GitLab CI is a powerful Continuous Integration system integrated into GitLab.
The tasks of the CI system are configured in scripts inside the OGS source code. The entry point is defined in .gitlab-ci.yml. Scripting and versioning the configuration together with the source code is very powerful, e.g. if you introduce a new OGS CMake configuration in a merge request even the change of the CI jobs configuration or jobs environment (Docker container definition) can be part of the merge request.
A CI run consists of a pipeline which contains stages which in turn contain jobs. A job runs a set of instructions (e.g. checking out the source code, building the code, testing the code) on a runner.
Each pipeline run is visualized as follows:
Jobs belong to a stage and each job will get a status (success, warnings, failure). Some jobs are optional (see the gear icon) and can be manually triggered by pressing the play button.
The master-branch of the main repository as well as all merge requests on that repository are automatically tested. See the pipelines page.
If you want to skip a pipeline run for a push add the -o ci.skip git push option. Example:
git push -o ci.skipOr add [ci skip] to the commit message to skip the pipeline for this commit. Example:
git commit -m "Added feature X [ci skip]"Or use the merge request label ci::skip.
During work on MR you may want to reduce the pipeline run time to get feedback faster. Following options are available and can be combined:
Set environment variables used during CI pipeline in the merge request description. The syntax is
CI-variables:
CTEST_ARGS="-R pytest"
BUILD_TESTS="false"
Possible variables to set:
CTEST_ARGS: Are passed to ctest invocations. Use e.g. -R to select specific tests (such as your currently worked on benchmark) or -LE to exclude labelled tests.BUILD_TESTS: Disable unit tests (testrunner) when set to false.BUILD_CTEST: Disable benchmark / notebook tests when set to false.OGSTOOLS_REF: Change ogstools version used in notebook tests (used by ogstools CI).These pipelines can be selected by using merge request labels:
ci::web only: Runs Jupyter notebook ctests only and builds the web site.ci::web only (fast): Creates a static web site preview without running Jupyter notebook ctests.ci::linux only and ci::mac only and ci::win only: Runs platform specific builds only.More MR labels affecting CI pipelines:
ci_large for enabling large ctests in merge request pipelines. Combine with ci::linux only for faster feedback on the benchmarks..gitlab-ci.yml and scripts/ci/pipelines/regular.yml (advanced usage)You can change the pipeline by editing the .gitlab-ci.yml and scripts/ci/jobs/*.yml files. It is good practice to mark these changes with commits starting with drop: ... in the commit message so they can be removed later easily.
All jobs get included in the include:-section in the file scripts/ci/pipelines/regular.yml. You can simple comment out files to disable jobs defined in that files. Please note that some jobs depend on other jobs.
All jobs are defined scripts/ci/jobs/*.yml. You can disable a single job by prefixing its name with a dot, e.g.:
# enabled job:
build linux arch:
# disabled job:
.build linux arch:This article was written by Lars Bilke. If you are missing something or you find an error please let us know.
Generated with Hugo 0.150.1
in CI job 743172
