(click to toggle)
import gmsh
(click to toggle)
if not out_dir.exists():
out_dir.mkdir(parents=True)
if not gmsh.isInitialized():
(click to toggle)
gmsh.initialize()
gmsh.model.add("Mesh")
gmsh.finalize()
Info : Meshing 1D...
Info : [ 0%] Meshing curve 1 (Circle)
Info : [ 20%] Meshing curve 2 (Circle)
Info : [ 30%] Meshing curve 3 (Line)
Info : [ 40%] Meshing curve 4 (Line)
Info : [ 50%] Meshing curve 5 (Line)
Info : [ 60%] Meshing curve 6 (Line)
Info : [ 70%] Meshing curve 7 (Line)
Info : [ 80%] Meshing curve 8 (Line)
Info : [ 90%] Meshing curve 9 (Line)
Info : [100%] Meshing curve 10 (Line)
Info : Done meshing 1D (Wall 0.00416439s, CPU 0.004895s)
Info : Meshing 2D...
Info : [ 0%] Meshing surface 1 (Transfinite)
Info : [ 40%] Meshing surface 2 (Plane, Delaunay)
Info : [ 70%] Meshing surface 3 (Plane, Delaunay)
Info : Done meshing 2D (Wall 0.00911088s, CPU 0.009226s)
Info : 1469 nodes 2051 elements
Info : Writing '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.msh'...
Info : Done writing '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.msh'
domain: 1674 cells
physical_group_arc: 19 cells
physical_group_left: 64 cells
physical_group_bottom: 64 cells
physical_group_top: 14 cells
physical_group_right: 14 cells
OGS_BIN_PATH: None .
OGS wheel: ModuleSpec(name='ogs', loader=<_frozen_importlib_external.SourceFileLoader object at 0x78ea032ceab0>, origin='/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/site-packages/ogs/__init__.py', submodule_search_locations=['/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/site-packages/ogs']) .
OGS in PATH: ['/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/bin/ogs', '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/bin/ogs'] .
Warning: Too many occurrences of 'ogs' found in PATH.
Please remove OGS from PATH.
[0] info: Reordering nodes...
[0] info: Corrected 1674 elements.
[0] info: VTU file written.
Create quadratic mesh for /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left.vtu
OGS wheel: ModuleSpec(name='ogs', loader=<_frozen_importlib_external.SourceFileLoader object at 0x78ea01d809b0>, origin='/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/site-packages/ogs/__init__.py', submodule_search_locations=['/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/site-packages/ogs']) .
[0] info: Create a quadratic order mesh
[0] info: Save the new mesh into a file
Create quadratic mesh for /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right.vtu
Create quadratic mesh for /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top.vtu
[0] info: Mesh reading time: 0.00883078 s
[0] info: MeshNodeSearcher construction time: 0.000244815 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 0.000529909 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00127344 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 5.771e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00023228 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.4017e-05 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000267008 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 1.538e-05 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.00022668 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 3.868e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000222673 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshNodes took 3.667e-06 s
[0] info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000205118 s
[0] info: identifySubdomains time: 0.00305573 s
[0] info: writing time: 0.0045911 s
[0] info: Entire run time: 1.28569 s
bulk_mesh = Path(mesh_dir, "domain.vtu")
(click to toggle)
num_parts = 3
ot.cli().partmesh("-s", "-i", bulk_mesh, "-o", mesh_dir)
ot.cli().partmesh(
"-m",
"-n",
str(num_parts),
"-i",
bulk_mesh,
"-o",
mesh_dir,
Path(mesh_dir, "left.vtu"),
Path(mesh_dir, "right.vtu"),
Path(mesh_dir, "top.vtu"),
Path(mesh_dir, "bottom.vtu"),
Path(mesh_dir, "arc.vtu"),
[0] info: Mesh 'domain' read: 4455 nodes, 1674 elements.
[0] info: Write the mesh into METIS input file.
[0] info: Total runtime: 0.00577884 s.
[0] info: Total CPU time: 0.005779 s.
[0] info: METIS is running ...
[0] info: Path to mpmetis is:
[0] info: Running: mpmetis -gtype=nodal "/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.mesh" 3
METIS 5.2.1 Copyright 1998-22, Regents of the University of Minnesota
(HEAD: unknown, Built on: Apr 23 2025, 08:49:08)
size of idx_t: 64bits, real_t: 32bits, idx_t *: 64bits
Mesh Information ------------------------------------------------------------
Name: /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain.mesh, #Elements: 1674, #Nodes: 4455, #Parts: 3
Options ---------------------------------------------------------------------
ptype=kway, objtype=cut, ctype=shem, rtype=greedy, iptype=metisrb
dbglvl=0, ufactor=1.030, minconn=NO, contig=NO, nooutput=NO
seed=-1, niter=10, ncuts=1
gtype=nodal, ncommon=1, niter=10, ncuts=1
Direct k-way Partitioning ---------------------------------------------------
- Edgecut: 519.
