Documentation sections
Cook's membrane example
$$ \newcommand{\B}{\text{B}} \newcommand{\F}{\text{F}} \newcommand{\I}{\mathbf I} \newcommand{\intD}[1]{\int_{\Omega_e}#1\mathrm{d}\Omega} $$
Cook’s membrane example for nearly icompressible solid
B bar method
Considering a strain decomposition: $\mathbf\epsilon = \underbrace{\mathbf\epsilon- \frac{1}{3}(\epsilon:\mathbf I)}_{\text{deviatoric}}\I + \underbrace{\frac{1}{3}(\epsilon:\mathbf I)}_{\text{dilatational}} \I$. The idea of the B bar method is to use another quadrature rule to interpolate the dilatational part, which leads to a modified B matrix [1]:
$$ \bar\B = \underbrace{\B - \B^{\text{dil}}}_{\text{original B elements}}+ \underbrace{{\bar\B}^{\text{dil}}}_{\text{by another quadrature rule} } $$
There are several methods to form ${\bar\B}^{\text{dil}}$ such as selective integration, generalization of the mean-dilatation formulation. In the current OGS, we use the latter, which reads
$$ {\bar\B}^{\text{dil}} = \frac{\intD{\B^{\text{dil}}(\xi)}}{\intD{}} $$
To verify the implementation of the B bar method, the so called Cook’s membrane is used as a benchmark. Illustrated in the following figure, this example simulates a tapered and swept panel of unit thickness. The left edge is clamped and the right edge is applied with a distributed shearing load $F$ = 100 N/mm. The plane strain condition is considered. This numerical model is exactly the same as that is presented in the paper by T. Elguedj et al [1,2].
Cook's membrane
def run_single_test(n: int, use_bbar: bool) -> ot.MeshSeries:… (click to toggle)
    model.replace_text(str(use_bbar).lower(), xpath="./processes/process/use_b_bar")
    prefix = f"cooks_membrane_n_{n}_bbar_{str(use_bbar).lower()}"
    model.replace_text("BiCGSTAB", xpath=".//solver_type")
    model.replace_text("ILUT", xpath=".//precon_type")
def get_top_uy(mesh: pv.UnstructuredGrid) -> np.ndarray:
def compare(mesh_a: pv.UnstructuredGrid, mesh_b: pv.UnstructuredGrid) -> plt.Figure:
    axs[0, 0].set_title("bbar = false")
    axs[0, 1].set_title("bbar = true")
    return fig
results_bbar_false = {n: run_single_test(n, use_bbar=False) for n in n_range}… (click to toggle)
uy_top_bbar_false = [get_top_uy(ms[-1]) for ms in results_bbar_false.values()]
uy_top_bbar_false_ref = np.array(
    [0.002164586784123102, 0.0022603329644579383, 0.002375295856067169,
     0.002519725590136146, 0.0026515294133790837, 0.002868289617025223]
)  # fmt: skip
np.testing.assert_allclose(uy_top_bbar_false, uy_top_bbar_false_ref, atol=1e-10)
 ogs -o /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Mechanics/CooksMembrane/CooksMembraneBbar -m . /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Mechanics/CooksMembrane/CooksMembraneBbar/modified.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Mechanics/CooksMembrane/CooksMembraneBbar', '-m', '.', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Mechanics/CooksMembrane/CooksMembraneBbar/modified.prj']
results_bbar_true = {n: run_single_test(n, use_bbar=True) for n in n_range}… (click to toggle)
uy_top_bbar_true = [get_top_uy(ms[-1]) for ms in results_bbar_true.values()]
uy_top_bbar_true_ref = np.array(
    [0.006957471385697900, 0.007772616910217863, 0.007897597955618913,
     0.007951479575082158, 0.007976349858390623, 0.007999718483861992]
)  # fmt: skip
np.testing.assert_allclose(uy_top_bbar_true, uy_top_bbar_true_ref, atol=2e-4)
Result
The following figure shows that the convergence of the solutions obtained by using the B bar method follows the one presented in the paper by T. Elguedj et al [1]. However, the results obtained without the B bar method are quit far from the converged solution with the finest mesh.
fig, ax = plt.subplots(figsize=(4, 3))… (click to toggle)
ax.plot(n_range, np.asarray(uy_top_bbar_true) * 1e3, "--o", label="B bar")
ax.plot(n_range, np.asarray(uy_top_bbar_false) * 1e3, "--x", label="non B bar")
ax.legend()
Comparison of results
for n in n_range:
    compare(results_bbar_false[n][-1], results_bbar_true[n][-1])
The contour plots show that even with the coarsest mesh, the B bar method still gives reasonable stress results.
Reference
[1] T.J.R. Hughes (1980). Generalization of selective integration procedures to anisotropic and nonlinear media. International Journal for Numerical Methods in Engineering, 15(9), 1413-1418.
[2] T. Elguedj, Y. Bazilevs, V.M. Calo, T.J.R. Hughes (2008), $\bar\B$ and $\bar\F$ projection methods for nearly incompressible linear and non-linear elasticity and plasticity using higher-order NURBS elements, Computer Methods in Applied Mechanics and Engineering, 197(33–40), 2732-2762.
This article was written by Wenqing Wang. If you are missing something or you find an error please reach out to us on our forum.
Generated with Hugo 0.164.0 in CI job 825193 | Last revision: June 11, 2024
