A 2D GREAT cell benchmark suite simulated using hydro-mechanical variational phase-field process
import shutil
import sys
import matplotlib as mpl
import meshio
from matplotlib import colormaps
mechanics_path = Path(
    "..", "..", "LIE", "Mechanics", "GreatCelljupyterNotebook"
).resolve()
sys.path.insert(0, str(mechanics_path))
# Local modules
from mesh_generator import (  # noqa: E402
    mesh_GreatCell_Borehole_VPF,
from ogs_model_runner import SingleOGSModel  # noqa: E402
from Plotter import Plotter  # noqa: E402
def truncated_cmap(name, minval=0.3, maxval=0.9, n=6):(click to toggle)
    base = colormaps.get_cmap(name)
    return lambda i: base(minval + (maxval - minval) * i / (n - 1))
mpl.rcdefaults()
mpl.rcParams.update(
        "text.usetex": False,
        "font.family": "serif",
        "axes.labelsize": 26,
        "axes.titlesize": 24,
        "legend.fontsize": 18,
        "xtick.labelsize": 18,
        "ytick.labelsize": 18,
ot.plot.setup.show_region_bounds = False(click to toggle)
if not out_dir.exists():
    out_dir.mkdir(parents=True)
Great cell
$\texttt{HM}_{3d}$: Fracture Nucleation from Borehole under Poly-Axial Stress
The $\texttt{HM}_{3d}$ benchmark simulates fracture nucleation directly from a borehole in an intact rock sample subjected to poly-axial stress conditions.
Fluid is injected at a rate of:
$$ Q_0 = 2 \times 10^{-7} \times 2\pi r \quad \text{m}^2/\text{s}, \quad \text{with } r = 0.005\,\text{m}. $$
This test provides insight into fluid-driven fracture processes under realistic in situ conditions and is especially useful for validating coupled hydro-mechanical models.
For full details, visit the GREAT Cell benchmark page: www.opengeosys.org/docs/benchmarks/small-deformations/greatcellm/
To run this benchmark, you need to have OGS built with PETSc and PIP support. The following steps outline the process:
  1. Configure & build OGS with PETSc & PIP
    cmake -S ogs-source -B build-folder --preset release-petsc \
      -DOGS_USE_PETSC=ON \
      -DOGS_USE_PIP=ON
  2. Run the benchmark
    cd build-folder/release-petsc
    ctest -R nb-HMPhaseField/GreatCell
  3. Verify output files
    ls build-folder/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCell
Material Properties
The material properties are provided in the following dictionary. The computational model incorporates two distinct elastic materials within its domain: a central circle ($r=0.097$ m) of rock surrounded by a rubber sheath in a 2D configuration.
materials = {(click to toggle)
materials = {
    "Gneiss": {
        "young_sample": 83.9e9,  # Young's modulus (Pa)
        "nu_sample": 0.21,  # Poisson's ratio
        "biot": 0.6,  # Biot coefficient
        "porosity": 0.001,  # Porosity
        "permeability": 1e-19,  # Permeability (m²)
        "density_solid": 2750,  # Solid density (kg/m³)
        "k_n": 200e9,  # Normal stiffness (Pa/m)
        "k_t": 100e9,  # Tangential stiffness (Pa/m)
        "c_f": 4.4e-10,  # Fluid compressibility (Pa⁻¹)
        "k_s": 4.82e10,  # Solid bulk modulus (Pa)
        "S_f": 4.4e-10,  # Specific storage (Pa⁻¹)
        "t_np": 10e6,  # Peak normal traction (Pa)
        "Gc": 59.375,  # Fracture toughness (J/m²)
        "w_init": 1e-6,  # initial fracture width (m)
        "fluid": {
            "density": 1000.0,  # Fluid density (kg/m³)
            "viscosity": 1e-3,  # Fluid viscosity (Pa·s)
            "injectionFlowRate_Inlet": 3.75e-7,  # Injection flow rate (m³/s)
            "p_outlet": 3.45e6,  # Outlet pressure (Pa)
        "rubber_sheath": {
            "young_modulus": 83.9e9,  # Young's modulus (Pa)
            "poisson_ratio": 0.21,  # Poisson's ratio
            "density": 2750,  # Density (kg/m³)
    # "Greywacke": {
    #     "young_sample": 26.87e9,  # Young's modulus (Pa)
    #     "nu_sample": 0.27,  # Poisson's ratio
    #     "biot": 0.8,  # Biot coefficient
    #     "porosity": 0.005,  # Porosity
    #     "permeability": 2.58e-19,  # Permeability (m²)
    #     "density_solid": 2650,  # Solid density (kg/m³)
    #     "k_n": 100e9,  # Normal stiffness (Pa/m)
    #     "k_t": 50e9,  # Tangential stiffness (Pa/m)
    #     "c_f": 4.4e-10,  # Fluid compressibility (Pa⁻¹)
    #     "k_s": 1.95e10,  # Solid bulk modulus (Pa)
    #     "S_f": 4.4e-10,  # Specific storage (Pa⁻¹)
    #     "t_np": 10e6,  # Peak normal traction (Pa)
    #     "Gc": 35.65,  # Fracture toughness (J/m²)
    #     "w_init": 1e-6,  # initial fracture width (m)
    #     "fluid": {
    #         "density": 1000.0,  # Fluid density (kg/m³)
    #         "viscosity": 1.0e-3,  # Fluid viscosity (Pa·s)
    #         "injectionFlowRate_Inlet": 3.75e-7,  # 1.75e-7,  # Injection flow rate (m³/s)
    #         "p_outlet": 3.45e6,  # Outlet pressure (Pa)
    #     "rubber_sheath": {
    #         "young_modulus": 26.87e9,  # Young's modulus (Pa)
    #         "poisson_ratio": 0.27,  # Poisson's ratio
    #         "density": 2650,  # Density (kg/m³)
material_names = list(materials.keys())
To run the benchmark with Greywacke, uncomment the “Greywacke” section in the materials dictionary above, also it suggested to use finer mesh size h=0.001 for Greywacke.
