The tool is build when the OGS_BUILD_UTILS CMake switch is set ON. The build
executable ReorderMesh is placed in the bin directory. The tool is a command line tool.
Running ReorderMesh tool will print the required arguments and a short usage message; for detailed usage add the --help argument.
To reorder a bulk mesh two arguments are required:
- file name for the input mesh including
bulk_node_ids and bulk_element_ids information,
- file name for the reordered mesh.
In contrast to a serial simulation
graph LR
OGS_PRJ[project file]:::InputStyle -->|xml format| OGS
OGS_BULK[bulk mesh]:::InputStyle -->|vtu format| OGS
OGS_BOUNDARY[boundary meshes]:::InputStyle -->|vtu format| OGS
OGS_SOURCE[source term meshes]:::InputStyle -->|vtu format| OGS
OGS(OpenGeoSys):::OGSStyle -->|vtu format| OGS_PRESSURE[simulation results]:::OGSOutputStyle
classDef InputStyle fill:#9090ff
classDef OGSStyle fill:#104eb2, color:#ffffff
classDef OGSOutputStyle fill:#a0a0f0
for a parallel simulation
graph LR
OGS_BULK[bulk mesh]:::InputStyle -->|vtu format| PARTMESH
OGS_BOUNDARY[boundary meshes]:::InputStyle -->|vtu format| PARTMESH
OGS_SOURCE[source term meshes]:::InputStyle -->|vtu format| PARTMESH
PARTMESH[domain decomposition]:::DDCStyle -->|binary format| OGS
OGS(parallel OpenGeoSys):::OGSStyle -->|pvtu format| OGS_PVTU[parallel simulation results]:::OGSOutputStyle
OGS(parallel OpenGeoSys):::OGSStyle -->|HDF5 format| OGS_XDMFHDF5[parallel simulation results]:::OGSOutputStyle
classDef DDCStyle fill:#f2a817
a domain decomposition is required as a preprocessing step. As you can see in
the following pictures the domain decomposition (into 2 sub-domains) changes the
sequence of nodes and elements. On the left the initial node and element
orderings are depicted, on the right the ordering after partitioning is shown.
Simple element-wise or node-wise comparisons of simulation results are not
possible. The tool ReorderMesh can be applied to reorder the nodes and
elements to the initial ordering.
Typically, the workflow is as follows:
graph LR
OGS_PARALLEL_SIMULATION_RESULTS(parallel simulation results):::InputStyle -->|pvtu| OGS_REMOVE_GHOST_DATA[pvtu2vtu]:::OGSStyle
OGS_REMOVE_GHOST_DATA[pvtu2vtu]:::OGSStyle -->|vtu|OGS_IDENTIFY_SUBDOMAIN(identifySubdomains):::OGSStyle
OGS_IDENTIFY_SUBDOMAIN:::OGSStyle -->|vtu with bulk ids|OGS_REORDER_MESH(ReorderMesh):::OGSStyle
OGS_REORDER_MESH(ReorderMesh):::OGSStyle -->OGS_REORDERED_PARALLEL_SIMULATION_RESULTS(reordered simulation results):::OGSOutputStyle
A similar workflow is implemented using snakemake for testing the ReorderMesh
tool.
Generated with Hugo 0.150.1
in CI job 743172
