] info: [time] Iteration #1 took 6.13897 s.
[0] info: [time] Assembly took 0.110271 s.
[0] info: [time] Applying Dirichlet BCs took 0.0161142 s.
converged in 70 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.32593 s.
[0] info: Convergence criterion, component 0: |dx|=3.3119e-15, |x|=5.4951e-02, |dx|/|x|=6.0269e-14
[0] info: Convergence criterion, component 1: |dx|=1.4205e-15, |x|=1.3435e-01, |dx|/|x|=1.0573e-14
[0] info: [time] Iteration #2 took 2.62397 s.
[0] info: [time] Solving process #0 took 8.77893 s in time step #2
[0] info: [time] Time step #2 took 8.87101 s.
[0] info: [time] Output of timestep 2 took 0.3283 s.
[0] info: Time step #3 started. Time: 42280. Step size: 17280.
[0] info: [time] Assembly took 0.142578 s.
[0] info: [time] Applying Dirichlet BCs took 0.0860472 s.
converged in 424 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 10.6777 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=9.2933e-02, |dx|/|x|=4.0870e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=2.2721e-01, |dx|/|x|=4.0870e-01
[0] info: [time] Iteration #1 took 10.9629 s.
[0] info: [time] Assembly took 0.104015 s.
[0] info: [time] Applying Dirichlet BCs took 0.0130493 s.
converged in 153 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 1.36591 s.
[0] info: Convergence criterion, component 0: |dx|=4.7517e-14, |x|=9.2933e-02, |dx|/|x|=5.1131e-13
[0] info: Convergence criterion, component 1: |dx|=8.5945e-14, |x|=2.2721e-01, |dx|/|x|=3.7827e-13
[0] info: [time] Iteration #2 took 1.52929 s.
[0] info: [time] Solving process #0 took 12.4953 s in time step #3
[0] info: [time] Time step #3 took 12.553 s.
[0] info: [time] Output of timestep 3 took 0.137161 s.
[0] info: Time step #4 started. Time: 59560. Step size: 17280.
[0] info: [time] Assembly took 0.110532 s.
[0] info: [time] Applying Dirichlet BCs took 0.110042 s.
converged in 427 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 3.18367 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=1.3091e-01, |dx|/|x|=2.9013e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=3.2007e-01, |dx|/|x|=2.9013e-01
[0] info: [time] Iteration #1 took 3.43688 s.
[0] info: [time] Assembly took 0.0791753 s.
[0] info: [time] Applying Dirichlet BCs took 0.00112776 s.
converged in 49 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.45501 s.
[0] info: Convergence criterion, component 0: |dx|=9.4164e-16, |x|=1.3091e-01, |dx|/|x|=7.1927e-15
[0] info: Convergence criterion, component 1: |dx|=1.0780e-15, |x|=3.2007e-01, |dx|/|x|=3.3680e-15
[0] info: [time] Iteration #2 took 2.617 s.
[0] info: [time] Solving process #0 took 6.05398 s in time step #4
[0] info: [time] Time step #4 took 6.12101 s.
[0] info: [time] Output of timestep 4 took 0.118606 s.
[0] info: Time step #5 started. Time: 76840. Step size: 17280.
[0] info: [time] Assembly took 0.0756104 s.
[0] info: [time] Applying Dirichlet BCs took 0.000179606 s.
converged in 412 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.14726 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=1.6890e-01, |dx|/|x|=2.2488e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=4.1293e-01, |dx|/|x|=2.2488e-01
[0] info: [time] Iteration #1 took 2.25596 s.
[0] info: [time] Assembly took 0.0821007 s.
[0] info: [time] Applying Dirichlet BCs took 0.0110977 s.
converged in 146 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 1.25016 s.
[0] info: Convergence criterion, component 0: |dx|=7.4173e-15, |x|=1.6890e-01, |dx|/|x|=4.3916e-14
[0] info: Convergence criterion, component 1: |dx|=9.4037e-15, |x|=4.1293e-01, |dx|/|x|=2.2773e-14
[0] info: [time] Iteration #2 took 1.35777 s.
