According to the references $[1,2]$, a modified deformation gradient, $\overline{\mathbf{F}}$, is introduced to compute stresses in order to alleviate the spurious locking exhibited by the standard bi-linear and tri-linear elements near the incompressible limit.
The deformation gradient $\mathbf{F}$ can be expressed as a composition of dilatational change and deviatoric change as
$$ \mathbf{F}=\mathbf{F}_{d} \mathbf{F}_{v} $$With $\left(\mathbf{F}_{0}\right)_{v}=\operatorname{det}\left[\mathbf{F}_{0}\right]^{1 / n} \mathbf{I}$ and $\mathbf{F}_{d}=\operatorname{det}[\mathbf{F}]^{-1 / n} \mathbf{F}_{d}, \overline{\mathbf{F}}$ is defined as the composition of the deviatoric component of $\mathbf{F}$ with the volumetric component of $\mathbf{F}_{0}$ as
$$ \overline{\mathbf{F}}:=\mathbf{F}_{d}\left(\mathbf{F}_{0}\right)_{v}=\left(\frac{\operatorname{det}\left[\mathbf{F}_{0}\right]}{\operatorname{det}[\mathbf{F}]}\right)^{\frac{1}{n}} \mathbf{F} $$with $\mathbf{F}_{0}$ the value of $\mathbf{F}$ at the element center, $n$ the space dimension. Alternatively, $\mathbf{F}_{0}$ can be computed as a average value as
$$ \mathbf{F}_{0}=\frac{\int_{\Omega_{e}} \mathbf{F} \mathrm{~d} \Omega}{\int_{\Omega_{e}} \mathrm{~d} \Omega} $$Hereafter, we denote $\left(\frac{\operatorname{det}\left[\mathbf{F}_{0}\right]}{\operatorname{det}[\mathbf{F}]}\right)^{\frac{1}{n}}$ as $\alpha$.
We assume that $\left\{\Omega^{t}: \mathbf{x} \in \mathbb{R}^{n}\right\}$ is the current deformed configuration, $\left\{\Omega: \mathbf{X} \in \mathbb{R}^{n}\right\}$ is the reference configuration, and $\phi(\mathbf{X})$ is the coordinate mapping $\left\{\phi(\mathbf{X}): \Omega \rightarrow \Omega^{t}\right\}$ such as $\mathbf{x}=\phi(\mathbf{X})$. The displacement and its gradient can be written as
$$ \begin{align*} & \mathbf{u}=\mathbf{x}-\mathbf{X}=\phi(\mathbf{X})-\mathbf{X} \tag{1}\\ & \mathbf{F}=\nabla \phi(\mathbf{X}) \tag{2} \end{align*} $$Let $\mathcal{S}$ is the space of admissible deformations defined by
$$ \begin{equation*} \mathcal{S}=\phi: \Omega \rightarrow \mathbb{R}^{n}\left|\operatorname{det}\left(\nabla_{X} \phi\right)>0, \phi\right|_{\partial \Omega_{\phi}}=\phi_{b} \tag{3} \end{equation*} $$and $\mathcal{V}_{\phi}$ is the tangent space to $\mathcal{S}$ at $\phi$ as
$$ \begin{equation*} \mathcal{V}_{\phi}=d \mathbf{w} \circ \phi: \Omega \rightarrow \mathbb{R}^{n}\left|\operatorname{det}\left(\nabla_{X} \phi\right)>0, d \mathbf{w} \circ \phi\right|_{\partial \Omega_{\phi}}=0 \tag{4} \end{equation*} $$In the total Lagrangian formulation, the equilibrium equations are derived from the principle of virtual work in the reference configuration $\Omega$. This leads to find $\phi \in \mathcal{S}$ such that $\forall d \mathbf{w} \in \mathcal{V}_{\phi}$ it satisfies
