Saturated Varible-Densitty Flow and Mass Transport(Elder)
Overview
The elder benchmark is based on a experiment in a Hele-Shaw cells conducted by John W. Elder in 1965. Although unlike the original experiment the flow is caused by a difference in density then a difference in temperature, but by scaling the parameters a similar Rayleigh number can be achieved and therefore similar results observed. Due to being used to test early modeling software it has become a basic test case for such problem. Over the years studies about this benchmark where conducted, for example by if and when the results converge with the grid density and numerical stability.
Unfortunately the is at the moment no analytical solution for the Elder benchmark. The simulation works by assuming a dense fluid in a mixable single phase environment. On with a hight-concentration fluid is placed on top (in our case on the top right) witch is dissolved and by the power of gravity and diffusion is able to penetrate in to the domain and builds concentration fingers.
Setup
For the simulation the following variables where chosen:
variable value unit
length (L) 300 $m$
height (d) 150 $m$
extent of intrusion (e) 150 $m$
pore diffusion ($D_d$) $3.57\cdot 10^{-6}$ $m^2/s$
retardation factor 1 -
viscosity ($\mu$) $10^{-3}$ $kg/m\cdot s$
permeability 4.8404 $\cdot 10^{-13}$ $m^2$
longitudinal diversity ($\beta_L$) 0 $m$
transversal diversity ($\beta_T$) 0 $m$
gravitational acceleration(g) 9,81 $m/s^{2}$
expansion coefficient($\alpha$) 0.2 -
porosity ($\epsilon$) 0.1 -
density ($\rho$) 1000 $kg/m^{3}$
Running the simulation
The simulation of the Elder experiment takes too long to be executed as part of the webpage benchmark. Instead, in the next section pre-computed reference results will be loaded. To actually run the simulation, you can use following code:
# import ogstools as ogs(click to toggle)
# path_to_prj = '../elder/elder.prj'
# model = ot.Project(input_file = path_to_prj, output_file=path_to_prj)
# model.run_model(write_logs=True)
Post processing
Defining the variables of interest
import matplotlib.pyplot as plt(click to toggle)
ot.plot.setup.dpi = 30  # resolution
ot.plot.setup.fontsize = 30
Read data
First, we are going to load the dataset produces by the simulation:
mesh_series = ot.MeshSeries("../elder/elder_reference.pvd")
Next, the data at the 1st time step is read:
mesh_t0 = mesh_series.mesh(1).slice(normal="y")
and at the last one:
mesh_tend = mesh_series.mesh(-1).slice(normal="y")
Plotting results
The concentration and pressure at the beginning of the simulation are shown in the figures below.
fig_t0_si = ot.plot.contourf(mesh_t0, ot.variables.saturation, vmin=0)
fig_t0_p = ot.plot.contourf(mesh_t0, ot.variables.pressure)
The concentration and pressure at the end of the simulation are shown in the figures below.
fig_tend_si = ot.plot.contourf(mesh_tend, ot.variables.saturation, vmin=0)
fig_tend_p = ot.plot.contourf(mesh_tend, ot.variables.pressure)
Animate results
Down below the results are shown in an animated plot
ms_2D = mesh_series.transform(lambda mesh: mesh.slice("y", [0, 0, 0]))(click to toggle)
fig = ot.plot.contourf(ms_2D[0], ot.variables.saturation, vmin=0, vmax=100, dpi=50)
def plot_contourf(timevalue: float, mesh: pv.UnstructuredGrid) -> None:
    fig.axes[0].clear()
    ot.plot.contourf(mesh, ot.variables.saturation, ax=fig.axes[0], dpi=50)
anim = ot.plot.animate(fig, plot_contourf, ms_2D.timevalues, ms_2D)
HTML(anim.to_jshtml())
/tmp/ipykernel_433988/4259789432.py:1: PyVistaDeprecationWarning:
/tmp/ipykernel_433988/4259789432.py:1: Argument 'origin' must be passed as a keyword argument to function 'DataObjectFilters.slice'.
Literature
Diersch, H.-J.G., Kolditz, O., 1998. Coupled groundwater flow and transport: 2. Thermohaline and 3D convection systems. Adv. Water Resour. 21, 401–425. doi:10.1016/S0309-1708(97)00003-1.
Elder, J.W., 1965. Numerical experiments with free convection in a vertical slot. J. Fluid Mech. 24, 823. doi:10.1017/S0022112066001022.
Elder, J., Simmons, C., Diersch, H.-J., Frolkovič, P., Holzbecher, E., Johannsen, K., 2017. The Elder Problem. Fluids 2, 11. doi:10.3390/fluids2010011.
Graf, T., Degener, L., 2011. Grid convergence of variable-density flow simulations in discretely-fractured porous media. Adv. Water Resour. 34, 760–769. doi:10.1016/j.advwatres.2011.04.002.
Guo, W., Langevin, C.D., 2002. User`s Guide to SEAWAT: A computer program for simulation of three-dimensional variable-density ground-water flow, USGS Techniques of Water Resources Investigations. ISBN: 0607992573.
Johannsen, K., 2003. On the Validity of the Boussinesq Approximation for the Elder Problem. Comput. Geosci. 7, 169–182. doi:10.1023/A:1025515229807.
Musuuza, J.L., Attinger, S., Radu, F.A., 2009. An extended stability criterion for density-driven flows in homogeneous porous media. Adv. Water Resour. 32, 796–808. doi:10.1016/j.advwatres.2009.01.012.
H.-J.G. Diersch, O. Kolditz, 2002,Variable-density flow and transport in porous media: approaches and challenges,Advances in Water Resources.25, 899-944,do:10.1016/S0309-1708(02)00063-5.
Elder, John W., Craig T. Simmons, Hans-Jörg Diersch, Peter Frolkovič, Ekkehard Holzbecher, and Klaus Johannsen. 2017. “The Elder Problem” Fluids 2, no. 1: 11. https://doi.org/10.3390/fluids2010011
This article was written by Marc Walther, Lion Ahrendt. If you are missing something or you find an error please reach out to us on our forum.
Generated with Hugo 0.164.0 in CI job 825193 | Last revision: August 9, 2024
