Reactive transport and retention in stochastically generated DFNs: A PorePy–OpenGeoSys Workflow
import json… (click to toggle)
import json
import platform
import ogs
import porepy as pp
from numpy.random import default_rng
from scipy.spatial import cKDTree
ot.plot.setup.show_Region_bounds = False… (click to toggle)
if not out_dir.exists():
    out_dir.mkdir(parents=True)
Protecting the environment over geological timescales requires isolating hazardous substances (e.g., radionuclides and industrial chemicals) from the biosphere. Accurate prediction of solute transport is essential for the safe design of deep geological repositories and for long-term groundwater contamination protection.
Why is solute retention critical?
Natural retention processes — matrix diffusion and sorption — serve as critical barriers that delay contaminant migration, helping to prevent their spread through the environment.
  • Matrix Diffusion: The movement of solutes from regions of high to low concentration within a solid matrix, governed by concentration gradients and diffusion coefficients.
  • Sorption: The process by which solutes are retained on or in a solid, encompassing adsorption (solutes attaching to the surface) and absorption (solutes entering the solid matrix). This process is influenced by surface chemistry, solute properties, and environmental conditions, and is quantified by the distribution coefficient.
How to study the solute retention?
Tracer tests are a primary method for investigating subsurface solute transport and retention. In these experiments, a known tracer is injected into the formation, and its concentration is monitored over time at a recovery location.
Different tracers are used to isolate transport mechanisms:
  • Nonsorbing tracers (e.g., tritiated water, bromide) reflect advective transport and matrix diffusion, providing information on physical transport mechanisms without chemical retention effects.
  • Sorption-active tracers (e.g., strontium, cesium) additionally capture chemical retention through sorption.
How to model the transport in fractured rock?
In crystalline rock formations, groundwater flow occurs primarily through discrete fracture networks (DFN), as the rock matrix itself exhibits low permeability. DFN models simulate flow and solute migration by treating fractures as discrete hydraulic features.
How to numerically model it?
To investigate solute transport and retention in fractured rocks, a DFN is generated using PorePy with stochastic fracture placement algorithms. The resulting DFN geometry is processed through OGSTools to create OpenGeoSys (OGS)-compatible input files, enabling the setup and execution of a Hydro-Component (HC) simulation for flow and solute transport, and retention in realistic fractured media.
alt text
DFN generating using Porepy
PorePy is an open-source Python library developed by the University of Bergen, designed for simulating multiphysics processes in fractured and porous media. It emphasizes discrete fracture network (DFN) modeling through a mixed-dimensional approach.
Installation
Install PorePy within the same virtual environment as OGS:
pip install porepy
For full installation instructions, see the PorePy Installation Guide.
Input data
domain_size = 100.0… (click to toggle)
domain_size = 100.0
mesh_size_boundary = 0.1 * domain_size
mesh_size_fracture = 0.05 * domain_size
mesh_size_min = 0.01 * domain_size
Domain seteup
Defines the minimum and maximum coordinates of a 3D cubic domain.
mins = np.array([0.0, 0.0, 0.0])… (click to toggle)
maxs = np.array([domain_size, domain_size, domain_size])
bounding_box = {
    "xmin": mins[0],
    "xmax": maxs[0],
    "ymin": mins[1],
    "ymax": maxs[1],
    "zmin": mins[2],
    "zmax": maxs[2],
domain = pp.Domain(bounding_box=bounding_box)
Fracture generation loop
  • The loop iterates n_fractures times, with each iteration generating a single fracture.
  • For every fracture:
    • A random center is generated within the domain by scaling a uniformly distributed random vector.
    • A random radius is selected within the radius_\text{R}ange, setting its size between the allowed minimum and maximum values.
    • Both the major axis and minor axis are set equal to the radius—while PorePy supports ellipses, we’re using circular fractures here.
    • Strike and dip angles are randomly drawn from the interval $[-\frac{\pi}{2}, \frac{\pi}{2}]$.
      • These angles define the fracture plane’s orientation (see link):
        • Strike angle: Sets the direction of the rotation axis in the horizontal plane, measured from the x-axis.
        • Dip angle: Describes the tilt of the fracture plane from the horizontal.
use_saved_fractures = True… (click to toggle)
fracture_params_file = Path("fracture_params.json")
fracture_params_path = Path(out_dir, "fracture_params.json")
radius_range = np.array([50, 80])
n_fractures = 10
# borehole
borehole_height = 60
borehole_radius = maxs[0] * 0.005  # radius in x/y
z_center = maxs[2]
y_center = 0.5 * (mins[1] + maxs[1])
x_left = 0.2 * maxs[0]
x_right = 0.8 * maxs[0]
fractures = []… (click to toggle)
fractures = []
if use_saved_fractures and fracture_params_file.exists():
    fracture_params = json.loads(fracture_params_file.read_text())
    print("Loaded existing fracture parameters.")
