Log and Debug Output
Introduction
For application output we use spdlog which is already integrated in OGS. Spdlog provides several verbosity levels which can be used with simple calls:
ERR("An error message!");
WARN("A warning message.");
INFO("An information message...");
DBUG("A debug message.");As arguments you can use the same functionality as in {fmt} —a modern formatting library:
int foo = 42;
double boo = 3.14;
WARN("Foo is {}! Current value is {:10.2g}.", foo, boo);For more information see the spdlog wiki .
On release builds the default log level is INFO, for debug builds it is
DEBUG.
The log level can be adjusted on the command line with -l <LOG_LEVEL> flag.
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