Timing Information ----------------------------------------------------------
I/O: 0.001 sec
Partitioning: 0.004 sec (METIS time)
Reporting: 0.000 sec
Memory Information ----------------------------------------------------------
Max memory used: 1.747 MB
rusage.ru_maxrss: 65.594 MB
proc/self/stat/VmPeak: 22.164 MB
[0] info: Partitioning the mesh in the node wise way ...
[0] info: partitionMesh(): Partition IDs per element computed in 0.000292758 s
[0] info: partitionMesh(): distribute nodes to partitions took 4.2924e-05 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 0.000313749 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 0.000250476 s
[0] info: partitionMesh(): distribute elements into partitions took 0.000140051 s
[0] info: partitionMesh(): determine / append ghost nodes took 5.9275e-05 s
[0] info: partitionMesh(): markDuplicateGhostCells took 2.445e-06 s
[0] info: Partitioning other meshes according to the main mesh partitions.
[0] info: Mesh 'left' from file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left.vtu' read: 129 nodes, 64 elements.
[0] info: partitionMesh(): Partition IDs per element computed in 4.97e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 3.647e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 7.825e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 4.198e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 6.863e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 3.968e-06 s
[0] info: partitionMesh(): markDuplicateGhostCells took 6.51e-07 s
[0] info: Mesh 'right' from file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right.vtu' read: 29 nodes, 14 elements.
[0] info: partitionMesh(): Partition IDs per element computed in 1.213e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.383e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 2.504e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.032e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 1.793e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 7.51e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 3.31e-07 s
[0] info: Mesh 'top' from file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top.vtu' read: 29 nodes, 14 elements.
[0] info: partitionMesh(): Partition IDs per element computed in 1.132e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.603e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 2.424e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.052e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 2.325e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 6.91e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 3.3e-07 s
[0] info: Mesh 'bottom' from file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom.vtu' read: 129 nodes, 64 elements.
[0] info: partitionMesh(): Partition IDs per element computed in 5.09e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 3.758e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 6.623e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 3.617e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 6.733e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 3.627e-06 s
[0] info: partitionMesh(): markDuplicateGhostCells took 6.81e-07 s
[0] info: Mesh 'arc' from file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc.vtu' read: 39 nodes, 19 elements.
[0] info: partitionMesh(): Partition IDs per element computed in 1.523e-06 s
[0] info: partitionMesh(): distribute nodes to partitions took 1.633e-06 s
[0] info: partitionMesh(): sorting [base nodes | higher order nodes] took 3.006e-06 s
[0] info: partitionMesh(): setting number of nodes and of all mesh base nodes took 1.573e-06 s
[0] info: partitionMesh(): distribute elements into partitions took 2.154e-06 s
[0] info: partitionMesh(): determine / append ghost nodes took 7.31e-07 s
[0] info: partitionMesh(): markDuplicateGhostCells took 3.1e-07 s
[0] info: Writing the partitions data into binary files took 0.00149517 s
[0] info: Total runtime: 0.0751029 s.
[0] info: Total CPU time: 0.019625 s.
0
output_prefix = "kirsch_mpi"
(click to toggle)
temporary_project = Path(out_dir, f"{output_prefix}.prj")
prj = ot.Project(
input_file="kirsch.prj",
output_file=temporary_project,
prj.replace_text(
output_prefix,
prj.write_input()
run(
f"mpirun -np {num_parts} ogs {temporary_project} -m {mesh_dir} -o {out_dir}",
shell=True,
check=True,
[0] [32minfo:[m OGS started on 2025-09-26 20:51:07+0200 with MPI. MPI processes: 3.
[0] [32minfo:[m This is OpenGeoSys-6 version 6.5.6-27-g655708b355. Log version: 2, Log level: info.
[0] [32minfo:[m Reading project file ../../../../../build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.prj.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/domain_partitioned_integration_point_properties_cfg3.bin'.
You can ignore this warning if the mesh does not contain integration_point-wise property data.
[0] [32minfo:[m [time] Reading the mesh took 0.650078 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/left_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.053277 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/right_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.263753 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/top_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.000747 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/bottom_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.012039 s.
[0] [32minfo:[m Reading corresponding part of mesh data from binary file /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc ...
[0] [33m[1mwarning:[m Could not open file '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh/arc_partitioned_integration_point_properties_cfg3.bin'.
[0] [32minfo:[m [time] Reading the mesh took 0.706781 s.