Loads
Table: Load Conditions
A 10.0 6.64 4.46 1.17 1.0 3.82 7.80 9.95
B 45.0° 7.80 9.95 10.0 6.64 4.46 1.17 1.0 3.82
C 90° 1.0 3.82 7.80 9.95 10.0 6.64 4.46 1.17
Schematic loading conditions
loads = {(click to toggle)
loads = {
    "A": [
        10.0e6,
        6.64e6,
        4.46e6,
        1.17e6,
        1.0e6,
        3.82e6,
        7.80e6,
        9.95e6,
        10.0e6,
        6.64e6,
        4.46e6,
        1.17e6,
        1.0e6,
        3.82e6,
        7.80e6,
        9.95e6,
    "B": [
        7.80e6,
        9.95e6,
        10.0e6,
        6.64e6,
        4.46e6,
        1.17e6,
        1.0e6,
        3.82e6,
        7.80e6,
        9.95e6,
        10.0e6,
        6.64e6,
        4.46e6,
        1.17e6,
        1.0e6,
        3.82e6,
    "C": [
        1.0e6,
        3.82e6,
        7.80e6,
        9.95e6,
        10.0e6,
        6.64e6,
        4.46e6,
        1.17e6,
        1.0e6,
        3.82e6,
        7.80e6,
        9.95e6,
        10.0e6,
        6.64e6,
        4.46e6,
        1.17e6,
angles_degrees = [(click to toggle)
angles_degrees = [
    0,
    -22.5,
    -45,
    -67.5,
    -90,
    -112.5,
    -135,
    -157.5,
    -180,
    -202.5,
    -225,
    -247.5,
    -270,
    -292.5,
    -315,
    -337.5,
circle_radius = 6
    ax = axs[idx]
    ax.set_aspect("equal")
    ax.axis("off")
    circle = plt.Circle(
        (0, 0),
        circle_radius,
        color="black",
        fill=False,
        linestyle="--",
        linewidth=2,
    ax.add_artist(circle)
        zip(circle_x, circle_y, scaled_values, strict=False)
        ax.annotate(
            xytext=line_end,
            xy=(x, y),
            arrowprops={
                "arrowstyle": "-|>",
                "color": "blue",
                "lw": 2,
                "mutation_scale": 15,
                "fill": True,
        ax.text(
            x - angle_offset[0],
            y - angle_offset[1],
            angle_label,
            fontsize=12,
            ha="center",
            va="center",
            color="m",
        ax.text(
            formatted_values[i],
            fontsize=18,
            ha="center",
            weight="bold",
    ax.plot(
        top_points_x,
        top_points_y,
        color="green",
        linestyle="-.",
        lw=2,
        marker="o",
        markersize=6,
        markerfacecolor="lightgreen",
        markeredgewidth=1.0,
        markeredgecolor="black",
    ax.set_xlim([-12, 12])
    ax.set_ylim([-12, 12])
    ax.text(
        0,
        0,
        f"Load {label}",
        fontsize=32,
        ha="center",
        va="center",
        family="serif",
plt.tight_layout()
Boundary Conditions
  • Dirichlet conditions (displacement control):
    \[ \begin{cases} u_y(x, 0) = 0, & \quad \text{for } x = \pm 0.09894~\text{m} \quad (\text{left and right points boundaries}), \\ u_x(0, y) = 0, & \quad \text{for } y = \pm 0.09894~\text{m} \quad (\text{top and bottom points boundaries}), \\ u_x = u_y = 0, & \quad \text{on } x^2 + y^2 = r_{\text{borehole}}^2 \end{cases} \]
  • Neumann conditions: Normal stress $\sigma_{rr}$ is applied on PEEs and DSSs. The DSS stress is calculated as:
    $$\sigma_\text{DSS}^i = \frac{\sigma_\text{PEE}^i + \sigma_\text{PEE}^{i+1}}{2}$$
Mesh generation of intact samples
Input
h = 0.001(click to toggle)
h = 0.001
borehole_radius = 0.0025
delta = 0.00025
meshname = "GreatCell"
mesh_path = Path(out_dir, "mesh_borehole").resolve()
print(mesh_path)
/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole
Boundary meshes
Gmsh
msh_file = mesh_GreatCell_Borehole_VPF((click to toggle)
    lc=0.0075,
    h=h,
    lc1=h,
    r0=0.097,
    r1=0.090,
    r2=0.065,
    borehole_radius=borehole_radius,
    delta=delta,
    out_dir=mesh_path,
    meshname=meshname,
    mode="BC",
    post_process=True,
    cmap="viridis",
    opacity=0.8,
Info    : Meshing 1D...
