import os…
(click to toggle)
import gmsh
from mesh import MeshGeneratorout_dir = Path(os.environ.get("OGS_TESTRUNNER_OUT_DIR", "_out"))…
(click to toggle)
if not out_dir.exists():
out_dir.mkdir(parents=True)
mesh_dir = Path(out_dir, "Mesh")if not gmsh.isInitialized():…
(click to toggle)
gmsh.initialize()
gmsh.model.add("Mesh")
gmsh.finalize()Info : Meshing 1D...
Info : [ 0%] Meshing curve 1 (Circle)
Info : [ 20%] Meshing curve 2 (Circle)
Info : [ 30%] Meshing curve 3 (Line)
Info : [ 40%] Meshing curve 4 (Line)
Info : [ 50%] Meshing curve 5 (Line)
Info : [ 60%] Meshing curve 6 (Line)
Info : [ 70%] Meshing curve 7 (Line)
Info : [ 80%] Meshing curve 8 (Line)
Info : [ 90%] Meshing curve 9 (Line)
Info : [100%] Meshing curve 10 (Line)
Info : Done meshing 1D (Wall 0.00430984s, CPU 0.0038s)
Info : Meshing 2D...
Info : [ 0%] Meshing surface 1 (Transfinite)
Info : [ 40%] Meshing surface 2 (Plane, Delaunay)
Info : [ 70%] Meshing surface 3 (Plane, Delaunay)
Info : Done meshing 2D (Wall 0.014699s, CPU 0.006753s)
Info : 1469 nodes 2051 elements
Info : Writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.msh'...
Info : Done writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.msh'
domain: 1674 cells
physical_group_arc: 19 cells
physical_group_left: 64 cells
physical_group_bottom: 64 cells
physical_group_top: 14 cells
physical_group_right: 14 cells
OGS_BIN_PATH: None .
OGS wheel: ModuleSpec(name='ogs', loader=<_frozen_importlib_external.SourceFileLoader object at 0x7fbf35023bf0>, origin='/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/site-packages/ogs/__init__.py', submodule_search_locations=['/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/site-packages/ogs']) .
OGS in PATH: ['/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/bin/ogs', '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/bin/ogs'] .
Warning: Too many occurrences of 'ogs' found in PATH.
Please remove OGS from PATH.
[0] info: Reordering nodes...
[0] info: Corrected 1674 elements.
[0] info: VTU file written.
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom.vtu
OGS wheel: ModuleSpec(name='ogs', loader=<_frozen_importlib_external.SourceFileLoader object at 0x7fbf34bd7410>, origin='/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/site-packages/ogs/__init__.py', submodule_search_locations=['/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/site-packages/ogs']) .
[0] info: Create a quadratic order mesh
[0] info: Save the new mesh into a file
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.vtu
[0] info: Mesh reading time: 0.0156729 s
[0] info: MeshNodeSearcher construction time: 0.000181407 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 0.000341442 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000828569 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.22e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000167746 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.017e-05 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000152346 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.085e-05 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000150635 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.86e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000158265 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.9e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000157466 s
[0] info: identifySubdomains time: 0.00203429 s
[0] info: writing time: 0.0286002 s
[0] info: Entire run time: -8.9885e+06 s
bulk_mesh = Path(mesh_dir, "domain.vtu")…
(click to toggle)
num_parts = 3
ot.cli().partmesh("-s", "-i", bulk_mesh, "-o", mesh_dir)
ot.cli().partmesh(
"-m",
"-n",
str(num_parts),
"-i",
bulk_mesh,
"-o",
mesh_dir,
Path(mesh_dir, "left.vtu"),
Path(mesh_dir, "right.vtu"),
Path(mesh_dir, "top.vtu"),
Path(mesh_dir, "bottom.vtu"),
Path(mesh_dir, "arc.vtu"),
)OGS_BIN_PATH: None .
[0] info: Mesh 'domain' read: 4455 nodes, 1674 elements.
[0] info: Property global_node_ids is added to mesh domain
[0] info: Property global_element_ids is added to mesh domain
[0] info: Write the mesh into METIS input file.
[0] info: Total runtime: 0.0166829 s.
[0] info: Total CPU time: 0.004673 s.
[0] info: METIS is running ...
[0] info: Path to mpmetis is:
[0] info: Running: mpmetis -gtype=nodal "/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.mesh" 3
METIS 5.2.1 Copyright 1998-22, Regents of the University of Minnesota
(HEAD: unknown, Built on: Oct 22 2025, 11:09:00)
size of idx_t: 64bits, real_t: 32bits, idx_t *: 64bits
Mesh Information ------------------------------------------------------------
Name: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.mesh, #Elements: 1674, #Nodes: 4455, #Parts: 3
Options ---------------------------------------------------------------------
ptype=kway, objtype=cut, ctype=shem, rtype=greedy, iptype=metisrb
dbglvl=0, ufactor=1.030, minconn=NO, contig=NO, nooutput=NO
seed=-1, niter=10, ncuts=1
gtype=nodal, ncommon=1, niter=10, ncuts=1
Direct k-way Partitioning ---------------------------------------------------
- Edgecut: 479.
