DEVELOPER GUIDE
Python bindings development
There are two ways to build OGS with Python bindings:
  • A regular build with OGS_USE_PIP=ON (preferred method)
    This creates a virtual environment inside your build-directory and installs test dependencies into it.
  • A wheel build
Regular build
  • Configure your build with -DOGS_USE_PIP=ON
  • Build
Advanced usage: You can also install the test dependencies by some other means (manually) and then configure without -DOGS_USE_PIP=ON.
To run the Python-based tests:
  • Source build-dir/.envrc (i.e., run source build-dir/.envrc in your terminal. This activates the virtual environment and sets OGS_USE_PATH environment variable).
  • Run e.g. pytest from inside the source directory. On Windows run Invoke-Expression build-dir/.envrc.ps1 in your PowerShell.
  • Run e.g. pytest from inside the source directory or pytest ../path/to/source/dir.
  • Alternatively you can also run the Python-based with ctest, e.g. ctest -R pytest.
If you make modifications on the C++ side you need to run make or ninja in the build directory again. If you modify Python code you need to run cmake . again in the build directory. Modifications on the Python tests are immediately available to pytest.
To get the output of a specific test:
pytest --capture=tee-sys ../../ogs/Tests/Python/test_wrapped_cli_tools.py
Wheel build (not recommend for regular use-cases)
Python wheel builds are driven by scikit-build-core which basically is a setuptools-wrapper for CMake-based projects.
The entry point is pyproject.toml in the root directory. It uses the wheel CMake preset. The preset can be overridden and even other CMake options can be passed via the environment variable CMAKE_ARGS (see also the scikit-build-core documentation ).
Requires pip >= 25.1!
You can locally develop and test with the following setup:
# Create a virtual environment inside your source directory
python3 -m venv .venv
# Activate the environment
source .venv/bin/activate
# Install (build) the local Python project
pip install -v --group dev-all
Successfully installed ogs-6.4.2.dev1207
# To build with additional CMake arguments, e.g.:
pip install -v --group dev-all --config-settings=cmake.define.OGS_BUILD_PROCESSES=SteadyStateDiffusion"
The pip install-step starts a new CMake-based OGS build in ../build/_skbuild-subdirectory (inside the source code) using the wheel-preset. When the CMake build is done it installs the wheel into the activated virtual environment and you can interact with it.
The contents of ../build/_skbuild/[platform-specific]/cmake-install will make up the wheel.
Please note that ogs.simulator is available in wheel builds only!
Testing with pytest
# Run python tests
pytest ../../ogs  # path to your ogs source code
============================================== test session starts ===============================================
platform darwin -- Python 3.10.6, pytest-7.1.3, pluggy-1.0.0
rootdir: ~/code/ogs/ogs, configfile: pyproject.toml, testpaths: Tests
collected 2 items
../../ogs/Tests/Python/test_cli.py .        [ 50%]
# Start the python interpreter
python3
>>> import ogs.mesh as mesh
>>> # The following works in a wheel build only:
>>> import ogs.simulator as sim
>>> sim.initialize(["", "--help"])
If you make modifications on the C++ side you need to run make (regular build) or pip install --group dev-all (wheel build) again. Modifications on the Python tests are immediately available to pytest.
Module structure
Python modules added in CMake via pybind11_add_module() should only contain the binding code and other (helper code) which is used by that module only! If you need helper code which is used by several modules (e.g. OGSMesh-class used in mesh- and simulator-module) it needs to be defined in a regular library and linked to the modules.
If you don’t do this you will get unresolved externals between the modules and when you try to link them together you will get runtime errors or it doesn’t link at all (at least on Windows, because of the .pyd library format).
CI
For generating the various wheels for different Python versions and platforms cibuildwheel is used.
You can test it locally with, e.g. only building for Python 3.10:
CIBW_BUILD="cp310*" uvx cibuildwheel
Please note that on Linux cibuildwheel runs the builds inside manylinux Docker containers. On other platforms the build happens with native tools. See the cibuildwheel docs for more information.
Wheels are generated in the wheelhouse/-folder.
cibuildwheel is configured in pyproject.toml:
[tool.cibuildwheel]
This article was written by Lars Bilke. If you are missing something or you find an error please reach out to us on our forum.