Info    : [ 10%] Meshing curve 2 (Circle)
Info    : [ 10%] Meshing curve 3 (Circle)
Info    : [ 10%] Meshing curve 4 (Circle)
Info    : [ 10%] Meshing curve 69 (Circle)
Info    : [ 10%] Meshing curve 70 (Circle)
Info    : [ 10%] Meshing curve 71 (Circle)
Info    : [ 10%] Meshing curve 72 (Circle)
Info    : [ 10%] Meshing curve 73 (Circle)
Info    : [ 20%] Meshing curve 74 (Circle)
Info    : [ 20%] Meshing curve 75 (Circle)
Info    : [ 20%] Meshing curve 76 (Circle)
Info    : [ 20%] Meshing curve 101 (Line)
Info    : [ 20%] Meshing curve 102 (Line)
Info    : [ 20%] Meshing curve 103 (Line)
Info    : [ 20%] Meshing curve 104 (Line)
Info    : [ 20%] Meshing curve 105 (Line)
Info    : [ 30%] Meshing curve 106 (Line)
Info    : [ 30%] Meshing curve 107 (Line)
Info    : [ 30%] Meshing curve 108 (Line)
Info    : [ 30%] Meshing curve 109 (Line)
Info    : [ 30%] Meshing curve 110 (Line)
Info    : [ 30%] Meshing curve 111 (Line)
Info    : [ 30%] Meshing curve 112 (Line)
Info    : [ 30%] Meshing curve 113 (Line)
Info    : [ 30%] Meshing curve 114 (Line)
Info    : [ 40%] Meshing curve 115 (Line)
Info    : [ 40%] Meshing curve 116 (Line)
Info    : [ 40%] Meshing curve 117 (Line)
Info    : [ 40%] Meshing curve 118 (Line)
Info    : [ 40%] Meshing curve 119 (Line)
Info    : [ 40%] Meshing curve 120 (Line)
Info    : [ 40%] Meshing curve 121 (Line)
Info    : [ 40%] Meshing curve 122 (Line)
Info    : [ 50%] Meshing curve 123 (Line)
Info    : [ 50%] Meshing curve 124 (Line)
Info    : [ 50%] Meshing curve 125 (Line)
Info    : [ 50%] Meshing curve 126 (Line)
Info    : [ 50%] Meshing curve 127 (Line)
Info    : [ 50%] Meshing curve 128 (Line)
Info    : [ 50%] Meshing curve 129 (Line)
Info    : [ 50%] Meshing curve 130 (Line)
Info    : [ 60%] Meshing curve 131 (Line)
Info    : [ 60%] Meshing curve 132 (Line)
Info    : [ 60%] Meshing curve 133 (Line)
Info    : [ 60%] Meshing curve 134 (Line)
Info    : [ 60%] Meshing curve 135 (Line)
Info    : [ 60%] Meshing curve 136 (Line)
Info    : [ 60%] Meshing curve 137 (Line)
Info    : [ 60%] Meshing curve 138 (Line)
Info    : [ 60%] Meshing curve 139 (Line)
Info    : [ 70%] Meshing curve 140 (Line)
Info    : [ 70%] Meshing curve 141 (Line)
Info    : [ 70%] Meshing curve 142 (Line)
Info    : [ 70%] Meshing curve 143 (Line)
Info    : [ 70%] Meshing curve 144 (Line)
Info    : [ 70%] Meshing curve 145 (Line)
Info    : [ 70%] Meshing curve 146 (Line)
Info    : [ 70%] Meshing curve 147 (Line)
Info    : [ 80%] Meshing curve 148 (Line)
Info    : [ 80%] Meshing curve 149 (Line)
Info    : [ 80%] Meshing curve 150 (Line)
Info    : [ 80%] Meshing curve 151 (Line)
Info    : [ 80%] Meshing curve 152 (Line)
Info    : [ 80%] Meshing curve 153 (Line)
Info    : [ 80%] Meshing curve 154 (Line)
Info    : [ 80%] Meshing curve 155 (Line)
Info    : [ 80%] Meshing curve 156 (Line)
Info    : [ 90%] Meshing curve 157 (Line)
Info    : [ 90%] Meshing curve 158 (Line)
Info    : [ 90%] Meshing curve 159 (Line)
Info    : [ 90%] Meshing curve 160 (Line)
Info    : [ 90%] Meshing curve 161 (Line)
Info    : [ 90%] Meshing curve 162 (Line)
Info    : [ 90%] Meshing curve 163 (Line)
Info    : [ 90%] Meshing curve 164 (Line)
Info    : [100%] Meshing curve 690 (Circle)
Info    : [100%] Meshing curve 700 (Circle)
Info    : [100%] Meshing curve 710 (Circle)
Info    : [100%] Meshing curve 720 (Circle)
Info    : [100%] Meshing curve 6900 (Circle)
Info    : [100%] Meshing curve 7000 (Circle)
Info    : [100%] Meshing curve 7100 (Circle)
Info    : [100%] Meshing curve 7200 (Circle)
Info    : Done meshing 1D (Wall 0.00494994s, CPU 0.005322s)
Info    : Meshing 2D...
Info    : [  0%] Meshing surface 1 (Plane, Delaunay)
Info    : [ 30%] Meshing surface 2 (Plane, Delaunay)
Info    : [ 50%] Meshing surface 3 (Plane, Delaunay)
Info    : [ 70%] Meshing surface 4 (Plane, Delaunay)
Info    : [ 90%] Meshing surface 5 (Plane, Delaunay)
Info    : Done meshing 2D (Wall 1.84183s, CPU 1.82906s)
Info    : 21558 nodes 43791 elements
Info    : Done meshing 2D (Wall 1.89933s, CPU 1.89328s)
Info    : Done meshing 2D (Wall 1.87643s, CPU 1.86882s)
Info    : Writing '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/GreatCell.msh'...
Info    : Done writing '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/GreatCell.msh'
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/domain.vtu (112 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_right.vtu (1 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_top.vtu (1 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_left.vtu (1 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_bottom.vtu (1 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE1.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE2.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE3.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE4.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE5.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE6.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE7.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE8.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE1a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE2a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE3a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE4a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE5a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE6a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE7a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE8a.vtu (4 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS1.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS2.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS3.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS4.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS5.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS6.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS7.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS8.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS1a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS2a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS3a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS4a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS5a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS6a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS7a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS8a.vtu (2 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_borehole_boundary.vtu (16 cells)
2025-10-28 16:20:31.217 (   7.834s) [    7F2EEF1D6BC0]vtkXOpenGLRenderWindow.:1416  WARN| bad X server connection. DISPLAY=
Computational domain mesh
Gmsh
    lc=0.0075,
    h=h,
    lc1=h,
    r0=0.097,
    r1=0.090,
    r2=0.065,
    delta=delta,
    out_dir=mesh_path,
    meshname=meshname,
    mode="domain",
    post_process=True,
    cmap="viridis",
    opacity=0.8,
Info    : Done meshing 1D (Wall 0.00437648s, CPU 0.005526s)
Info    : Done meshing 2D (Wall 1.85873s, CPU 1.84413s)
Info    : Done meshing 2D (Wall 1.94592s, CPU 1.93739s)
Info    : Done meshing 2D (Wall 1.92474s, CPU 1.91634s)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/domain.vtu (43002 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_Weakzone_sample.vtu (36 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_Central_sample.vtu (42618 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_OuterPart_sample.vtu (3970 cells)
Saved: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_Rubber_sheath.vtu (180 cells)
mesh_dir = Path(mesh_path).resolve()(click to toggle)
run(
        "NodeReordering",
        "-i",
        str(mesh_dir.joinpath("domain.vtu")),
        "-o",
    cwd=mesh_dir,
    check=True,
physical_groups = [
    "physical_group_DSS1.vtu",
    "physical_group_DSS1a.vtu",
    "physical_group_DSS2.vtu",
    "physical_group_DSS2a.vtu",
    "physical_group_DSS3.vtu",
    "physical_group_DSS3a.vtu",
    "physical_group_DSS4.vtu",
    "physical_group_DSS4a.vtu",
    "physical_group_DSS5.vtu",
    "physical_group_DSS5a.vtu",
    "physical_group_DSS6.vtu",
    "physical_group_DSS6a.vtu",
    "physical_group_DSS7.vtu",
    "physical_group_DSS7a.vtu",
    "physical_group_DSS8.vtu",
    "physical_group_DSS8a.vtu",
    "physical_group_PEE1.vtu",
    "physical_group_PEE1a.vtu",
    "physical_group_PEE2.vtu",
    "physical_group_PEE2a.vtu",
    "physical_group_PEE3.vtu",
    "physical_group_PEE3a.vtu",
    "physical_group_PEE4.vtu",
    "physical_group_PEE4a.vtu",
    "physical_group_PEE5.vtu",
    "physical_group_PEE5a.vtu",
    "physical_group_PEE6.vtu",
    "physical_group_PEE6a.vtu",
    "physical_group_PEE7.vtu",
    "physical_group_PEE7a.vtu",
    "physical_group_PEE8.vtu",
    "physical_group_PEE8a.vtu",
    "physical_group_p_bottom.vtu",
    "physical_group_p_left.vtu",
    "physical_group_p_right.vtu",
    "physical_group_p_top.vtu",
    "physical_group_borehole_boundary.vtu",
group_paths = [str(mesh_dir.joinpath(name)) for name in physical_groups]
run(
        "identifySubdomains",
        "-f",
        "-m",
        *group_paths,
    cwd=mesh_dir,
    check=True,
[0] info: Reordering nodes...
