McWhorter & Sunada Problem
McWhorter Problem
A detailed semi-analytical solution and a convenient tool for calculating the solution for different material parameters can be found here.
Material Parameters
Property Symbol Value Unit
Porosity $\phi$ 0.15 1
Intrinsic permeability $K$ $$1.0\cdot 10^{-10}$$ $m^2$
Residual saturation of the wetting phase $$s_\mathrm{L}^{res}$$ 0.02 1
Residual saturation of the non-wetting phase $$s_\mathrm{G}^{res}$$ 0.001 1
Dynamic viscosity of the wetting phase $\mu_\mathrm{L}$ $$1.0\cdot 10^{-3}$$ Pa s
Dynamic viscosity of the non-wetting pha $\mu_\mathrm{G}$ $$5.0\cdot 10^{-3}$$ Pa s
Brooks and Corey model parameter: entry pressure $p_b$ 5000 Pa
Brooks and Corey model parameter: pore size distribution index $\lambda$ 3.0 1
Problem Parameters
Initial saturation $$s_\mathrm{L}(t=0)$$ 0.05 1
Injection boundary saturation $$s_\mathrm{L}(x=0)$$ 0.8 1
Exact Solution
The exact solution is not yet calculated in this notebook, instead the online tool by Radek Fučík is used. This tool calculates the solution and outputs the results with arbitrary accuracy as CSV files, which are plotted below.
# Import analytical solution from a CSV file… (click to toggle)
reference = np.loadtxt("data/ref_solution_saturation.csv", delimiter=",")
ref_x, ref_saturation = reference.T
Numerical Solution
# run OGS… (click to toggle)
# run OGS
model = ot.Project(input_file="mcWhorter_h2.prj", output_file="mcWhorter_h2.prj")
Simulation: mcWhorter_h2.prj
Execution took 18.236694812774658 s
# Read the OGS results and sample the last timestep on the same points as in… (click to toggle)
# the reference.
ms = ot.MeshSeries(f"{out_dir}/result_McWhorter_H2.pvd")
pts = pv.PointSet([(x, 0, 0) for x in ref_x])
sL_num = pts.sample(ms.mesh(-1))["saturation"]
# Absolute and relative errors
err_abs = ref_saturation - sL_num
err_rel = err_abs / ref_saturation
assert np.all(np.abs(err_rel) < 0.5)
fig, (ax1, ax2) = plt.subplots(1, 2, figsize=(14, 4))… (click to toggle)
ax3 = ax2.twinx()
ax1.plot(ref_x, sL_num, "b", label=r"$s_\mathrm{L}$ numerical")
ax1.plot(ref_x, ref_saturation, "g", label=r"$s_\mathrm{L}$ exact")
lns_abs = ax2.plot(ref_x, err_abs, "-b", lw=2, label=r"absolute error")
lns_rel = ax3.plot(ref_x, err_rel, "-g", lw=2, label=r"relative error")
lns = lns_abs + lns_rel
ax1.legend()
ax1.set_xlabel("$x$ / m", fontsize=12)
ax1.set_ylabel(r"$s_\mathrm{L}$", fontsize=12)
ax2.set_xlabel("$x$ / m", fontsize=12)
ax2.set_ylabel(r"$\epsilon_\mathrm{abs}$", fontsize=12)
ax3.set_ylabel(r"$\epsilon_\mathrm{rel}$", fontsize=12)
time = ms.timevalues[-1]
fig.suptitle(f"Liquid saturation and errors at t={time} seconds")
Text(0.5, 0.98, 'Liquid saturation and errors at t=1000.0 seconds')
The numerical approximation fits the analytical solution very well in the whole area. Only in the area of the saturation front are deviations recognisable. These deviations are mainly due to the grid resolution and are well known in multiphase simulations. The error can be reduced almost arbitrarily by lowering the size of the grid elements.
Generated with Hugo 0.147.9 in CI job 639840 | Last revision: October 19, 2022