    rng = default_rng(12345)
    fracture_params = []
    for _ in range(n_fractures):
        center = rng.random(3) * (maxs - mins) + mins
        radius = rng.random() * (radius_range[1] - radius_range[0]) + radius_range[0]
        major_axis = minor_axis = radius
        major_axis_angle = rng.uniform(0, 2 * np.pi)
        strike_angle = rng.uniform(-0.5 * np.pi, 0.5 * np.pi)
        dip_angle = rng.uniform(-0.5 * np.pi, 0.5 * np.pi)
        fracture_params.append(
                "center": center.tolist(),
                "major_axis": major_axis,
                "minor_axis": minor_axis,
                "major_axis_angle": major_axis_angle,
                "strike_angle": strike_angle,
                "dip_angle": dip_angle,
    fracture_params_file.write_text(json.dumps(fracture_params, indent=4))
    print("New fracture parameters generated and saved explicitly.")
for p in fracture_params:
    frac = pp.create_elliptic_fracture(
        center=np.array(p["center"]),
        major_axis=p["major_axis"],
        minor_axis=p["minor_axis"],
        major_axis_angle=p["major_axis_angle"],
        strike_angle=p["strike_angle"],
        dip_angle=p["dip_angle"],
    fractures.append(frac)
#  vertical boreholes as long, thin fractures
center_left = np.array([x_left, y_center, z_center])
borehole_left = pp.create_elliptic_fracture(
    center=center_left,
    major_axis=borehole_height,
    minor_axis=borehole_radius,
    major_axis_angle=np.pi / 2,
    strike_angle=0.0,
    dip_angle=-0.5 * np.pi,
fractures.append(borehole_left)
center_right = np.array([x_right, y_center, z_center])
borehole_right = pp.create_elliptic_fracture(
    center=center_right,
    strike_angle=0.0,
fractures.append(borehole_right)
Fracture network generation
Once all fractures are generated, they’re passed as a list to create_fracture_network(), along with the domain’s bounding box. This creates a 3D Fracture Network object, representing the full 3D fracture system. The object takes care of intersection detection, applies the orientation from strike/dip angles, and prepares the geometry for meshing and simulation (see FractureNetwork3d documentation).
The system consists of two vertical fractures representing inlet and outlet boreholes, modeled as long, thin elliptic fractures. The minor axis is set to a small value (borehole_Radius = maxs[0] * 0.005) to reflect the narrow borehole dimensions.
  1. Left Borehole: Located at [x_Left, y_Center, zmax], with a major axis of borehole_height and a minor axis of borehole_Radius, oriented vertically (major_axis_angle =$\frac{\pi}{2}$, dip_angle =$\frac{\pi}{2}$).
  2. Right Borehole: Located at [x_Right, y_Center, zmax], with identical dimensions and orientation as the left borehole.
Both fractures are added to the fractures list.
network = pp.create_fracture_network(fractures=fractures, domain=domain)
Meshing the fracture network
We generate the computational mesh using PorePy’s mixed-dimensional approach:
  • cell_size_boundary: maximum cell size near the domain boundaries.
  • cell_size_fracture: target cell size along the fracture surfaces.
  • cell_size_min: minimum allowed cell size anywhere in the mesh.
  • simplex: enables triangular (2D) or tetrahedral (3D) elements.
This produces a mixed-dimensional grid (mdg) with 3D rock matrix cells, 2D fracture surfaces, and lower-dimensional intersections.
For fracture-only simulations, the 3D matrix is removed, leaving just the 2D fractures and their intersections.
mesh_args = {… (click to toggle)
mesh_args = {
    "cell_size_boundary": mesh_size_boundary,
    "cell_size_fracture": mesh_size_fracture,
    "cell_size_min": mesh_size_min,
    "export": True,
    "filename": "mdg2d",
    # "folder_name": out_dir,
mdg = pp.create_mdg("simplex", mesh_args, network)
# --- Remove the 3D matrix cells to keep only fractures + intersections ---
mdg2d = mdg.copy()
for sd in list(mdg2d.subdomains()):
    if sd.dim == 3:
        mdg2d.remove_subdomain(sd)
# --- Clean up empty 1D subdomains & interfaces (avoid IndexError on export) ---
for g in list(mdg2d.subdomains(dim=1)):
    cn = g.cell_nodes()
    if g.num_cells == 0 or cn.indices.size == 0 or cn.indptr.size <= 1:
        mdg2d.remove_subdomain(g)
Export the mesh to VTU format
Creates a VTK file of the 2D mixed-dimensional grid (mdg2d) using Exporter (see link). The output is compatible with visualization tools like ParaView, and serves as input for OpenGeoSys.
exporter = pp.Exporter(mdg2d, "mixed_dimensional_grid", folder_name=out_dir).write_vtu()
OpenGeosys
Preparing the mesh (.vtu) for OpenGeosys simulation
We generate s clean, standardized .vtu mesh containing only MaterialIDs as cell data — fully tailored for OpenGeoSys simulations in fractured media.
