Three point bending test
The notched beam under three-point bending is simulated to show how the phase field models can capture crack propagation and the structural strength. The geometry and boundary conditions of the model are depicted below. The bottom left point is fixed on both $x$ and $y$ directions and bottom right point is fixed on the $y$ direction. A displacement boundary condition $u^{\ast}$ is applied on the midpoint of the upper edge. The crack will initiate at the notch tip and propagate upward to the upper edge.
  • Three phase field models are implemented in OGS, i.e., $\texttt{COHESIVE}$, $\texttt{AT}_1$ and $\texttt{AT}_2$.
  • The energy-split models include EffectiveStress, Isotropic and the VolumetricDeviatoric.
  • The softening rules implemented for the $\texttt{COHESIVE}$ model are Linear and Exponential.
The force-displacement curves ($F^{\ast}$-$u^{\ast}$) for various sets of the above models will be recorded and compared with the experimental data.
Model
Model
Define some helper functions
import shutil
import time
from types import MethodType
from xml.dom import minidom
data_dir = os.environ.get("OGS_DATA_DIR", "../../..")… (click to toggle)
# define function to replace a specific curve, given by name
def replace_curve(
    self,
    name=None,
    value=None,
    coords=None,
    parametertype=None,
    valuetag="values",
    coordstag="coords",
    root = self._get_root()
# define function to change time_stepping in project file
    model.remove_element(
        model.add_block(
            blocktag="pair",
Define functions generating mesh, modifying project file and running ogs with given parameters
def ogs_TPB(… (click to toggle)
def ogs_TPB(
    phasefield_model,
    energy_split_model,
    softening_curve="Linear",
    length_scale=5.0,
    bc_displacement=-1.0,
    ts_coords="0 1.0",
    values="0 1.0",
    repeat_list=None,
    delta_t_list=None,
    hypre=False,
    MPI=True,
    ncores=4,
    ## define input file
    prj_name = "TPB.prj"
    print(
        f"> Running three point bending test {phasefield_model} - {energy_split_model} - {softening_curve} ... <"
    logfile = f"{out_dir}/log_{phasefield_model}_{energy_split_model}.txt"
    if phasefield_model == "COHESIVE":
        prefix = (
            f"{phasefield_model}" + f"_{energy_split_model}" + f"_{softening_curve}"
    if MPI:
        # partition mesh
        run(
            f"NodeReordering -i TPB.vtu -o {out_dir}/TPB.vtu >> {logfile}",
            shell=True,
            check=True,
        run(
            f"constructMeshesFromGeometry -m {out_dir}/TPB.vtu -g TPB.gml >> {logfile}",
            shell=True,
            check=True,
        shutil.move("TPB_left.vtu", f"{out_dir}/TPB_left.vtu")
        shutil.move("TPB_right.vtu", f"{out_dir}/TPB_right.vtu")
        shutil.move("TPB_top.vtu", f"{out_dir}/TPB_top.vtu")
        shutil.copy("TPB.gml", f"{out_dir}/TPB.gml")
        run(
            f"partmesh -s -o {out_dir} -i {out_dir}/TPB.vtu >> {logfile}",
            shell=True,
            check=True,
        run(
            f"partmesh -m -n {ncores} -o {out_dir} -i {out_dir}/TPB.vtu -- {out_dir}/TPB_right.vtu {out_dir}/TPB_left.vtu {out_dir}/TPB_top.vtu >> {logfile}",
            shell=True,
            check=True,
        run(
            shell=True,
            check=True,
    # change properties in prj file
    model.replace_text(
    model.replace_text(softening_curve, xpath="./processes/process/softening_curve")
    model.replace_parameter_value(name="dirichlet_load", value=bc_displacement)
    if hypre is True:
        model.replace_text(
            with_hypre,
            occurrence=1,
        model.replace_text(
            without_hypre,
            occurrence=1,
    if not MPI:
        # In the MPI case the boundary meshes are created by
        # constructMeshesFromGeometry and partmesh beforehand and are listed in
        # the <meshes> section. Adding the geometry would create boundary meshes
        # of the same names a second time.
        model.replace_text("TPB.gml", xpath="./geometry")
    # run ogs
    t0 = time.time()
    if MPI:
        print(f"  > OGS started execution with MPI - {ncores} cores...")
        run(
            shell=True,
            check=True,
        print("  > OGS started execution ...")
        run(
            shell=True,
            check=True,
    tf = time.time()
Input data
The general parameters are chosen as follows.
Name Value Unit Symbol
Young’s modulus 20000 MPa $E$
Poisson’s ratio 0.2 $-$ $v$
Critical energy release rate 0.113 N/mm $G_{c}$
Regularization parameter 5 mm $\ell$
Minimum element size 1 mm $h$
The material parameters for the COHESIVE model are as follows.
Tensile strength 2.4 MPa $f_t$
Irwin’s length 392.4 mm $\ell_{ch}$
Run Simulations
In the following, coarse time steps are chosen for the sake of less computational cost.