[0] info: VTU file written.
[0] info: Mesh reading time: 0.0420444 s
[0] info: MeshNodeSearcher construction time: 0.000951056 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 9.013e-06 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS1' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00136109 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.21e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS1a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.0015524 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.02e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS2' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00359028 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.61e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS2a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00101306 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.81e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS3' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000980971 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 6.41e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS3a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000978258 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.6e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS4' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000976675 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.41e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS4a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000972639 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.31e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS5' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000978689 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.1e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS5a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000984447 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 9.62e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS6' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000985438 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.31e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS6a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000974152 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.01e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS7' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000988904 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.91e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS7a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000988152 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.11e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS8' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00098026 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_DSS8a' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000971397 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.81e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE1' and it is not equal to the newly computed values.
[0] info: Overwriting 'bulk_node_ids' property.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000983566 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.031e-06 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE1a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000985429 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.71e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE2' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000984818 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 8.21e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE2a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000981142 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.152e-06 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE3' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000982504 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 9.22e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE3a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000976995 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.61e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE4' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000984046 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 8.11e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE4a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.0010014 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE5' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000987531 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE5a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000983485 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 9.01e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE6' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000998487 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 6.91e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE6a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000979289 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 9.72e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE7' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00098663 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.061e-06 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE7a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000990636 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.232e-06 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE8' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000963275 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 7.51e-07 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_PEE8a' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000964547 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 3.91e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_p_bottom' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000968552 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_p_left' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000976114 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 3.6e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_p_right' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000986129 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 3.1e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_p_top' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000984326 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.304e-06 s
[0] warning: There is already a 'bulk_node_ids' property present in the subdomain mesh 'physical_group_borehole_boundary' and it is not equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000982664 s
[0] info: identifySubdomains time: 0.0402281 s
[0] info: writing time: 0.0575813 s
[0] info: Entire run time: -6.76317e+06 s
CompletedProcess(args=['identifySubdomains', '-f', '-m', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/domain.vtu', '--', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS1.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS1a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS2.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS2a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS3.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS3a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS4.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS4a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS5.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS5a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS6.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS6a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS7.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS7a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS8.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_DSS8a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE1.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE1a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE2.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE2a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE3.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE3a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE4.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE4a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE5.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE5a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE6.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE6a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE7.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE7a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE8.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_PEE8a.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_bottom.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_left.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_right.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_p_top.vtu', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole/physical_group_borehole_boundary.vtu'], returncode=0)
Since the mesh may differ slightly depending on the operating system (macOS or Linux), we use the following pre-existing mesh path for ctest.
mesh_path_pre_existing = Path("mesh_borehole_pre_existing").resolve()(click to toggle)
# Compare generated and pre-existing meshes
meshes = {
    "mesh_path": pv.read(mesh_path.joinpath("domain.vtu")),
    "mesh_path_pre_existing": pv.read(mesh_path_pre_existing.joinpath("domain.vtu")),
for name, m in meshes.items():
    print(name, "Nodes:", m.n_points, "Elements:", m.n_cells)
d_nodes = meshes["mesh_path_pre_existing"].n_points - meshes["mesh_path"].n_points
d_cells = meshes["mesh_path_pre_existing"].n_cells - meshes["mesh_path"].n_cells
print("Δ Nodes:", d_nodes, " Δ Elements:", d_cells)
mesh_path_pre_existing_copy = (
    Path(out_dir).joinpath("mesh_borehole_pre_existing").resolve()
if mesh_path_pre_existing_copy.exists():
    shutil.rmtree(mesh_path_pre_existing_copy)
shutil.copytree(mesh_path_pre_existing, mesh_path_pre_existing_copy)
mesh_path Nodes: 21557 Elements: 43002
mesh_path_pre_existing Nodes: 4201 Elements: 8298
Δ Nodes: -17356  Δ Elements: -34704
PosixPath('/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing')
Intact rock sample with fluid injection ($\texttt{HM}_1$)
This benchmark, which does not consider any fracture, is designed to verify the basic computational setting for hydro-mechanical simulations. In addition to the mechanical loads, a zero constant pore pressure is prescribed at the outer boundary. At the center of sample, fluid is injected at a rate of $Q_0^{\text{v}} = 2.085 \times 10^{-9}$ m$^3$/s
The hydro-mechanical simulations follows a two-stage process: a 3000s equilibrium phase under mechanical loading to stabilize initial conditions, followed by a 500s fluid injection phase to model fluid flow. This loading condition is applied to both Greywacke and Gneiss samples
Run the simulation
Inputs
# Times for load curves(click to toggle)
times = "0.0  500. 3500"
simulation_end_time = 3500.0
n_fracture_p_ncs = 3
model_type = "HM3d"
output_prefix = "HM3d_VPF"
# Load
PEE_load_values = {
prj_file = Path("HM3d_VPF.prj")
prj = ot.Project(input_file=prj_file, output_file=Path(out_dir, f"{output_prefix}.prj"))
Run OGS
# Create SingleOGSModel(click to toggle)
sing_ogs_model = SingleOGSModel(
    model=prj,
    out_dir=out_dir,
    mesh_path=mesh_path_pre_existing_copy,
    output_prefix=output_prefix,
    method="VPF",
    model_type=model_type,
    materials=materials,
    n_mpi=4,
# Run simulations
vtu_files_dict_HM = sing_ogs_model.run_simulations_with_fracture(
    times=times,
    base_project_file=prj_file,
    load_cases=PEE_load_values,
    out_dir=out_dir,
    method="VPF",
    fracture_model_type="VolumetricDeviatoric",
    mesh_size=h,
    delta=delta,
    borehole_r=borehole_radius,
    n_mpi=4,
mesh path: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing
[DEBUG] Current working directory: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/ogs/Tests/Data/HMPhaseField/GreatCell
[DEBUG] output project file: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF.prj
Modifying mesh for VPF method at /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing with crack type: full and h1: 0.001
[0] info: Mesh 'domain' read: 4201 nodes, 8298 elements.