  • Loads the .vtu file into a mesh object for processing.
  • If MaterialIDs are missing, they’re generated from subdomain_id, starting at 0 — OGS uses them to identify physical regions.
  • Removes all other cell and point data, keeping only what’s necessary for OGS.
  • Saves the meshes ready for use in an OGS .prj setup.
DFN_2D = ot.Mesh(f"{out_dir}/mixed_dimensional_grid_2.vtu")… (click to toggle)
if "MaterialIDs" not in DFN_2D.cell_data:
    DFN_2D["MaterialIDs"] = (
        DFN_2D["subdomain_id"] - DFN_2D["subdomain_id"].min()
    ).astype(np.int32)
DFN_2D.save(f"{out_dir}/mixed_dimensional_grid_2.vtu")
    ).astype(np.int32)
for key in list(DFN_2D.cell_data):
    if key != "MaterialIDs":
        DFN_2D.cell_data.remove(key)
for key in list(DFN_2D.point_data):
    DFN_2D.point_data.remove(key)
orig_dir = Path.cwd()… (click to toggle)
%cd {out_dir}
# remove duplicated nodes using PyVista
mesh_c = pv.read("mixed_dimensional_grid_2.vtu")
clean_mesh = mesh_c.clean(tolerance=1e-12)
clean_mesh.save("mixed_dimensional_grid_2.vtu")
print(f"Original points: {mesh_c.n_points}, Cleaned points: {clean_mesh.n_points}")
/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-all/Tests/Data/Parabolic/ComponentTransport/DFN_PorePy/DFNbyPorePy_to_OGS
Original points: 12110, Cleaned points: 10340
ogs.cli.reviseMesh(i="mixed_dimensional_grid_2.vtu", o="temp.vtu")… (click to toggle)
ogs.cli.NodeReordering(
    i="mixed_dimensional_grid_2.vtu", o="mixed_dimensional_grid_2.vtu"
ogs.cli.checkMesh("mixed_dimensional_grid_2.vtu", v=True)
info: Mesh read: 10340 nodes, 20662 elements.
info: Simplifying the mesh...
warning: Property MaterialIDs exists but does not have the requested mesh item type node.
warning: Property MaterialIDs exists but does not have the requested type f.
warning: Property MaterialIDs exists but does not have the requested type d.
warning: Property PointMergeMap exists but does not have the requested type i.
warning: Property PointMergeMap exists but does not have the requested type f.
warning: Property PointMergeMap exists but does not have the requested type d.
warning: PropertyVector PointMergeMap not being converted.
info: Revised mesh: 10340 nodes, 20662 elements.
info: Reordering nodes...
info: Corrected 0 elements.
info: VTU file written.
info: Memory size: 4 MiB
info: Time for reading: 0.0232304 s
info: Axis aligned bounding box: 	x [-1.77636e-15, 100) (extent 100)
	y [0, 100) (extent 100)
	z [0, 100) (extent 100)
info: Min/max edge lengths: [0.0336252, 6.85976]
info: 	Triangles: 20662
info: Mesh Quality Control:
info: 10360 elements found with wrong node order.