$$ \begin{equation*} \int_{\Omega_{e}} \mathbf{S}: d \overline{\mathbf{E}}(d \mathbf{w}) \mathrm{d} \Omega=\int_{\Omega_{e}} \mathbf{f} \cdot d \mathbf{w} \mathrm{~d} \Omega+\int_{\left.\partial \Omega\right|_{\tau}} d \mathbf{w} \cdot \tau \mathrm{~d} \Gamma \tag{5} \end{equation*} $$where $\mathbf{S}$ is the second Piola-Kirchhoff stress tensor, $\overline{\mathbf{E}}$ is the Green-Lagrange strain calculated with $\overline{\mathbf{F}}$ and $\mathbf{f}$ is the external load vector, The Green-Lagrange strain is defined by
$$ \begin{equation*} \mathbf{E}=\frac{1}{2}\left(\mathbf{F}^{\mathrm{T}} \mathbf{F}-\mathbf{I}\right), \tag{6} \end{equation*} $$Using the F bar method, the modified Green-Lagrange strain $\overline{\mathbf{E}}$ is
$$ \begin{align*} \overline{\mathbf{E}} & =\frac{1}{2}\left(\overline{\mathbf{F}}^{\mathrm{T}} \overline{\mathbf{F}}-\mathbf{I}\right), \tag{7}\\ & =\frac{1}{2}\left(\alpha^{2} \mathbf{F}^{\mathrm{T}} \mathbf{F}-\alpha^{2} \mathbf{I}+\alpha^{2} \mathbf{I}-\mathbf{I}\right), \tag{8}\\ & =\alpha^{2} \mathbf{E}+\frac{1}{2}\left(\alpha^{2}-1\right) \mathbf{I} . \tag{9} \end{align*} $$Consequently, the stress is computed as
$$ \begin{equation*} \mathbf{S}:=\mathbf{S}(\overline{\mathbf{E}}) . \tag{10} \end{equation*} $$To linearize the equilibrium equations, we first derive some fundamental derivatives.
The directional derivative of a multivariable differentiable (scalar) function along a given vector $\mathbf{v}$ at a given point $\mathbf{x}$ intuitively represents the instantaneous rate of change of the function, moving through $\mathbf{x}$ with a velocity specified by $\mathbf{v}$ : The directional derivative of a scalar function $f(\mathbf{x}), \mathbf{x} \in \mathbb{R}^{n}$ along a vector $\mathbf{v} \in \mathbb{R}^{n}$ is the function $\nabla_{\mathbf{v}} f(\mathbf{x})$ defined by the limit:
$$ \begin{equation*} \nabla_{\mathbf{v}} f(\mathbf{x})=\lim _{h \rightarrow 0} \frac{f(\mathbf{x}+h \mathbf{v})-f(\mathbf{x})}{h}=\left.\frac{\partial}{\partial h} f(\mathbf{x}+h \mathbf{v})\right|_{\lim _{h \rightarrow 0}} \tag{11} \end{equation*} $$If $f(\mathbf{x})$ is differentiable at $\mathbf{x}$, the following equation holds after applying the first order Taylor approximation to $f(\mathbf{x}+h \mathbf{v})$ in the above definition
$$ \begin{equation*} \nabla_{\mathbf{v}} f(\mathbf{x})=\nabla f(\mathbf{x}) \mathbf{v}=\left.\frac{\partial}{\partial h} f(\mathbf{x}+h \mathbf{v})\right|_{\lim _{h \rightarrow 0}} \tag{12} \end{equation*} $$We will use the definition of directional derivatives to simplify the linearization.