[0] [32minfo:[m readRasters ...
[0] [32minfo:[m readRasters done
[0] [32minfo:[m ConstantParameter: E
[0] [32minfo:[m ConstantParameter: nu
[0] [32minfo:[m ConstantParameter: zero
[0] [32minfo:[m ConstantParameter: initial_displacement
[0] [32minfo:[m FunctionParameter: sigma0
[0] [32minfo:[m ConstantParameter: sigma_top
[0] [32minfo:[m FunctionParameter: decay_function
[0] [32minfo:[m No source terms for process variable 'displacement' found.
[0] [32minfo:[m Threads used for ParallelVectorMatrixAssembler: 1. This is the default when OGS_ASM_THREADS environment variable is not set.
[0] [32minfo:[m SmallDeformation process initializeSubmeshOutput().
[0] [32minfo:[m Initialize processes.
[0] [32minfo:[m Time step #0 started. Time: 0. Step size: 0.
[0] [32minfo:[m [time] Output of timestep 0 took 0.247735 s.
[0] [32minfo:[m Calculate non-equilibrium initial residuum.
[0] [32minfo:[m Number of threads: 1
[0] [32minfo:[m Time step #0 took 0.5406 s.
[0] [32minfo:[m Solve processes.
[0] [32minfo:[m Time step #1 started. Time: 10000. Step size: 10000.
[0] [32minfo:[m Solving process #0 started.
[0] [32minfo:[m Iteration #1 started.
[0] [32minfo:[m [time] Assembly took 0.160246 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0230992 s.
Linear solver bcgs with bjacobi preconditioner using PRECONDITIONED
converged in 434 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 4.19647 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.1980e-02, |x|=2.1980e-02, |dx|/|x|=1.0000e+00
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.3739e-02, |x|=5.3739e-02, |dx|/|x|=1.0000e+00
[0] [32minfo:[m [time] Iteration #1 took 4.46365 s.
[0] [32minfo:[m Iteration #2 started.
[0] [32minfo:[m [time] Assembly took 0.156146 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.1511e-05 s.
converged in 40 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.178753 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.0501e-16, |x|=2.1980e-02, |dx|/|x|=1.3876e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.5173e-16, |x|=5.3739e-02, |dx|/|x|=1.7710e-14
[0] [32minfo:[m [time] Iteration #2 took 0.335545 s.
[0] [32minfo:[m [time] Solving process #0 took 4.79929 s in time step #1
[0] [32minfo:[m [time] Time step #1 took 4.81992 s.
[0] [32minfo:[m [time] Output of timestep 1 took 0.0652424 s.
[0] [32minfo:[m Time step #2 started. Time: 25000. Step size: 15000.
[0] [32minfo:[m [time] Assembly took 0.080273 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000203194 s.
converged in 451 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 2.09781 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.2971e-02, |x|=5.4951e-02, |dx|/|x|=6.0000e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=8.0608e-02, |x|=1.3435e-01, |dx|/|x|=6.0000e-01
[0] [32minfo:[m [time] Iteration #1 took 2.17892 s.
[0] [32minfo:[m [time] Assembly took 0.0926772 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.116e-05 s.
converged in 61 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.30061 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.2245e-15, |x|=5.4951e-02, |dx|/|x|=2.2283e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.1048e-15, |x|=1.3435e-01, |dx|/|x|=2.3111e-14
[0] [32minfo:[m [time] Iteration #2 took 0.393952 s.
[0] [32minfo:[m [time] Solving process #0 took 2.57295 s in time step #2
[0] [32minfo:[m [time] Time step #2 took 2.60682 s.
[0] [32minfo:[m [time] Output of timestep 2 took 0.10138 s.
[0] [32minfo:[m Time step #3 started. Time: 42280. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.124286 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000163978 s.
converged in 457 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 4.55181 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=9.2933e-02, |dx|/|x|=4.0870e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=2.2721e-01, |dx|/|x|=4.0870e-01
[0] [32minfo:[m [time] Iteration #1 took 4.72953 s.
[0] [32minfo:[m [time] Assembly took 0.316925 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0599777 s.
converged in 46 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.79344 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=6.6200e-16, |x|=9.2933e-02, |dx|/|x|=7.1234e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.9870e-16, |x|=2.2721e-01, |dx|/|x|=4.3955e-15
[0] [32minfo:[m [time] Iteration #2 took 2.17095 s.
[0] [32minfo:[m [time] Solving process #0 took 6.90058 s in time step #3
[0] [32minfo:[m [time] Time step #3 took 6.95428 s.
[0] [32minfo:[m [time] Output of timestep 3 took 0.156682 s.