[0] info: Property global_node_ids is added to mesh domain
[0] info: Property global_element_ids is added to mesh domain
[0] info: Write the mesh into METIS input file.
[0] info: Total runtime: 0.0122016 s.
[0] info: Total CPU time: 0.012152 s.
[0] info: METIS is running ...
[0] info: Path to mpmetis is:
[0] info: Running: mpmetis -gtype=nodal "/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/domain.mesh" 4
METIS 5.2.1 Copyright 1998-22, Regents of the University of Minnesota
 (HEAD: unknown, Built on: Sep 29 2025, 16:46:04)
 size of idx_t: 64bits, real_t: 32bits, idx_t *: 64bits
Mesh Information ------------------------------------------------------------
 Name: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/domain.mesh, #Elements: 8298, #Nodes: 4201, #Parts: 4
Options ---------------------------------------------------------------------
 ptype=kway, objtype=cut, ctype=shem, rtype=greedy, iptype=metisrb
 dbglvl=0, ufactor=1.030, minconn=NO, contig=NO, nooutput=NO
 seed=-1, niter=10, ncuts=1
 gtype=nodal, ncommon=1, niter=10, ncuts=1
Direct k-way Partitioning ---------------------------------------------------
 - Edgecut: 336.
Timing Information ----------------------------------------------------------
  I/O:          		   0.001 sec
  Partitioning: 		   0.003 sec   (METIS time)
  Reporting:    		   0.000 sec
Memory Information ----------------------------------------------------------
  Max memory used:		   1.218 MB
  rusage.ru_maxrss:		 114.859 MB
  proc/self/stat/VmPeak:	  26.117 MB
[0] info: Partitioning the mesh in the node wise way ...
[0] info: partitionMesh(): Partition IDs per element computed in 0.000314475 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.946e-05 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 0.000193032 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 6.5248e-05 s
[0] info: partitionMesh(): distribute elements into partitions took 0.000146011 s
[0] info: partitionMesh(): determine / append ghost nodes took 4.1243e-05 s
[0] info: partitionMesh(): markDuplicateGhostCells took 3.416e-06 s
[0] info: Partitioning other meshes according to the main mesh partitions.
[0] info: Mesh 'physical_group_DSS1' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS1.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS1
[0] info: Property global_element_ids is added to mesh physical_group_DSS1
[0] info: partitionMesh(): Partition IDs per element computed in 1.7e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.2e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.9e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.2e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.2e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 3e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.4e-07 s
[0] info: Mesh 'physical_group_DSS1a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS1a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS1a
[0] info: Property global_element_ids is added to mesh physical_group_DSS1a
[0] info: partitionMesh(): distribute nodes to partitions took 2.2e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.41e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.21e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.31e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 3.01e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.3e-07 s
[0] info: Mesh 'physical_group_DSS2' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS2.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS2
[0] info: Property global_element_ids is added to mesh physical_group_DSS2
[0] info: partitionMesh(): distribute nodes to partitions took 1.3e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.71e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 9e-08 s
[0] info: partitionMesh(): determine / append ghost nodes took 3.11e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.31e-07 s
[0] info: Mesh 'physical_group_DSS2a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS2a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS2a
[0] info: Property global_element_ids is added to mesh physical_group_DSS2a
[0] info: partitionMesh(): Partition IDs per element computed in 1.8e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 2.5e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.51e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.2e-07 s
[0] info: Mesh 'physical_group_DSS3' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS3.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS3
[0] info: Property global_element_ids is added to mesh physical_group_DSS3
[0] info: partitionMesh(): Partition IDs per element computed in 2.81e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.8e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.8e-07 s
[0] info: Mesh 'physical_group_DSS3a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS3a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS3a
[0] info: Property global_element_ids is added to mesh physical_group_DSS3a
[0] info: partitionMesh(): distribute nodes to partitions took 2.21e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.21e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.01e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.9e-07 s
[0] info: Mesh 'physical_group_DSS4' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS4.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS4
[0] info: Property global_element_ids is added to mesh physical_group_DSS4
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.11e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.1e-07 s
[0] info: Mesh 'physical_group_DSS4a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS4a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS4a
[0] info: Property global_element_ids is added to mesh physical_group_DSS4a
[0] info: partitionMesh(): Partition IDs per element computed in 1.41e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 2.1e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 5.91e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.3e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 7.11e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.31e-07 s
[0] info: Mesh 'physical_group_DSS5' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS5.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS5
[0] info: Property global_element_ids is added to mesh physical_group_DSS5
[0] info: partitionMesh(): Partition IDs per element computed in 2.7e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.31e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.61e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 6.51e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.4e-07 s
[0] info: Mesh 'physical_group_DSS5a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS5a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS5a
[0] info: Property global_element_ids is added to mesh physical_group_DSS5a
[0] info: partitionMesh(): Partition IDs per element computed in 2e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.21e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.81e-07 s
[0] info: Mesh 'physical_group_DSS6' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS6.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS6
[0] info: Property global_element_ids is added to mesh physical_group_DSS6
[0] info: partitionMesh(): Partition IDs per element computed in 1.91e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.4e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.71e-07 s
[0] info: Mesh 'physical_group_DSS6a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS6a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS6a
[0] info: Property global_element_ids is added to mesh physical_group_DSS6a
[0] info: partitionMesh(): distribute nodes to partitions took 2.3e-07 s
[0] info: Mesh 'physical_group_DSS7' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS7.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS7
[0] info: Property global_element_ids is added to mesh physical_group_DSS7
[0] info: partitionMesh(): Partition IDs per element computed in 2.01e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.6e-07 s
[0] info: Mesh 'physical_group_DSS7a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS7a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS7a
[0] info: Property global_element_ids is added to mesh physical_group_DSS7a
[0] info: partitionMesh(): distribute nodes to partitions took 2.41e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.5e-07 s
[0] info: Mesh 'physical_group_DSS8' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS8.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS8
[0] info: Property global_element_ids is added to mesh physical_group_DSS8
[0] info: partitionMesh(): distribute nodes to partitions took 1.61e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.91e-07 s
[0] info: Mesh 'physical_group_DSS8a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_DSS8a.vtu' read: 3 nodes, 2 elements.