Therefore, the variation of the modified Green-Lagrange strain gives
$$ \begin{equation*} d \overline{\mathbf{E}}=\alpha^{2} d \mathbf{E}+\alpha(2 \mathbf{E}+\mathbf{I}) d \alpha \tag{15} \end{equation*} $$Note that the derivative of the determinant of a matrix with respect to the matrix itself is used to obtain the above derivatives, which is
$$ \begin{equation*} \frac{\partial}{\partial \mathbf{A}}(\operatorname{det}(\mathbf{A}))=\operatorname{det}(\mathbf{A}) \mathbf{A}^{-\mathrm{T}} \tag{16} \end{equation*} $$This gives
$$ \begin{align*} d \alpha & =\frac{\alpha}{\mathrm{n}}\left(\mathbf{F}_{0}^{-\mathrm{T}}: d \mathbf{F}_{0}-\mathbf{F}^{-\mathrm{T}}: d \mathbf{F}\right) \tag{17}\\ & =\frac{\alpha}{\mathrm{n}}\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right) \tag{18} \end{align*} $$Consequently,
$$ \begin{align*} d \overline{\mathbf{E}} & =\alpha^{2} d \mathbf{E}+\alpha(2 \mathbf{E}+\mathbf{I})\left(\frac{\alpha}{\mathrm{n}}\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)\right) \tag{20}\\ & =\alpha^{2}\left(d \mathbf{E}+\frac{1}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)\right) \tag{21} \end{align*} $$Assume that the body force $\mathbf{f}$ and the traction $\tau$ are independent of the displacement, the Jacobian for the Newton-Raphson method can be obtained by deriving the variation of the virtual strain energy as
$$ \begin{equation*} d_{u} \int_{\Omega_{e}} \mathbf{S}(\overline{\mathbf{E}}): d \overline{\mathbf{E}} \mathrm{~d} \Omega=\int_{\Omega_{e}} \nabla_{u}(\mathbf{S}(\overline{\mathbf{E}}): d \overline{\mathbf{E}}) \delta \mathbf{u} \mathrm{d} \Omega \tag{22} \end{equation*} $$with $\delta \mathbf{u} \in \mathcal{V}_{\phi}$ According to the directional derivative rule,
$$ \begin{align*} \nabla_{u}(\mathbf{S}(\overline{\mathbf{E}}): d \overline{\mathbf{E}}) \delta \mathbf{u}= & \left.\frac{\partial}{\partial h}(\mathbf{S}(\overline{\mathbf{E}}(\phi+h \delta \mathbf{u})): d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u}))\right|_{\lim _{h \rightarrow 0}} \tag{23}\\ = & \frac{\partial \mathbf{S}(\overline{\mathbf{E}}(\phi+h \delta \mathbf{u})}{\partial \overline{\mathbf{E}}(\phi+h \delta \mathbf{u})}: \frac{\partial \overline{\mathbf{E}}(\phi+h \delta \mathbf{u})}{\partial h}:\left.d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u})\right|_{\lim _{h \rightarrow 0}} \tag{24}\\ & +\mathbf{S}(\overline{\mathbf{E}}(\phi+h \delta \mathbf{u})):\left.\frac{\partial}{\partial h}(d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u}))\right|_{\lim _{h \rightarrow 0}} \tag{25} \end{align*} $$where $\partial \mathbf{S}\left(\overline{\mathbf{E}}(\phi+h \delta \mathbf{u}) /\left.\partial \overline{\mathbf{E}}(\phi+h \delta \mathbf{u})\right|_{\lim _{h \rightarrow 0}}=\partial \mathbf{S}(\overline{\mathbf{E}}(\phi) / \partial \overline{\mathbf{E}}(\phi)\right.$ is the material tangential, which is a forth order tensor, hereafter we denote it as $\mathbf{C}$.
Since
$$ \begin{equation*} \left.\frac{\partial \overline{\mathbf{E}}(\phi+h \delta \mathbf{u})}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\nabla_{\phi} \overline{\mathbf{E}}(\phi) \delta \mathbf{u}=\delta \overline{\mathbf{E}}(\phi), \tag{26} \end{equation*} $$we have
$$ \begin{equation*} \delta \overline{\mathbf{E}}=\alpha^{2}\left(\delta \mathbf{E}+\frac{1}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right)\right) \tag{27} \end{equation*} $$by the same way deriving $d \overline{\mathbf{E}}$. Expanding $\partial\left(d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u}) /\left.\partial h\right|_{\lim _{h \rightarrow 0}}\right.$ leads to