[0] [32minfo:[m Time step #4 started. Time: 59560. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.140435 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000179077 s.
[0] [32minfo:[m [time] Linear solver took 3.87574 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=1.3091e-01, |dx|/|x|=2.9013e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=3.2007e-01, |dx|/|x|=2.9013e-01
[0] [32minfo:[m [time] Iteration #1 took 4.0568 s.
[0] [32minfo:[m [time] Assembly took 0.0960177 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 4.663e-05 s.
[0] [32minfo:[m [time] Linear solver took 0.258524 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=6.7960e-16, |x|=1.3091e-01, |dx|/|x|=5.1911e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.7747e-15, |x|=3.2007e-01, |dx|/|x|=5.5447e-15
[0] [32minfo:[m [time] Iteration #2 took 0.355188 s.
[0] [32minfo:[m [time] Solving process #0 took 4.41209 s in time step #4
[0] [32minfo:[m [time] Time step #4 took 4.49729 s.
[0] [32minfo:[m [time] Output of timestep 4 took 0.0476537 s.
[0] [32minfo:[m Time step #5 started. Time: 76840. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0932046 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000199527 s.
converged in 432 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 3.51688 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=1.6890e-01, |dx|/|x|=2.2488e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=4.1293e-01, |dx|/|x|=2.2488e-01
[0] [32minfo:[m [time] Iteration #1 took 3.61088 s.
[0] [32minfo:[m [time] Assembly took 0.163926 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.2352e-05 s.
converged in 51 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.356134 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=9.0814e-16, |x|=1.6890e-01, |dx|/|x|=5.3769e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.9733e-15, |x|=4.1293e-01, |dx|/|x|=4.7787e-15
[0] [32minfo:[m [time] Iteration #2 took 0.537407 s.
[0] [32minfo:[m [time] Solving process #0 took 4.14838 s in time step #5
[0] [32minfo:[m [time] Time step #5 took 4.21157 s.
[0] [32minfo:[m [time] Output of timestep 5 took 0.0934887 s.
[0] [32minfo:[m Time step #6 started. Time: 94120. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0981738 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000212142 s.
converged in 427 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 2.25875 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.0688e-01, |dx|/|x|=1.8360e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=5.0579e-01, |dx|/|x|=1.8360e-01
[0] [32minfo:[m [time] Iteration #1 took 2.35778 s.
[0] [32minfo:[m [time] Assembly took 0.107273 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.8874e-05 s.
converged in 114 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.554262 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.2432e-15, |x|=2.0688e-01, |dx|/|x|=1.5677e-14
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.5969e-15, |x|=5.0579e-01, |dx|/|x|=1.8974e-14
[0] [32minfo:[m [time] Iteration #2 took 0.667602 s.
[0] [32minfo:[m [time] Solving process #0 took 3.0255 s in time step #6
[0] [32minfo:[m [time] Time step #6 took 3.09559 s.
[0] [32minfo:[m [time] Output of timestep 6 took 0.100095 s.
[0] [32minfo:[m Time step #7 started. Time: 111400. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.144422 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000168046 s.
converged in 439 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 3.9204 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.4486e-01, |dx|/|x|=1.5512e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=5.9865e-01, |dx|/|x|=1.5512e-01
[0] [32minfo:[m [time] Iteration #1 took 4.06559 s.
[0] [32minfo:[m [time] Assembly took 0.180934 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.2904e-05 s.
converged in 202 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 4.07882 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.0308e-13, |x|=2.4486e-01, |dx|/|x|=4.2098e-13
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.7821e-13, |x|=5.9865e-01, |dx|/|x|=2.9769e-13
[0] [32minfo:[m [time] Iteration #2 took 4.26039 s.
[0] [32minfo:[m [time] Solving process #0 took 8.3261 s in time step #7
[0] [32minfo:[m [time] Time step #7 took 8.42644 s.
[0] [32minfo:[m [time] Output of timestep 7 took 0.130239 s.
[0] [32minfo:[m Time step #8 started. Time: 128680. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.236508 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0593847 s.
converged in 429 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 4.91401 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=2.8284e-01, |dx|/|x|=1.3429e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=6.9151e-01, |dx|/|x|=1.3429e-01
[0] [32minfo:[m [time] Iteration #1 took 5.21053 s.
[0] [32minfo:[m [time] Assembly took 0.165697 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.7752e-05 s.
converged in 57 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.213209 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.8563e-15, |x|=2.8284e-01, |dx|/|x|=6.5631e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.1648e-15, |x|=6.9151e-01, |dx|/|x|=3.1306e-15
[0] [32minfo:[m [time] Iteration #2 took 0.379646 s.
