The problem is solved on a rectangular domain $2m \times 1m$. Nodal fluid flux is applied on the left boundary nodes with a value of 0.001 $kg/s$ via the property of NodalSourceTerm. The pore pressure on the right boundary is equal to the initial pore pressure of $10⁵$ $Pa$. The displacement in the normal direction of all boundaries except the left one is fixed.
Property | Value | Unit |
Fluid density | $10^3$ | $\mathrm{kg} / \mathrm{m}^3$ |
Viscosity | $10^{-3}$ | Pa.s |
Permeability | $10^{-14}$ | $\mathrm{m}^2$ |
Young’s modulus (bulk) | $2.5 \cdot 10^9$ | Pa |
Poisson ratio (bulk) | 0.27 | - |
Biot coefficient | 0.9 | - |
The time period of 86400s (1 day) is discretised into 100 steps.
# importing libraries
(click to toggle)
(click to toggle)
# Initiate the OGS
(click to toggle)
# Initiate the OGS
input_file="nodal_source_test.prj", output_file="nodal_source_test.prj"
# Run the simulation
model.run_model(logfile=Path(out_dir) / "log.txt")
Simulation: nodal_source_test.prj
Execution took 0.8262348175048828 s
The distributions of pressure and displacement at the end time are shown in the following figure:
# Plotting
(click to toggle)
# Plotting
mesh = MeshSeries("HM_NodalSourceTem.pvd").mesh(20)
fig, (ax1, ax2) = plt.subplots(1, 2, figsize=(20, 6))
mesh.plot_contourf(
ot.variables.pressure.replace(data_name="pressure_interpolated"),
fig=fig,
ax=ax1,
fontsize=15,
mesh.plot_contourf(ot.variables.displacement, fig=fig, ax=ax2, fontsize=15)
plt.subplots_adjust(wspace=0.3) # increase horizontal space
plt.tight_layout()
This article was written by Wenqing Wang, Noor Hasan. If you are missing something or you find an error please let us know.
in CI job 633446
Last revision: April 14, 2021