$$ \begin{align*} \left.\frac{\partial}{\partial h}(d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u}))\right|_{\lim _{h \rightarrow 0}=} & \left.\frac{\partial}{\partial h}\left(\alpha^{2}\left(d \mathbf{E}+\frac{1}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)\right)\right)\right|_{\lim _{h \rightarrow 0}} \tag{28}\\ = & \left.2 \alpha\left(d \mathbf{E}+\frac{1}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)\right) \frac{\partial \alpha}{\partial h}\right|_{\lim _{h \rightarrow 0}} \tag{29}\\ & +\left.\alpha^{2} \frac{\partial d \mathbf{E}}{\partial h}\right|_{\lim _{h \rightarrow 0}}+\left.\frac{2 \alpha^{2}}{\mathrm{n}} \frac{\partial \mathbf{E}}{\partial h}\right|_{\lim _{h \rightarrow 0}}\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right) \tag{30}\\ & +\frac{\alpha^{2}}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\left.\frac{\partial}{\partial h}\left(\mathbf{F}_{0}^{-\mathrm{T}}\right)\right|_{\lim _{h \rightarrow 0}}: \nabla d \mathbf{w}_{0}-\left.\frac{\partial}{\partial h}\left(\mathbf{F}^{-\mathrm{T}}\right)\right|_{\lim _{h \rightarrow 0}}: \nabla d \mathbf{w}\right) \tag{31} \end{align*} $$where
$$ \begin{gather*} \left.\frac{\partial \alpha}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\left.\frac{\partial \alpha(\phi+h \delta \mathbf{u})}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\nabla_{\mathbf{u}} \alpha \delta \mathbf{u}=\delta \alpha=\frac{\alpha}{\mathrm{n}}\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right), \tag{32}\\ \left.\frac{\partial d \mathbf{E}}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\left.\frac{1}{2} \frac{\partial}{\partial h}\left((\nabla d \mathbf{w})^{\mathrm{T}} \mathbf{F}+\mathbf{F}^{\mathrm{T}} \nabla d \mathbf{w}\right)\right|_{\lim _{h \rightarrow 0}} \tag{33}\\ =\frac{1}{2}\left((\nabla d \mathbf{w})^{\mathrm{T}} \nabla \delta \mathbf{u}+(\nabla \delta \mathbf{u})^{t r} \nabla d \mathbf{w}\right), \tag{34}\\ \left.\frac{\partial \mathbf{E}}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\left.\frac{\partial \mathbf{E}(\phi+h \delta \mathbf{u})}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\frac{1}{2}\left((\nabla \delta \mathbf{u})^{\mathrm{T}} \mathbf{F}+\mathbf{F}^{\mathrm{T}} \nabla \delta \mathbf{u}\right), \tag{35}\\ \left.\frac{\partial \mathbf{F}_{0}^{-\mathrm{T}}}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\left.\frac{\partial F_{0}^{-\mathrm{T}}}{\partial \mathbf{F}_{0}} \frac{\partial \mathbf{F}_{0}(\phi+h \delta \mathbf{u})}{\partial h}\right|_{\lim _{h \rightarrow 0}}=-\mathbf{F}_{0}^{-\mathrm{T}} \otimes \mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}, \tag{36}\\ \left.\frac{\partial \mathbf{F}^{-\mathrm{T}}}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\left.\frac{\partial F^{-\mathrm{T}}}{\partial \mathbf{F}} \frac{\partial \mathbf{F}(\phi+h \delta \mathbf{u})}{\partial h}\right|_{\lim _{h \rightarrow 0}}=-\mathbf{F}^{-\mathrm{T}} \otimes \mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u} . \tag{37} \end{gather*} $$We have
$$ \begin{align*} \left.\frac{\partial}{\partial h}(d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u}))\right|_{\lim _{h \rightarrow 0}}= & \delta(d \overline{\mathbf{E}}) \tag{38}\\ = & \frac{2 \alpha^{2}}{\mathrm{n}}\left(d \mathbf{E}+\frac{1}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)\right) \tag{39}\\ & \quad\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right) \tag{40}\\ & +\left.\alpha^{2} \frac{\partial d \mathbf{E}}{\partial h}\right|_{\lim _{h \rightarrow 0}} \tag{41}\\ & +\frac{\alpha^{2}}{\mathrm{n}}\left((\nabla \delta \mathbf{u})^{\mathrm{T}} \mathbf{F}+\mathbf{F}^{\mathrm{T}} \nabla \delta \mathbf{u}\right)\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right) \tag{42}\\ & \quad-\frac{\alpha^{2}}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}} \otimes \mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}} \otimes \mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}: \nabla d \mathbf{w}\right) \tag{43} \end{align*} $$Finally, we obtain the expression the variation of the virtual strain energy as