Timing Information ----------------------------------------------------------
I/O: 0.001 sec
Partitioning: 0.003 sec (METIS time)
Reporting: 0.000 sec
Memory Information ----------------------------------------------------------
Max memory used: 1.725 MB
rusage.ru_maxrss: 111.492 MB
proc/self/stat/VmPeak: 26.582 MB
[0] info: Partitioning the mesh in the node wise way ...
[0] info: partitionMesh(): Partition IDs per element computed in 5.2722e-05 s
[0] info: partitionMesh(): distribute nodes to partitions took 2.451e-05 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 0.000126834 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 0.000122134 s
[0] info: partitionMesh(): distribute elements into partitions took 4.0822e-05 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.3521e-05 s
[0] info: partitionMesh(): markDuplicateGhostCells took 8.3e-07 s
[0] info: Partitioning other meshes according to the main mesh partitions.
[0] info: Mesh 'left' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left.vtu' read: 129 nodes, 64 elements.
[0] info: Property global_node_ids is added to mesh left
[0] info: Property global_element_ids is added to mesh left
[0] info: partitionMesh(): Partition IDs per element computed in 1.7e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.23e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 2.54e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.31e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 2.11e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 1.3e-06 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2e-07 s
[0] info: Mesh 'right' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right.vtu' read: 29 nodes, 14 elements.
[0] info: Property global_node_ids is added to mesh right
[0] info: Property global_element_ids is added to mesh right
[0] info: partitionMesh(): Partition IDs per element computed in 3.7e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 3.7e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 8.21e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 3.6e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 5.7e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.4e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.3e-07 s
[0] info: Mesh 'top' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top.vtu' read: 29 nodes, 14 elements.
[0] info: Property global_node_ids is added to mesh top
[0] info: Property global_element_ids is added to mesh top
[0] info: partitionMesh(): Partition IDs per element computed in 4.4e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 5.4e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 8.8e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 1.07e-06 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.2e-07 s
[0] info: Mesh 'bottom' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom.vtu' read: 129 nodes, 64 elements.
[0] info: Property global_node_ids is added to mesh bottom
[0] info: Property global_element_ids is added to mesh bottom
[0] info: partitionMesh(): Partition IDs per element computed in 1.92e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.3e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 2.441e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.3e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 2e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 1.32e-06 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.1e-07 s
[0] info: Mesh 'arc' from file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc.vtu' read: 39 nodes, 19 elements.
[0] info: Property global_node_ids is added to mesh arc
[0] info: Property global_element_ids is added to mesh arc
[0] info: partitionMesh(): Partition IDs per element computed in 4.2e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 4.6e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 9.5e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 4.7e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 7.8e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.3e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.11e-07 s
[0] info: Writing the partitions data into binary files took 0.00701491 s
[0] info: Total runtime: 0.0995529 s.
[0] info: Total CPU time: 0.010729 s.
0
output_prefix = "kirsch_mpi"…
(click to toggle)
temporary_project = Path(out_dir, f"{output_prefix}.prj")
prj = ot.Project(
input_file="kirsch.prj",
output_file=temporary_project,
prj.replace_text(
output_prefix,
prj.write_input()
run(
f"mpirun -np {num_parts} ogs {temporary_project} -m {mesh_dir} -o {out_dir}",
shell=True,
check=True,
)[0] [32minfo:[m OGS started on 2026-01-30 13:05:38+0100 with MPI. MPI processes: 3.
[0] [32minfo:[m This is OpenGeoSys-6 version 6.5.7. Log version: 2, Log level: info.
[0] [32minfo:[m Reading project file ../../../../../build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.prj.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain_partitioned_integration_point_properties_cfg3.bin'.
You can ignore this warning if the mesh does not contain integration_point-wise property data.
[0] [32minfo:[m [time] Reading the mesh took 0.083262 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.026981 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.031300 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.081521 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.045807 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.144089 s.
[0] [32minfo:[m readRasters ...
[0] [32minfo:[m readRasters done
[0] [32minfo:[m ConstantParameter: E
[0] [32minfo:[m ConstantParameter: nu
[0] [32minfo:[m ConstantParameter: zero
[0] [32minfo:[m ConstantParameter: initial_displacement
[0] [32minfo:[m FunctionParameter: sigma0
[0] [32minfo:[m ConstantParameter: sigma_top
[0] [32minfo:[m FunctionParameter: decay_function
[0] [32minfo:[m Configure mesh 'left' for boundary condition or source term.
