Under the toughness-dominated regime without leak-off, the fluid viscosity dissipation is negligible compared to the energy released for fracture surface formation (Detournay et al., 2016). Therefore, in this regime, we can neglect the pressure loss within the fracture and use the Sneddon solution for crack opening (Bourdin et al., 2012, Sneddon et al., 1969) to determine the pressure and length evolution.
The work of the pressure force is as follows:
$$ \begin{equation} \mathcal{W}(R) =\frac{2 p^2 a^2}{E'}. \end{equation} $$Applying Clapeyron’s theorem, the elastic energy can be determined as
$$ \begin{equation} \mathcal{E}(R) =-\frac{\pi p^2 a^2}{E'}, \end{equation} $$and the energy release rate with respect to the crack length $a$ propagating along the initial inclination is
$$ \begin{equation} G(R) = - \frac{\partial \mathcal{E}}{\partial (2 a)} = \frac{\pi p^2 a}{E'}. \end{equation} $$Griffith's criterion (Griffith et al., 1920) states that the fracture propagates when $G=G_c$ and the critical volume for crack propagation is $V_c := \sqrt{\dfrac{4 \pi G_c a^3}{E' }}$ in a quasi-static volume control setting (the fracture propagation is always unstable with pressure control).
The evolution of the corresponding pressure and fracture length
$$ \begin{equation} p(V) = \begin{cases} \dfrac{E' V}{2 \pi a_0^2} &\text{for} V < V_c \\ \left[ \dfrac{2 E' G_c^2}{\pi V} \right] ^{\frac{1}{3}}&\text{for} V \geq V_c, \end{cases} \end{equation} $$$$ \begin{equation} a(V) = \begin{cases} a_0 & V < V_c \\ \left[ \dfrac{E' V^2}{4 \pi G_c} \right ] ^{\frac{1}{3}} & V \geq V_c. \end{cases} \end{equation} $$Based on Sneddon's solution (Sneddon et al., 1969), we verified the model with plane-strain hydraulic fracture propagation in a toughness-dominated regime. In an infinite 2D domain, the problem was solved with a line fracture $[-a_0, a_0] \times \{0\}$ ($a_0$ = 0.05). We considered a large finite domain $[-40a_0,40a_0] \times [-40a_0,40a_0]$ to account for the infinite boundaries in the closed-form solution. The effective size of an element, $h$, is $1\times10^{-2}$.
Taking advantage of the linearity of the system, the simulations were run with the dimensionless properties listed in the Table below.
| Name | Value | Symbol |
| Young’s modulus | 1 | $E$ |
| Poisson’s ratio | 0.15 | $\nu$ |
| Fracture toughness | 1 | $G_{c}$ |
| Regularization parameter | 2$h$ | $\ell_s$ |
| Length | 4 | $L$ |
| Height | 4 | $H$ |
| Initial crack length | 0.1 | $2a_0$ |
import math…
(click to toggle)
import math
import re
import time
import gmsh
import pyvista as pvpi = math.pi
plt.rcParams["text.usetex"] = TrueE = 1.0…
(click to toggle)
E = 1.0
nu = 0.15
Gc = 1.0
h = 0.01
a0 = 0.05 # half of the initial crack length
phasefield_model = "AT1" # AT1/AT2# file's name…
(click to toggle)
# file's name
prj_name = "Kregime_Propagating.prj"
meshname = "mesh_full_pf"
out_dir.mkdir(parents=True, exist_ok=True)def mesh_generation(lc, lc_fine):…
(click to toggle)
L = 4.0 # Length
H = 4.0 # Height
b = 0.4 # Length/Height of subdomain with fine mesh
gmsh.initialize()
gmsh.model.add("rectangle")
# Dimensions
dim0 = 0
dim1 = 1
dim2 = 2
# Points
# Lines
# Line loops
gmsh.model.geo.synchronize()
# Prepare structured grid
# Physical groups
P1 = gmsh.model.addPhysicalGroup(dim0, [1])
gmsh.model.setPhysicalName(dim0, P1, "P1")
P2 = gmsh.model.addPhysicalGroup(dim0, [2])
gmsh.model.setPhysicalName(dim0, P2, "P2")
gmsh.write(output_file)
gmsh.finalize()def pre_processing(h, a0):…