$$ \begin{align*} \int_{\Omega_{e}} \nabla_{u}(\mathbf{S}(\overline{\mathbf{E}}): d \overline{\mathbf{E}}) \delta \mathbf{u} \mathrm{d} \Omega= & \int_{\Omega_{e}} \mathbf{C}: \delta \overline{\mathbf{E}}: d \overline{\mathbf{E}} \mathrm{~d} \Omega \tag{44}\\ & +\int_{\Omega_{e}} \mathbf{S}(\overline{\mathbf{E}}): \delta(d \overline{\mathbf{E}}(\phi+h \delta \mathbf{u})) \mathrm{d} \Omega \tag{45} \end{align*} $$After the discretization with the Galerkin approach, we have
$$ \begin{equation*} \delta \mathbf{u}=\mathbf{N} \delta \hat{\mathbf{u}}, \quad d \mathbf{u}=\mathbf{N} \hat{\mathbf{u}} \tag{46} \end{equation*} $$with $\mathbf{N}$ the shape functions, $\hat{\delta \mathbf{u}}$ and $\hat{d \mathbf{u}}$ the arbitrary virtual nodal displacements. This gives
$$ \begin{equation*} d \mathbf{E}=\frac{\partial \mathbf{E}}{\partial \hat{\mathbf{u}}}: \hat{d \mathbf{u}}, \quad \delta \mathbf{E}=\frac{\partial \mathbf{E}}{\partial \hat{\mathbf{u}}}: \hat{\delta \mathbf{u}} \tag{47} \end{equation*} $$Assuming that stress tensor and strain tensor are symmetry, and considering the matrix form of $\partial \mathbf{E} / \partial \hat{\mathbf{u}}$ gives
$$ \begin{equation*} \frac{\partial \mathbf{E}}{\partial \hat{\mathbf{u}}}:=\mathrm{B} . \tag{48} \end{equation*} $$where $\mathrm{B}=\mathrm{B}_{l}+\mathrm{B}_{n l}$ with $\mathrm{B}_{n}$ and $\mathrm{B}_{n l}$ the linear and non-linear parts of the B matrix, respectively.
Additional B matrix from $d \overline{\mathbf{E}}$ and $\delta \overline{\mathbf{E}}$ As for $d \overline{\mathbf{E}}$, let’s denote $\alpha^{2}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d w_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d w\right) / \mathrm{n}$ as $d \bar{\varepsilon}$, which gives
$$ \begin{equation*} d \overline{\mathbf{E}}=\alpha^{2} d \mathbf{E}+d \bar{\varepsilon} \tag{49} \end{equation*} $$Expanding $\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)$ gives:
$$ \begin{equation*} \left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)=\left(\mathbf{F}_{0}^{-T}\right)_{i j} d \hat{w}_{i}^{L} N_{, j}^{L}\left(\xi_{0}\right)-\left(\mathbf{F}^{-T}\right)_{i j} d \hat{w}_{i}^{L} N_{, j}^{L}=\left(\mathbf{q}_{0}-\mathbf{q}\right) d \hat{\mathbf{w}} \tag{50} \end{equation*} $$where $\mathbf{q}$ is a $1 \times \mathrm{n} \cdot$ NE matrix or a transposed vector as
$$ \begin{gather*} \mathbf{q}=\left(\mathbf{q}_{\mathrm{col} 1}, \mathbf{q}_{\mathrm{col} 2}\right), \text { or } \mathbf{q}=\left(\mathbf{q}_{\mathrm{col} 1}, \mathbf{q}_{\mathrm{col} 2}, \mathbf{q}_{\mathrm{col} 3}\right) \tag{51}\\ \mathbf{q}_{\mathrm{col} \mathrm{i}}=\left(\left(\mathbf{F}^{-1}\right)_{j i} N_{, j}^{1}, \quad\left(\mathbf{F}^{-1}\right)_{j i} N_{, j}^{2}, \quad \cdots,\left(\mathbf{F}^{-1}\right)_{j i} N_{, j}^{\mathrm{NE}}\right), \quad i, j=1, \cdots, \operatorname{dim} . \tag{52} \end{gather*} $$with NE the number of nodes, and $\mathbf{q}_{0}$ the value of $\mathbf{q}$ at the element center $\xi_{0}$. This can be written into a matrix form as
$$ \begin{equation*} [d \bar{\varepsilon}]=\hat{\mathrm{B}} d \hat{\mathbf{w}} \tag{53} \end{equation*} $$with $[d \bar{\varepsilon}]$ the vector form of $d \bar{\varepsilon}$, and
$$ \begin{equation*} \hat{\mathrm{B}}=\frac{\alpha^{2}}{\mathrm{n}}[2 \mathbf{E}+\mathbf{I}]\left(\mathbf{q}_{0}-\mathbf{q}\right) \tag{54} \end{equation*} $$where $[2 \mathbf{E}+\mathbf{I}]=\left(2 E_{11}+1,2 E_{22}+1,2 E_{33}+1,2 E_{12}\right)^{\mathrm{T}}$ for plane strain problems, and $[2 \mathbf{E}+\mathbf{I}]=\left(2 E_{11}+1,2 E_{22}+1,2 E_{33}+1,2 E_{12}, 2 E_{23}, 2 E_{13}\right)^{\mathrm{T}}$ for 3D problems, respectively.