[0] [32minfo:[m Configure mesh 'bottom' for boundary condition or source term.
[0] [32minfo:[m Configure mesh 'top' for boundary condition or source term.
[0] [32minfo:[m Configure mesh 'arc' for boundary condition or source term.
[0] [32minfo:[m No source terms for process variable 'displacement' found.
[0] [32minfo:[m Threads used for ParallelVectorMatrixAssembler: 1.
[0] [32minfo:[m SmallDeformation process initializeSubmeshOutput().
[0] [32minfo:[m Initialize processes.
[0] [32minfo:[m Checking correct model evaluation order in the constitutive setting.
[0] [32minfo:[m Model evaluation order is correct.
[0] [32minfo:[m Time step #0 started. Time: 0. Step size: 0.
[0] [32minfo:[m [time] Output of timestep 0 took 0.0666599 s.
[0] [32minfo:[m Calculate non-equilibrium initial residuum.
[0] [32minfo:[m Number of threads: 1
[0] [32minfo:[m Time step #0 took 0.220028 s.
[0] [32minfo:[m Solve processes.
[0] [32minfo:[m Time step #1 started. Time: 10000. Step size: 10000.
[0] [32minfo:[m Solving process #0 started.
[0] [32minfo:[m Iteration #1 started.
[0] [32minfo:[m [time] Assembly took 0.0185406 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000197268 s.
Linear solver bcgs with bjacobi preconditioner using PRECONDITIONED
converged in 425 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.64074 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.1980e-02, |x|=2.1980e-02, |dx|/|x|=1.0000e+00
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.3739e-02, |x|=5.3739e-02, |dx|/|x|=1.0000e+00
[0] [32minfo:[m [time] Iteration #1 took 1.68676 s.
[0] [32minfo:[m Iteration #2 started.
[0] [32minfo:[m [time] Assembly took 0.0563419 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000144116 s.
converged in 34 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.118237 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=4.2084e-16, |x|=2.1980e-02, |dx|/|x|=1.9146e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.7411e-16, |x|=5.3739e-02, |dx|/|x|=1.0683e-14
[0] [32minfo:[m [time] Iteration #2 took 0.191048 s.
[0] [32minfo:[m [time] Solving process #0 took 1.87796 s in time step #1
[0] [32minfo:[m [time] Time step #1 took 1.8926 s.
[0] [32minfo:[m [time] Output of timestep 1 took 0.0139504 s.
[0] [32minfo:[m Time step #2 started. Time: 25000. Step size: 15000.
[0] [32minfo:[m [time] Assembly took 0.0398374 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0293432 s.
converged in 438 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.57295 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.2971e-02, |x|=5.4951e-02, |dx|/|x|=6.0000e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=8.0608e-02, |x|=1.3435e-01, |dx|/|x|=6.0000e-01
[0] [32minfo:[m [time] Iteration #1 took 1.64343 s.
[0] [32minfo:[m [time] Assembly took 0.0563498 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00437468 s.
converged in 65 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.244558 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.6129e-15, |x|=5.4951e-02, |dx|/|x|=2.9352e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.9886e-15, |x|=1.3435e-01, |dx|/|x|=1.4802e-14
[0] [32minfo:[m [time] Iteration #2 took 0.30828 s.
[0] [32minfo:[m [time] Solving process #0 took 1.95187 s in time step #2
[0] [32minfo:[m [time] Time step #2 took 1.96803 s.
[0] [32minfo:[m [time] Output of timestep 2 took 0.0662407 s.
[0] [32minfo:[m Time step #3 started. Time: 42280. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0380026 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0145692 s.
converged in 419 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.51632 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=9.2933e-02, |dx|/|x|=4.0870e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=2.2721e-01, |dx|/|x|=4.0870e-01
[0] [32minfo:[m [time] Iteration #1 took 1.61864 s.
[0] [32minfo:[m [time] Assembly took 0.0380163 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000138495 s.
converged in 60 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.432651 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=7.6723e-16, |x|=9.2933e-02, |dx|/|x|=8.2557e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.7361e-15, |x|=2.2721e-01, |dx|/|x|=1.2043e-14
[0] [32minfo:[m [time] Iteration #2 took 0.48818 s.
[0] [32minfo:[m [time] Solving process #0 took 2.10691 s in time step #3
[0] [32minfo:[m [time] Time step #3 took 2.12344 s.
[0] [32minfo:[m [time] Output of timestep 3 took 0.0615784 s.
