Following up the benchmark about the BGRa creep model described on the this page, this example represents the creep in the near field of drift in the deep rock salt after excavation. The domain and the geometry are shown in the following figure:
Domain Mesh
Mesh and Geometry.
Cap rock Rock salt Unit
Density 2000 2170 $\mathrm{kg} / \mathrm{m}^3$
Young’s Modulus 7.0 7.65 GPa
Poisson ratio 0.3 2.7 -
Thermal conductivity 5 5 W/(mK)
The parameters of the BGRa creep model are $A = 0.18d^{-1}$, $m = 5$, $Q = 54$ $kJ/mol$ for the rock salt. For the cap rock, $A$ is set to zero.
  • top boundary: $\tau_x$ = $\sigma_{xy} = 0$, $\tau_y = \sigma_y = - 10$ $MPa$, $T = 310$ $K$
  • two lateral boundaries: normal displacement is fixed, and no heat flux.
  • bottom boundary: normal displacement is fixed, and $T = 320 K$
  • circle of drift surface: traction free $(\sigma \cdot \mathbf{n} = 0)$ and $T = 310$ $K$ as excavation conditions.
The following three figures are plotted by using the results of the simulation of 1000 days creep. The three figures display the distribution of horizontal and vertical stresses at times of 109 days, 409 days and 1000 days, respectively.
# creating output path if it doesn't exist already.(click to toggle)
    input_file="CreepAfterExcavation.prj",
    output_file="CreepAfterExcavation_modified.prj",
# Update end time of simulation
model.replace_text(
    xpath="./time_loop/processes/process/time_stepping/t_end", value="86400.0e+3"
model.run_model(logfile=Path(out_dir) / "log.txt")
Simulation: CreepAfterExcavation_modified.prj
Execution took 198.37938332557678 s
ms = ot.MeshSeries("CreepAfterExcavation.pvd").scale(time=("s", "d"))(click to toggle)
ts_109d = np.where(np.round(ms.timevalues) == 109)[0].item()  # 109 days
ts_409d = np.where(np.round(ms.timevalues) == 409)[0].item()  # 409 days
ts_1000d = np.where(np.round(ms.timevalues) == 1000)[0].item()  # 1000 days
ms_109d = ms.mesh(ts_109d)
ms_409d = ms.mesh(ts_409d)
ms_1000d = ms.mesh(ts_1000d)
def plot_stress_dist(day, mesh):(click to toggle)
    obs_pts = np.array([150.0, -600, 0])
    ms_pts = ot.MeshSeries.extract_probe(ms, obs_pts)
    fig, ax = plt.subplots(nrows=1, ncols=3, figsize=(25, 10))
    ot.plot.line(
        ms_pts,
        "time",
        ot.variables.stress["xx"],
        ax=ax[0],
        fontsize=15,
        label="stress xx",
    ot.plot.line(
        ms_pts,
        "time",
        ot.variables.stress["yy"],
        ax=ax[0],
        fontsize=15,
        color="red",
        label="stress yy",
    ax[0].axvline(day, color="green")
    mesh.plot_contourf(ot.variables.stress["xx"], fig=fig, ax=ax[1], fontsize=15)
    mesh.plot_contourf(ot.variables.stress["yy"], fig=fig, ax=ax[2], fontsize=15)
    fig.suptitle(f"Stress distribution at the time of {day} days", fontsize=20)
    plt.tight_layout()
Now the stress distributions at 109, 409, and 1000 days will be plotted:
# Stress distrubtion at 109 days
plot_stress_dist(109, ms_109d)
# Stress distrubtion at 409 days
plot_stress_dist(409, ms_409d)
# Stress distrubtion at 1000 days
plot_stress_dist(1000, ms_1000d)
fig_strain, ax = plt.subplots(nrows=1, ncols=2, figsize=(15, 6))(click to toggle)
ms_1000d.plot_contourf(ot.variables.strain["xx"], fig=fig_strain, ax=ax[0], fontsize=15)
ms_1000d.plot_contourf(ot.variables.strain["yy"], fig=fig_strain, ax=ax[1], fontsize=15)
fig_strain.suptitle("Strain distribution at the time of 1000 days")
plt.tight_layout()
fig_temp, ax = plt.subplots(figsize=(10, 6))(click to toggle)
ms_1000d.plot_contourf(ot.variables.temperature, fig=fig_temp, ax=ax, fontsize=15)
ax.set_title("Temperature distribution at the time of 1000 days.")
plt.tight_layout()
This article was written by Wenqing Wang, Noor Hasan. If you are missing something or you find an error please let us know.
Generated with Hugo 0.147.9 in CI job 635984 | Last revision: August 10, 2018