Note: the shear strain $E_{12}, E_{23}, E_{13}$ are assumed being scaled with $\sqrt{2}$ for the computation with the Kelvin vector.
The same for $\delta \overline{\mathbf{E}}$, we have $\delta \bar{\varepsilon}=\hat{\mathrm{B}} \delta \hat{\mathbf{u}}$. Since $d \overline{\mathbf{E}}=\alpha^{2} d \mathbf{E}+d \bar{\varepsilon}$,
$$ \begin{equation*} [d \overline{\mathbf{E}}]=\left(\alpha^{2} \mathrm{~B}+\hat{\mathrm{B}}\right) d \hat{\mathbf{w}} \tag{55} \end{equation*} $$where $[d \overline{\mathbf{E}}]$ means the vector form of $d \overline{\mathbf{E}}$. We denote $\alpha^{2} \mathrm{~B}+\hat{\mathrm{B}}$ as $\overline{\mathrm{B}}$, which simplifies the expression of the Jacobian from $\int_{\Omega_{e}} \mathbf{C}$ : $\delta \overline{\mathbf{E}}: d \overline{\mathbf{E}} \mathrm{~d} \Omega$ as
$$ \begin{equation*} \int_{\Omega_{e}} \mathbf{C}:(\delta \overline{\mathbf{E}}): d \overline{\mathbf{E}} \mathrm{~d} \Omega \xrightarrow{\text { matrix-vector form }} \int_{\Omega_{e}} \overline{\mathrm{~B}}^{\mathrm{T}}[\mathbf{C}] \overline{\mathrm{B}} \mathrm{~d} \Omega \tag{56} \end{equation*} $$where $[\mathbf{C}]$ is matrix from of $\mathbf{C}$.
From this term, we obtain the standard G matrix related Jacobian contribution as
$$ \begin{equation*} \int_{\Omega_{e}} \alpha^{2} \mathbf{G}^{\mathrm{T}}[[\mathbf{S}]] \mathbf{G} \mathrm{d} \Omega \tag{57} \end{equation*} $$with $[[\mathbf{S}]]$ for a matrix with stress matrix as diagonal blocks. 3.2.2 Term with $\frac{2 \alpha^{2}}{\mathbf{n}}\left(d \mathbf{E}+\frac{1}{\mathbf{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathbf{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathbf{T}}: \nabla d \mathbf{w}\right)\right)$
$$ \left(\mathbf{F}_{0}^{-\mathbf{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathbf{T}}: \nabla \delta \mathbf{u}\right) $$The corresponding term in the linearized weak form is
$$ \begin{array}{r} \int_{\Omega_{e}} \mathbf{S}: \frac{2 \alpha^{2}}{\mathrm{n}}\left(d \mathbf{E}+\frac{1}{\mathrm{n}}(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)\right) \\ \left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right) \mathrm{d} \Omega \tag{59} \end{array} $$which can be written:
$$ \begin{equation*} \frac{2}{\mathrm{n}} \int_{\Omega_{e}} \mathbf{S}: d \overline{\mathbf{E}}\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right) \mathrm{d} \Omega \tag{60} \end{equation*} $$Note that
$$ \begin{equation*} \mathbf{S}: d \overline{\mathbf{E}}=(\overline{\mathrm{B}} d \hat{\mathbf{w}})^{\mathrm{T}}[\mathbf{S}] \tag{61} \end{equation*} $$with $[\mathbf{S}]$ the stress in vector type, e.g. the stress in the Kelvin vector. While
$$ \begin{equation*} \left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right)=\left(\mathbf{q}_{0}-\mathbf{q}\right) \hat{\delta \mathbf{u}} \tag{62} \end{equation*} $$Therefore the additional Jacobian obtained from this term is
