Build configuration
Overview
Before compiling the developer has to choose a configuration of the software. OGS comes in lots of different flavours (e.g. serial / parallelized), can be build with optional features or modules (e.g. MFront material models).
To separate source code from generated files such as compiled libraries, executables, test outputs and IDE projects we create build-directories. They can be placed arbitrarily but not inside the source code directory (so called out-of-source builds). You can have as many build-directories as you like for e.g. different configurations but they will all use one source code directory. A typically directory structure:
ogs-source-code(or simplyogs)build(has to be placed outside the source directory)releasedebug
Configure with CMake
For configuring a build the open source tool CMake
is used. CMakeLists.txt files replace traditional Makefiles or IDE project files.
We provide CMake configuration presets defined in CMakePresets.json for simple build configuration! Otherwise see Configure manually ). See the following table for commonly used presets:
Available CMake presets
| Ninja1 | Visual Studio | |
| CLI Release | release | msvc-release |
| CLI Debug | debug | msvc-debug |
| GUI Release | release-gui | msvc-release-gui |
| GUI Debug | debug-gui | msvc-debug-gui |
| PETSc Release2 | release-petsc | - |
| PETSc Debug2 | debug-petsc | - |
Configure with a preset
In the source directory run cmake with a preset:
# Usage: cmake --preset [preset-name]
cmake --preset releaseThis will create a build-directory outside the source tree (../build/release) with the default CMake options and the Release configuration.
Additionally you can pass any CMake variable or option with -DVARIABLE_NAME=VALUE (note the -D in front!) to the CMake command. You can also overwrite the generator with the -G parameter or the build-directory with the -B parameter (to see all available options just run cmake --help).
Also all the compiled files will be generated in this directory. This keeps the actual source code clean from intermediate files which are generated from the source code. Nothing inside the build directory will ever be version controlled because its contents can be regenerated anytime from the source code.
When you want to start over with a new configuration simply delete the build-directory, create a new one and reconfigure.
See this for a list of commonly used available options.
The example below shows how to create custom presets using the OGS_USE_PIP=ON
CMake-option. Enabling this option is recommended if you want to execute or develop Jupyter notebooks for more interactive benchmarks.
OGS_USE_PIP=ON requires uv
a tool that handles Python dependencies and virtual environments.
I.e., please install uv if you want to set OGS_USE_PIP=ON.
See the Jupyter page
for more info.
User-defined presets
You can also create a CMakeUserPresets.json file in the root source directory with your own presets (this file is ignored by git):
"version": 1,
"configurePresets": [
"name": "my-release",
"inherits": "release",
"cacheVariables": {
"OGS_USE_PIP": "ON"
}Windows notes
Ninja requirement: Use the Visual Studio command line
To use the Ninja build tool you need to configure in the Visual Studio command line. In the Start menu under Visual Studio 2022 you find a application link to x64 Native Tools Command Prompt for VS 2022. This starts a command line setup for Visual Studio 64-bit. Now you can use a Ninja preset:
cmake --preset releaseMulti-configuration with Visual Studio
OGS requires you to have one build directory which corresponds to one configuration. If you want to have e.g. a release and a debug build you need to create two build directories. This is nothing new to Linux / GCC user but differs to Visual Studios default behavior having just one build-folder / project with different configurations. A typical Visual Studio setup with both Release and Debug configurations would be initialized as follows:
cmake --preset msvc-release # creates ../build/msvc-release/OGS.sln
cmake --preset msvc-debug # creates ../build/msvc-debug/OGS.slnPlease also note that in Visual Studio you have to choose the correct configuration (i.e. when opening the solution-file in the release-folder you have to switch the Visual Studio configuration to Release)!
Pro Tip: Use a better terminal application
Use the Windows Terminal for a better terminal experience. It offers modern terminal features such as multiple tabs and panes.
Option: Configure manually
If you cannot use CMake presets (e.g. when your CMake installation does not support it) manually create a build directory and run CMake from within with all required parameters, e.g:
# in ogs source-directory
mkdir -p ../build/release
cd ../build/release
cmake ../../ogs -G Ninja -DCMAKE_BUILD_TYPE=ReleaseUsing a different compiler
Set the CC and CXX environment variables, e.g.:
CC=mpicc CXX=mpic++ cmake ../ogs -G Ninja -DCMAKE_BUILD_TYPE=Release -DOGS_USE_PETSC=ONUsing a python virtual environment
Additionally to
sudo apt-get install python3 python3-pip(from Set Up Prerequisites ), do
sudo apt-get install python3-venvand then you can use the -DOGS_USE_PIP=ON option:
cmake ../ogs -DOGS_USE_PIP=ON -DCMAKE_BUILD_TYPE="Release" -G NinjaOption: Configure with a visual tool
CMake comes with a graphical tool called cmake-gui. You can find it in the Windows Start Menu. First you need to set the source and build directory. Then click Configure. Now choose the generator to be used (e.g. Visual Studio 17 2022 for Visual Studio 2022). Now choose your desired configuration options by toggling the corresponding checkboxes. Click Configure again. Click Configure often enough until the Generate-button becomes visible. Pressing Generate will finally generate the project files inside the chosen build directory.
A more convenient way of running CMake on the command line is to use the ccmake tool. This is a shell tool but with some graphical user interface. If you want to use a preset configure with regular cmake first (ccmake does not support presets) and then run ccmake supplying the path to the build directory:
ccmake ../build/releaseYou are now presented the available configuration options. You can navigate in the list with the cursor keys and toggle / alter options with Enter. You may also press T to toggle (previously hidden) advanced options. Press C again until the Generate-option becomes visible. Press G to generate the project files and exit ccmake.
There is also the tool cmake-gui available (which supports presets), please see the Win-Tab for a description.
Please see the Linux instructions!
Requires the
ninja-tool. See install instructions . ↩︎ -
Requires the
pkg-config-tool. Can be installed via e.g.aptorbrew. ↩︎ ↩︎
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