[0] info: Property global_node_ids is added to mesh physical_group_DSS8a
[0] info: Property global_element_ids is added to mesh physical_group_DSS8a
[0] info: partitionMesh(): Partition IDs per element computed in 1.4e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 2e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 9.1e-08 s
[0] info: Mesh 'physical_group_PEE1' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE1.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE1
[0] info: Property global_element_ids is added to mesh physical_group_PEE1
[0] info: partitionMesh(): distribute nodes to partitions took 3.5e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.81e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 4.5e-07 s
[0] info: Mesh 'physical_group_PEE1a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE1a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE1a
[0] info: Property global_element_ids is added to mesh physical_group_PEE1a
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.1e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 3.2e-07 s
[0] info: Mesh 'physical_group_PEE2' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE2.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE2
[0] info: Property global_element_ids is added to mesh physical_group_PEE2
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 5.11e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.71e-07 s
[0] info: Mesh 'physical_group_PEE2a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE2a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE2a
[0] info: Property global_element_ids is added to mesh physical_group_PEE2a
[0] info: partitionMesh(): Partition IDs per element computed in 3.11e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.7e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.81e-07 s
[0] info: Mesh 'physical_group_PEE3' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE3.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE3
[0] info: Property global_element_ids is added to mesh physical_group_PEE3
[0] info: partitionMesh(): distribute nodes to partitions took 2.71e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 5.31e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 3.31e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 6.61e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.21e-07 s
[0] info: Mesh 'physical_group_PEE3a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE3a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE3a
[0] info: Property global_element_ids is added to mesh physical_group_PEE3a
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 4.91e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.8e-07 s
[0] info: Mesh 'physical_group_PEE4' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE4.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE4
[0] info: Property global_element_ids is added to mesh physical_group_PEE4
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 5.01e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.3e-07 s
[0] info: Mesh 'physical_group_PEE4a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE4a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE4a
[0] info: Property global_element_ids is added to mesh physical_group_PEE4a
[0] info: partitionMesh(): Partition IDs per element computed in 2.1e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 3e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 2.5e-07 s
[0] info: Mesh 'physical_group_PEE5' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE5.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE5
[0] info: Property global_element_ids is added to mesh physical_group_PEE5
[0] info: partitionMesh(): distribute nodes to partitions took 2.8e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.91e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 1.1e-07 s
[0] info: Mesh 'physical_group_PEE5a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE5a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE5a
[0] info: Property global_element_ids is added to mesh physical_group_PEE5a
[0] info: partitionMesh(): Partition IDs per element computed in 1.9e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 2.6e-07 s
[0] info: Mesh 'physical_group_PEE6' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE6.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE6
[0] info: Property global_element_ids is added to mesh physical_group_PEE6
[0] info: partitionMesh(): Partition IDs per element computed in 2.5e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 2.9e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 4.01e-07 s
[0] info: Mesh 'physical_group_PEE6a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE6a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE6a
[0] info: Property global_element_ids is added to mesh physical_group_PEE6a
[0] info: partitionMesh(): distribute nodes to partitions took 2.4e-07 s
[0] info: Mesh 'physical_group_PEE7' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE7.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE7
[0] info: Property global_element_ids is added to mesh physical_group_PEE7
[0] info: partitionMesh(): distribute nodes to partitions took 2.7e-07 s
[0] info: Mesh 'physical_group_PEE7a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE7a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE7a
[0] info: Property global_element_ids is added to mesh physical_group_PEE7a
[0] info: partitionMesh(): Partition IDs per element computed in 1.6e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 2.51e-07 s
[0] info: Mesh 'physical_group_PEE8' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE8.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE8
[0] info: Property global_element_ids is added to mesh physical_group_PEE8
[0] info: partitionMesh(): distribute nodes to partitions took 2.61e-07 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 5.71e-07 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.4e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 3.7e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 6.71e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.1e-07 s
[0] info: Mesh 'physical_group_PEE8a' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_PEE8a.vtu' read: 5 nodes, 4 elements.
[0] info: Property global_node_ids is added to mesh physical_group_PEE8a
[0] info: Property global_element_ids is added to mesh physical_group_PEE8a
[0] info: partitionMesh(): distribute nodes to partitions took 2.81e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 3.3e-07 s
[0] info: partitionMesh(): determine / append ghost nodes took 7.31e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.2e-07 s
[0] info: Mesh 'physical_group_p_bottom' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_p_bottom.vtu' read: 1 nodes, 1 elements.
