Introduction
Installation
There are various ways to obtain a (pre-built) running version of OpenGeoSys (OGS) on your machine. You can have OGS for different operating systems including Windows, Linux, and macOS. The basic modelling platform is available for all operating systems. The different operating systems and installation methods give you the feature matrix:
Operating system / Installation method MFront PETSc MKL
Windows / binary download
Windows / pip
macOS / pip & conda
Linux / pip & conda
Linux / Serial Container
Linux / PETSc Container
Using Linux binaries on other operating systems
Please note that you can use Linux binaries installed via pip or in the form of a container also on other operating systems.
For Windows we recommend the Windows Subsystem for Linux (WSL).
On macOS you can use either a virtual machine (e.g. via UTM) or run a Docker container.
Install via pip
A straightforward way of installing OGS is via Python’s pip-tool:
# Optional: create a Python virtual environment, see below
python -m venv .venv
.\venv\Scripts\Activate.ps1 # for PowerShell OR
.\venv\Scripts\activate.bat # for Command Prompt
# Install latest ogstools and ogs release (6.5.7) via pip:
pip install ogstools[ogs]
# OR: Install latest ogs master (weekly) via pip:
pip install --pre --index-url https://gitlab.opengeosys.org/api/v4/projects/120/packages/pypi/simple ogstools[ogs]
If you get errors when calling the Activate.ps1 script you have to run the following command once:
Set-Execution-Policy Unrestricted -Scope CurrentUser
python -m venv .venv      # or `python3 -m venv .venv`
source .venv/bin/activate
See Linux-tab!
Please note that this requires a Python installation (version 3.10 - 3.13) with the pip-tool.
We recommend using Python within a virtual environment to keep possible conflicts of different Python-packages localised. If you use pip for installation of OGS in a virtual environment and you activate the virtual environment, then OGS and its tools are automatically also in the PATH. If the virtual environment is not activated you may still use OGS, but either have to give the full path to ogs being located in the bin folder (or Scripts folder on Windows) of the virtual environment, or add this path to your PATH-environment. Moreover, pip may print instructions which directory needs to be added to the PATH.
Advanced usage: Use binaries from PATH instead of pip package
When using the OGS Python bindings it may be desired to use a different OGS version than provided by the pip package. This can be achieved by setting the environment variable OGS_USE_PATH. E.g.:
pip install ogs
# now ogs from pip is used
export PATH=/path/to/ogs/bin:$PATH
OGS_USE_PATH=1 python
# now in Python interpreter:
>>> import ogs
>>> ogs.cli.ogs("--version") # uses /path/to/ogs/bin/ogs instead of ogs from pip
Alternative: Install via binary downloads
Another way to obtain a running version is to just download the latest stable or development release of OpenGeoSys from the Releases-page.
By downloading from the release page you will get a bunch of folders and files. However, OGS itself will come as a simple executable file, which you will find in the bin sub-folder. You can put the executable wherever you like. For convenience you may put it into a location which is in your PATH-environment variable or modify the PATH environment variable which allows you to start the executable without specifying its full file path. Then just calling ogs from the terminal is sufficient.
Alternative: Install via conda
You can use the Conda package manager to install OGS:
conda config --add channels conda-forge
conda create -n my-ogs-env
conda activate my-ogs-env
conda install ogs
When the environment is activated then just calling ogs from the terminal is sufficient.
Download benchmarks
You can download the latest benchmark files from GitLab:
  • On our OGS repository on GitLab browse to the Tests/Data -folder
  • Browse to the process subfolder you are interested in, e.g. Elliptic (1.)
  • Find the Downloads-dropdown (2.)
  • Choose an appropriate format under Download this directory (3.)
  • Uncompress the downloaded file
See the Benchmarks section for more information on the benchmarks.
Instructions for downloading benchmarks
Running
OGS is a command line application and requires the path to a .prj-file as an argument.
To run it open a new command line shell (called cmd.exe). Now simply type ogs (if the executable is in your PATH -environment variable) or specify its full path (e.g.: C:\Users\MyUserName\Downloads\ogs.exe) and hit ENTER.
OGS prints out its usage instructions:
PARSE ERROR:
             Required argument missing: project-file
Brief USAGE:
   ogs  [--] [--version] [-h] <PROJECT FILE>
For complete USAGE and HELP type:
   ogs --help
You can see that there is the project-file missing.
Then simply supply the path to a project file as an argument to the OGS executable:
ogs .\Path\to\BenchmarkName.prj
To run it open a new command line shell (Terminal). Now simply type ogs (if the executable is in your PATH-environment variable) or specify its full path (e.g.: ./path/to/ogs) and hit ENTER.
PARSE ERROR:
Brief USAGE:
   ogs --help
ogs ./path/to/BenchmarkName.prj
PARSE ERROR:
Brief USAGE:
   ogs --help
Generated with Hugo 0.154.5 in CI job 743084 | Last revision: March 10, 2026
Commit: [cmake] Introduced clang base preset. 222b33c5f  | Edit this page on
