Kozeny-Carman for ComponentTransport
This notebook defines a minimal 1D ComponentTransport problem to verify the Kozeny-Carman constitutive update under controlled hydraulic loading.
The pressure boundary conditions are prescribed as
$$ p_{\text{inlet}} = 110000\ \text{Pa}, \qquad p_{\text{outlet}} = 100000\ \text{Pa}. $$
Permeability is evaluated using the Kozeny-Carman relation
$$ k_{\text{KozenyCarman}} = k_0 \left(\frac{1-\phi_0}{1-\phi}\right)^2 \left(\frac{\phi}{\phi_0}\right)^3, $$
with initial values $k_0$ and $\phi_0$, and time-dependent porosity
$$ \phi(t)= \begin{cases} 0.10, & t < 0.51\ \text{s},\\ 0.50, & t \ge 0.51\ \text{s}. \end{cases} $$
Run OpenGeoSys
prj_in = "Kozeny_Carman_NonChemical.prj"… (click to toggle)
model = ot.Project(input_file=prj_in, output_file=out_dir / prj_in)
model.run_model(
    logfile=out_dir / "ogs.log",
    args=f"-o {out_dir} -m .",
 ogs -o /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Parabolic/ComponentTransport/ReactiveTransport/Porositychange/Kozeny_Carman_NonChemical -m . /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Parabolic/ComponentTransport/ReactiveTransport/Porositychange/Kozeny_Carman_NonChemical/Kozeny_Carman_NonChemical.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Parabolic/ComponentTransport/ReactiveTransport/Porositychange/Kozeny_Carman_NonChemical', '-m', '.', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/Parabolic/ComponentTransport/ReactiveTransport/Porositychange/Kozeny_Carman_NonChemical/Kozeny_Carman_NonChemical.prj']
Post-processing
Read project constants
tree = ET.parse(prj_in)… (click to toggle)
root = tree.getroot()
def get_parameter_value(name: str) -> float:
    for p in root.findall("./parameters/parameter"):
        pname = p.findtext("name")
        if pname == name:
            return float(p.findtext("value"))
    msg = f"Parameter '{name}' not found."
    raise KeyError(msg)
phi0 = get_parameter_value("poro0")
k0 = get_parameter_value("kappa0")
print(f"phi0 = {phi0}")
print(f"k0   = {k0:.3e} m^2")
phi0 = 0.1
k0   = 1.000e-14 m^2
Load OGS output
pvd_file = out_dir / "simple1d_kozeny.pvd"… (click to toggle)
ms = ot.MeshSeries(pvd_file)
times = np.asarray(ms.timevalues, dtype=float)
phi_vals = np.nanmean(ms.cell_data["porosity_avg"], axis=1)
k_ogs = np.nanmean(ms.cell_data["permeability_avg"], axis=1)
k_theory = k0 * ((1.0 - phi0) / (1.0 - phi_vals)) ** 2 * (phi_vals / phi0) ** 3
err_rel = np.abs(k_ogs - k_theory) / np.maximum(np.abs(k_theory), 1e-30)
Observation point over time
obs_point = ms.mesh(0).cell_centers().points[[0]]… (click to toggle)
phi_obs = ot.MeshSeries.probe(ms, obs_point, data_name="porosity_avg").values(
    "porosity_avg"
k_obs = ot.MeshSeries.probe(ms, obs_point, data_name="permeability_avg").values(
    "permeability_avg"
fontsize = 14
fig_obs, (ax_phi, ax_k) = plt.subplots(1, 2, figsize=(16, 5.5))
ax_phi.plot(times, np.ravel(phi_obs), marker="o", ms=5)
ax_k.plot(times, np.ravel(k_obs), marker="s", ms=5)
ax_phi.set_ylabel("porosity / 1")
ax_k.set_ylabel("permeability / m$^2$")
ax_k.set_yscale("log")
for ax in (ax_phi, ax_k):
    ax.set_xlabel("time / s")
    ot.plot.utils.update_font_sizes(ax, fontsize=fontsize)
fig_obs.tight_layout()
fig_obs.subplots_adjust(wspace=0.45)
Compare Kozeny-Carman and OGS permeability
At each time step, the theoretical value $k_{\text{KozenyCarman}}$ is compared against the simulated value $k_{\text{OGS}}$ (from permeability_avg) through the relative error
$$ e_{\text{rel}} = \frac{\left|k_{\text{OGS}} - k_{\text{KozenyCarman}}\right|} {k_{\text{KozenyCarman}}}. $$
The verification objective is constitutive consistency: $k_{\text{OGS}} \approx k_{\text{KozenyCarman}}$ and $e_{\text{rel}}$ should remain close to zero.
if not (np.all(np.isfinite(k_ogs)) and np.all(np.isfinite(k_theory))):… (click to toggle)
    msg = (
        "permeability contains non-finite values; this benchmark's mesh has no "
        "inactive elements, so a NaN/inf here indicates a regression."
    raise RuntimeError(msg)
fig_cmp, ax_cmp = plt.subplots(figsize=(8, 5.5))
ax_cmp.plot(
    times,
    k_theory,
    "k-o",
    lw=2,
    ms=5,
    label="Kozeny-Carman model",
ax_cmp.plot(times, k_ogs, "s", ms=5, label="OGS")
ax_cmp.set_xlabel("time / s")
ax_cmp.set_ylabel("permeability / m$^2$")
ax_cmp.set_yscale("log")
ax_cmp.grid(True, which="both", alpha=0.3)
ax_cmp.legend()
ot.plot.utils.update_font_sizes(ax_cmp, fontsize=fontsize)
fig_cmp.tight_layout()
np.testing.assert_array_less(… (click to toggle)
    err_rel,
    1e-12,
    err_msg="Kozeny-Carman relative error exceeds tolerance 1e-12.",
print("max relative error:", f"{np.max(err_rel):.3e}")
max relative error: 9.466e-16
This article was written by Mostafa Mollaali. If you are missing something or you find an error please reach out to us on our forum.
Generated with Hugo 0.164.0 in CI job 825193 | Last revision: February 24, 2026