(click to toggle)
mesh = pv.read(f"{out_dir}/mesh_full_pf_domain.vtu")
pv.set_plot_theme("document")
if (
phase_field[node_id] = 0.0
mesh.save(f"{out_dir}/mesh_full_pf_OGS_pf_ic.vtu")pv.set_plot_theme("document")…
(click to toggle)
def Hydraulic_Fracturing_Toughness_Dominated_numerical(h, phasefield_model):
# mesh properties
ls = 2 * h
filename = f"results_h_{h:0.4f}_{phasefield_model}"
mesh_generation(0.1, h)
pv.save_meshio(f"{out_dir}/mesh_full_pf_{name}.vtu", mesh)
%cd {out_dir}
run(
"identifySubdomains -f -m mesh_full_pf_domain.vtu -- mesh_full_pf_physical_group_*.vtu",
shell=True,
check=True,
%cd -
input_file=prj_name,
MKL=True,
args=f"-o {out_dir}",
# run simulation with ogs
t0 = time.time()
run(
f"ogs {out_dir}/{prj_name} -o {out_dir} > {out_dir}/log.txt",
shell=True,
check=True,
tf = time.time()
print(">>> OGS terminated execution <<< Elapsed time: ", round(tf - t0, 2), " s.")Hydraulic_Fracturing_Toughness_Dominated_numerical(h, phasefield_model)Info : Meshing 1D...
Info : [ 0%] Meshing curve 1 (Line)
Info : [ 20%] Meshing curve 2 (Line)
Info : [ 30%] Meshing curve 3 (Line)
Info : [ 40%] Meshing curve 4 (Line)
Info : [ 60%] Meshing curve 5 (Line)
Info : [ 70%] Meshing curve 6 (Line)
Info : [ 80%] Meshing curve 7 (Line)
Info : [ 90%] Meshing curve 8 (Line)
Info : Done meshing 1D (Wall 0.000459656s, CPU 0s)
Info : Meshing 2D...
Info : [ 0%] Meshing surface 1 (Plane, Frontal-Delaunay)
Info : [ 0%] Blossom: 24032 internal 482 closed
Info : [ 0%] Blossom recombination completed (Wall 0.732655s, CPU 0.34262s): 7878 quads, 0 triangles, 0 invalid quads, 0 quads with Q < 0.1, avg Q = 0.793024, min Q = 0.371315
Info : [ 60%] Meshing surface 2 (Transfinite)
Info : Done meshing 2D (Wall 1.11612s, CPU 0.496835s)
Info : 14439 nodes 14848 elements
Info : Writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/PhaseField/Kregime_Propagating_jupyter_notebook/Kregime_Propagating_jupyter/mesh_full_pf.msh'...
Info : Done writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/PhaseField/Kregime_Propagating_jupyter_notebook/Kregime_Propagating_jupyter/mesh_full_pf.msh'
[0] info: Mesh reading time: 0.0827256 s
[0] info: MeshNodeSearcher construction time: 0.000509858 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.0981e-05 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Bottom' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00785734 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 0.00109892 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Computational_domain' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.0147933 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.26e-06 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Left' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00058183 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.6e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_P1' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00056512 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.9e-07 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_P2' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.0005677 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.12e-06 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Right' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00055169 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 4.71e-06 s
[0] info: There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Top' and it is equal to the newly computed values.