[0] info: [time] Solving process #0 took 3.61674 s in time step #5
[0] info: [time] Time step #5 took 3.63973 s.
[0] info: [time] Output of timestep 5 took 0.0531941 s.
[0] info: Time step #6 started. Time: 94120. Step size: 17280.
[0] info: [time] Assembly took 0.0351429 s.
[0] info: [time] Applying Dirichlet BCs took 0.00399309 s.
converged in 422 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.59105 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.0688e-01, |dx|/|x|=1.8360e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=5.0579e-01, |dx|/|x|=1.8360e-01
[0] info: [time] Iteration #1 took 2.66495 s.
[0] info: [time] Assembly took 0.104102 s.
[0] info: [time] Applying Dirichlet BCs took 0.00112178 s.
converged in 114 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.541034 s.
[0] info: Convergence criterion, component 0: |dx|=8.1613e-15, |x|=2.0688e-01, |dx|/|x|=3.9450e-14
[0] info: Convergence criterion, component 1: |dx|=8.4038e-15, |x|=5.0579e-01, |dx|/|x|=1.6615e-14
[0] info: [time] Iteration #2 took 0.708236 s.
[0] info: [time] Solving process #0 took 3.37621 s in time step #6
[0] info: [time] Time step #6 took 3.40802 s.
[0] info: [time] Output of timestep 6 took 0.0912531 s.
[0] info: Time step #7 started. Time: 111400. Step size: 17280.
[0] info: [time] Assembly took 0.0446209 s.
[0] info: [time] Applying Dirichlet BCs took 0.000200736 s.
converged in 423 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.67901 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.4486e-01, |dx|/|x|=1.5512e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=5.9865e-01, |dx|/|x|=1.5512e-01
[0] info: [time] Iteration #1 took 2.76907 s.
[0] info: [time] Assembly took 0.0999917 s.
[0] info: [time] Applying Dirichlet BCs took 0.000140694 s.
converged in 116 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.441316 s.
[0] info: Convergence criterion, component 0: |dx|=9.2767e-15, |x|=2.4486e-01, |dx|/|x|=3.7885e-14
[0] info: Convergence criterion, component 1: |dx|=1.6779e-14, |x|=5.9865e-01, |dx|/|x|=2.8028e-14
[0] info: [time] Iteration #2 took 0.56589 s.
[0] info: [time] Solving process #0 took 3.34192 s in time step #7
[0] info: [time] Time step #7 took 3.37675 s.
[0] info: [time] Output of timestep 7 took 0.0392009 s.
[0] info: Time step #8 started. Time: 128680. Step size: 17280.
[0] info: [time] Assembly took 0.11827 s.
[0] info: [time] Applying Dirichlet BCs took 0.015742 s.
converged in 440 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.78587 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.8284e-01, |dx|/|x|=1.3429e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=6.9151e-01, |dx|/|x|=1.3429e-01
[0] info: [time] Iteration #1 took 2.93229 s.
[0] info: [time] Assembly took 0.072851 s.
[0] info: [time] Applying Dirichlet BCs took 0.000143184 s.
converged in 85 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.33604 s.
[0] info: Convergence criterion, component 0: |dx|=1.7434e-15, |x|=2.8284e-01, |dx|/|x|=6.1640e-15
[0] info: Convergence criterion, component 1: |dx|=8.1319e-15, |x|=6.9151e-01, |dx|/|x|=1.1760e-14
[0] info: [time] Iteration #2 took 0.45276 s.
[0] info: [time] Solving process #0 took 3.38896 s in time step #8
[0] info: [time] Time step #8 took 3.42199 s.
[0] info: [time] Output of timestep 8 took 0.0792302 s.
[0] info: Time step #9 started. Time: 145960. Step size: 17280.