$$ \begin{equation*} \frac{2}{\mathrm{n}} \int_{\Omega_{e}}(\overline{\mathrm{~B}})^{\mathrm{T}}[\mathbf{S}]\left(\mathbf{q}_{0}-\mathbf{q}\right) \mathrm{d} \Omega \tag{63} \end{equation*} $$Note that $\left.\frac{\partial \mathbf{E}}{\partial h}\right|_{\lim _{h \rightarrow 0}}=\delta \mathbf{E}$ in that term, the term corresponding integration term is
$$ \begin{equation*} \int_{\Omega_{e}} \frac{2 \alpha^{2}}{\mathrm{n}} \mathbf{S}: \delta \mathbf{E}\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right) \mathrm{d} \Omega \tag{64} \end{equation*} $$We see that
$$ \begin{equation*} \mathbf{S}: \delta \mathbf{E}=[\mathbf{S}]^{t r} \mathrm{~B} \hat{\delta} \hat{\mathbf{u}} \tag{65} \end{equation*} $$with $[\mathbf{S}]$ the stress in vector type. The same for $\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right)$, the discretized of $\left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right)$ takes the form
$$ \begin{equation*} \left(\mathbf{F}_{0}^{-\mathrm{T}}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}}: \nabla d \mathbf{w}\right):=\left(\mathbf{q}_{0}-\mathbf{q}\right) \hat{d \mathbf{w}}=\hat{d \mathbf{w}^{t r}}\left(\mathbf{q}_{0}^{t r}-\mathbf{q}^{t r}\right) \tag{66} \end{equation*} $$Therefore the integration can be written as
$$ \begin{equation*} \frac{2}{\mathrm{n}} \int_{\Omega_{e}} \hat{d \mathbf{w}} \hat{\alpha}^{t r}\left[\mathbf{q}_{0}^{t r}-\mathbf{q}^{t r}\right](\mathbf{S})^{t r} \mathrm{~B} \hat{\delta} \hat{\mathbf{u}} \mathrm{~d} \Omega \tag{67} \end{equation*} $$This Jacobian contribution from this integration is
$$ \begin{equation*} \frac{2}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2}\left[\mathbf{q}_{0}^{t r}-\mathbf{q}^{t r}\right](\mathbf{S})^{t r} \operatorname{Bd} \Omega \tag{68} \end{equation*} $$The corresponding integration is
$$ \begin{equation*} -\frac{1}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2} \mathbf{S}:(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}} \otimes \mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}} \otimes \mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}: \nabla d \mathbf{w}\right) \mathrm{d} \Omega \tag{69} \end{equation*} $$Note that $\mathbf{F}^{-\mathrm{T}} \otimes \mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}: \nabla d \mathbf{w}=\left(\mathbf{F}^{-\mathrm{T}}: d \mathbf{w}\right)\left(\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}\right)$
From the above description, we know that $\mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}:=\mathbf{q} \hat{\delta \mathbf{u}}$ and $\mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}:=\mathbf{q}_{0} \hat{\delta \mathbf{u}}$ after discretization. Therefore, the integration can be written as
