We start with Poisson equation:
$$ \begin{equation} \- k\\; \Delta p = Q \quad \text{in }\Omega \end{equation}$$w.r.t boundary conditions
$$ \eqalign{ p(x) = g_D(x) &\quad \text{on }\Gamma_D,\cr k\\;{\partial p(x) \over \partial n} = g_N(x) &\quad \text{on }\Gamma_N, }$$where $p$ could be the pressure, the subscripts $D$ and $N$ denote the Dirichlet- and Neumann-type boundary conditions, $n$ is the normal vector pointing outside of $\Omega$, and $\Gamma = \Gamma_D \cup \Gamma_N$ and $\Gamma_D \cap \Gamma_N = \emptyset$.
We solve the Poisson equation on a square domain $[0\times 1]^2$ with $k = 1$ w.r.t. the specific boundary conditions:
$$ \eqalign{ p(x,y) = 1 &\quad \text{on } (x=0,y) \subset \Gamma_D,\cr p(x,y) = 0 &\quad \text{on } (x=1,y) \subset \Gamma_D,\cr k\\;{\partial p(x,y) \over \partial n} = 0 &\quad \text{on }\Gamma_N. }$$and the source term is $Q=1$.
$$ p(x,y) = - \frac{1}{2} (x^2 + x) + 1. $$The main project file is
square_1e2_volumetricsourceterm.prj. It describes the
processes to be solved and the related process variables together with their
initial and boundary conditions. It also references the bulk mesh and the
boundary meshes associated with the bulk mesh.
ogs square_1e2_volumetricsourceterm.prjOGS writes the computed results (pressure, Darcy velocity) into the output file
square_1e2_volumetricsourceterm_pcs_0_ts_1_t_1.000000.vtu, which can be
directly visualized and analysed in ParaView for example.
The output on the console will be similar to:
info: ConstantParameter: K
info: ConstantParameter: p0
info: ConstantParameter: p_Dirichlet_left
info: ConstantParameter: p_Dirichlet_right
info: ConstantParameter: volumetric_source_term_parameter
info: Initialize processes.
info: Solve processes.
info: [time] Output of timestep 0 took 0.000145912 s.
info: [time] Assembly took 0.000147104 s.
info: [time] Applying Dirichlet BCs took 1.81198e-05 s.
info: iteration: 11/10000
info: residual: 3.965614e-17
info: [time] Linear solver took 7.79629e-05 s.
info: [time] Iteration #1 took 0.000268221 s.
info: [time] Solving process #0 took 0.000288963 s in time step #1
info: [time] Time step #1 took 0.000308037 s.
info: [time] Output of timestep 1 took 0.000105858 s.
info: [time] Execution took 0.00692892 s.
info: OGS terminated on 2018-10-12 06:30:13+020The numerical solution shown in the following picture is almost a linear
gradient:
The difference between the computed solution and the analytical solution is in
the range of machine precision and therefore almost negligible:
This article was written by Tom Fischer. If you are missing something or you find an error please let us know.
Generated with Hugo 0.150.1
in CI job 743172
