Benchmark documentation can also be given in form of Jupyter Notebooks, see Jupyter notebooks as documentation for details.
PATH. Attention: Use the extended version: e.g. hugo_extended_0.146.0_Windows-64bit.zipweb-target, this creates the web site in [build-dir]/web/public, orpreview-web-target, which starts a Hugo server where you can preview the site at http://localhost:1313.As you make modifications to the site it will be rebuild and the page in the browser gets reloaded when then preview server is running.
To manually build the site:
cd [build-dir]/web
yarn
yarn build
# OR
yarn serverTo view all available yarn commands run yarn run.
Executed Jupyter notebooks show up in the preview server too, e.g. in your build-directory:
ctest -R nb- -j 4 # Runs all available notebooks
ninja preview-web
# If not opened automatically, open http://localhost:1313 in your browserSimply create a new index.md-file in the correct location and fill it by yourself. Prefer to use page bundles when you want to add other assets, e.g. images, to the page.
content/
├── docs
│ ├── my-post
│ │ └── index.mdThis page will be available at the URL /docs/my-post/ and the content of the page is in index.md.
Page meta data is given in frontmatter.
weight: Navigation is handled automatically by the folder structure. Use the weight-parameter in the frontmatter to specify the order of pages in ascending order (top -> down).image: Specify an image in the page bundle used for the gallery view.We use Markdown for the actual content. Hugo uses the GoldMark Markdown parser with the following additional markdown extensions:
Use regular Markdown syntax:
The path to the image is the relative path to the current page bundle.
You can add size attributes to the filename with a #-character:
Possible size values are one-third, one-half and two-third.
For even more flexible image handling you can use Hugo’s figure-shortcode, e.g.:
{{< figure src="elephant.jpg" width="50%" title="An elephant at sunset" >}}Or for two images side-by-side:
{{< figure src="image_left.png" class="w-1/2 float-left" >}}
{{< figure src="image_right.png" class="w-1/2 float-left" >}}Equations can be set with typical LaTeX syntax by using MathJax. Blocks are defined by $$ at the beginning and $$ at the end of the block or by simply using a LaTex environment like \begin{equation}...\end{equation}. Inline math uses one $ as the delimiter. For more usage instructions see the MathJax LaTeX help.
Files belonging directly to a page (e.g. images shown on that same page) should be added directly. Other stuff such as linked PDF files, book chapter input files should be uploaded elsewhere and linked to. You can ask @bilke to host these files for you (on S3 storage).
Bibliography items from any .bib-file in web/content/publications/ can be referenced by their cite key with the bib-shortcode:
{{< bib "Kolditz2012" >}}produces
O. Kolditz et al. (2012): OpenGeoSys: an open-source initiative for numerical simulation of thermo-hydro-mechanical/chemical (THM/C) processes in porous media. Environmental Earth Sciences, No. 2, vol. 67, p. 589-599, DOI:10.1007/s12665-012-1546-x@article{Kolditz2012,
abstract = {In this paper we describe the OpenGeoSys (OGS) project, which is a scientific open-source initiative for numerical simulation of thermo-hydro-mechanical-chemical processes in porous media. The basic concept is to provide a flexible numerical framework (using primarily the Finite Element Method (FEM)) for solving multifield problems in porous and fractured media for applications in geoscience and hydrology. To this purpose OGS is based on an object-oriented FEM concept including a broad spectrum of interfaces for pre- and postprocessing. The OGS idea has been in development since the mid-eighties. We provide a short historical note about the continuous process of concept and software development having evolved through Fortran, C, and C++ implementations. The idea behind OGS is to provide an open platform to the community, outfitted with professional software-engineering tools such as platform-independent compiling and automated benchmarking. A comprehensive benchmarking book has been prepared for publication. Benchmarking has been proven to be a valuable tool for cooperation between different developer teams, for example, for code comparison and validation purposes (DEVOVALEX and CO2 BENCH projects). On one hand, object-orientation (OO) provides a suitable framework for distributed code development; however, the parallelization of OO codes still lacks efficiency. High-performance-computing efficiency of OO codes is subject to future research.},
author = {Kolditz, O. and Bauer, S. and Bilke, L. and Böttcher, N. and Delfs, J. O. and Fischer, T. and Görke, U. J. and Kalbacher, T. and Kosakowski, G. and McDermott, C. I. and Park, C. H. and Radu, F. and Rink, K. and Shao, H. and Shao, H. B. and Sun, F. and Sun, Y. Y. and Singh, A. K. and Taron, J. and Walther, M. and Wang, W. and Watanabe, N. and Wu, Y. and Xie, M. and Xu, W. and Zehner, B.},
category = {Methods},
day = {01},
doi = {10.1007/s12665-012-1546-x},
issn = {1866-6299},
journal = {Environmental Earth Sciences},
month = {Sep},
number = {2},
pages = {589-599},
title = {OpenGeoSys: an open-source initiative for numerical simulation of thermo-hydro-mechanical/chemical (THM/C) processes in porous media},
volume = {67},
year = {2012}
# Creates a link to the project-parameter on a benchmark page
{{< data-link >}}produces
Elliptic/cube_1x1x1_SteadyStateDiffusion/drainage_excavation.prj# Creates a URL to the given file in Tests/Data
{{< data-url "Elliptic/cube_1x1x1_SteadyStateDiffusion/drainage_excavation.prj" >}}https://gitlab.opengeosys.org/ogs/ogs/-/blob/6.5.8/Tests/Data/Elliptic/cube_1x1x1_SteadyStateDiffusion/drainage_excavation.prj# Reads the versions.json file outputs values
{{< dataFile "versions.minimum_version.gcc" >}}13.3.0# Outputs the pip package. Use this to have consistent package
# version on the versioned web pages.
{{< ogs-pip-package >}}ogs==6.5.8# Outputs the pip package of ogstools. Use this to have consistent package
{{< ogstools-pip-package >}}ogstools# Produces 'master' or current tag for releases.
# Use this to construct consistent links to links to files.
{{< repo-ref >}}6.5.8This article was written by Lars Bilke. If you are missing something or you find an error please let us know.
Generated with Hugo 0.150.1
in CI job 743172