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00656588 s
[0] info: identifySubdomains time: 0.0398408 s
[0] info: writing time: 0.0710347 s
[0] info: Entire run time: -8.98848e+06 s
/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/ogs/Tests/Data/PhaseField/Kregime_Propagating_jupyter_notebook
>>> OGS terminated execution <<< Elapsed time: 815.56 s.
def Analytical_solution(phasefield_model, h):…
(click to toggle)
v = np.linspace(1e-10, 0.3, 31)
pres = np.linspace(0, 1.0, 31)
length = np.linspace(0, 1.0, 31)
ls = 2 * h
# Effective Gc and a for AT1/A2
if phasefield_model == "AT1":
Gc_ref = Gc * (3 * h / 8.0 / ls + 1.0)
Gc_ref = Gc * (h / (2.0 * ls) + 1.0)
Eprime = E / (1 - nu**2)
V_c = (4 * pi * Gc_ref * a_eff**3 / Eprime) ** 0.5
P_c = (Eprime * Gc_ref / (pi * a_eff)) ** 0.5
for i in range(len(v)):
if v[i] < V_c:
pres[i] = Eprime * v[i] / (2 * pi * a_eff**2) / P_c
length[i] = a_eff
pres[i] = (2 * Eprime * Gc_ref**2 / (pi * v[i])) ** 0.333333 / P_c
length[i] = (Eprime * v[i] ** 2 / (4 * pi * Gc_ref)) ** 0.333333
return v, pres, length, Gc_ref, P_c
fluidVolume_analytical = Analytical_solution(phasefield_model, h)[0]
pressure_analytical = Analytical_solution(phasefield_model, h)[1]
length_analytical = Analytical_solution(phasefield_model, h)[2]
Gc_ref = Analytical_solution(phasefield_model, h)[3]
P_c = Analytical_solution(phasefield_model, h)[4]In phase field approach, we can retrieve the crack length $a$ as:
$$ \begin{equation} a = \dfrac{\displaystyle \int_\Omega \frac{G_c}{4 c_n} \left(\frac{(1-v)^n}{\ell}+ \ell |\nabla v|^2\right)\,\mathrm{d} \Omega }{G_c \left( \dfrac{h}{4 c_n \ell} + 1 \right)}. \end{equation} $$where $n=1$ corresponds to $\texttt{AT}_1$ ($c_n = 2/3$) and $n=2$ to $\texttt{AT}_2$ ($c_n = 1/2$).
plt.subplots(figsize=(12, 4))…
(click to toggle)
plt.subplot(1, 2, 1)
fluid_volume = []
surface_energy = []
# Open the file for reading
with (out_dir / "log.txt").open() as fd:
# Iterate over the lines
for _i, line in enumerate(fd):
match_surface_energy = re.search(
r"""Surface energy: (\d+\.\d*) Pressure work: (\d+\.\d*) at time: (\d+\.\d*)""",
line,
if match_surface_energy:
surface_energy.append(float(match_surface_energy.group(1)))
fluid_volume.append(float(match_surface_energy.group(3)))
plt.grid(linestyle="dashed")
plt.xlabel("Volume")
plt.ylabel("Crack length")
plt.plot(fluidVolume_analytical, length_analytical, "black", label="Closed form")
plt.plot(
fluid_volume,
np.array(surface_energy[:]) / Gc_ref / 2,
"bo",
fillstyle="none",
label="Phase-field",
plt.subplot(1, 2, 2)
fluid_volume = []
pressure = []
match_pressure = re.search(
r"""Pressure: (\d+\.\d*) at time: (\d+\.\d*)""", line
if match_pressure:
fluid_volume.append(float(match_pressure.group(2)))
pressure.append(float(match_pressure.group(1)))
plt.ylabel("$p_f/p_c$")
plt.plot(fluidVolume_analytical, pressure_analytical, "black", label="Closed form")
plt.plot(
np.array(fluid_volume[:]),
np.array(pressure[:]) / P_c,
"g<",
fillstyle="none",
(click to toggle)
plt.plot(
fluidVolume_analytical[1:],
abs(length_analytical[1:] - np.array(surface_energy[:]) / (2 * Gc_ref))
/ (np.array(surface_energy[:]) / (2 * Gc_ref))
* 100,
"-.ob",
fillstyle="none",
label="Closed form",
plt.ylim([0.0, 10])
plt.ylabel(
r"$\frac{|a_\mathrm{num}-{a}_\mathrm{ana}|}{{a}_\mathrm{num}}\times 100\%$",
fontsize=14,
plt.plot(
(abs(pressure_analytical[1:] - np.array(pressure[:]) / P_c) / pressure[:]) * 100,
"-.<g",
fillstyle="none",
plt.ylim([0.0, 10])
plt.ylabel(
r"$\frac{|p_\mathrm{num}-{p}_\mathrm{ana}|}{{p}_\mathrm{num}}\times 100\%$",
fontsize=14,
In order to reduce computation time, we perform the simulation with a coarse mesh; the results for the $\texttt{AT}_1$ Model with a mesh size of $h=0.001$ are provided below.