ElementIDs: 0, 2, 5, 6, 8, 9, 13, 14, 15, 17, 18, 20, 22, 24, 26, 27, 28, 30, 33, 35, 37, 39, 41, 42, 43, 45, 47, 50, 51, 53, 57, 59, 62, 63, 66, 67, 70, 72, 73, 77, 80, 83, 85, 86, 88, 92, 95, 97, 98, 100, 101, 104, 105, 107, 109, 110, 113, 115, 117, 119, 120, 124, 128, 132, 138, 142, 146, 151, 152, 154, 155, 156, 158, 159, 160, 161, 162, 164, 166, 167, 168, 170, 171, 178, 181, 185, 188, 193, 196, 198, 200, 202, 203, 204, 206, 208, 212, 214, 216, 220, 223, 226, 230, 232, 235, 237, 245, 249, 253, 257, 261, 267, 269, 273, 276, 277, 278, 279, 281, 282, 283, 284, 286, 287, 288, 291, 292, 293, 295, 296, 297, 299, 301, 303, 304, 307, 309, 311, 313, 315, 317, 319, 321, 322, 325, 326, 328, 330, 331, 333, 335, 337, 339, 343, 346, 347, 349, 351, 354, 355, 359, 360, 363, 366, 367, 369, 370, 372, 373, 375, 377, 380, 384, 386, 387, 389, 391, 392, 395, 398, 401, 402, 405, 406, 409, 410, 412, 413, 417, 420, 424, 428, 431, 433, 434, 435, 436, 437, 439, 440, 441, 444, 446, 449, 451, 454, 456, 459, 461, 464, 465, 467, 469, 471, 472, 473, 475, 478, 480, 481, 483, 486, 488, 490, 493, 495, 497, 501, 505, 508, 510, 511, 512, 513, 515, 516, 517, 519, 520, 521, 523, 525, 527, 528, 530, 532, 534, 536, 539, 541, 542, 544, 547, 548, 550, 552, 553, 556, 558, 559, 560, 562, 564, 566, 568, 570, 571, 572, 573, 576, 580, 582, 585, 586, 588, 589, 592, 593, 596, 597, 598, 599, 601, 603, 608, 609, 612, 613, 615, 616, 617, 620, 621, 625, 628, 629, 631, 634, 635, 637, 638, 639, 641, 642, 643, 647, 649, 651, 653, 655, 657, 658, 659, 660, 662, 664, 666, 668, 671, 673, 675, 676, 678, 680, 681, 682, 683, 685, 686, 688, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 702, 703, 705, 713, 715, 716, 719, 721, 722, 727, 728, 730, 731, 732, 736, 737, 738, 741, 742, 743, 747, 748, 749, 750, 753, 757, 758, 760, 761, 762, 764, 769, 770, 771, 772, 775, 778, 779, 784, 785, 786, 787, 789, 790, 791, 796, 797, 798, 800, 803, 805, 806, 807, 808, 812, 813, 818, 819, 820, 822, 823, 829, 830, 831, 832, 836, 841, 843, 844, 845, 846, 847, 849, 852, 854, 856, 857, 858, 861, 863, 865, 866, 867, 868, 871, 872, 878, 879, 880, 885, 886, 887, 891, 894, 895, 896, 897, 898, 899, 901, 902, 906, 907, 908, 912, 914, 915, 916, 917, 919, 920, 926, 930, 934, 935, 937, 939, 943, 944, 946, 947, 948, 950, 952, 956, 959, 960, 961, 963, 964, 965, 968, 969, 970, 972, 973, 974, 977, 978, 979, 980, 985, 986, 987, 990, 991, 992, 997, 998, 999, 1002, 1003, 1004, 1009, 1010, 1011, 1014, 1015, 1016, 1017, 1021, 1022, 1027, 1028, 1032, 1033, 1034, 1035, 1037, 1038, 1043, 1044, 1045, 1046, 1048, 1049, 1050, 1051, 1053, 1054, 1058, 1059, 1061, 1062, 1063, 1065, 1067, 1071, 1072, 1073, 1074, 1075, 1080, 1081, 1086, 1087, 1088, 1091, 1092, 1093, 1098, 1099, 1103, 1104, 1105, 1106, 1110, 1111, 1115, 1116, 1117, 1118, 1122, 1123, 1124, 1127, 1133, 1134, 1135, 1136, 1141, 1143, 1145, 1147, 1148, 1149, 1150, 1151, 1152, 1153, 1156, 1160, 1163, 1165, 1166, 1169, 1170, 1171, 1175, 1176, 1177, 1181, 1182, 1183, 1186, 1187, 1189, 1191, 1193, 1196, 1197, 1198, 1202, 1203, 1204, 1205, 1206, 1208, 1209, 1210, 1215, 1216, 1217, 1218, 1219, 1220, 1221, 1226, 1227, 1228, 1233, 1235, 1236, 1237, 1238, 1239, 1240, 1245, 1248, 1256, 1258, 1259, 1260, 1261, 1262, 1263, 1264, 1267, 1277, 1278, 1279, 1280, 1281, 1283, 1286, 1287, 1288, 1291, 1292, 1293, 1297, 1298, 1299, 1300, 1301, 1303, 1304, 1305, 1306, 1307, 1308, 1312, 1313, 1317, 1318, 1319, 1320, 1327, 1334, 1335, 1339, 