[0] [32minfo:[m Time step #4 started. Time: 59560. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0198766 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00497959 s.
converged in 427 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.00301 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=1.3091e-01, |dx|/|x|=2.9013e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=3.2007e-01, |dx|/|x|=2.9013e-01
[0] [32minfo:[m [time] Iteration #1 took 1.0678 s.
[0] [32minfo:[m [time] Assembly took 0.079842 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.028048 s.
converged in 185 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.782063 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.0561e-13, |x|=1.3091e-01, |dx|/|x|=8.0671e-13
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.6249e-13, |x|=3.2007e-01, |dx|/|x|=8.2010e-13
[0] [32minfo:[m [time] Iteration #2 took 0.955419 s.
[0] [32minfo:[m [time] Solving process #0 took 2.02339 s in time step #4
[0] [32minfo:[m [time] Time step #4 took 2.04601 s.
[0] [32minfo:[m [time] Output of timestep 4 took 0.0282347 s.
[0] [32minfo:[m Time step #5 started. Time: 76840. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0569804 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00915596 s.
[0] [32minfo:[m [time] Linear solver took 1.05319 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=1.6890e-01, |dx|/|x|=2.2488e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=4.1293e-01, |dx|/|x|=2.2488e-01
[0] [32minfo:[m [time] Iteration #1 took 1.13692 s.
[0] [32minfo:[m [time] Assembly took 0.0361315 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000142276 s.
converged in 29 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.056479 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.8912e-16, |x|=1.6890e-01, |dx|/|x|=1.7118e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.0513e-16, |x|=4.1293e-01, |dx|/|x|=1.2233e-15
[0] [32minfo:[m [time] Iteration #2 took 0.101194 s.
[0] [32minfo:[m [time] Solving process #0 took 1.24516 s in time step #5
[0] [32minfo:[m [time] Time step #5 took 1.25873 s.
[0] [32minfo:[m [time] Output of timestep 5 took 0.0273742 s.
[0] [32minfo:[m Time step #6 started. Time: 94120. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.028208 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00028625 s.
converged in 429 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.796223 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.0688e-01, |dx|/|x|=1.8360e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=5.0579e-01, |dx|/|x|=1.8360e-01
[0] [32minfo:[m [time] Iteration #1 took 0.825306 s.
[0] [32minfo:[m [time] Assembly took 0.0298162 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000138176 s.
converged in 55 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0543208 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=7.7939e-16, |x|=2.0688e-01, |dx|/|x|=3.7674e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.2927e-15, |x|=5.0579e-01, |dx|/|x|=2.5558e-15
[0] [32minfo:[m [time] Iteration #2 took 0.0847879 s.
[0] [32minfo:[m [time] Solving process #0 took 0.910315 s in time step #6
[0] [32minfo:[m [time] Time step #6 took 0.926535 s.
[0] [32minfo:[m [time] Output of timestep 6 took 0.0451144 s.
[0] [32minfo:[m Time step #7 started. Time: 111400. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0241751 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000240339 s.
[0] [32minfo:[m [time] Linear solver took 0.717032 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.4486e-01, |dx|/|x|=1.5512e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=5.9865e-01, |dx|/|x|=1.5512e-01
[0] [32minfo:[m [time] Iteration #1 took 0.748115 s.
[0] [32minfo:[m [time] Assembly took 0.0340123 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000135056 s.
converged in 159 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.302316 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.2877e-14, |x|=2.4486e-01, |dx|/|x|=5.2589e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.0611e-14, |x|=5.9865e-01, |dx|/|x|=1.0125e-13
[0] [32minfo:[m [time] Iteration #2 took 0.350873 s.
[0] [32minfo:[m [time] Solving process #0 took 1.09908 s in time step #7
[0] [32minfo:[m [time] Time step #7 took 1.11003 s.
[0] [32minfo:[m [time] Output of timestep 7 took 0.0302995 s.
[0] [32minfo:[m Time step #8 started. Time: 128680. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0198872 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00509335 s.
converged in 422 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.998647 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.8284e-01, |dx|/|x|=1.3429e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=6.9151e-01, |dx|/|x|=1.3429e-01
[0] [32minfo:[m [time] Iteration #1 took 1.03278 s.
[0] [32minfo:[m [time] Assembly took 0.0471605 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00412441 s.
converged in 92 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.179102 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.7960e-15, |x|=2.8284e-01, |dx|/|x|=6.3497e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=7.5759e-15, |x|=6.9151e-01, |dx|/|x|=1.0956e-14
[0] [32minfo:[m [time] Iteration #2 took 0.243247 s.
[0] [32minfo:[m [time] Solving process #0 took 1.28285 s in time step #8
[0] [32minfo:[m [time] Time step #8 took 1.29698 s.
[0] [32minfo:[m [time] Output of timestep 8 took 0.0315967 s.