[0] info: [time] Assembly took 0.0690794 s.
[0] info: [time] Applying Dirichlet BCs took 0.000174345 s.
converged in 437 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.29401 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=3.2083e-01, |dx|/|x|=1.1839e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=7.8437e-01, |dx|/|x|=1.1839e-01
[0] info: [time] Iteration #1 took 2.38773 s.
[0] info: [time] Assembly took 0.0556486 s.
[0] info: [time] Applying Dirichlet BCs took 0.00911381 s.
converged in 152 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 1.51638 s.
[0] info: Convergence criterion, component 0: |dx|=6.6370e-15, |x|=3.2083e-01, |dx|/|x|=2.0687e-14
[0] info: Convergence criterion, component 1: |dx|=1.0265e-14, |x|=7.8437e-01, |dx|/|x|=1.3087e-14
[0] info: [time] Iteration #2 took 1.59078 s.
[0] info: [time] Solving process #0 took 3.9786 s in time step #9
[0] info: [time] Time step #9 took 4.00549 s.
[0] info: [time] Output of timestep 9 took 0.0802035 s.
[0] info: Time step #10 started. Time: 163240. Step size: 17280.
[0] info: [time] Assembly took 0.0543569 s.
[0] info: [time] Applying Dirichlet BCs took 0.00115742 s.
converged in 444 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 2.70402 s.
[0] info: Convergence criterion, component 0: |dx|=3.7982e-02, |x|=3.5881e-01, |dx|/|x|=1.0586e-01
[0] info: Convergence criterion, component 1: |dx|=9.2860e-02, |x|=8.7723e-01, |dx|/|x|=1.0586e-01
[0] info: [time] Iteration #1 took 2.79387 s.
[0] info: [time] Assembly took 0.0562745 s.
[0] info: [time] Applying Dirichlet BCs took 0.0121223 s.
[0] info: [time] Linear solver took 0.122006 s.
[0] info: Convergence criterion, component 0: |dx|=6.6400e-16, |x|=3.5881e-01, |dx|/|x|=1.8506e-15
[0] info: Convergence criterion, component 1: |dx|=1.2077e-15, |x|=8.7723e-01, |dx|/|x|=1.3768e-15
[0] info: [time] Iteration #2 took 0.230979 s.
[0] info: [time] Solving process #0 took 3.03492 s in time step #10
[0] info: [time] Time step #10 took 3.07301 s.
[0] info: [time] Output of timestep 10 took 0.0511437 s.
[0] info: Time step #11 started. Time: 180520. Step size: 17280.
[0] info: [time] Assembly took 0.0495058 s.
[0] info: [time] Applying Dirichlet BCs took 0.00515561 s.
[0] info: [time] Linear solver took 2.66302 s.
[0] info: Convergence criterion, component 0: |dx|=2.1013e-02, |x|=3.7982e-01, |dx|/|x|=5.5324e-02
[0] info: Convergence criterion, component 1: |dx|=5.1374e-02, |x|=9.2860e-01, |dx|/|x|=5.5324e-02
[0] info: [time] Iteration #1 took 2.77308 s.
[0] info: [time] Assembly took 0.0939292 s.
[0] info: [time] Applying Dirichlet BCs took 0.000141954 s.
converged in 56 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.322042 s.
[0] info: Convergence criterion, component 0: |dx|=1.4874e-15, |x|=3.7982e-01, |dx|/|x|=3.9160e-15
[0] info: Convergence criterion, component 1: |dx|=1.6142e-15, |x|=9.2860e-01, |dx|/|x|=1.7383e-15
[0] info: [time] Iteration #2 took 0.434781 s.
[0] info: [time] Solving process #0 took 3.22593 s in time step #11
[0] info: [time] Time step #11 took 3.31776 s.
[0] info: [time] Output of timestep 11 took 0.0621456 s.
[0] info: Time step #12 started. Time: 197800. Step size: 17280.
