The following example consists of a simple mechanics problem.
import os…
(click to toggle)
from datetime import datetime
import ogstools as otout_dir = Path(os.environ.get("OGS_TESTRUNNER_OUT_DIR", "_out"))
out_dir.mkdir(parents=True, exist_ok=True)prj_name = "SimpleMechanics"…
(click to toggle)
model = ot.Project(output_file=(out_dir / f"{prj_name}.prj"))
model.geometry.add_geometry(filename="./square_1x1.gml")
model.mesh.add_mesh(filename="./square_1x1_quad_1e2.vtu")
model.processes.set_process(
name="SD",
type="SMALL_DEFORMATION",
integration_order="2",
specific_body_force="0 0",
model.processes.set_constitutive_relation(
model.processes.add_process_variable(
model.processes.add_secondary_variable(internal_name="sigma", output_name="sigma")
model.time_loop.add_process(
process="SD",
convergence_type="DeltaX",
norm_type="NORM2",
abstol="1e-15",
model.time_loop.set_stepping(
process="SD",
type="FixedTimeStepping",
t_initial="0",
t_end="1",
repeat="4",
delta_t="0.25",
model.time_loop.add_output(
type="VTK",
prefix=prj_name,
repeat="1",
each_steps="4",
model.media.add_property(
medium_id="0", phase_type="Solid", name="density", type="Constant", value="1"
model.parameters.add_parameter(name="E", type="Constant", value="1")
model.parameters.add_parameter(name="nu", type="Constant", value="0.3")
model.parameters.add_parameter(name="displacement0", type="Constant", values="0 0")
model.parameters.add_parameter(name="dirichlet0", type="Constant", value="0")
model.parameters.add_parameter(name="dirichlet1", type="Constant", value="0.05")
model.process_variables.set_ic(
components="2",
order="1",
model.process_variables.add_bc(
geometry="left",
type="Dirichlet",
component="0",
parameter="dirichlet0",
geometry="bottom",
type="Dirichlet",
component="1",
geometry="top",
type="Dirichlet",
component="1",
parameter="dirichlet1",
model.nonlinear_solvers.add_non_lin_solver(
type="Newton",
max_iter="4",
model.linear_solvers.add_lin_solver(
name="general_linear_solver",
kind="lis",
solver_type="cg",
precon_type="jacobi",
max_iteration_step="10000",
error_tolerance="1e-16",
kind="eigen",
solver_type="CG",
precon_type="DIAGONAL",
kind="petsc",
prefix="sd",
solver_type="cg",
precon_type="bjacobi",
try:
model.run_model(
logfile=(out_dir / f"{prj_name}-out.txt"), args=f"-o {out_dir} -m ."
except Exception as inst:
print(f"{type(inst)}: {inst.args[0]}")
print(datetime.now())Project file written to output.
Simulation: /var/lib/gitlab-runner/builds/Sbm-BZZt4/1/ogs/build/release-all/Tests/Data/Mechanics/Linear/SimpleMechanics/SimpleMechanics.prj
Execution took 0.12003159523010254 s
2026-01-30 13:05:03.512972
ms = ot.MeshSeries(f"{out_dir}/{prj_name}.pvd").scale(time=("s", "a"))…
(click to toggle)
points_labels = ["pt0", "pt1"]fig, ax = plt.subplots(nrows=1, ncols=1)…
(click to toggle)
colors = {"x": ["b", "r"], "y": ["g", "m"]}
linestyles = {"linear": "-", "nearest": "--"}
for component in ["x", "y"]:
for interp_method in ["linear", "nearest"]:
labels = [f"$u_{component}$ {label} {interp_method}" for label in points_labels]
ms_pts = ot.MeshSeries.extract_probe(
ms, points_coords, interp_method=interp_method
ot.plot.line(
ms_pts,
"time",
ot.variables.displacement[component],
labels=labels,
ax=fig.axes[0],
colors=colors[component],
linestyle=linestyles[interp_method],
This article was written by Lars Bilke, Jörg Buchwald. If you are missing something or you find an error please let us know.
in CI job 683680
Last revision: September 10, 2021