[0] [32minfo:[m [time] Solving process #0 took 5.59025 s in time step #8
[0] [32minfo:[m [time] Time step #8 took 5.64978 s.
[0] [32minfo:[m [time] Output of timestep 8 took 0.034654 s.
[0] [32minfo:[m Time step #9 started. Time: 145960. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0935346 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000193506 s.
converged in 421 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 3.99389 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=3.2083e-01, |dx|/|x|=1.1839e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=7.8437e-01, |dx|/|x|=1.1839e-01
[0] [32minfo:[m [time] Iteration #1 took 4.16832 s.
[0] [32minfo:[m [time] Assembly took 0.156326 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0570323 s.
converged in 83 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.800002 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.5193e-15, |x|=3.2083e-01, |dx|/|x|=7.8526e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.9836e-15, |x|=7.8437e-01, |dx|/|x|=8.9035e-15
[0] [32minfo:[m [time] Iteration #2 took 1.03727 s.
[0] [32minfo:[m [time] Solving process #0 took 5.20567 s in time step #9
[0] [32minfo:[m [time] Time step #9 took 5.26851 s.
[0] [32minfo:[m [time] Output of timestep 9 took 0.260304 s.
[0] [32minfo:[m Time step #10 started. Time: 163240. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.296419 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0829752 s.
converged in 420 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 3.66711 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.7982e-02, |x|=3.5881e-01, |dx|/|x|=1.0586e-01
[0] [32minfo:[m Convergence criterion, component 1: |dx|=9.2860e-02, |x|=8.7723e-01, |dx|/|x|=1.0586e-01
[0] [32minfo:[m [time] Iteration #1 took 4.04715 s.
[0] [32minfo:[m [time] Assembly took 0.465687 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0266885 s.
converged in 70 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.43364 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=6.3524e-16, |x|=3.5881e-01, |dx|/|x|=1.7704e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.3729e-15, |x|=8.7723e-01, |dx|/|x|=1.5650e-15
[0] [32minfo:[m [time] Iteration #2 took 1.97286 s.
[0] [32minfo:[m [time] Solving process #0 took 6.02011 s in time step #10
[0] [32minfo:[m [time] Time step #10 took 6.04735 s.
[0] [32minfo:[m [time] Output of timestep 10 took 0.0414862 s.
[0] [32minfo:[m Time step #11 started. Time: 180520. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.106977 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000184087 s.
converged in 415 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 4.27154 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.1013e-02, |x|=3.7982e-01, |dx|/|x|=5.5324e-02
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.1374e-02, |x|=9.2860e-01, |dx|/|x|=5.5324e-02
[0] [32minfo:[m [time] Iteration #1 took 4.37931 s.
[0] [32minfo:[m [time] Assembly took 0.152407 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 5.3133e-05 s.
converged in 60 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.43617 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.4751e-15, |x|=3.7982e-01, |dx|/|x|=3.8836e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.9229e-15, |x|=9.2860e-01, |dx|/|x|=2.0707e-15
[0] [32minfo:[m [time] Iteration #2 took 1.69565 s.
[0] [32minfo:[m [time] Solving process #0 took 6.09833 s in time step #11
[0] [32minfo:[m [time] Time step #11 took 6.21193 s.
[0] [32minfo:[m [time] Output of timestep 11 took 0.423539 s.
[0] [32minfo:[m Time step #12 started. Time: 197800. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.213396 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0926592 s.
converged in 56 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.17743 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.1047e-15, |x|=3.7982e-01, |dx|/|x|=2.9084e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=1.5709e-15, |x|=9.2860e-01, |dx|/|x|=1.6917e-15
[0] [32minfo:[m [time] Iteration #1 took 1.5766 s.
[0] [32minfo:[m [time] Solving process #0 took 1.57669 s in time step #12
[0] [32minfo:[m [time] Time step #12 took 1.60432 s.
[0] [32minfo:[m [time] Output of timestep 12 took 0.123574 s.
[0] [32minfo:[m Time step #13 started. Time: 215080. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.362971 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000143829 s.
converged in 27 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.930435 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.0800e-16, |x|=3.7982e-01, |dx|/|x|=5.4763e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=5.0378e-16, |x|=9.2860e-01, |dx|/|x|=5.4251e-16
[0] [32minfo:[m [time] Iteration #1 took 1.30015 s.
[0] [32minfo:[m [time] Solving process #0 took 1.30022 s in time step #13
[0] [32minfo:[m [time] Time step #13 took 1.37305 s.
[0] [32minfo:[m [time] Output of timestep 13 took 0.175346 s.
[0] [32minfo:[m Time step #14 started. Time: 232360. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.235358 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000161954 s.
