TOOLS
geometryToGmshGeo
Introduction
The tool geometryToGmshGeo takes OGS geometries (GML files) and creates a Gmsh .geo file. The user can specify several command line arguments to influence the creation procedure. A list of the arguments as well as a description of each argument can be obtained with the --help option.
geometryToGmshGeo --input <input file name> --output <output file>
The --input argument is accepted multiple times.
Simple examples
First Example: Simple Geometry
First, the Gmsh geometry file is create from the GML file square_1x1.gml :
geometryToGmshGeo -i square_1x1.gml -o /tmp/square_1x1.geo --mesh_density_scaling_at_points 0.05
Then, the Gmsh geometry can be meshed:
gmsh /tmp/square_1x1.geo -2 -algo meshadapt -format msh22 -o /tmp/square_1x1.msh
geometry
1x1 square geometry
coarse mesh
simple coarse mesh (density scaling 0.5)
fine mesh
simple fine mesh (density scaling 0.05)
even finer mesh
even finer mesh (density scaling 0.005)
Second Example: Simple Geometry with Additional Geometrical Information
First, the Gmsh geometry file is create from the GML files
                  -i square_0.15_0.25x0.15_0.25.gml
                  -i square_0.45_0.55x0.45_0.55.gml
                  -o /tmp/square_1x1.geo --mesh_density_scaling_at_points 0.5
geometry
1x1 square geometry and sub geometries
coarse mesh
fine mesh