[0] info: [time] Assembly took 0.0373645 s.
[0] info: [time] Applying Dirichlet BCs took 0.000169735 s.
converged in 32 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.119316 s.
[0] info: Convergence criterion, component 0: |dx|=2.9402e-16, |x|=3.7982e-01, |dx|/|x|=7.7410e-16
[0] info: Convergence criterion, component 1: |dx|=9.9822e-16, |x|=9.2860e-01, |dx|/|x|=1.0750e-15
[0] info: [time] Iteration #1 took 0.199876 s.
[0] info: [time] Solving process #0 took 0.200935 s in time step #12
[0] info: [time] Time step #12 took 0.247767 s.
[0] info: [time] Output of timestep 12 took 0.203145 s.
[0] info: Time step #13 started. Time: 215080. Step size: 17280.
[0] info: [time] Assembly took 0.0445282 s.
[0] info: [time] Applying Dirichlet BCs took 0.000205667 s.
converged in 41 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.196256 s.
[0] info: Convergence criterion, component 0: |dx|=5.1501e-16, |x|=3.7982e-01, |dx|/|x|=1.3559e-15
[0] info: Convergence criterion, component 1: |dx|=5.0948e-16, |x|=9.2860e-01, |dx|/|x|=5.4865e-16
[0] info: [time] Iteration #1 took 0.340976 s.
[0] info: [time] Solving process #0 took 0.349893 s in time step #13
[0] info: [time] Time step #13 took 0.436001 s.
[0] info: [time] Output of timestep 13 took 0.0951341 s.
[0] info: Time step #14 started. Time: 232360. Step size: 17280.
[0] info: [time] Assembly took 0.107276 s.
[0] info: [time] Applying Dirichlet BCs took 0.0190909 s.
converged in 25 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.228 s.
[0] info: Convergence criterion, component 0: |dx|=2.8381e-16, |x|=3.7982e-01, |dx|/|x|=7.4723e-16
[0] info: Convergence criterion, component 1: |dx|=4.8480e-16, |x|=9.2860e-01, |dx|/|x|=5.2207e-16
[0] info: [time] Iteration #1 took 0.380475 s.
[0] info: [time] Solving process #0 took 0.382397 s in time step #14
[0] info: [time] Time step #14 took 0.441001 s.
[0] info: [time] Output of timestep 14 took 0.0372116 s.
[0] info: Time step #15 started. Time: 249640. Step size: 17280.
[0] info: [time] Assembly took 0.0732697 s.
[0] info: [time] Applying Dirichlet BCs took 0.038045 s.
converged in 21 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.132951 s.
[0] info: Convergence criterion, component 0: |dx|=1.5303e-16, |x|=3.7982e-01, |dx|/|x|=4.0291e-16
[0] info: Convergence criterion, component 1: |dx|=3.2689e-16, |x|=9.2860e-01, |dx|/|x|=3.5203e-16
[0] info: [time] Iteration #1 took 0.298173 s.
[0] info: [time] Solving process #0 took 0.30117 s in time step #15
[0] info: [time] Time step #15 took 0.319731 s.
[0] info: [time] Output of timestep 15 took 0.0542184 s.
[0] info: Time step #16 started. Time: 266920. Step size: 17280.
[0] info: [time] Assembly took 0.0544756 s.
[0] info: [time] Applying Dirichlet BCs took 0.00119014 s.
[0] info: [time] Linear solver took 0.381979 s.
[0] info: Convergence criterion, component 0: |dx|=1.4365e-16, |x|=3.7982e-01, |dx|/|x|=3.7821e-16
[0] info: Convergence criterion, component 1: |dx|=3.9251e-16, |x|=9.2860e-01, |dx|/|x|=4.2268e-16
[0] info: [time] Iteration #1 took 0.463309 s.
[0] info: [time] Solving process #0 took 0.463405 s in time step #16
[0] info: [time] Time step #16 took 0.522756 s.