[0] [32minfo:[m Time step #9 started. Time: 145960. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0177102 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00169894 s.
[0] [32minfo:[m [time] Linear solver took 0.558834 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=3.2083e-01, |dx|/|x|=1.1839e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=7.8437e-01, |dx|/|x|=1.1839e-01
[0] [32minfo:[m [time] Iteration #1 took 0.585295 s.
[0] [32minfo:[m [time] Assembly took 0.0191271 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00499611 s.
converged in 137 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.191848 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.6810e-15, |x|=3.2083e-01, |dx|/|x|=1.1473e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.5678e-14, |x|=7.8437e-01, |dx|/|x|=1.9987e-14
[0] [32minfo:[m [time] Iteration #2 took 0.224067 s.
[0] [32minfo:[m [time] Solving process #0 took 0.809575 s in time step #9
[0] [32minfo:[m [time] Time step #9 took 0.821078 s.
[0] [32minfo:[m [time] Output of timestep 9 took 0.0231775 s.
[0] [32minfo:[m Time step #10 started. Time: 163240. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0140544 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000249908 s.
converged in 432 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.547479 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=3.5881e-01, |dx|/|x|=1.0586e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=8.7723e-01, |dx|/|x|=1.0586e-01
[0] [32minfo:[m [time] Iteration #1 took 0.569475 s.
[0] [32minfo:[m [time] Assembly took 0.0391833 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00878124 s.
converged in 104 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.228962 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.3737e-15, |x|=3.5881e-01, |dx|/|x|=6.6157e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.3148e-15, |x|=8.7723e-01, |dx|/|x|=7.1985e-15
[0] [32minfo:[m [time] Iteration #2 took 0.283477 s.
[0] [32minfo:[m [time] Solving process #0 took 0.853104 s in time step #10
[0] [32minfo:[m [time] Time step #10 took 0.866447 s.
[0] [32minfo:[m [time] Output of timestep 10 took 0.0363999 s.
[0] [32minfo:[m Time step #11 started. Time: 180520. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0177213 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000206428 s.
[0] [32minfo:[m [time] Linear solver took 0.676895 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.1013e-02, |x|=3.7982e-01, |dx|/|x|=5.5324e-02
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.1374e-02, |x|=9.2860e-01, |dx|/|x|=5.5324e-02
[0] [32minfo:[m [time] Iteration #1 took 0.710472 s.
[0] [32minfo:[m [time] Assembly took 0.0254555 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00611588 s.
converged in 35 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0609193 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.8796e-16, |x|=3.7982e-01, |dx|/|x|=1.0214e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.6881e-16, |x|=9.2860e-01, |dx|/|x|=7.2023e-16
[0] [32minfo:[m [time] Iteration #2 took 0.0982841 s.
[0] [32minfo:[m [time] Solving process #0 took 0.808869 s in time step #11
[0] [32minfo:[m [time] Time step #11 took 0.822751 s.
[0] [32minfo:[m [time] Output of timestep 11 took 0.0629574 s.
[0] [32minfo:[m Time step #12 started. Time: 197800. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0318775 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000464757 s.
converged in 30 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0833064 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.1815e-16, |x|=3.7982e-01, |dx|/|x|=5.7435e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.1842e-16, |x|=9.2860e-01, |dx|/|x|=6.6596e-16
[0] [32minfo:[m [time] Iteration #1 took 0.127921 s.
[0] [32minfo:[m [time] Solving process #0 took 0.127991 s in time step #12
[0] [32minfo:[m [time] Time step #12 took 0.134571 s.
[0] [32minfo:[m [time] Output of timestep 12 took 0.026339 s.
[0] [32minfo:[m Time step #13 started. Time: 215080. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0179705 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000241658 s.
converged in 21 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0337338 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.3399e-16, |x|=3.7982e-01, |dx|/|x|=3.5278e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.8019e-16, |x|=9.2860e-01, |dx|/|x|=3.0174e-16
[0] [32minfo:[m [time] Iteration #1 took 0.0540006 s.
[0] [32minfo:[m [time] Solving process #0 took 0.0541061 s in time step #13
[0] [32minfo:[m [time] Time step #13 took 0.0627633 s.
[0] [32minfo:[m [time] Output of timestep 13 took 0.0402188 s.
[0] [32minfo:[m Time step #14 started. Time: 232360. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0365463 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00108199 s.
converged in 22 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0159316 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.2602e-16, |x|=3.7982e-01, |dx|/|x|=3.3179e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.4609e-16, |x|=9.2860e-01, |dx|/|x|=3.7270e-16
[0] [32minfo:[m [time] Iteration #1 took 0.0600447 s.
[0] [32minfo:[m [time] Solving process #0 took 0.0601926 s in time step #14
[0] [32minfo:[m [time] Time step #14 took 0.0672369 s.