[0] [32minfo:[m [time] Linear solver took 0.381266 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.4469e-16, |x|=3.7982e-01, |dx|/|x|=3.8094e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=4.7927e-16, |x|=9.2860e-01, |dx|/|x|=5.1612e-16
[0] [32minfo:[m [time] Iteration #1 took 0.684373 s.
[0] [32minfo:[m [time] Solving process #0 took 0.684481 s in time step #14
[0] [32minfo:[m [time] Time step #14 took 0.749604 s.
[0] [32minfo:[m [time] Output of timestep 14 took 0.186384 s.
[0] [32minfo:[m Time step #15 started. Time: 249640. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.0944043 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0237217 s.
converged in 17 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.209002 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.0163e-16, |x|=3.7982e-01, |dx|/|x|=2.6758e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.1761e-16, |x|=9.2860e-01, |dx|/|x|=2.3434e-16
[0] [32minfo:[m [time] Iteration #1 took 0.371367 s.
[0] [32minfo:[m [time] Solving process #0 took 0.371469 s in time step #15
[0] [32minfo:[m [time] Time step #15 took 0.451881 s.
[0] [32minfo:[m [time] Output of timestep 15 took 0.106599 s.
[0] [32minfo:[m Time step #16 started. Time: 266920. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.173752 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000433742 s.
converged in 26 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.651693 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.9557e-16, |x|=3.7982e-01, |dx|/|x|=5.1491e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=6.2263e-16, |x|=9.2860e-01, |dx|/|x|=6.7050e-16
[0] [32minfo:[m [time] Iteration #1 took 0.828108 s.
[0] [32minfo:[m [time] Solving process #0 took 0.828192 s in time step #16
[0] [32minfo:[m [time] Time step #16 took 0.913946 s.
[0] [32minfo:[m [time] Output of timestep 16 took 0.432557 s.
[0] [32minfo:[m Time step #17 started. Time: 284200. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.37014 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.223185 s.
converged in 25 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.64377 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.3199e-16, |x|=3.7982e-01, |dx|/|x|=3.4752e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.6227e-16, |x|=9.2860e-01, |dx|/|x|=3.9013e-16
[0] [32minfo:[m [time] Iteration #1 took 2.27415 s.
[0] [32minfo:[m [time] Solving process #0 took 2.27426 s in time step #17
[0] [32minfo:[m [time] Time step #17 took 2.4495 s.
[0] [32minfo:[m [time] Output of timestep 17 took 0.296914 s.
[0] [32minfo:[m Time step #18 started. Time: 301480. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.206039 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.00210351 s.
converged in 24 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.898035 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.6459e-16, |x|=3.7982e-01, |dx|/|x|=4.3335e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=3.8548e-16, |x|=9.2860e-01, |dx|/|x|=4.1512e-16
[0] [32minfo:[m [time] Iteration #1 took 1.10931 s.
[0] [32minfo:[m [time] Solving process #0 took 1.17288 s in time step #18
[0] [32minfo:[m [time] Time step #18 took 1.26649 s.
[0] [32minfo:[m [time] Output of timestep 18 took 0.161331 s.
[0] [32minfo:[m Time step #19 started. Time: 318760. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.254608 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.0308235 s.
converged in 33 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 1.34338 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=3.9237e-16, |x|=3.7982e-01, |dx|/|x|=1.0330e-15
[0] [32minfo:[m Convergence criterion, component 1: |dx|=8.7358e-16, |x|=9.2860e-01, |dx|/|x|=9.4074e-16
[0] [32minfo:[m [time] Iteration #1 took 1.62989 s.
[0] [32minfo:[m [time] Solving process #0 took 1.62996 s in time step #19
[0] [32minfo:[m [time] Time step #19 took 1.77179 s.
[0] [32minfo:[m [time] Output of timestep 19 took 0.283509 s.
[0] [32minfo:[m Time step #20 started. Time: 336040. Step size: 17280.
[0] [32minfo:[m [time] Assembly took 0.136434 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000305423 s.
converged in 30 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.51084 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=2.4859e-16, |x|=3.7982e-01, |dx|/|x|=6.5449e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=7.4545e-16, |x|=9.2860e-01, |dx|/|x|=8.0277e-16
[0] [32minfo:[m [time] Iteration #1 took 0.680723 s.
[0] [32minfo:[m [time] Solving process #0 took 0.681022 s in time step #20
[0] [32minfo:[m [time] Time step #20 took 0.759564 s.
[0] [32minfo:[m [time] Output of timestep 20 took 0.117856 s.
[0] [32minfo:[m Time step #21 started. Time: 345600. Step size: 9560.
[0] [32minfo:[m [time] Assembly took 0.165247 s.