[0] info: [time] Output of timestep 16 took 0.0642183 s.
[0] info: Time step #17 started. Time: 284200. Step size: 17280.
[0] info: [time] Assembly took 0.083146 s.
[0] info: [time] Applying Dirichlet BCs took 0.000181037 s.
converged in 36 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.0896673 s.
[0] info: Convergence criterion, component 0: |dx|=4.1812e-16, |x|=3.7982e-01, |dx|/|x|=1.1008e-15
[0] info: Convergence criterion, component 1: |dx|=6.6471e-16, |x|=9.2860e-01, |dx|/|x|=7.1582e-16
[0] info: [time] Iteration #1 took 0.225001 s.
[0] info: [time] Solving process #0 took 0.225074 s in time step #17
[0] info: [time] Time step #17 took 0.247003 s.
[0] info: [time] Output of timestep 17 took 0.038221 s.
[0] info: Time step #18 started. Time: 301480. Step size: 17280.
[0] info: [time] Assembly took 0.0458266 s.
[0] info: [time] Applying Dirichlet BCs took 0.0680557 s.
converged in 28 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.180948 s.
[0] info: Convergence criterion, component 0: |dx|=3.0327e-16, |x|=3.7982e-01, |dx|/|x|=7.9846e-16
[0] info: Convergence criterion, component 1: |dx|=5.5376e-16, |x|=9.2860e-01, |dx|/|x|=5.9633e-16
[0] info: [time] Iteration #1 took 0.32611 s.
[0] info: [time] Solving process #0 took 0.327078 s in time step #18
[0] info: [time] Time step #18 took 0.367749 s.
[0] info: [time] Output of timestep 18 took 0.072228 s.
[0] info: Time step #19 started. Time: 318760. Step size: 17280.
[0] info: [time] Assembly took 0.0992197 s.
[0] info: [time] Applying Dirichlet BCs took 0.0260634 s.
converged in 26 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.316976 s.
[0] info: Convergence criterion, component 0: |dx|=2.6002e-16, |x|=3.7982e-01, |dx|/|x|=6.8459e-16
[0] info: Convergence criterion, component 1: |dx|=4.1246e-16, |x|=9.2860e-01, |dx|/|x|=4.4417e-16
[0] info: [time] Iteration #1 took 0.462353 s.
[0] info: [time] Solving process #0 took 0.462446 s in time step #19
[0] info: [time] Time step #19 took 0.508019 s.
[0] info: [time] Output of timestep 19 took 0.142169 s.
[0] info: Time step #20 started. Time: 336040. Step size: 17280.
[0] info: [time] Assembly took 0.0893041 s.
[0] info: [time] Applying Dirichlet BCs took 0.000178197 s.
converged in 34 iterations (absolute convergence criterion fulfilled).
[0] info: [time] Linear solver took 0.239503 s.
[0] info: Convergence criterion, component 0: |dx|=3.3235e-16, |x|=3.7982e-01, |dx|/|x|=8.7501e-16
[0] info: Convergence criterion, component 1: |dx|=1.1227e-15, |x|=9.2860e-01, |dx|/|x|=1.2090e-15
[0] info: [time] Iteration #1 took 0.354432 s.
[0] info: [time] Solving process #0 took 0.35544 s in time step #20
[0] info: [time] Time step #20 took 0.403005 s.
[0] info: [time] Output of timestep 20 took 0.0865017 s.
[0] info: Time step #21 started. Time: 345600. Step size: 9560.
[0] info: [time] Assembly took 0.0593081 s.
[0] info: [time] Applying Dirichlet BCs took 0.00816145 s.
[0] info: [time] Linear solver took 0.213565 s.
[0] info: Convergence criterion, component 0: |dx|=3.4415e-16, |x|=3.7982e-01, |dx|/|x|=9.0609e-16
[0] info: Convergence criterion, component 1: |dx|=8.3804e-16, |x|=9.2860e-01, |dx|/|x|=9.0248e-16
[0] info: [time] Iteration #1 took 0.296863 s.