1340, 1342, 1343, 1344, 1350, 1351, 1353, 1354, 1356, 1357, 1359, 1362, 1364, 1367, 1371, 1375, 1376, 1377, 1378, 1383, 1384, 1386, 1387, 1391, 1392, 1393, 1394, 1395, 1397, 1398, 1403, 1404, 1405, 1409, 1410, 1411, 1412, 1413, 1415, 1416, 1420, 1424, 1425, 1426, 1427, 1428, 1430, 1436, 1437, 1438, 1441, 1442, 1443, 1448, 1449, 1450, 1451, 1453, 1454, 1461, 1462, 1463, 1466, 1467, 1468, 1473, 1474, 1475, 1477, 1478, 1482, 1483, 1484, 1487, 1488, 1489, 1490, 1494, 1495, 1496, 1497, 1501, 1504, 1506, 1511, 1512, 1515, 1516, 1517, 1518, 1521, 1522, 1527, 1528, 1529, 1530, 1535, 1537, 1538, 1540, 1541, 1545, 1547, 1548, 1554, 1555, 1558, 1559, 1560, 1561, 1562, 1563, 1565, 1566, 1570, 1571, 1572, 1577, 1578, 1582, 1583, 1584, 1585, 1588, 1589, 1590, 1595, 1597, 1598, 1603, 1604, 1607, 1608, 1611, 1612, 1613, 1617, 1618, 1619, 1622, 1623, 1624, 1625, 1629, 1630, 1635, 1636, 1637, 1638, 1641, 1645, 1647, 1648, 1649, 1650, 1652, 1657, 1658, 1660, 1661, 1662, 1667, 1669, 1670, 1672, 1673, 1674, 1678, 1679, 1680, 1681, 1682, 1685, 1687, 1692, 1694, 1695, 1696, 1697, 1703, 1704, 1705, 1709, 1710, 1715, 1716, 1717, 1718, 1720, 1725, 1726, 1727, 1728, 1729, 1730, 1736, 1737, 1738, 1739, 1743, 1744, 1745, 1746, 1748, 1749, 1750, 1755, 1756, 1757, 1758, 1764, 1765, 1766, 1767, 1771, 1772, 1777, 1778, 1779, 1782, 1786, 1787, 1788, 1789, 1790, 1791, 1793, 1794, 1796, 1801, 1802, 1803, 1805, 1808, 1809, 1813, 1814, 1816, 1819, 1821, 1823, 1824, 1828, 1829, 1833, 1834, 1835, 1836, 1841, 1842, 1843, 1845, 1848, 1852, 1854, 1856, 1859, 1860, 1863, 1865, 1869, 1871, 1874, 1877, 1878, 1880, 1881, 1882, 1887, 1888, 1891, 1894, 1899, 1900, 1901, 1903, 1904, 1905, 1906, 1909, 1910, 1913, 1916, 1918, 1921, 1924, 1926, 1928, 1929, 1934, 1935, 1937, 1939, 1941, 1944, 1947, 1950, 1951, 1952, 1953, 1955, 1960, 1961, 1965, 1966, 1968, 1969, 1972, 1974, 1976, 1978, 1979, 1982, 1984, 1985, 1987, 1990, 1992, 1993, 1997, 2002, 2003, 2004, 2005, 2006, 2007, 2009, 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2020, 2022, 2025, 2026, 2027, 2028, 2029, 2030, 2032, 2033, 2035, 2036, 2037, 2039, 2040, 2043, 2045, 2046, 2049, 2050, 2052, 2059, 2060, 2061, 2062, 2064, 2065, 2071, 2072, 2079, 2080, 2082, 2085, 2090, 2092, 2094, 2095, 2100, 2102, 2106, 2110, 2112, 2114, 2116, 2118, 2120, 2122, 2125, 2128, 2130, 2133, 2135, 2136, 2143, 2145, 2147, 2148, 2149, 2150, 2152, 2155, 2157, 2158, 2159, 2162, 2164, 2166, 2169, 2171, 2173, 2174, 2176, 2177, 2180, 2181, 2182, 2183, 2185, 2190, 2191, 2193, 2194, 2197, 2198, 2199, 2202, 2203, 2204, 2206, 2207, 2208, 2212, 2215, 2216, 2217, 2220, 2221, 2223, 2227, 2228, 2229, 2231, 2232, 2233, 2234, 2235, 2239, 2240, 2241, 2242, 2243, 2246, 2249, 2250, 2251, 2252, 2254, 2258, 2264, 2267, 2268, 2270, 2272, 2273, 2274, 2275, 2276, 2277, 2279, 2284, 2286, 2287, 2288, 2289, 2290, 2294, 2295, 2296, 2298, 2300, 2301, 2305, 2306, 2307, 2308, 2311, 2315, 2317, 2319, 2320, 2324, 2325, 2326, 2327, 2329, 2332, 2334, 2337, 2338, 2339, 2340, 2343, 2344, 2347, 2349, 2352, 2356, 2359, 