This tool marks all elements in a voxel grid (i.e. a structured hex grid, for instance created with Layers2Grid or Vtu2Grid) that are intersected by a triangulated 2D mesh representing a fault or some other significant structure. The material group for those intersected elements can be explicitly specified. Otherwise the largest existing MaterialID will be increased by one and defined as MaterialID for those elements.
AddFaultToVoxelGrid -i <string> -f <string> -o <string>
[-m <non-negative integer>] [--] [--version] [-h]
-i <string>, --input <string>
(required) name of the input file list containing the paths the all
-f <string>, --fault <string>
(required) name of mesh representing fault (*.vtu)
-o <string>, --output <string>
(required) name of output mesh (*.vtu)
-m <non-negative integer>, --material <non-negative integer>
material id for cells intersected by fault
--, --ignore_rest
--version
-h, --help
Displays usage information and exits.AddFaultToVoxelGrid -i grid.vtu -f fault.vtu -o grid_fault.vtu
Fig. 1 The left figure shows the input grid with the intersecting triangulated 2D mesh, which is highlighted in red. The center and right figure show the output voxel grid.
Generated with Hugo 0.150.1
in CI job 743172