[0] info: [time] Solving process #0 took 0.300913 s in time step #21
[0] info: [time] Time step #21 took 0.332254 s.
[0] info: [time] Output of timestep 21 took 0.0692287 s.
[0] info: The whole computation of the time stepping took 21 steps, in which
	 the accepted steps are 21, and the rejected steps are 0.
[0] info: [time] Simulation completed. It took 67.709 s.
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There are 2 unused database options. They are:
Option left: name:-m value: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh source: command line
Option left: name:-o value: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch source: command line
[0] info: OGS completed on 2026-05-18 15:57:24+0200.
CompletedProcess(args='mpirun -np 3 ogs /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.prj -m /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh -o /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch', returncode=0)
4. Contour plotting of the simulation results
pvd = Path(out_dir, f"{output_prefix}.pvd")… (click to toggle)
ms = ot.MeshSeries(pvd).scale(time="d")
print(pvd)
mesh_last = ms[-1]
fig = ot.plot.contourf(
    mesh_last,
    figsize=(6, 4),
    fontsize=8,
    cmap="jet",
[0] info: Reading meshes took 0.010748363000000039 s
[0] info: Collection of 1674 regular elements and computing element map took 9.64999999997218e-06 s
[0] info: Collection of 4720 nodes and computing offsets took 2.839999999837417e-06 s
[0] info: Make nodes unique (4455 unique nodes) / computing map took 0.0014660600000000468 s
[0] info: Reset nodes in regular elements took 0.0037835479999999144 s
[0] info: creation of merged mesh took 0.0002876590000000512 s
[0] info: merge properties into merged mesh took 0.0001784559999999935 s
[0] info: writing mesh took 0.0058025660000000645 s
/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.pvd
[0] info: Reading meshes took 0.02085976299999981 s
[0] info: Collection of 1674 regular elements and computing element map took 9.651000000054921e-06 s
[0] info: Collection of 4720 nodes and computing offsets took 2.899999999916858e-06 s
[0] info: Make nodes unique (4455 unique nodes) / computing map took 0.0013623860000000487 s
[0] info: Reset nodes in regular elements took 0.004610905999999915 s
[0] info: creation of merged mesh took 0.0002948400000000184 s
[0] info: merge properties into merged mesh took 0.00017170600000016023 s
[0] info: writing mesh took 0.005729154000000181 s
fig = ot.plot.contourf(… (click to toggle)
    mesh_last, ot.variables.displacement["y"], figsize=(6, 4), fontsize=8, cmap="jet"
    mesh_last, ot.variables.stress["xx"], figsize=(6, 4), fontsize=8, cmap="jet"
    mesh_last, ot.variables.stress["yy"], figsize=(6, 4), fontsize=8, cmap="jet"
5. Result comparison
point_a = (6.5, -857.0, 0)… (click to toggle)
point_b = (70.0, -857.0, 0)
profile = ms[-1].sample_over_line(point_a, point_b, resolution=30)
xs = profile["Distance"] + 6.5
plt.plot(
    xs, profile["sigma"][:, 0] * 1e-6, color="C2", label="Release nodal force (MPI)"
a = 6.5
sigma_t = -20  # MPa
sigma_x_a = np.asarray(
    [0.5 * (3.0 * a * a / (r * r) - 3 * a**4 / (r**4)) * sigma_t for r in xs],
plt.plot(xs, sigma_x_a, linestyle="dotted", color="C0", label="Analytical solution")
plt.xlabel("x / m")
plt.ylabel(r"stress $\sigma_{xx}$ / MPa")
plt.legend()
plt.grid()
In the above figure, the radial stress $\sigma_r$ profiles along the $\theta = 0^\circ$ axis, obtained using the release nodal force approach, and the analytical solution, are compared.