2360, 2361, 2363, 2364, 2367, 2368, 2371, 2373, 2375, 2379, 2380, 2381, 2384, 2388, 2389, 2393, 2394, 2396, 2397, 2399, 2402, 2405, 2406, 2408, 2409, 2413, 2414, 2417, 2418, 2420, 2422, 2425, 2427, 2428, 2429, 2433, 2436, 2437, 2438, 2440, 2443, 2445, 2446, 2447, 2449, 2451, 2453, 2457, 2458, 2462, 2468, 2472, 2474, 2475, 2476, 2480, 2483, 2485, 2486, 2487, 2489, 2491, 2493, 2495, 2497, 2498, 2500, 2502, 2503, 2505, 2506, 2508, 2509, 2511, 2513, 2514, 2516, 2517, 2524, 2528, 2530, 2534, 2535, 2541, 2545, 2547, 2551, 2553, 2557, 2561, 2562, 2563, 2565, 2567, 2568, 2569, 2570, 2571, 2573, 2574, 2576, 2580, 2582, 2586, 2588, 2592, 2594, 2598, 2604, 2608, 2613, 2616, 2618, 2619, 2620, 2621, 2622, 2624, 2625, 2626, 2628, 2629, 2633, 2636, 2638, 2639, 2644, 2645, 2648, 2649, 2650, 2651, 2653, 2654, 2656, 2659, 2661, 2662, 2663, 2666, 2667, 2668, 2670, 2672, 2674, 2675, 2676, 2678, 2681, 2682, 2685, 2687, 2688, 2689, 2690, 2692, 2695, 2697, 2698, 2700, 2702, 2703, 2705, 2707, 2709, 2710, 2711, 2714, 2716, 2718, 2720, 2722, 2723, 2724, 2726, 2727, 2728, 2732, 2734, 2736, 2738, 2739, 2741, 2743, 2745, 2747, 2749, 2751, 2753, 2755, 2756, 2757, 2759, 2763, 2767, 2769, 2773, 2779, 2781, 2783, 2785, 2787, 2788, 2790, 2793, 2796, 2800, 2802, 2804, 2805, 2806, 2807, 2809, 2811, 2813, 2814, 2815, 2817, 2819, 2820, 2824, 2826, 2827, 2828, 2830, 2831, 2833, 2837, 2839, 2840, 2841, 2843, 2844, 2845, 2848, 2850, 2854, 2855, 2857, 2859, 2861, 2862, 2865, 2867, 2868, 2871, 2873, 2875, 2877, 2878, 2879, 2881, 2882, 2884, 2885, 2886, 2887, 2889, 2890, 2892, 2894, 2895, 2896, 2898, 2900, 2903, 2906, 2908, 2912, 2914, 2917, 2919, 2921, 2923, 2924, 2925, 2928, 2930, 2934, 2935, 2938, 2940, 2941, 2943, 2944, 2945, 2948, 2949, 2952, 2955, 2959, 2960, 2962, 2966, 2968, 2969, 2971, 2975, 2978, 2979, 2980, 2982, 2984, 2987, 2989, 2991, 2993, 2995, 2998, 3004, 3007, 3009, 3010, 3011, 3016, 3017, 3020, 3021, 3023, 3026, 3028, 3029, 3030, 3032, 3034, 3035, 3039, 3041, 3042, 3045, 3050, 3053, 3054, 3058, 3061, 3067, 3069, 3070, 3071, 3072, 3079, 3081, 3083, 3084, 3085, 3088, 3093, 3094, 3095, 3096, 3102, 3103, 3104, 3107, 3111, 3112, 3113, 3114, 3115, 3120, 3121, 3122, 3123, 3126, 3127, 3130, 3131, 3136, 3141, 3142, 3143, 3144, 3145, 3146, 3148, 3149, 3154, 3155, 3162, 3164, 3165, 3166, 3167, 3172, 3173, 3174, 3175, 3176, 3180, 3181, 3182, 3183, 3184, 3185, 3186, 3187, 3192, 3193, 3197, 3198, 3199, 3205, 3211, 3213, 3214, 3217, 3218, 3219, 3223, 3224, 3226, 3227, 3232, 3233, 3234, 3237, 3240, 3241, 3242, 3243, 3247, 3250, 3251, 3252, 3254, 3259, 3261, 3263, 3264, 3265, 3270, 3272, 3273, 3274, 3275, 3276, 3277, 3280, 3284, 3285, 3286, 3287, 3288, 3293, 3294, 3296, 3297, 3299, 3306, 3307, 3308, 3309, 3310, 3311, 3316, 3317, 3318, 3320, 3323, 3325, 3329, 3330, 3331, 3334, 3335, 3336, 3341, 3342, 3344, 3346, 3351, 3355, 3356, 3358, 3360, 3361, 3364, 3366, 3367, 3368, 3371, 3374, 3375, 3377, 3378, 3379, 3380, 3382, 3383, 3385, 3386, 3389, 3390, 3391, 3392, 3393, 3396, 3397, 3398, 3400, 3402, 3403, 3404, 3406, 3412, 