Code style and formatting
We aim for a consistent and readable coding style. You do not need to worry about styling if you use the right tools we present in the following. Please also enable pre-commit in your repository to have these check run automatically for you on every commit!
C++
Use clang-format. It can be added to be automatically run on save in your editor / IDE:
  • Vim
  • Visual Studio
  • Visual Studio Code (part of the C++ extension)
    • Important: Set the setting editor.formatOnSaveMode to modificationsIfAvailable to only format modified lines.
The current style is defined in .clang-format.
Runs also automatically (no installation necessary) on git commit using pre-commit which needs to be enabled once with pre-commit install.
Python
Use black. It can be added to be automatically run on save in your editor / IDE:
black is also run by our pre-commit-hooks. To run manually:
pre-commit run black --all-files
CMake
Use cmake-format. It can be added to be automatically run on save in your editor / IDE:
The current style is defined in .cmake-format.yaml.
On installation make sure to install with the YAML option:
pip install cmakelang[YAML]
Build targets
You can run clang-format and cmake-format on the full OGS code base by building the following targets:
Language Shows formatting Applies formatting
C++ clang-format fix-clang-format
CMake cmake-format fix-cmake-format