plt.plot(… (click to toggle)
plt.plot(
    xs, profile["sigma"][:, 1] * 1e-6, color="C2", label="Release nodal force (MPI)"
a = 6.5
sigma_t = -20  # MPa
sigma_y_a = np.asarray(
    [0.5 * (2 + a * a / (r * r) + 3 * a**4 / (r**4)) * sigma_t for r in xs],
plt.plot(xs, sigma_y_a, linestyle="dotted", color="C0", label="Analytical solution")
plt.xlabel("x / m")
plt.ylabel(r"stress $\sigma_{yy}$ / MPa")
plt.legend()
plt.grid()
In the above two figures, the tangential stress $\sigma_{\theta}$ profiles along the $\theta = 0^\circ$ axis, obtained using the release nodal force approach, and the analytical solution, are compared.
expected_sigma = np.asarray(… (click to toggle)
        [-5.94322287e05, -6.19135039e07, -1.27523478e07, 2.88857972e04],
        [-7.47350139e06, -3.61722449e07, -7.09372389e06, -4.31847097e03],
        [-7.02632921e06, -2.82291119e07, -4.57663234e06, -3.04634647e03],
        [-5.69811254e06, -2.49548130e07, -3.19587766e06, -2.33539317e03],
        [-4.52129471e06, -2.33397674e07, -2.35831864e06, -1.87907695e03],
        [-3.60618350e06, -2.24352157e07, -1.81241976e06, -1.49642711e03],
        [-2.90810489e06, -2.18773279e07, -1.43562983e06, -1.21999451e03],
        [-2.37358359e06, -2.15068967e07, -1.16414410e06, -1.00559463e03],
        [-1.95790335e06, -2.12450510e07, -9.60886316e05, -8.50316451e02],
        [-1.63102314e06, -2.10507797e07, -8.04540863e05, -7.21601922e02],
        [-1.36956366e06, -2.08999790e07, -6.80862806e05, -6.21075254e02],
        [-1.15718662e06, -2.07782330e07, -5.80625884e05, -5.47100152e02],
        [-9.83183398e05, -2.06769008e07, -4.98025268e05, -4.73813630e02],
        [-8.38590438e05, -2.05896257e07, -4.28464851e05, -2.91454098e02],
        [-7.18847960e05, -2.05193954e07, -3.71473022e05, -5.83689809e02],
        [-6.15597155e05, -2.04493120e07, -3.19472761e05, -2.60734404e02],
        [-5.26222722e05, -2.03832868e07, -2.72852858e05, -1.22193725e02],
        [-4.48460991e05, -2.03225868e07, -2.31314329e05, -1.40384160e02],
        [-3.81052951e05, -2.02633176e07, -1.93311164e05, 8.27105976e00],
        [-3.21267935e05, -2.02058999e07, -1.58150365e05, 1.25229397e02],
        [-2.68380912e05, -2.01489856e07, -1.25209966e05, -2.03819778e02],
        [-2.21121750e05, -2.00919675e07, -9.39267720e04, -5.98779759e02],
        [-1.79147229e05, -2.00335377e07, -6.38054888e04, 6.67763887e02],
        [-1.41291420e05, -1.99727511e07, -3.42127668e04, -2.09343375e02],
        [-1.07444543e05, -1.99093000e07, -5.02336097e03, -6.12146069e02],
        [-7.76109665e04, -1.98407209e07, 2.45004314e04, -3.90010177e02],
        [-5.18790616e04, -1.97699451e07, 5.34527661e04, -3.13328250e02],
        [-3.10211876e04, -1.96869485e07, 8.46090962e04, -3.15443054e01],
        [-1.35909887e04, -1.96029252e07, 1.15045144e05, 3.61051256e02],
        [-4.03024845e03, -1.94999513e07, 1.48805539e05, 7.61397500e02],
computed_sigma = np.asarray(profile["sigma"])
np.testing.assert_allclose(actual=computed_sigma, desired=expected_sigma, atol=1e-10)
