Command-line arguments
The following arguments are available:
$ ogs --help
   --enable-fpe
     enables floating point exceptions
   --unbuffered-std-out
     use unbuffered standard output
   --config-warnings-nonfatal
     warnings from parsing the configuration file will not trigger program
     abortion
   -l <LOG_LEVEL>,  --log-level <LOG_LEVEL>
     the verbosity of logging messages: none, error, warn, info, debug, all
   -m <PATH>,  --mesh-input-directory <PATH>
     the directory where the meshes are read from, default is project file directory
   -o <PATH>,  --output-directory <PATH>
     the output directory to write to
   --write-prj
     Writes processed project file to output path /
     [prj_base_name]_processed.prj.
   -p <>,  --xml-patch <>  (accepted multiple times)
     the xml patch file(s) which is (are) applied (in the given order) to
     the PROJECT_FILE
   -r <PATH>,  --reference <PATH>
     Run output result comparison after successful simulation comparing to
     all files in the given path. This requires test definitions to be
     present in the project file.
   --,  --ignore_rest
   --version
   -h,  --help
   <PROJECT_FILE>
     (required)  Path to the ogs6 project file.
Generated with Hugo 0.154.5 in CI job 743084 | Last revision: March 10, 2026
Commit: [cmake] Introduced clang base preset. 222b33c5f  | Edit this page on