[0] [32minfo:[m [time] Output of timestep 14 took 0.0135062 s.
[0] [32minfo:[m Time step #15 started. Time: 249640. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0254292 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00299863 s.
converged in 50 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0296611 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.5080e-16, |x|=3.7982e-01, |dx|/|x|=9.2360e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=8.9550e-16, |x|=9.2860e-01, |dx|/|x|=9.6435e-16
[0] [32minfo:[m [time] Iteration #1 took 0.0690524 s.
[0] [32minfo:[m [time] Solving process #0 took 0.0774614 s in time step #15
[0] [32minfo:[m [time] Time step #15 took 0.0968567 s.
[0] [32minfo:[m [time] Output of timestep 15 took 0.0157071 s.
[0] [32minfo:[m Time step #16 started. Time: 266920. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.013926 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00318201 s.
[0] [32minfo:[m [time] Linear solver took 0.0220739 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.2207e-16, |x|=3.7982e-01, |dx|/|x|=5.8468e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.6323e-16, |x|=9.2860e-01, |dx|/|x|=7.1422e-16
[0] [32minfo:[m [time] Iteration #1 took 0.0418185 s.
[0] [32minfo:[m [time] Solving process #0 took 0.0419739 s in time step #16
[0] [32minfo:[m [time] Time step #16 took 0.0459662 s.
[0] [32minfo:[m [time] Output of timestep 16 took 0.0476875 s.
[0] [32minfo:[m Time step #17 started. Time: 284200. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0331257 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00402885 s.
converged in 43 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.465967 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.0276e-16, |x|=3.7982e-01, |dx|/|x|=5.3382e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=7.3963e-16, |x|=9.2860e-01, |dx|/|x|=7.9649e-16
[0] [32minfo:[m [time] Iteration #1 took 0.515417 s.
[0] [32minfo:[m [time] Solving process #0 took 0.515531 s in time step #17
[0] [32minfo:[m [time] Time step #17 took 0.531555 s.
[0] [32minfo:[m [time] Output of timestep 17 took 0.0285741 s.
[0] [32minfo:[m Time step #18 started. Time: 301480. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0181507 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000210147 s.
converged in 24 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0390656 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.1218e-16, |x|=3.7982e-01, |dx|/|x|=2.9534e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.2179e-16, |x|=9.2860e-01, |dx|/|x|=3.4654e-16
[0] [32minfo:[m [time] Iteration #1 took 0.0612076 s.
[0] [32minfo:[m [time] Solving process #0 took 0.0612914 s in time step #18
[0] [32minfo:[m [time] Time step #18 took 0.0674554 s.
[0] [32minfo:[m [time] Output of timestep 18 took 0.179568 s.
[0] [32minfo:[m Time step #19 started. Time: 318760. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0204658 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0146619 s.
[0] [32minfo:[m [time] Linear solver took 0.215773 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.3491e-16, |x|=3.7982e-01, |dx|/|x|=3.5521e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.6773e-16, |x|=9.2860e-01, |dx|/|x|=3.9600e-16
[0] [32minfo:[m [time] Iteration #1 took 0.267499 s.
[0] [32minfo:[m [time] Solving process #0 took 0.267581 s in time step #19
[0] [32minfo:[m [time] Time step #19 took 0.282592 s.
[0] [32minfo:[m [time] Output of timestep 19 took 0.0245547 s.
[0] [32minfo:[m Time step #20 started. Time: 336040. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0793027 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0047123 s.
[0] [32minfo:[m [time] Linear solver took 0.0323282 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.0527e-16, |x|=3.7982e-01, |dx|/|x|=2.7716e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.5103e-16, |x|=9.2860e-01, |dx|/|x|=2.7033e-16
[0] [32minfo:[m [time] Iteration #1 took 0.133234 s.
[0] [32minfo:[m [time] Solving process #0 took 0.133312 s in time step #20
[0] [32minfo:[m [time] Time step #20 took 0.143997 s.
[0] [32minfo:[m [time] Output of timestep 20 took 0.030237 s.
[0] [32minfo:[m Time step #21 started. Time: 345600. Step size: 9560.
[0] [32minfo:[m [time] Assembly took 0.029073 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000178067 s.
converged in 26 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.0535429 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.4709e-16, |x|=3.7982e-01, |dx|/|x|=3.8726e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.2369e-16, |x|=9.2860e-01, |dx|/|x|=3.4857e-16
[0] [32minfo:[m [time] Iteration #1 took 0.0833434 s.
[0] [32minfo:[m [time] Solving process #0 took 0.0838788 s in time step #21
[0] [32minfo:[m [time] Time step #21 took 0.101232 s.