$\texttt{AT}_1$ Model:
filename = f"results_h_{h:0.4f}_{phasefield_model}"…
(click to toggle)
reader = pv.get_reader(f"{out_dir}/" + filename + ".pvd")
plotter = pv.Plotter(shape=(1, 2), border=False)
plotter.open_gif(f"{out_dir}/Kregime_Propagating.gif")
mesh = reader.read()[0]
sargs = {
"title": "Phase field",
"title_font_size": 16,
"label_font_size": 12,
"n_labels": 5,
"position_x": 0.25,
"position_y": 0.15,
"fmt": "%.1f",
"width": 0.5,
clim = [0, 1.0]
xs = mesh.points[:, 0]
ys = mesh.points[:, 1]
plotter.clear()
plotter.add_mesh(
mesh,
scalars=pf,
show_scalar_bar=True,
colormap="coolwarm",
clim=clim,
scalar_bar_args=sargs,
lighting=False,
plotter.add_text(f"Time: {time_value:0.02f}", color="black")
plotter.view_xy()
plotter.write_frame()
plotter.close()[0m[33m2026-01-30 13:19:03.790 ( 835.880s) [ 7F6BAC047BC0]vtkXOpenGLRenderWindow.:1416 WARN| bad X server connection. DISPLAY=[0m
mesh = reader.read()[0]…
(click to toggle)
clim = [0, 1.0]
sargs = {
"n_labels": 5,
"position_x": 0.25,
"position_y": 0.0,
"fmt": "%.1f",
"width": 0.5,
plotter.add_mesh(
mesh,
scalars=pf,
show_edges=False,
clim=clim,
lighting=False,
plotter.view_xy()
plotter.camera.zoom(1.5)
plotter.window_size = [1000, 500]
plotter.show()Widget(value='<iframe src="http://localhost:46085/index.html?ui=P_0x7f6b62f8f750_31&reconnect=auto" class="pyv…
[1] Detournay, Emmanuel. Mechanics of hydraulic fractures. Annual review of fluid mechanics 48 (2016): 311-339.
[2] Bourdin, Blaise, Chukwudi Chukwudozie, and Keita Yoshioka. A variational approach to the numerical simulation of hydraulic fracturing. In SPE annual technical conference and exhibition. OnePetro, 2012.
[4] Griffith, Alan Arnold. VI. The phenomena of rupture and flow in solids. Philosophical transactions of the royal society of london. Series A, containing papers of a mathematical or physical character 221, no. 582-593 (1921): 163-198.
[5] Yoshioka, Keita, Francesco Parisio, Dmitri Naumov, Renchao Lu, Olaf Kolditz, and Thomas Nagel. Comparative verification of discrete and smeared numerical approaches for the simulation of hydraulic fracturing. GEM-International Journal on Geomathematics 10, no. 1 (2019): 1-35.
in CI job 683680
Last revision: March 3, 2023