3413, 3416, 3417, 3418, 3419, 3423, 3426, 3427, 3429, 3431, 3432, 3433, 3435, 3436, 3438, 3439, 3440, 3442, 3445, 3447, 3448, 3450, 3451, 3452, 3458, 3459, 3460, 3461, 3465, 3466, 3469, 3470, 3471, 3478, 3479, 3480, 3481, 3483, 3484, 3485, 3486, 3492, 3493, 3494, 3495, 3499, 3500, 3501, 3505, 3506, 3507, 3508, 3511, 3512, 3513, 3514, 3515, 3517, 3518, 3520, 3522, 3523, 3524, 3526, 3527, 3530, 3532, 3534, 3535, 3537, 3540, 3544, 3545, 3546, 3548, 3550, 3554, 3555, 3557, 3558, 3560, 3563, 3564, 3566, 3567, 3569, 3570, 3573, 3574, 3577, 3580, 3585, 3588, 3590, 3591, 3594, 3595, 3597, 3599, 3600, 3601, 3602, 3603, 3611, 3614, 3617, 3618, 3621, 3622, 3628, 3629, 3630, 3631, 3632, 3633, 3634, 3638, 3639, 3644, 3645, 3646, 3649, 3650, 3651, 3656, 3657, 3658, 3660, 3661, 3665, 3666, 3668, 3669, 3670, 3673, 3674, 3676, 3681, 3682, 3683, 3684, 3685, 3686, 3687, 3692, 3693, 3694, 3697, 3699, 3701, 3702, 3705, 3709, 3710, 3711, 3716, 3717, 3721, 3722, 3723, 3724, 3725, 3726, 3727, 3728, 3733, 3734, 3735, 3739, 3741, 3743, 3745, 3746, 3747, 3748, 3750, 3751, 3755, 3756, 3757, 3760, 3761, 3762, 3767, 3768, 3769, 3771, 3773, 3774, 3779, 3780, 3781, 3785, 3786, 3787, 3788, 3789, 3792, 3793, 3798, 3799, 3805, 3806, 3808, 3818, 3819, 3820, 3822, 3824, 3825, 3826, 3827, 3829, 3830, 3831, 3832, 3833, 3834, 3835, 3836, 3837, 3838, 3839, 3842, 3843, 3844, 3850, 3852, 3855, 3858, 3859, 3860, 3862, 3863, 3866, 3869, 3873, 3877, 3878, 3880, 3881, 3886, 3887, 3895, 3896, 3901, 3903, 3904, 3907, 3908, 3913, 3914, 3917, 3918, 3920, 3921, 3923, 3924, 3928, 3930, 3931, 3934, 3935, 3938, 3942, 3945, 3946, 3948, 3951, 3953, 3955, 3956, 3957, 3958, 3963, 3964, 3965, 3969, 3970, 3971, 3972, 3975, 3977, 3978, 3979, 3980, 3981, 3982, 3986, 3987, 3988, 3989, 3992, 3994, 3995, 3997, 3998, 3999, 4002, 4003, 4007, 4010, 4011, 4013, 4014, 4017, 4021, 4022, 4026, 4027, 4028, 4035, 4036, 4038, 4040, 4042, 4046, 4047, 4048, 4049, 4051, 4053, 4055, 4057, 4061, 4063, 4067, 4068, 4069, 4071, 4076, 4077, 4079, 4081, 4083, 4085, 4086, 4088, 4089, 4090, 4091, 4092, 4093, 4095, 4096, 4097, 4098, 4101, 4103, 4105, 4106, 4108, 4110, 4111, 4112, 4117, 4118, 4119, 4120, 4122, 4125, 4128, 4129, 4130, 4132, 4136, 4138, 4140, 4142, 4143, 4144, 4145, 4148, 4149, 4151, 4154, 4155, 4158, 4159, 4162, 4163, 4165, 4168, 4170, 4172, 4173, 4174, 4176, 4178, 4182, 4183, 4184, 4185, 4187, 4191, 4195, 4199, 4201, 4202, 4204, 4205, 4207, 4209, 4210, 4212, 4214, 4216, 4218, 4219, 4221, 4225, 4227, 4228, 4232, 4234, 4235, 4237, 4238, 4239, 4240, 4242, 4243, 4245, 4247, 4250, 4251, 4253, 4257, 4259, 4260, 4262, 4263, 4268, 4270, 4272, 4274, 4276, 4279, 4280, 4282, 4284, 4286, 4288, 4294, 4298, 4302, 4306, 4309, 4313, 4317, 4319, 4320, 4321, 4322, 4323, 4324, 4326, 4327, 4328, 4330, 4332, 4338, 4340, 4341, 4345, 4346, 4347, 4349, 4350, 4352, 4353, 4354, 4355, 4356, 4357, 4359, 4360, 4361, 4362, 4365, 4368, 4369, 4370, 4371, 4372, 4374, 4376, 4380, 4383, 4390, 4394, 4396, 4400, 4401, 4402, 4406, 4409, 4410, 4412, 4415, 4417, 4419, 4420, 4422, 