profile_1 = ms[1].sample_over_line(point_a, point_b, resolution=30)
[0] info: Reading meshes took 0.019586981000000003 s
[0] info: Collection of 1674 regular elements and computing element map took 9.840000000149729e-06 s
[0] info: Collection of 4720 nodes and computing offsets took 3.2800000000499097e-06 s
[0] info: Make nodes unique (4455 unique nodes) / computing map took 0.001368336000000081 s
[0] info: Reset nodes in regular elements took 0.003674423999999954 s
[0] info: creation of merged mesh took 0.0002858290000000707 s
[0] info: merge properties into merged mesh took 0.00016971600000004194 s
[0] info: writing mesh took 0.006260490999999924 s
expected_sigma_at_time_step1 = np.array(… (click to toggle)
        [-4.32494293e05, -2.09358938e07, -4.10516429e05, -2.49911515e02],
        [-4.06616274e05, -2.04762218e07, -2.64851408e05, -1.76293199e02],
        [-3.29751883e05, -2.02867369e07, -1.84946624e05, -1.35150068e02],
        [-2.61649000e05, -2.01932736e07, -1.36476773e05, -1.08742879e02],
        [-2.08691175e05, -2.01409268e07, -1.04885403e05, -8.65987912e01],
        [-1.68293107e05, -2.01086417e07, -8.30804300e04, -7.06015339e01],
        [-1.37360161e05, -2.00872047e07, -6.73694502e04, -5.81941335e01],
        [-1.13304592e05, -2.00720516e07, -5.56068470e04, -4.92081280e01],
        [-9.43879134e04, -2.00608090e07, -4.65590777e04, -4.17593705e01],
        [-7.92571563e04, -2.00520821e07, -3.94017827e04, -3.59418550e01],
        [-6.69668185e04, -2.00450366e07, -3.36010349e04, -3.16608884e01],
        [-5.68971874e04, -2.00391725e07, -2.88209067e04, -2.74197703e01],
        [-4.85295392e04, -2.00341219e07, -2.47954196e04, -1.68665566e01],
        [-4.15999977e04, -2.00300576e07, -2.14972814e04, -3.37783455e01],
        [-3.56248353e04, -2.00260019e07, -1.84880070e04, -1.50887965e01],
        [-3.04527038e04, -2.00221809e07, -1.57900959e04, -7.07139610e00],
        [-2.59526036e04, -2.00186682e07, -1.33862459e04, -8.12408336e00],
        [-2.20516754e04, -2.00152383e07, -1.11869887e04, 4.78649290e-01],
        [-1.85918944e04, -2.00119155e07, -9.15222018e03, 7.24707160e00],
        [-1.55313028e04, -2.00086219e07, -7.24594709e03, -1.17951260e01],
        [-1.27963975e04, -2.00053222e07, -5.43557708e03, -3.46516064e01],
        [-1.03673165e04, -2.00019408e07, -3.69244727e03, 3.86437434e01],
        [-8.17658683e03, -1.99984231e07, -1.97990549e03, -1.21147786e01],
        [-6.21785551e03, -1.99947512e07, -2.90703760e02, -3.54251197e01],
        [-4.49137538e03, -1.99907825e07, 1.41784904e03, -2.25700334e01],
        [-3.00226051e03, -1.99866866e07, 3.09333137e03, -1.81324219e01],
        [-1.79520762e03, -1.99818836e07, 4.89635973e03, -1.82548063e00],
        [-7.86515552e02, -1.99770211e07, 6.65770509e03, 2.08941699e01],
        [-2.33231970e02, -1.99710620e07, 8.61143168e03, 4.40623553e01],
computed_sigma_t1 = np.asarray(profile_1["sigma"])
    actual=computed_sigma_t1, desired=expected_sigma_at_time_step1, atol=1e-10
Generated with Hugo 0.150.1 in CI job 743172 | Last revision: August 27, 2025
