DEVELOPER GUIDE
Executable Testing / Test Data
Introduction
An executable test can be run with several wrappers, e.g. with valgrind, memcheck or a simple time-measurement. Each wrapper run can then be validated (called testers), e.g. with file-diffs or -greps. This can be configured in CMake:
AddTest(
    NAME GroundWaterFlowProcess
    PATH Elliptic/quad_20x10_GroundWaterFlow
    EXECUTABLE ogs
    EXECUTABLE_ARGS quad_20x10_GroundWaterFlow.prj
    RUNTIME 35                                                        # optional
    WRAPPER time                                                      # optional
    TESTER diff                                                       # optional
    DIFF_DATA quad_20x10_constMat0.mesh.vtu quad_20x10_left_right.gml # optional
Tests are then run with ninja ctest or for more verbose output with ctest -VV (you may also use other ctest options ). If the checker has some errors they are displayed. RUNTIME specifies the typical runtime in seconds on an Intel Xeon E5-2680 v2 @ 2.80 GHz with 500 GiB RAM (envinf1). Tests with a RUNTIME > 60 are considered LARGE-tests.
The functionality is very flexible and more wrappers and checker can be added later on. e.g. for running some statistics on output files and comparing them with statistics from reference files.
Run tests with CMake presets
Similar to the configure and build presets there are test presets, e.g. in your source-directory:
ctest --preset release                          # equivalent to running `ninja ctest` above
ctest --preset release -j 6 --label-regex Utils # run 6 tests in parallel which have a Utils label
To sum up: from a clean source directory you can fully configure, build and test OGS with these 3 commands:
cmake --preset release
cmake --build --preset release
Test Data
Test data is stored in Tests/Data. Generated test output files should be found in [build-dir]/Tests/Data.
In the OGS-cli outputting to [build-dir]/Tests/Data is already handled (via the -o parameter). For other executables you have to implement this, e.g. a with parameter specifying the output directory.
In code BaseLib::BuildInfo::data_path (from BuildInfo.h) references the data source directory and BaseLib::BuildInfo::data_binary_path references the data output directory.
For adding new data files simply commit the new files as usual.
Performance tests
In order to prove the effectiveness of optimization features or to exclude performance regressions it’s good practice to implement performance tests. This can be done with pytest and the log parser from OGSTools. In order to run such tests for OGS you need a set up environment. See this page to learn how to do that.
One example performance test is the one testing an optimization in the heat transport BHE process assembly . It uses pytest’s abilities to modify environment variables and to capture the stdout and stderr streams. It might serve as a starting point for your own performance tests.
Performance tests relying on time measurements should be marked with the pytest mark performance_test (it’s a custom mark in the OGS test suite):
@pytest.mark.performance_test
def test_assembly_optimization():
    assert 1 == 0  # some meaningful test
That will ensure that this test is handled correctly in the OGS CI pipeline: a failing performance tests will usually not be a strict failure in the OGS CI pipelines, because on usual machines time measurements might be not meaningful (e.g., if multiple concurrent processes run). Therefore, in the OGS CI pipelines performance test failures will make the test suite fail only on isolated CI agents, where no other jobs run at the same time.
That means: only mark tests relying on time measurements with @pytest.mark.performance_test!
Performance test behaviour/selection
If a performance test failure is a strict failure can be controlled with the environment variable OGS_PERFORMANCE_TESTS_ALLOWED_TO_FAIL. The behaviour is as follows:
  • environment variable unset or set to false: performance test failure will be treated as a failure
  • environment variable set to true: performance test failure will be treated as an expected failure (xfail in pytest terms) and will not make the test suite fail
Hence, the default is “treat as failure”. On most CI agents the environment variable is set to true, only on “isolated” CI machines it is set to false.
That means, that on you local machine by default failing performance tests will make pytest fail. Since your local machine is probably not an isolated machine you might want to change that. Thus, either you set the environment variable as described above or you deselect performance tests entirely, e.g. (see also the pytest documentation ):
pytest -m 'not performance_test'
Notebook tests
For notebook-based tests see its dedicated page .
This article was written by Lars Bilke. If you are missing something or you find an error please reach out to us on our forum.
