A test with nodal source term
The problem is solved on a rectangular domain $2m \times 1m$. Nodal fluid flux is applied on the left boundary nodes with a value of 0.001 $kg/s$ via the property of NodalSourceTerm. The pore pressure on the right boundary is equal to the initial pore pressure of $10⁵$ $Pa$. The displacement in the normal direction of all boundaries except the left one is fixed.
Property Value Unit
Fluid density $10^3$ $\mathrm{kg} / \mathrm{m}^3$
Viscosity $10^{-3}$ Pa.s
Permeability $10^{-14}$ $\mathrm{m}^2$
Young’s modulus (bulk) $2.5 \cdot 10^9$ Pa
Poisson ratio (bulk) 0.27 -
Biot coefficient 0.9 -
The time period of 86400s (1 day) is discretised into 100 steps.
# importing libraries(click to toggle)
# creating output path if it doesn't exist already.(click to toggle)
# Initiate the OGS(click to toggle)
# Initiate the OGS
    input_file="nodal_source_test.prj", output_file="nodal_source_test.prj"
# Run the simulation
model.run_model(logfile=Path(out_dir) / "log.txt")
Simulation: nodal_source_test.prj
Execution took 0.6294786930084229 s
The distributions of pressure and displacement at the end time are shown in the following figure:
# Plotting(click to toggle)
# Plotting
mesh = MeshSeries("HM_NodalSourceTem.pvd").mesh(20)
fig, (ax1, ax2) = plt.subplots(1, 2, figsize=(20, 6))
mesh.plot_contourf(
    ot.variables.pressure.replace(data_name="pressure_interpolated"),
    fig=fig,
    ax=ax1,
    fontsize=15,
mesh.plot_contourf(ot.variables.displacement, fig=fig, ax=ax2, fontsize=15)
plt.subplots_adjust(wspace=0.3)  # increase horizontal space
plt.tight_layout()
This article was written by Wenqing Wang, Noor Hasan. If you are missing something or you find an error please let us know.
Generated with Hugo 0.147.9 in CI job 683680 | Last revision: April 14, 2021