[0] [32minfo:[m [time] Applying Dirichlet BCs took 0.000412071 s.
converged in 20 iterations (absolute convergence criterion fulfilled).
[0] [32minfo:[m [time] Linear solver took 0.425859 s.
[0] [32minfo:[m Convergence criterion, component 0: |dx|=1.1912e-16, |x|=3.7982e-01, |dx|/|x|=3.1363e-16
[0] [32minfo:[m Convergence criterion, component 1: |dx|=2.5182e-16, |x|=9.2860e-01, |dx|/|x|=2.7118e-16
[0] [32minfo:[m [time] Iteration #1 took 0.6684 s.
[0] [32minfo:[m [time] Solving process #0 took 0.668505 s in time step #21
[0] [32minfo:[m [time] Time step #21 took 0.828672 s.
[0] [32minfo:[m [time] Output of timestep 21 took 0.243622 s.
[0] [32minfo:[m The whole computation of the time stepping took 21 steps, in which
the accepted steps are 21, and the rejected steps are 0.
[0] [32minfo:[m [time] Simulation completed. It took 76.227 s.
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There are 2 unused database options. They are:
Option left: name:-m value: /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh source: command line
Option left: name:-o value: /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch source: command line
[0] [32minfo:[m OGS completed on 2025-09-26 20:52:23+0200.
CompletedProcess(args='mpirun -np 3 ogs /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.prj -m /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/Mesh -o /var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch', returncode=0)
pvd = Path(out_dir, f"{output_prefix}.pvd")
(click to toggle)
ms = ot.MeshSeries(pvd).scale(time=("s", "d"))
print(pvd)
mesh_last = ms[-1]
fig = mesh_last.plot_contourf(
figsize=(6, 4),
fontsize=8,
cmap="jet",
/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/Mechanics/ReleaseNodalForceKirsch/mpi_parallel_run_kirsch/kirsch_mpi.pvd
(click to toggle)
ot.variables.displacement["y"], figsize=(6, 4), fontsize=8, cmap="jet"
(click to toggle)
ot.variables.stress["xx"], figsize=(6, 4), fontsize=8, cmap="jet"
(click to toggle)
ot.variables.stress["yy"], figsize=(6, 4), fontsize=8, cmap="jet"
point_a = (6.5, -857.0, 0)
(click to toggle)
point_b = (70.0, -857.0, 0)
profile = ms[-1].sample_over_line(point_a, point_b, resolution=30)
xs = profile["Distance"] + 6.5
plt.plot(
xs, profile["sigma"][:, 0] * 1e-6, color="C2", label="Release nodal force (MPI)"
a = 6.5
sigma_t = -20 # MPa
sigma_x_a = np.asarray(
[0.5 * (3.0 * a * a / (r * r) - 3 * a**4 / (r**4)) * sigma_t for r in xs],
plt.plot(xs, sigma_x_a, linestyle="dotted", color="C0", label="Analytical solution")
plt.xlabel("x / m")
plt.ylabel(r"stress $\sigma_{xx}$ / MPa")
plt.legend()
plt.grid()
In the above figure, the radial stress $\sigma_r$ profiles along the $\theta = 0^\circ$ axis, obtained using the release nodal force approach, and the analytical solution, are compared.
plt.plot(
(click to toggle)
plt.plot(
xs, profile["sigma"][:, 1] * 1e-6, color="C2", label="Release nodal force (MPI)"
a = 6.5
sigma_t = -20 # MPa
sigma_y_a = np.asarray(
[0.5 * (2 + a * a / (r * r) + 3 * a**4 / (r**4)) * sigma_t for r in xs],
plt.plot(xs, sigma_y_a, linestyle="dotted", color="C0", label="Analytical solution")
plt.xlabel("x / m")
plt.ylabel(r"stress $\sigma_{yy}$ / MPa")
plt.legend()
plt.grid()
In the above two figures, the tangential stress $\sigma_{\theta}$ profiles along the $\theta = 0^\circ$ axis, obtained using the release nodal force approach, and the analytical solution, are compared.