[0] info: Property global_node_ids is added to mesh physical_group_p_bottom
[0] info: Property global_element_ids is added to mesh physical_group_p_bottom
[0] info: partitionMesh(): Partition IDs per element computed in 1.71e-07 s
[0] info: partitionMesh(): distribute nodes to partitions took 6.1e-08 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 6e-08 s
[0] info: partitionMesh(): distribute elements into partitions took 1.41e-07 s
[0] info: Mesh 'physical_group_p_left' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_p_left.vtu' read: 1 nodes, 1 elements.
[0] info: Property global_node_ids is added to mesh physical_group_p_left
[0] info: Property global_element_ids is added to mesh physical_group_p_left
[0] info: partitionMesh(): distribute nodes to partitions took 6e-08 s
[0] info: partitionMesh(): distribute elements into partitions took 1.3e-07 s
[0] info: Mesh 'physical_group_p_right' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_p_right.vtu' read: 1 nodes, 1 elements.
[0] info: Property global_node_ids is added to mesh physical_group_p_right
[0] info: Property global_element_ids is added to mesh physical_group_p_right
[0] info: partitionMesh(): distribute nodes to partitions took 7.1e-08 s
[0] info: Mesh 'physical_group_p_top' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_p_top.vtu' read: 1 nodes, 1 elements.
[0] info: Property global_node_ids is added to mesh physical_group_p_top
[0] info: Property global_element_ids is added to mesh physical_group_p_top
[0] info: partitionMesh(): Partition IDs per element computed in 1.2e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 1.4e-07 s
[0] info: Mesh 'physical_group_borehole_boundary' from file '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/mesh_borehole_pre_existing/physical_group_borehole_boundary.vtu' read: 8 nodes, 8 elements.
[0] info: Property global_node_ids is added to mesh physical_group_borehole_boundary
[0] info: Property global_element_ids is added to mesh physical_group_borehole_boundary
[0] info: partitionMesh(): Partition IDs per element computed in 3.3e-07 s
[0] info: partitionMesh(): distribute elements into partitions took 4.2e-07 s
[0] info: Writing the partitions data into binary files took 0.00165494 s
[0] info: Total runtime: 0.108744 s.
[0] info: Total CPU time: 0.052924 s.
[DEBUG] output project file: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF_A.prj
Running simulation for load case: A with method: VPF, tension_cutoff: False
DEBUG: Setting ls to 0.002 based on mesh size 0.001
ls 0.002
Material properties for 'Gneiss' (VPF) applied successfully.
Simulation: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF_A.prj
Execution took 183.12219762802124 s
[DEBUG] output project file: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF_B.prj
Running simulation for load case: B with method: VPF, tension_cutoff: False
ls 0.002
Simulation: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF_B.prj
Execution took 153.2369155883789 s
[DEBUG] output project file: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF_C.prj
Running simulation for load case: C with method: VPF, tension_cutoff: False
ls 0.002
Simulation: /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-petsc/Tests/Data/HMPhaseField/GreatCell/GreatCellHM_VPF_propagating/HM3d_VPF_C.prj
Execution took 162.01914834976196 s
Post-processing
Profiles
(click to toggle)
custom_cb = {
    "u": {"vmin": 0, "vmax": 1e-2, "cmap": "Greens"},
    "stress": {"vmin": -20, "vmax": 10, "cmap": "coolwarm"},
    "strain": {"vmin": -0.025, "vmax": 0.05, "cmap": "RdBu_r"},
    "pressure": {"vmin": 0.1, "vmax": 8, "cmap": "jet"},
plotter = Plotter(
    output_dir=out_dir,
    colorbar_opts=custom_cb,
    save_extracted_data=True,
plotter.plot_field_variables(vtu_files_dict_HM)
Load: A, File 0, Benchmark: HM3d, Material: Gneiss
[0] info: Reading meshes took 0.010602342999999959 s
[0] info: Collection of 8298 regular elements and computing element map took 0.00016681200000001617 s
[0] info: Collection of 4542 nodes and computing offsets took 3.7950000000286366e-06 s
[0] info: Make nodes unique (4201 unique nodes) / computing map took 0.0013660640000001667 s
[0] info: Reset nodes in regular elements took 0.007716775000000009 s
[0] info: creation of merged mesh took 0.0007576240000000123 s
[0] info: merge properties into merged mesh took 0.0004756180000000665 s
[0] info: writing mesh took 0.014362041999999908 s
Load: B, File 0, Benchmark: HM3d, Material: Gneiss
[0] info: Reading meshes took 0.010530685000000206 s
[0] info: Collection of 8298 regular elements and computing element map took 0.00016765399999996156 s
[0] info: Collection of 4542 nodes and computing offsets took 3.385000000077909e-06 s
[0] info: Make nodes unique (4201 unique nodes) / computing map took 0.0013742160000000947 s
[0] info: Reset nodes in regular elements took 0.007738847999999798 s
[0] info: creation of merged mesh took 0.0007867880000000937 s
[0] info: merge properties into merged mesh took 0.0005458039999999276 s
[0] info: writing mesh took 0.01824606800000006 s
Load: C, File 0, Benchmark: HM3d, Material: Gneiss
[0] info: Reading meshes took 0.010558056999999899 s
[0] info: Collection of 8298 regular elements and computing element map took 0.00015816800000001408 s
[0] info: Collection of 4542 nodes and computing offsets took 3.3950000000171343e-06 s
[0] info: Make nodes unique (4201 unique nodes) / computing map took 0.001376328999999954 s
[0] info: Reset nodes in regular elements took 0.007831978999999878 s
[0] info: creation of merged mesh took 0.0007692419999998368 s
[0] info: merge properties into merged mesh took 0.0004706500000000169 s
[0] info: writing mesh took 0.01501194299999975 s
