Converts a 2D surface mesh into a Shapefile such that each element is represented by a polygon. Cell attributes are transferred onto shape polygons while point attributes are ignored.
Mesh2Shape -i <input_file.vtu> -o <output_file.shp>
-i <input_file.vtu>, --input-file <input_file.vtu>
(required) OGS mesh file (*.vtu, *.msh)
-o <output_file.shp>, --output-file <output_file.shp>
(required) Esri Shapefile (*.shp)Input data:
Command:
Mesh2Shape -i Mueglitz2D_Point2Cell.vtu -o Mueglitz2D_Point2Cell.shp
The utility allows to export meshes, and in particular simulation results, into existing GIS-projects and use the data as input for subsequent workflows.
Generated with Hugo 0.150.1
in CI job 743172
