Debugging OpenGeoSys with VS Code
Visual Studio Code is a powerful text editor that can be extended into a full-featured IDE using plugins. This guide walks you through setting up debugging for OpenGeoSys (OGS) on macOS and Linux.
1. Prerequisites
Install system tools
On macOS:
xcode-select --install
On Linux:
sudo apt update
sudo apt install build-essential cmake gdb lldb ninja-build
Clone and build OGS in debug mode
git clone https://gitlab.opengeosys.org/ogs/ogs.git
cd ogs
cmake --preset debug
ninja -C build/debug ogs
This creates a debug build in build/debug/.
2. VS Code Setup
Install VS Code
Download from https://code.visualstudio.com
Install required extensions
In the Extensions view (Ctrl+Shift+X on Linux, Cmd+Shift+X on macOS), install:
3. Project configuration
Open the project
Open the source code ogs/ folder in VS Code.
Optional: Add a build task
To build OGS from within VS Code:
mkdir -p .vscode
cat > .vscode/tasks.json <<EOF
  "version": "2.0.0",
  "tasks": [
      "label": "Build OGS (CMake debug)",
      "type": "shell",
      "command": "cmake --preset debug && ninja -C ../build/debug ogs",
      "group": {
        "kind": "build",
        "isDefault": true
EOF
To run the build task, press Shift + Command + B on macOS or Ctrl+Shift+B on Linux.
Configure debugging
Create .vscode/launch.json:
[ "${PWD##*/}" = ".vscode" ] || cd .vscode
cat > launch.json <<EOF
   "version": "0.2.0",
  "configurations": [
      "name": "Debug with LLDB",
      "type": "lldb",
      "request": "launch",
      "program": "${workspaceFolder}/../build/debug/bin/ogs",
      "args": [
        "${workspaceFolder}/Tests/Data/LIE/Mechanics/coulomb_load_path.prj"
      "cwd": "${workspaceFolder}/../build/debug",
      "stopOnEntry": false,
      "externalConsole": false
EOF
4. Start a debug session
  1. Open the file Applications/CLI/ogs.cpp.
  2. Set a breakpoint at the first line inside the main() function. Start debugging
  3. Start debugging by clicking the green “Run and Debug” icon, or press F5 (Linux) / Fn + F5 (macOS).
  4. Choose the debug configuration by its name set in launch.json (e.g., Debug with LLDB). Running debug session
  5. The debugger will stop at your breakpoint. You can now step through code, inspect variables, and use the debug toolbar to control execution. Running debug session
This article was written by Mostafa Mollaali, Lars Bilke. If you are missing something or you find an error please let us know.