# phasefield_model = ["COHESIVE",'AT1', 'AT2']… (click to toggle)
# energy_split_model = ["EffectiveStress",'VolumetricDeviatoric','Isotropic']
# softening_curve = ['Line','Exponential']
disp = -1.0
ls = 5.0
mpi_cores = 4  # MPI cores
## only run selected cases
# For the COHESIVE model
for a in ["Linear", "Exponential"]:
    ogs_TPB(
        "COHESIVE",
        "EffectiveStress",
        a,
        length_scale=ls,
        bc_displacement=disp,
        repeat_list=["1"],
        delta_t_list=["1e-1"],
        ncores=mpi_cores,
# For AT1 and AT2 models with isotropic split
for b in ["AT1", "AT2"]:
    ogs_TPB(
        b,
        "Isotropic",
        length_scale=ls,
        repeat_list=["1"],
        ncores=mpi_cores,
> Running three point bending test COHESIVE - EffectiveStress - Linear ... <
  > OGS terminated execution. Elapsed time:  46.84  s.
> Running three point bending test COHESIVE - EffectiveStress - Exponential ... <
  > OGS terminated execution. Elapsed time:  132.96  s.
> Running three point bending test AT1 - Isotropic - Linear ... <
  > OGS terminated execution. Elapsed time:  52.85  s.
> Running three point bending test AT2 - Isotropic - Linear ... <
  > OGS terminated execution. Elapsed time:  51.42  s.
The phase field profile in the final time step of the COHESIVE EffectiveStress case with Exponential softening is shown below.
Phase-field
Phase-field
Post-processing
The force-displacement curves ($F^{\ast}$-$u^{\ast}$) applied to the beam are compared.
# define function to obtain displacement applied at the loading point from vtu file… (click to toggle)
def displ_midpoint(filename):
    data = pv.read(filename)
    return np.sum(
        data.point_data["displacement"][:, 1],
        where=(data.points[:, 0] == 225) * (data.points[:, 1] == 100),
# define function to obtain force at the loading point from vtu file
def force_midpoint(filename):
    return (
        np.sum(
            data.point_data["NodalForces"][:, 1],
        / 10.0
# define function to apply the above functions on all vtu files listed in pvd file, returning force-displacement curves
    doc = minidom.parse(pvd)
    forces_midpoint = [force_midpoint(f"{out_dir}/{x}") for x in vtu_files]
    displs_midpoint = [displ_midpoint(f"{out_dir}/{x}") for x in vtu_files]
    return [forces_midpoint, displs_midpoint]
Plot force-displacement curves
# Load experimental data… (click to toggle)
data_lower = pd.read_csv("figures/experiment_data_lower_limit.csv")
data_upper = pd.read_csv("figures/experiment_data_upper_limit.csv")
prefixes = [… (click to toggle)
prefixes = [
    "AT1_Isotropic",
    "AT2_Isotropic",
    "COHESIVE_EffectiveStress_Linear",
    "COHESIVE_EffectiveStress_Exponential",
labels = [
    r"${AT}_1$ Isotropic",
    r"${AT}_2$ Isotropic",
    r"${COHESIVE}$ EffectiveStress Linear",
    r"${COHESIVE}$ EffectiveStress Exponential",
ls = ["-.", "--", ".", "-"]
colors = ["#ffdf4d", "#006ddb", "#8f4e00", "#ff6db6"]
fig, ax = plt.subplots()
    pvd = f"{out_dir}/{pre}.pvd"
    if Path(pvd).is_file():
        plt.plot(
            curve[1],
            curve[0],
            ls[i % 2],
            label=labels[i],
            linewidth=2,
            color=colors[i],
            alpha=1,
plt.rcParams["xtick.labelsize"] = 12
plt.rcParams["ytick.labelsize"] = 12
ax.grid(linestyle="dashed")
ax.set_xlabel("$u^{\\ast}$ [mm]", fontsize=12)
ax.set_ylabel("$F^{\\ast}$ [kN]", fontsize=12)
plt.xlim(plt.xlim()[::-1])
plt.ylim(plt.ylim()[::-1])
plt.legend(ncol=1)
plt.fill_between(
    data_upper.iloc[:, 0], 0, data_upper.iloc[:, 1], facecolor="green", alpha=0.3
plt.fill_between(
    data_lower.iloc[:, 0], 0, data_lower.iloc[:, 1], facecolor="white", alpha=1
<matplotlib.collections.FillBetweenPolyCollection at 0x7fab3d137750>
Running all the selected cases with fine time steps (100 steps) yields the following figure in which the green patch bounds the experimental data. The cohesive models match the experimental results better than $\texttt{AT}_1$ and $\texttt{AT}_2$.
This article was written by Tao You, Keita Yoshioka, Mostafa Mollaali. If you are missing something or you find an error please reach out to us on our forum.
Generated with Hugo 0.164.0 in CI job 825193 | Last revision: November 28, 2022
