Project file structure
The main input taken by OpenGeoSys is a path to a project file. This file has a “.prj” extension and describes all aspects of the simulation that OpenGeoSys is expected to execute.
The syntax of the project file follows the syntax of a typical XML file and can be edited with any editor capable of working with this kind of files.
The structure of the project file is relatively flexible: as long as the semantics of the file is intact, the main blocks can be provided in any order.
Depending on the scope of the simulation, the content of the project file will differ. However, there are some basic requirement that have to be fulfilled.
Please note, that this page is not a complete description of the XML standard. It only provides some information to interact with and understand OpenGeoSys "*.prj" files. More meta-information on XML can be found here: XML Standard.
The XML files structure follows an abstract idea of a tree: i.e., here one starts from the roots and continues up to the leaves. As such the main tag within an XML file is called root. In OpenGeoSys project files the root tag looks like this: < OpenGeoSysProject> </OpenGeoSysProject>. Between opening and closing tags all the project relevant information is contained. Everything between those tags follows a hierarchical structure. There will be thematic blocks that cover specific aspects of the simulation. They define for example mesh files, or a process used in the simulation. The following XML-snippet shows a small structure containing the two elementary blocks, which are empty for now:
<OpenGeoSysProject>
    <mesh>
    </mesh>
    <process>
    </process>
The blocks <mesh> </mesh> and <processes> </processes> are at the same “level”, which is indicated by the indent. Those are the child elements of the root <OpenGeoSysProject>, which is their parent element. As they are on the same level, they can be described as siblings. This hierarchy is recursive. This means, that each of the child elements can have it’s own child elements and be parent to them (think of family structure: grandparents -> parent -> children, where the children are grandchildren of the grandparents).
In following snippet you can see a <processes> </processes> element containing child element <processes> </processes>, which again contains two child elements: <name> </name> and <type> </type>:
<OpenGeoSysProject>
    <process>
        <process>
        </process>
    </process>
This snippet can be understood in more human readable way as follows:
In this project file used by OpeGeoSys there is one instance of <processes>, which we call SteadyStateDiffusion and this instance is a realization of the type STEADY_STATE_DIFFUSION implemented in OpenGeoSys.
Attributes
If a value is set between < and >, beside the tag, it is called attribute. For example:
<planet satellite_name="Moon">
The entity planet has the attribute satellite_name, which is set to Moon.
In project files, attributes are used in some blocks to distinguished between multiple instances of the same entity. For example media are identified by their attribute “id”:
<medium id="0">
and processes in time loop by the “ref” attribute:
Comments
If you want to switch between two version of a certain part of the project file, two values etc, but without need to remove those fragments completely from the file, you can comment them out:
<!--value>this value will be comment out and ignored by OpenGeoSys</value-->
<value>this value will be read and used by OpenGeoSys</value>
Please note that comments cannot be nested. If you try to comment out a block that already contains a commented section, it will result in an error.
More information
More details on what blocks are required/available in the project file and what they can contain, please see: Project file over view.
File encoding
In order to ensure correct encoding, it is good practice to add following line at the beginning of the project file:
This article was written by Feliks Kiszkurno. If you are missing something or you find an error please let us know.
Generated with Hugo 0.154.5 in CI job 743084 | Last revision: March 10, 2026
Commit: [cmake] Introduced clang base preset. 222b33c5f  | Edit this page on