Pressure over time at observation points
(click to toggle)
obs_points = {"pt0": np.array([[0.0, 0.0025, 0.0]])}
plotter.plot_observation_points_vs_time(
    vtu_files_dict_HM,
    obs_points,
    var=ot.variables.pressure,
    methods_to_include=["VPF"],
    time_min=2900,
    time_max=3500,
ref_base = "HM3d_VPF_A_Gneiss_ts_78_t_3500_000000"(click to toggle)
expected_dir = Path("expected")
out_dir = Path(out_dir)
series_prefix = ref_base.split("_ts_")[0]
pvd_path = out_dir.joinpath(f"{series_prefix}.pvd")
def last_pvtu_from_series(pvd: Path, prefix: str) -> Path:
    ds = ET.parse(pvd).getroot().findall(".//DataSet")
    ds = [
        d
        for d in ds
        if d.attrib.get("file", "").startswith(prefix)
        and d.attrib["file"].endswith(".pvtu")
    ds.sort(key=lambda d: float(d.attrib.get("timestep", "0")))
    if not ds:
        msg = f"No matching DataSet for '{prefix}' in {pvd}"
        raise RuntimeError(msg)
    return (pvd.parent.joinpath(ds[-1].attrib["file"])).resolve()
ref_pvtu = expected_dir.joinpath(f"{ref_base}.pvtu")
ref_vtu = expected_dir.joinpath(f"{ref_base}.vtu")
run(["pvtu2vtu", "-i", str(ref_pvtu), "-o", str(ref_vtu)], check=True)
last_pvtu = last_pvtu_from_series(pvd_path, series_prefix)
last_vtu = last_pvtu.with_suffix(".vtu")
run(["pvtu2vtu", "-i", str(last_pvtu), "-o", str(last_vtu)], check=True)
# ---------------- VTU comparer ----------------
def read_mesh(path):
    m = meshio.read(str(path))
    pts = m.points.astype(float)
    if pts.shape[1] == 2:
        pts = np.c_[pts, np.zeros(len(pts))]
    return pts, m.point_data
def sort_index_by_points(pts):
    return np.lexsort((pts[:, 2], pts[:, 1], pts[:, 0]))
def reorder_point_data(pd, idx):
    out = {}
    for k, v in pd.items():
        arr = np.asarray(v)
        if arr.ndim == 1:
            arr = arr[:, None]
        out[k] = arr[idx]
    return out
def safe_max_rel_diff(a, b):
    denom = np.maximum(np.abs(b), 1e-12)
    return float(np.max(np.abs((a - b) / denom)))
def compare_arrays(a, b, rtol=1e-6, atol=1e-8, equal_nan=False):
    a = np.asarray(a)
    b = np.asarray(b)
    if a.ndim == 1:
        a = a[:, None]
    if b.ndim == 1:
        b = b[:, None]
    if a.shape != b.shape:
        return {"status": "SHAPE MISMATCH", "a_shape": a.shape, "b_shape": b.shape}
    try:
        np.testing.assert_allclose(a, b, rtol=rtol, atol=atol, equal_nan=equal_nan)
        return {"status": "MATCH"}
    except AssertionError:
        return {
            "status": "MISMATCH",
            "max_abs_diff": float(np.max(np.abs(a - b))),
            "max_rel_diff": safe_max_rel_diff(a, b),
            "count_not_close": int(
                np.sum(~np.isclose(a, b, rtol=rtol, atol=atol, equal_nan=equal_nan))
            "a_min": float(np.nanmin(a)),
            "a_max": float(np.nanmax(a)),
            "b_min": float(np.nanmin(b)),
            "b_max": float(np.nanmax(b)),
def compare_vtu_files(
    fileA, fileB, array_names=None, rtol=1e-6, atol=1e-8, equal_nan=False
    ptsA, pdA = read_mesh(fileA)
    ptsB, pdB = read_mesh(fileB)
    if len(ptsA) != len(ptsB):
        return {
            "fatal": "Different point counts",
            "A_points": len(ptsA),
            "B_points": len(ptsB),
    idxA = sort_index_by_points(ptsA)
    idxB = sort_index_by_points(ptsB)
    ptsA_sorted = ptsA[idxA]
    ptsB_sorted = ptsB[idxB]
    # looser atol for float noise in coordinates
    if not np.allclose(ptsA_sorted, ptsB_sorted, rtol=0.0, atol=1e-9):
        return {"fatal": "Point coordinate mismatch even after sorting"}
    pdA_sorted = reorder_point_data(pdA, idxA)
    pdB_sorted = reorder_point_data(pdB, idxB)
    if array_names is None:
        names = sorted(set(pdA_sorted.keys()) & set(pdB_sorted.keys()))
        names = [n for n in array_names if n in pdA_sorted and n in pdB_sorted]
    out = {"point_data": {}, "compared_arrays": names}
    for name in names:
        out["point_data"][name] = compare_arrays(
            pdA_sorted[name], pdB_sorted[name], rtol, atol, equal_nan
    return out
res = compare_vtu_files(
    ref_vtu,
    last_vtu,
    array_names=["displacement"],
    rtol=1e-4,
    atol=1e-4,
    equal_nan=True,
for name, result in res["point_data"].items():
    assert result["status"] == "MATCH", f"Field '{name}' mismatch: {result}"
[0] info: Reading meshes took 0.010113846000000093 s
[0] info: Collection of 8298 regular elements and computing element map took 0.00015918999999997574 s
[0] info: Collection of 4546 nodes and computing offsets took 3.2349999998793066e-06 s
[0] info: Make nodes unique (4201 unique nodes) / computing map took 0.0013783319999998156 s
[0] info: Reset nodes in regular elements took 0.0077849579999997864 s
[0] info: creation of merged mesh took 0.0007893720000000659 s
[0] info: merge properties into merged mesh took 0.00041582799999995146 s
[0] info: writing mesh took 0.017334341000000197 s
[0] info: Reading meshes took 0.010520229999999797 s
[0] info: Collection of 8298 regular elements and computing element map took 0.00016328600000004023 s
[0] info: Collection of 4542 nodes and computing offsets took 3.2850000000195223e-06 s
[0] info: Make nodes unique (4201 unique nodes) / computing map took 0.0013785920000000118 s
[0] info: Reset nodes in regular elements took 0.007715884000000006 s
[0] info: creation of merged mesh took 0.0007712150000001028 s
[0] info: merge properties into merged mesh took 0.0005397649999998588 s
[0] info: writing mesh took 0.0194294359999998 s
This article was written by Mostafa Mollaali. If you are missing something or you find an error please let us know.
Generated with Hugo 0.147.9 in CI job 638941 | Last revision: April 3, 2025