[0] [32minfo:[m [time] Output of timestep 21 took 0.0581285 s.
[0] [32minfo:[m The whole computation of the time stepping took 21 steps, in which
the accepted steps are 21, and the rejected steps are 0.
[0] [32minfo:[m [time] Simulation completed. It took 18.3955 s.
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There are 2 unused database options. They are:
Option left: name:-m value: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh source: command line
Option left: name:-o value: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch source: command line
[0] [32minfo:[m OGS completed on 2026-01-30 13:05:57+0100.
CompletedProcess(args='mpirun -np 3 ogs /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.prj -m /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh -o /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch', returncode=0)
pvd = Path(out_dir, f"{output_prefix}.pvd")…
(click to toggle)
ms = ot.MeshSeries(pvd).scale(time=("s", "d"))
print(pvd)
mesh_last = ms[-1]
fig = mesh_last.plot_contourf(
figsize=(6, 4),
fontsize=8,
cmap="jet",
)/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.pvd
fig = mesh_last.plot_contourf(…
(click to toggle)
ot.variables.displacement["y"], figsize=(6, 4), fontsize=8, cmap="jet"
(click to toggle)
ot.variables.stress["xx"], figsize=(6, 4), fontsize=8, cmap="jet"
(click to toggle)
ot.variables.stress["yy"], figsize=(6, 4), fontsize=8, cmap="jet"
point_a = (6.5, -857.0, 0)…
(click to toggle)
point_b = (70.0, -857.0, 0)
profile = ms[-1].sample_over_line(point_a, point_b, resolution=30)
xs = profile["Distance"] + 6.5
plt.plot(
xs, profile["sigma"][:, 0] * 1e-6, color="C2", label="Release nodal force (MPI)"
a = 6.5
sigma_t = -20 # MPa
sigma_x_a = np.asarray(
[0.5 * (3.0 * a * a / (r * r) - 3 * a**4 / (r**4)) * sigma_t for r in xs],
plt.plot(xs, sigma_x_a, linestyle="dotted", color="C0", label="Analytical solution")
plt.xlabel("x / m")
plt.ylabel(r"stress $\sigma_{xx}$ / MPa")
plt.legend()
plt.grid()
In the above figure, the radial stress $\sigma_r$ profiles along the $\theta = 0^\circ$ axis, obtained using the release nodal force approach, and the analytical solution, are compared.
plt.plot(…
(click to toggle)
plt.plot(
xs, profile["sigma"][:, 1] * 1e-6, color="C2", label="Release nodal force (MPI)"
a = 6.5
sigma_t = -20 # MPa
sigma_y_a = np.asarray(
[0.5 * (2 + a * a / (r * r) + 3 * a**4 / (r**4)) * sigma_t for r in xs],
plt.plot(xs, sigma_y_a, linestyle="dotted", color="C0", label="Analytical solution")
plt.xlabel("x / m")
plt.ylabel(r"stress $\sigma_{yy}$ / MPa")
plt.legend()
plt.grid()
In the above two figures, the tangential stress $\sigma_{\theta}$ profiles along the $\theta = 0^\circ$ axis, obtained using the release nodal force approach, and the analytical solution, are compared.
expected_sigma = np.asarray(…
(click to toggle)
[-5.94322287e05, -6.19135039e07, -1.27523478e07, 2.88857972e04],
[-7.47350139e06, -3.61722449e07, -7.09372389e06, -4.31847097e03],
[-7.02632921e06, -2.82291119e07, -4.57663234e06, -3.04634647e03],
[-5.69811254e06, -2.49548130e07, -3.19587766e06, -2.33539317e03],
[-4.52129471e06, -2.33397674e07, -2.35831864e06, -1.87907695e03],
[-3.60618350e06, -2.24352157e07, -1.81241976e06, -1.49642711e03],
[-2.90810489e06, -2.18773279e07, -1.43562983e06, -1.21999451e03],
[-2.37358359e06, -2.15068967e07, -1.16414410e06, -1.00559463e03],
[-1.95790335e06, -2.12450510e07, -9.60886316e05, -8.50316451e02],
[-1.63102314e06, -2.10507797e07, -8.04540863e05, -7.21601922e02],
[-1.36956366e06, -2.08999790e07, -6.80862806e05, -6.21075254e02],
[-1.15718662e06, -2.07782330e07, -5.80625884e05, -5.47100152e02],
