TOOLS
Extract Boundary
General
The tool extracts either lines in case of a 2D bulk mesh as input or quads/triangles in case of a 3D bulk mesh as input. The input mesh can be given either in the VTU or MSH format. Since the algorithm uses the element surface normals a correct node ordering of the element nodes is required.
ExtractBoundary -i [<file name of input mesh>] [-o <file name of output mesh>]
New data arrays containing the original IDs for nodes, elements, and faces from the source mesh are added to the extracted surface mesh. These data arrays are required for specifying source terms or setting boundary conditions during a simulation run of OpenGeoSys.
Examples
Extract the boundary from a quad mesh
ExtractBoundary -i square_1x1_quad.vtu -o square_1x1_quad_border.vtu
The square mesh consists of 16 cells/elements.
The square mesh consists of 16 cells/elements. The numbers in the cells are the cell IDs. The generated boundary grid consists of the somewhat thicker and colored line elements.
Extract the boundary from a triangular mesh
ExtractBoundary -i square_1x1_tri.vtu -o square_1x1_tri_border.vtu
The square mesh consists of 32 triangle shaped cells.
The square mesh consists of 32 triangle shaped cells. The numbers in the triangle are the cell IDs. The generated boundary grid consists of the somewhat thicker and colored line elements.