$$ \begin{align*} & -\frac{1}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2} \mathbf{S}:(2 \mathbf{E}+\mathbf{I})\left(\mathbf{F}_{0}^{-\mathrm{T}} \otimes \mathbf{F}_{0}^{-\mathrm{T}}: \nabla \delta \mathbf{u}_{0}: \nabla d \mathbf{w}_{0}-\mathbf{F}^{-\mathrm{T}} \otimes \mathbf{F}^{-\mathrm{T}}: \nabla \delta \mathbf{u}: \nabla d \mathbf{w}\right) \mathrm{d} \Omega \tag{70}\\ & \quad=-\frac{1}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2} \mathbf{S}:(2 \mathbf{E}+\mathbf{I})\left(\left(\mathbf{q}_{0} d \mathbf{w}\right)^{\mathrm{T}} \mathbf{q}_{0} \delta \mathbf{u}-(\mathbf{q} d \mathbf{w})^{\mathrm{T}} \mathbf{q} \delta \mathbf{u}\right) \mathrm{d} \Omega \tag{71}\\ & \left.\quad=-\frac{1}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2} \mathbf{S}:(2 \mathbf{E}+\mathbf{I})(d \mathbf{w})^{\mathrm{T}} \mathbf{q}_{0}^{t r} \mathbf{q}_{0} \delta \mathbf{u}-d \mathbf{w}^{\mathrm{T}} \mathbf{q}^{t r} \mathbf{q} \delta \mathbf{u}\right) \mathrm{d} \Omega \tag{72} \end{align*} $$Therefore the Jacobian contribution from this term is
$$ \begin{equation*} -\frac{1}{n} \int_{\Omega_{e}} \alpha^{2} \mathbf{S}:(2 \mathbf{E}+\mathbf{I})\left(\mathbf{q}_{0}^{t r} \mathbf{q}_{0}-\mathbf{q}^{t r} \mathbf{q}\right) \mathrm{d} \Omega \tag{73} \end{equation*} $$Note that $\mathbf{S}:(2 \mathbf{E}+\mathbf{I})$ is a scalar, and it can be computed by the dot product of stress vectors as $[\mathbf{S}] \cdot[(2 \mathbf{E}+\mathbf{I})]$.
Finally, we obtain the Jacobian for the total Lagrange formulation with the F bar method:
$$ \begin{align*} & \int_{\Omega_{e}} \overline{\mathrm{~B}}^{\mathrm{T}}[\mathbf{C}] \overline{\mathrm{B}} \mathrm{~d} \Omega+\int_{\Omega_{e}} \alpha^{2} \mathbf{G}^{\mathrm{T}}[[\mathbf{S}]] \mathbf{G} \mathrm{d} \Omega+\frac{2}{\mathrm{n}} \int_{\Omega_{e}}(\overline{\mathrm{~B}})^{\mathrm{T}}[\mathbf{S}]\left(\mathbf{q}_{0}-\mathbf{q}\right) \mathrm{d} \Omega \tag{74}\\ & +\frac{2}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2}\left[\mathbf{q}_{0}^{t r}-\mathbf{q}^{t r}\right](\mathbf{S})^{t r} \mathrm{Bd} \Omega-\frac{1}{\mathrm{n}} \int_{\Omega_{e}} \alpha^{2} \mathbf{S}:(2 \mathbf{E}+\mathbf{I})\left(\mathbf{q}_{0}^{t r} \mathbf{q}_{0}-\mathbf{q}^{t r} \mathbf{q}\right) \mathrm{d} \Omega \tag{75} \end{align*} $$With the equilibrium equation (5), the discretized residual is
$$ \begin{equation*} \mathbf{R}=\int_{\Omega_{e}} \overline{\mathrm{~B}}[\mathbf{S}] \mathrm{d} \Omega-\int_{\Omega_{e}} \mathbf{f} \mathrm{~N} \mathrm{~d} \Omega-\int_{\left.\partial \Omega\right|_{\tau}} \tau \mathrm{N} \mathrm{~d} \Gamma=\mathbf{0} \tag{76} \end{equation*} $$with N the shape function matrix.
[1] EA de Souza Neto, D Perić, M Dutko, and DRJ1400785 Owen. Design of simple low order finite elements for large strain analysis of nearly incompressible solids. International Journal of Solids and Structures, 33(20-22):3277-3296, 1996.
[2] Thomas Elguedj, Yuri Bazilevs, Victor M Calo, and Thomas JR Hughes. $\overline{\mathrm{B}}$ and $\overline{\mathrm{F}}$ projection methods for nearly incompressible linear and non-linear elasticity and plasticity using higher-order nurbs elements. Computer methods in applied mechanics and engineering, 197(33-40):2732-2762, 2008.
This article was written by Wenqing Wang, Thomas Nagel. If you are missing something or you find an error please let us know.
Generated with Hugo 0.150.1
in CI job 743172