[-9.83183398e05, -2.06769008e07, -4.98025268e05, -4.73813630e02],
[-8.38590438e05, -2.05896257e07, -4.28464851e05, -2.91454098e02],
[-7.18847960e05, -2.05193954e07, -3.71473022e05, -5.83689809e02],
[-6.15597155e05, -2.04493120e07, -3.19472761e05, -2.60734404e02],
[-5.26222722e05, -2.03832868e07, -2.72852858e05, -1.22193725e02],
[-4.48460991e05, -2.03225868e07, -2.31314329e05, -1.40384160e02],
[-3.81052951e05, -2.02633176e07, -1.93311164e05, 8.27105976e00],
[-3.21267935e05, -2.02058999e07, -1.58150365e05, 1.25229397e02],
[-2.68380912e05, -2.01489856e07, -1.25209966e05, -2.03819778e02],
[-2.21121750e05, -2.00919675e07, -9.39267720e04, -5.98779759e02],
[-1.79147229e05, -2.00335377e07, -6.38054888e04, 6.67763887e02],
[-1.41291420e05, -1.99727511e07, -3.42127668e04, -2.09343375e02],
[-1.07444543e05, -1.99093000e07, -5.02336097e03, -6.12146069e02],
[-7.76109665e04, -1.98407209e07, 2.45004314e04, -3.90010177e02],
[-5.18790616e04, -1.97699451e07, 5.34527661e04, -3.13328250e02],
[-3.10211876e04, -1.96869485e07, 8.46090962e04, -3.15443054e01],
[-1.35909887e04, -1.96029252e07, 1.15045144e05, 3.61051256e02],
[-4.03024845e03, -1.94999513e07, 1.48805539e05, 7.61397500e02],
computed_sigma = np.asarray(profile["sigma"])
np.testing.assert_allclose(actual=computed_sigma, desired=expected_sigma, atol=1e-10)profile_1 = ms[1].sample_over_line(point_a, point_b, resolution=30)expected_sigma_at_time_step1 = np.array(…
(click to toggle)
[-4.32494293e05, -2.09358938e07, -4.10516429e05, -2.49911515e02],
[-4.06616274e05, -2.04762218e07, -2.64851408e05, -1.76293199e02],
[-3.29751883e05, -2.02867369e07, -1.84946624e05, -1.35150068e02],
[-2.61649000e05, -2.01932736e07, -1.36476773e05, -1.08742879e02],
[-2.08691175e05, -2.01409268e07, -1.04885403e05, -8.65987912e01],
[-1.68293107e05, -2.01086417e07, -8.30804300e04, -7.06015339e01],
[-1.37360161e05, -2.00872047e07, -6.73694502e04, -5.81941335e01],
[-1.13304592e05, -2.00720516e07, -5.56068470e04, -4.92081280e01],
[-9.43879134e04, -2.00608090e07, -4.65590777e04, -4.17593705e01],
[-7.92571563e04, -2.00520821e07, -3.94017827e04, -3.59418550e01],
[-6.69668185e04, -2.00450366e07, -3.36010349e04, -3.16608884e01],
[-5.68971874e04, -2.00391725e07, -2.88209067e04, -2.74197703e01],
[-4.85295392e04, -2.00341219e07, -2.47954196e04, -1.68665566e01],
[-4.15999977e04, -2.00300576e07, -2.14972814e04, -3.37783455e01],
[-3.56248353e04, -2.00260019e07, -1.84880070e04, -1.50887965e01],
[-3.04527038e04, -2.00221809e07, -1.57900959e04, -7.07139610e00],
[-2.59526036e04, -2.00186682e07, -1.33862459e04, -8.12408336e00],
[-2.20516754e04, -2.00152383e07, -1.11869887e04, 4.78649290e-01],
[-1.85918944e04, -2.00119155e07, -9.15222018e03, 7.24707160e00],
[-1.55313028e04, -2.00086219e07, -7.24594709e03, -1.17951260e01],
[-1.27963975e04, -2.00053222e07, -5.43557708e03, -3.46516064e01],
[-1.03673165e04, -2.00019408e07, -3.69244727e03, 3.86437434e01],
[-8.17658683e03, -1.99984231e07, -1.97990549e03, -1.21147786e01],
[-6.21785551e03, -1.99947512e07, -2.90703760e02, -3.54251197e01],
[-4.49137538e03, -1.99907825e07, 1.41784904e03, -2.25700334e01],
[-3.00226051e03, -1.99866866e07, 3.09333137e03, -1.81324219e01],
[-1.79520762e03, -1.99818836e07, 4.89635973e03, -1.82548063e00],
[-7.86515552e02, -1.99770211e07, 6.65770509e03, 2.08941699e01],
[-2.33231970e02, -1.99710620e07, 8.61143168e03, 4.40623553e01],
computed_sigma_t1 = np.asarray(profile_1["sigma"])
actual=computed_sigma_t1, desired=expected_sigma_at_time_step1, atol=1e-10
)This article was written by Wenqing Wang. If you are missing something or you find an error please let us know.
in CI job 683680
Last revision: August 27, 2025
