Permeability in EDZ
Theoretical Background
This implementation report presents the theoretical basis of the failure index dependent permeabilitymodel for the excavation damaged zone (EDZ) by taking into account HM response in rock due to excavation [2] as well as the implementation in OGS-6. The type of that permeability model in OGS-6 is PermeabilityMohrCoulombFailureIndexModel.
The failure index dependent permeability model according to [2] is defined as
$$ \mathbf{k} = \mathbf{k}_0 + H(f - 1) k_r e^{bf} \mathbf{I} \tag{1} $$
where $k_0$ is the intrinsic permeability of the undamaged material, $H$ is the Heaviside step function, $f$ is the failure index, $k_r$ is a reference permeability, $b$ is a fitting parameter. $k_r$ and $b$ can be calibrated by experimental data.
The failure index $f$ is calculated from the Mohr-Coulomb failure criterion comparing an acting shearstress. With the conventional mechanics notations, which mean that tensile stress is positive, the Mohr-Coulomb failure criterion [1] takes the form
$$ \tau_f(\sigma) = c - \sigma \tan\phi \tag{2} $$
with $\tau$ the shear strength, $c$ the cohesion, $\sigma$ the normal stress, and $\phi$ the internal friction angle. We further introduce the maximum shear stress $\tau_{\mathrm{m}}=\left(\sigma_3-\sigma_1\right) / 2$ and the mean stress $\sigma_{\mathrm{m}}=\left(\sigma_1+\sigma_3\right) / 2$, where $\sigma_1$ and $\sigma_3$ are the minimum and maximum shear stress, respectively. A second criterion is implemented similar to a tension cut-off. Let $\sigma_{\mathrm{m}}^{\max } \in(0, c / \tan \phi)$ be a limit value related (but not equivalent) to tensile strength of the material. Then, the failure index is determined by
$$ f= \begin{cases}\frac{\left|\tau_{\mathrm{m}}\right|}{\cos (\phi) \tau_{\mathrm{f}}\left(\sigma_{\mathrm{m}}\right)} & \text { if } \sigma_{\mathrm{m}} \leq \sigma_{\mathrm{m}}^{\max } \\ \max \left\{\frac{\left|\tau_{\mathrm{m}}\right|}{\cos (\phi) \tau_{\mathrm{f}}\left(\sigma_{\mathrm{m}}\right)}, \frac{\sigma_{\mathrm{m}}}{\sigma_{\mathrm{m}}^{\max }}\right\} & \text { if } \sigma_{\mathrm{m}}>\sigma_{\mathrm{m}}^{\max }\end{cases} \tag{3} $$
The computed permeability components are restricted with an upper bound, i.e. $\mathbf{k} := k_{ij} < k_{max}$
The material properties for the test example are given in Table 1.
Table 1: Material properties
Property Value Unit
Fluid
Density 1000 $\mathrm{~kg} / \mathrm{m}^3$
Fluid viscosity $10^{-3}$ Pa s
Solid
Density 2650 $\mathrm{~kg} / \mathrm{m}^3$
Porous medium
Porosity 0.15 -
Intrinsic permeability the EDZ model $\mathrm{m}^2$
Elasticity
Young’s modulus $6 \cdot 10^9$ Pa
Poisson’s ratio 0.3 -
Biot’s coefficient 0.6 -
The parameters of the EDZ permeability with the Mohr Coulumb failure index are
$$ \begin{aligned} & \mathbf{k}_0 = \{10^{-20}\} \mathbf{m}^2, \\ & k_r = 10^{-19} \mathbf{m}^2, b=3.0, c=1 \mathbf{MPa}, \phi=15^\circ, \\ & k_{\max} = 10^{-6} \mathbf{m}^2, \sigma_{\mathrm{m}}^{\max} = 0.8 \frac{c}{\tan \phi} = 2.985640646055102e6 \mathbf{MPa} \end{aligned} \tag{4} $$
This geometry of this example is a square of [0,50] $\times$ [-25,25] $m²$ with a half circle hole with a radius of 2.3 m and a center at (0,0).
The initial pore pressure is 4.7 MPa. The initial displacement and stress components are all zero.
Table 2: Boundary
Boundary Mass balance equation Momentum balance equation
Left No flux $u_x=0, \tau_y=0$
Right No flux $\tau_x=-15 \mathrm{MPa}, \tau_y=0$
Bottom No flux $u_y=0, \tau_x=0$
Top No flux $\tau_x=0, \tau_y=-12 \mathrm{MPa}$
Hole surface $p=0.1 \mathrm{MPa}$ $\tau_n=0$
# creating output path if it doesn't exist already.(click to toggle)
    input_file="quad_with_half_hole.prj", output_file="quad_with_half_hole.prj"
model.run_model(logfile=Path(out_dir) / "log.txt")
Simulation: quad_with_half_hole.prj
Execution took 0.506908655166626 s
The computed permeability is shown in Fig. 1, in which one can see that the permeability near the hole is increased with a reasonable distribution pattern. This implies that the permeability model can describe the permeability change in EDZ.
ms = MeshSeries("quad_with_half_hole.pvd").mesh(1)(click to toggle)
fig_perm, ax = plt.subplots(figsize=(8, 6))
ms.plot_contourf("permeability", fig=fig_perm, ax=ax, fontsize=15)
ax.set_title("Figure 1: Calculated permeability distribution in [m$^2$].")
plt.tight_layout()
The distributions of the horizontal stress, $\sigma_{xx}$ , and the pore pressure are illustrated in Fig. 2.
pressure = ot.variables.pressure.replace(data_name="pressure_interpolated")(click to toggle)
fig_stress, ax = plt.subplots(nrows=1, ncols=2, figsize=(20, 8))
ms.plot_contourf(ot.variables.stress["xx"], fig=fig_stress, ax=ax[0], fontsize=15)
ms.plot_contourf(pressure, fig=fig_stress, ax=ax[1], fontsize=15)
plt.suptitle(
    "Figure 2: Calculated distributions of horizontal stress (left) and pore pressure (right), in [MPa] respectively",
    fontsize=20,
plt.tight_layout()
[1] J.F. Labuz and A. Zang. Mohr–Coulomb failure criterion. Rock Mechanics and Rock Engineering,45(6):975–979, 2012.
[2] W.Q. Wang, H. Shao, Th. Nagel, and O. Kolditz. Analysis of coupled thermal-hydro-mechanical processes during small scale in-situ heater experiment in Callovo-Oxfordian clay rock introducing a failure-index permeability model. International Journal of Rock Mechanics and Mining Sciences, revised manuscript under review, 2020.
This article was written by Wenqing Wang, Dmitri Naumov, Thomas Nagel, Olaf Kolditz, Noor Hasan. If you are missing something or you find an error please let us know.
Generated with Hugo 0.147.9 in CI job 683680 | Last revision: June 11, 2020
