Create a simple parallel model
Unsupported Processes
LIE related processes are not supported to use the parallel FEM scheme with PETSc.
Software Modules and Compilation on EVE
  • Checkout the OGS-6 source code
    • Source the environment scripts scripts/env/eve/cli.sh
  • Configure with utilities enabled to:
    • Create the binary for generation of the structured mesh
    • Create the binary for the mesh partitioner tool partmesh
    • cmake <path_to_source> -DOGS_BUILD_UTILS=ON
  • Configure OGS for parallel usage with PETSc:
    • Source the environment scripts scripts/env/eve/petsc.sh
    • cmake <path_to_source> -DOGS_USE_PETSC=ON
  • Build the source code with make
Create a structured mesh
In order to discretize the domain of a unit cube with boundaries execute bin/generateStructuredMesh -o cube_1x1x1_hex_axbxc.vtu -e hex --lx 1 --ly 1 --lz 1 --nx a --ny b --nz c where a, b, and c should be chosen according to the needs.
a b c #cells in 10^6 compute cores success
150 150 150 ~ 3.38 20 yes
175 175 175 ~ 5.36 20 yes
190 190 190 ~ 6.86 20 yes
196 196 196 ~ 7.59 20 no
216 216 216 ~ 10.08 40 yes
236 236 236 ~ 13.14 40 yes
292 292 292 ~ 24.90 80 yes
368 368 368 ~ 49.84 160 yes
422 422 422 ~ 75.15 240 yes
465 465 465 ~ 100.54 320
For the boundary conditions the boundary meshes left, right, top, bottom, front, and back were already constructed by the generateStructuredMesh tool. Alternatively, if the boundaries are simple (i.e. homogeneous), a .gml file is sufficient for the serial case, but for heterogeneous boundary conditions or for the parallelization boundary mesh files are needed.
There are two possibilities to create such files:
  • If there is a .gml file, use constructMeshesFromGeometry tool which takes the mesh file and geometry and creates all the boundaries which are named in the .gml file with the required bulk_node_ids and bulk_element_ids mappings.
  • If there is a boundary mesh (generated by Gmsh or Salome, or extracted in ParaView, for example) use the identifySubdomains tool to create or verify the needed bulk_node_ids and bulk_element_ids mappings.
Partition the mesh with partmesh
  1. Convert VTU mesh into METIS input mesh
    bin/partmesh -i cube_1x1x1_hex_axbxc.vtu --ogs2metis
    => results in a file cube_1x1x1_hex_axbxc.mesh
  2. partition the mesh and the corresponding boundaries.
    bin/partmesh -n number_of_partitions -m -i cube_1x1x1_hex_axbxc.vtu -- boundary_meshes*.vtu
    This will result in a bunch of .bin files.
Deciding the part to benchmark
  • Usually, for solving elliptic problems (for instance, the steady state groundwater flow) the time for the linear solver is the main part of the simulation.
  • The hydro-thermal process can be used for testing of the IO capabilities.
  • In the mechanics process large parts of the computational resources are spent for the assembly.
ToDo
  • script to create models and partitions
  • submit script to cluster
  • Metrics to take into account could be
    • weak scaling (problem size increases as the number of processors increases)
    • strong scaling (fixed problem size, use increasing number of processors => speedup and parallel efficiency)
    • fixed number of processors, increasing problem size
