TOOLS
AddLayer
Introduction
The tool AddLayer adds one layer of elements with a specified thickness thickness on either on top or bottom of an existing mesh input-mesh and returns the newly generated mesh output-mesh that has an new layer.
One might want to take care that the material groups are reduced, e.g. material groups should not be [0,2,5], but [0,1,2]. The new layer will have the material group ID of the highest material group +1 if not otherwise specified. With the switch --copy-material-ids the material group IDs of the extruded layer will be kept. With the switch --set-material-id the material group id of the new layer can be set to a different value than the default value of ‘highest material group number plus one’.
The tool requires the OGS-6 node ordering in the elements. A different node ordering may lead to unexpected results. In case one might try to change the ordering using the tool NodeReordering.
AddLayer -i <input-mesh> -o <output-mesh> [-t <thickness>]
Simple example
One material
A simple cube mesh with one material group (red).
Added layer
The updated mesh where an additional layer (blue) was added on top of the domain with a second material group.
Usage for example:
AddLayer -i quad.vtu -o quad_with_new_top_layer.vtu -t 1
Application
The tool was used to add a “soil” layer to the hydro-geological model of the Unstrut catchment within the INFLUINS project:
T. Fischer et al. (2015): GO2OGS 1.0: a versatile workflow to integrate complex geological information with fault data into numerical simulation models. Geosci. Model Dev., vol. 8, p. 3681–3694, DOI:10.5194/gmd-8-3681-2015, Publisher link
The tool is used in the OGS-GIScape workflow.