expected_sigma = np.asarray(
(click to toggle)
[-5.94322287e05, -6.19135039e07, -1.27523478e07, 2.88857972e04],
[-7.47350139e06, -3.61722449e07, -7.09372389e06, -4.31847097e03],
[-7.02632921e06, -2.82291119e07, -4.57663234e06, -3.04634647e03],
[-5.69811254e06, -2.49548130e07, -3.19587766e06, -2.33539317e03],
[-4.52129471e06, -2.33397674e07, -2.35831864e06, -1.87907695e03],
[-3.60618350e06, -2.24352157e07, -1.81241976e06, -1.49642711e03],
[-2.90810489e06, -2.18773279e07, -1.43562983e06, -1.21999451e03],
[-2.37358359e06, -2.15068967e07, -1.16414410e06, -1.00559463e03],
[-1.95790335e06, -2.12450510e07, -9.60886316e05, -8.50316451e02],
[-1.63102314e06, -2.10507797e07, -8.04540863e05, -7.21601922e02],
[-1.36956366e06, -2.08999790e07, -6.80862806e05, -6.21075254e02],
[-1.15718662e06, -2.07782330e07, -5.80625884e05, -5.47100152e02],
[-9.83183398e05, -2.06769008e07, -4.98025268e05, -4.73813630e02],
[-8.38590438e05, -2.05896257e07, -4.28464851e05, -2.91454098e02],
[-7.18847960e05, -2.05193954e07, -3.71473022e05, -5.83689809e02],
[-6.15597155e05, -2.04493120e07, -3.19472761e05, -2.60734404e02],
[-5.26222722e05, -2.03832868e07, -2.72852858e05, -1.22193725e02],
[-4.48460991e05, -2.03225868e07, -2.31314329e05, -1.40384160e02],
[-3.81052951e05, -2.02633176e07, -1.93311164e05, 8.27105977e00],
[-3.21267935e05, -2.02058999e07, -1.58150365e05, 1.25229397e02],
[-2.68380912e05, -2.01489856e07, -1.25209966e05, -2.03819778e02],
[-2.21121750e05, -2.00919675e07, -9.39267720e04, -5.98779759e02],
[-1.79147229e05, -2.00335377e07, -6.38054888e04, 6.67763887e02],
[-1.41291420e05, -1.99727511e07, -3.42127668e04, -2.09343375e02],
[-1.07444543e05, -1.99093000e07, -5.02336097e03, -6.12146069e02],
[-7.76109665e04, -1.98407209e07, 2.45004314e04, -3.90010177e02],
[-5.18790616e04, -1.97699451e07, 5.34527661e04, -3.13328250e02],
[-3.10211876e04, -1.96869485e07, 8.46090962e04, -3.15443053e01],
[-1.35909887e04, -1.96029252e07, 1.15045144e05, 3.61051256e02],
[-4.03024845e03, -1.94999513e07, 1.48805539e05, 7.61397500e02],
computed_sigma = np.asarray(profile["sigma"])
np.testing.assert_allclose(actual=computed_sigma, desired=expected_sigma, atol=1e-10)
profile_1 = ms[1].sample_over_line(point_a, point_b, resolution=20)
expected_sigma_at_time_step1 = np.asarray(
(click to toggle)
[-3.43936509e04, -2.24255500e07, -7.37983093e05, 1.67163178e03],
[-4.35117232e05, -2.06504420e07, -3.25667756e05, -2.12390771e02],
[-3.29751883e05, -2.02867369e07, -1.84946624e05, -1.35150068e02],
[-2.33407685e05, -2.01637005e07, -1.19132466e05, -9.66888540e01],
[-1.68293107e05, -2.01086417e07, -8.30804300e04, -7.06015339e01],
[-1.24599311e05, -2.00790254e07, -6.10874003e04, -5.33395317e01],
[-9.43879134e04, -2.00608090e07, -4.65590777e04, -4.17593705e01],
[-7.28030052e04, -2.00483867e07, -3.63569215e04, -3.36367087e01],
[-5.68971874e04, -2.00391725e07, -2.88209067e04, -2.74197703e01],
[-4.50766486e04, -2.00321132e07, -2.31569574e04, -8.97500479e01],
[-3.56248353e04, -2.00260019e07, -1.84880070e04, -1.50887965e01],
[-2.81301938e04, -2.00204214e07, -1.45654912e04, 1.01901038e01],
[-2.20516754e04, -2.00152383e07, -1.11869887e04, 4.78649292e-01],
[-1.70045020e04, -2.00102692e07, -8.18211982e03, 8.83595571e00],
[-1.27963975e04, -2.00053222e07, -5.43557708e03, -3.46516064e01],
[-9.25396696e03, -2.00002131e07, -2.84010683e03, 2.65168603e01],
[-6.21785551e03, -1.99947512e07, -2.90703760e02, -3.54251197e01],
[-3.71622809e03, -1.99887338e07, 2.26497684e03, -1.92526923e01],
[-1.79520762e03, -1.99818836e07, 4.89635973e03, -1.82548063e00],
[-4.84662002e02, -1.99740677e07, 7.63428203e03, 2.14277079e01],
computed_sigma_t1 = np.asarray(profile_1["sigma"])
actual=computed_sigma_t1, desired=expected_sigma_at_time_step1, atol=1e-10
in CI job 621130
Last revision: August 27, 2025
