Cook's membrane example
Cook’s membrane example for nearly incompressible solid under large deformation
The example has been analyzed in many references, for example with the F-bar method in [1] and [2]. This example is also used as benchmark for SmallDeformation. Hereby we analyze it again under finite strain assumption using the F-bar method for the total Lagrange formulation (see the attached PDF for its theory). For the finite strain assumption, the constitutive law is replaced with a hyperelasticity one, the Neo-Hookean. The Neo-Hookean model defines an energy function as the sum of volumetric component $U_{\text{dil}}(\F)$ and deviatoric component $U_{\text{dev}}(\F)$ as
where
with $K$ the bulk modulus, and $G$ the shear modulus. The values of $K$ and $G$ are taken from references [1] and [2], which are $40.0942\cdot 10^{4}$ MPa and $80.1938$ MPa, respectively. For OGS input, the corresponding Young’s modulus and Poisson ratio are 240.565 MPa, and 0.499, respectively.
def run_single_test(n: int, fbar: bool) -> ot.MeshSeries:… (click to toggle)
    if not fbar:
        model.replace_text("none", xpath="./processes/process/f_bar")
    prefix = f"cooks_membrane_n_{n}_bbar_{str(fbar).lower()}"
    if 20 <= n <= 25:
        model.replace_text("0.5", xpath=".//time_stepping/timesteps/pair/delta_t")
        model.replace_text("FRamp", xpath=".//boundary_condition[3]/parameter")
def get_top_uy(mesh: pv.UnstructuredGrid) -> np.ndarray:
def compare(mesh_a: pv.UnstructuredGrid, mesh_b: pv.UnstructuredGrid) -> plt.Figure:
    axs[0, 0].set_title("fbar = false")
    axs[0, 1].set_title("fbar = true")
    return fig
results_fbar_false = {n: run_single_test(n, fbar=False) for n in n_range}… (click to toggle)
uy_top_fbar_false = [get_top_uy(ms[-1]) for ms in results_fbar_false.values()]
uy_top_fbar_false_ref = np.array(
    [0.0022867221436878916, 0.0028406921658587160, 0.0033745807476269606,
     0.0038811997172937490, 0.0042429289476765735, 0.004702757454266369]
)  # fmt: skip
np.testing.assert_allclose(uy_top_fbar_false, uy_top_fbar_false_ref, atol=1e-10)
 ogs -o /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LargeDeformation/CooksMembrane/CooksMembraneFbar -m . /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LargeDeformation/CooksMembrane/CooksMembraneFbar/modified.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LargeDeformation/CooksMembrane/CooksMembraneFbar', '-m', '.', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LargeDeformation/CooksMembrane/CooksMembraneFbar/modified.prj']
results_fbar_true = {n: run_single_test(n, fbar=True) for n in n_range}… (click to toggle)
uy_top_fbar_true = [get_top_uy(ms[-1]) for ms in results_fbar_true.values()]
uy_top_fbar_true_ref = np.array(
    [0.0061413833572504320, 0.006746283955378773, 0.0068241828268382505,
     0.0068589364838052315, 0.006873125862208623, 0.006891409184641067]
)  # fmt: skip
np.testing.assert_allclose(uy_top_fbar_true, uy_top_fbar_true_ref, atol=2e-4)
Result
The following figure shows that the convergence of the solutions obtained by using the F bar method follows the one presented in the paper by T. Elguedj et al [1]. However, the results obtained without the F bar method are quit far from the converged solution with the finest mesh.
fig, ax = plt.subplots(figsize=(4, 3))… (click to toggle)
ax.plot(n_range, np.asarray(uy_top_fbar_true) * 1e3, "--o", label="B bar")
ax.plot(n_range, np.asarray(uy_top_fbar_false) * 1e3, "--x", label="non B bar")
ax.legend()
Comparison of results
The contour plots show that even with the coarsest mesh, the F bar method still gives reasonable stress result.
for n in n_range:
    compare(results_fbar_false[n][-1], results_fbar_true[n][-1])
Reference
  1. E.A. de Souza Neto, D. Perić, M. Dutko, D.R.J. Owen, Design of simple low order finite elements for large strain analysis of nearly incompressible solids, International Journal of Solids and Structures, Volume 33, Issues 20–22, 1996, Pages 3277-3296.
  2. T. Elguedj, Y. Bazilevs, V.M. Calo, T.J.R. Hughes (2008), $\bar\B$ and $\bar{\text F}$ projection methods for nearly incompressible linear and non-linear elasticity and plasticity using higher-order NURBS elements, Computer Methods in Applied Mechanics and Engineering, 197(33–40), 2732-2762.
This article was written by Wenqing Wang & Thomas Nagel. If you are missing something or you find an error please let us know.
Generated with Hugo 0.150.1 in CI job 743172 | Last revision: July 3, 2024
