Complete workflow for simulating a geological model with time and space dependent boundary conditions (advancing glacier)
In this three-part tutorial we look at the mechanical deformation of a sedimentary basin under an advancing glacier. In detail we show you a possibility how to
- create a mesh with Gmsh ,
- implement space- and time-dependent boundary conditions,
- write an OGS input file,
- visualize the results with ParaView .
As a common programming language we use Python .
Part 1: Preprocessing
Part 2: Solving
Part 3: Postprocessing
Supplementary material
- mesh_basin.msh
- mesh_basin.py
- OGSinput_basin.prj
- timeBCs_glacier.py
- glacierclass.py
- history.sh
- msh2vtu -now integrated in ogstools
- Transient hydrodynamics within intercratonic sedimentary basins during glacial cycles, V. F. Bense M. A. Person, DOI: 10.1029/2007JF000969
NOTE: Due to ongoing development, msh2vtu.py was integrated in the ogs-repository for ogstools . In order to work with the tutorial and apply msh2vtu on mesh_basin.msh, ogstools need to be installed at first.
ogstools can be installed from PyPI using pip. It is recommended to set up a virtual environment beforehand:
python -m venv .venv
source .venv/bin/activate
pip install ogstools[ogs]More detailed information about the usages and development of ogstools can be found in ogstools Documentation . After installation the tool can be applied as described in the first video-tutorial. To apply msh2vtu on the mesh_basin.msh the command should look like:
msh2vtu --reindex mesh_basin.msh -o .This article was written by Dominik Kern. If you are missing something or you find an error please reach out
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
