Modularizing project files
Project files .prj have to be valid XML documents. For information of specific tags see our Doxygen-documentation.
Two methods allow you to modularize your project files and avoid repetition:
Option 1: Include XML-content from other files
The <include file="other_file.xml" />-tag allows to include the content of another XML into the current project file.
Limitation: Only one child include-element per (regular) XML-element is allowed.
Tests/Data/Elliptic/circle_radius_1/circle_1e1_axi.prj:
    <processes>
        <include file="../cube_1x1x1_SteadyStateDiffusion/SteadyStateDiffusion.xml"/>
    </processes>
Tests/Data/Elliptic/cube_1x1x1_SteadyStateDiffusion/SteadyStateDiffusion.xml:
<process>
    <process_variables>
        <process_variable>pressure</process_variable>
    </process_variables>
    <secondary_variables>
        <secondary_variable internal_name="darcy_velocity" output_name="v"/>
    </secondary_variables>
</process>
Note on file encoding
Please do not use UTF-8 with BOM-encoding! The BOM-marker from the included file will be included somewhere in the middle of the final prj-file and this will cause OGS’ ConfigTree to crash. In a text editor you typically can convert a file to other encodings. Please also check your text editor for default encodings on creating new files. In general UTF-8 or ISO 8859-1 should be fine.
Option 2: Apply patch files to the project file
Patch files contain <replace>, <add> and <remove>-elements with XPath-selectors to modify a specific part of the project file (in-memory during run-time):
Tests/Data/Elliptic/square_1x1_SteadyStateDiffusion/square_neumann.xml:
<OpenGeoSysProjectDiff>
    <add sel="/*/time_loop/output/prefix/text()" pos="after">_neumann</add>
    <replace sel="/*/parameters/parameter[2]/name/text()">p_neumann</replace>
    <replace sel="/*/parameters/parameter[3]/name/text()">p_Dirichlet</replace>
    <replace sel="/*/parameters/parameter[3]/value/text()">1</replace>
    <replace sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[1]/parameter/text()">p_Dirichlet</replace>
    <replace sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[2]/type/text()">Neumann</replace>
    <replace sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[2]/parameter/text()">p_neumann</replace>
    <add sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[1]" pos="after">
        <boundary_condition>
            <geometrical_set>square_1x1_geometry</geometrical_set>
            <geometry>bottom</geometry>
            <type>Dirichlet</type>
            <parameter>p_Dirichlet</parameter>
        </boundary_condition>
    </add>
</OpenGeoSysProjectDiff>
For more examples see this page on the XML Patch Operations Framework.
Option 2a: Supply patch file(s) additionally to the prj-file
ogs -p path/to/square_1e0_neumann.xml [other/optional/patch_file.xml] path/to/square_1e0.prj
Supplied patch files are applied in the given order.
Option 2b: Use a patch file directly
If the patch file specifies a base_file:
Tests/Data/Elliptic/cube_1x1x1_SteadyStateDiffusion/cube_1e1.xml:
<OpenGeoSysProjectDiff base_file="cube_1e0.prj">
    <replace sel="/*/mesh/text()">cube_1x1x1_hex_1e1.vtu</replace>
    <replace sel="/*/time_loop/output/prefix/text()">cube_1e1</replace>
you can just pass this patch file:
ogs path/to/cube_1e1.xml
In this case you have just one patch file.
Combination of include and patch method
When both methods are combined the logical order is the following:
  1. Apply patches
  2. Insert includes
  3. Apply patches marked with after_includes="true"-attribute only.
Example:
    <!-- The first line is run before the includes: -->
    <!-- The following is evaluated after the includes are run: -->
    <replace sel="/*/time_loop/output/prefix/text()" after_includes="true">cube_1e1</replace>
Check project file syntax with xmllint
You can check the formatting with the xmllint-tool:
xmllint --noout myproj.prj
Installation of xmllint
We recommend to install via Chocolatey:
choco install xsltproc
Alternative installation
Another method is to use the Windows Subsystem for Linux where you can simply install Linux packages:
sudo apt-get install libxml2-utils
xmllint is part of the Homebrew xmlstarlet package:
brew install xmlstarlet
Generated with Hugo 0.154.5 in CI job 743084 | Last revision: March 10, 2026
Commit: [cmake] Introduced clang base preset. 222b33c5f  | Edit this page on
