Create a simple parallel model
Unsupported Processes
LIE related processes are not supported to use the parallel FEM scheme with PETSc.
Software Modules and Compilation on EVE
- Checkout the OGS-6 source code
- Source the environment scripts
scripts/env/eve/cli.sh
- Configure with utilities enabled to:
- Create the binary for generation of the structured mesh
- Create the binary for the mesh partitioner tool
partmesh cmake <path_to_source> -DOGS_BUILD_UTILS=ON
- Configure OGS for parallel usage with PETSc:
scripts/env/eve/petsc.sh cmake <path_to_source> -DOGS_USE_PETSC=ON
- Build the source code with
make
Create a structured mesh
In order to discretize the domain of a unit cube with boundaries execute
bin/generateStructuredMesh -o cube_1x1x1_hex_axbxc.vtu -e hex --lx 1 --ly 1 --lz 1 --nx a --ny b --nz c
where a, b, and c should be chosen according to the needs.
a |
b |
c |
#cells in 10^6 | compute cores | success |
| 150 | 150 | 150 | ~ 3.38 | 20 | yes |
| 175 | 175 | 175 | ~ 5.36 | 20 | yes |
| 190 | 190 | 190 | ~ 6.86 | 20 | yes |
| 196 | 196 | 196 | ~ 7.59 | 20 | no |
| 216 | 216 | 216 | ~ 10.08 | 40 | yes |
| 236 | 236 | 236 | ~ 13.14 | 40 | yes |
| 292 | 292 | 292 | ~ 24.90 | 80 | yes |
| 368 | 368 | 368 | ~ 49.84 | 160 | yes |
| 422 | 422 | 422 | ~ 75.15 | 240 | yes |
| 465 | 465 | 465 | ~ 100.54 | 320 |
For the boundary conditions the boundary meshes left, right, top, bottom, front, and back were already constructed by the generateStructuredMesh tool.
Alternatively, if the boundaries are simple (i.e. homogeneous), a .gml file is sufficient for the serial case, but for heterogeneous
boundary conditions or for the parallelization boundary mesh files are needed.
There are two possibilities to create such files:
- If there is a
.gmlfile, useconstructMeshesFromGeometrytool which takes the mesh file and geometry and creates all the boundaries which are named in the.gmlfile with the requiredbulk_node_idsandbulk_element_idsmappings. - If there is a boundary mesh (generated by Gmsh or Salome, or extracted in
ParaView, for example) use the
identifySubdomainstool to create or verify the neededbulk_node_idsandbulk_element_idsmappings.
Partition the mesh with partmesh
- Convert VTU mesh into METIS input mesh
bin/partmesh -i cube_1x1x1_hex_axbxc.vtu --ogs2metis
=> results in a filecube_1x1x1_hex_axbxc.mesh - partition the mesh and the corresponding boundaries.
bin/partmesh -n number_of_partitions -m -i cube_1x1x1_hex_axbxc.vtu -- boundary_meshes*.vtu
This will result in a bunch of.binfiles.
Deciding the part to benchmark
- Usually, for solving elliptic problems (for instance, the steady state groundwater flow) the time for the linear solver is the main part of the simulation.
- The hydro-thermal process can be used for testing of the IO capabilities.
- In the mechanics process large parts of the computational resources are spent for the assembly.
ToDo
- script to create models and partitions
- submit script to cluster
- Metrics to take into account could be
- weak scaling (problem size increases as the number of processors increases)
- strong scaling (fixed problem size, use increasing number of processors => speedup and parallel efficiency)
- fixed number of processors, increasing problem size
This article was written by Thomas Fischer. If you are missing something or you find an error please reach out
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
