Unit Testing
Introduction
Unit testing can be used for testing small pieces of functionality. We use GoogleTest as our test framework.
Running Tests
GoogleTest is already included in the OGS source code. Running tests is as simple as building the tests-target.
Writing Tests
All tests are located inside the Tests-directory in library-specific subfolders. To write a new test you simply create a new .cpp-file and use the GoogleTest macros.
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