4424, 4425, 4426, 4428, 4429, 4430, 4432, 4435, 4436, 4437, 4439, 4442, 4444, 4447, 4450, 4452, 4454, 4455, 4456, 4458, 4459, 4461, 4463, 4464, 4465, 4466, 4468, 4469, 4470, 4472, 4474, 4476, 4477, 4479, 4480, 4483, 4485, 4488, 4490, 4491, 4493, 4494, 4495, 4498, 4505, 4506, 4507, 4509, 4512, 4513, 4517, 4518, 4520, 4522, 4525, 4526, 4528, 4529, 4531, 4533, 4534, 4536, 4537, 4540, 4541, 4542, 4543, 4545, 4548, 4551, 4552, 4553, 4555, 4556, 4558, 4559, 4561, 4563, 4571, 4572, 4577, 4578, 4580, 4581, 4584, 4585, 4586, 4588, 4589, 4591, 4594, 4596, 4598, 4603, 4604, 4606, 4608, 4610, 4612, 4615, 4617, 4619, 4622, 4624, 4626, 4629, 4631, 4633, 4635, 4637, 4640, 4642, 4644, 4646, 4649, 4651, 4654, 4656, 4658, 4660, 4661, 4663, 4665, 4668, 4669, 4671, 4673, 4676, 4677, 4682, 4684, 4685, 4687, 4689, 4692, 4694, 4698, 4700, 4701, 4703, 4706, 4708, 4709, 4711, 4714, 4716, 4718, 4719, 4720, 4722, 4723, 4725, 4727, 4728, 4730, 4732, 4734, 4738, 4740, 4742, 4746, 4754, 4755, 4758, 4759, 4762, 4764, 4767, 4769, 4770, 4771, 4773, 4775, 4777, 4778, 4781, 4784, 4785, 4787, 4788, 4792, 4795, 4798, 4800, 4802, 4805, 4807, 4808, 4810, 4813, 4815, 4818, 4819, 4822, 4823, 4825, 4827, 4829, 4832, 4833, 4835, 4837, 4840, 4843, 4845, 4846, 4847, 4848, 4851, 4857, 4859, 4860, 4861, 4863, 4864, 4865, 4867, 4871, 4872, 4873, 4876, 4878, 4879, 4880, 4882, 4883, 4884, 4886, 4887, 4891, 4896, 4898, 4901, 4902, 4905, 4906, 4908, 4909, 4910, 4911, 4913, 4914, 4917, 4921, 4922, 4924, 4926, 4928, 4929, 4930, 4932, 4933, 4934, 4936, 4938, 4941, 4942, 4945, 4946, 4947, 4951, 4952, 4953, 4955, 4956, 4959, 4960, 4961, 4962, 4965, 4969, 4970, 4972, 4974, 4976, 4978, 4983, 4985, 4988, 4991, 4993, 4996, 4997, 5000, 5005, 5007, 5008, 5009, 5012, 5016, 5018, 5020, 5021, 5023, 5027, 5028, 5029, 5030, 5037, 5038, 5039, 5040, 5041, 5045, 5046, 5047, 5048, 5052, 5053, 5057, 5058, 5059, 5060, 5064, 5065, 5069, 5070, 5071, 5072, 5076, 5077, 5078, 5080, 5081, 5087, 5088, 5089, 5090, 5091, 5092, 5096, 5097, 5098, 5099, 5105, 5111, 5112, 5113, 5117, 5118, 5119, 5120, 5121, 5122, 5123, 5124, 5125, 5126, 5131, 5132, 5136, 5137, 5138, 5139, 5142, 5143, 5144, 5149, 5150, 5151, 5153, 5154, 5158, 5161, 5162, 5163, 5165, 5166, 5170, 5171, 5172, 5175, 5176, 5177, 5178, 5181, 5182, 5183, 5188, 5189, 5190, 5191, 5194, 5198, 5199, 5200, 5201, 5202, 5205, 5206, 5208, 5214, 5216, 5217, 5218, 5219, 5220, 5224, 5225, 5226, 5227, 5233, 5234, 5235, 5239, 5240, 5243, 5244, 5245, 5251, 5252, 5255, 5256, 5257, 5258, 5259, 5261, 5262, 5263, 5267, 5268, 5269, 5273, 5278, 5282, 5283, 5284, 5285, 5286, 5288, 5289, 5290, 5294, 5295, 5296, 5300, 5301, 5302, 5303, 5304, 5305, 5306, 5312, 5319, 5320, 5321, 5322, 5324, 5328, 5331, 5332, 5335, 5336, 5337, 5341, 5344, 5345, 5346, 5351, 5353, 5355, 5356, 5357, 5360, 5362, 5363, 5364, 5367, 5368, 5371, 5372, 5375, 5377, 5378, 5379, 5384, 5385, 5386, 5387, 5388, 5389, 5395, 5396, 5397, 5398, 5401, 5404, 5405, 5406, 5407, 5411, 5412, 5413, 5416, 5418, 5420, 5421, 5423, 5425, 5427, 5430, 5432, 5434, 5435, 5436, 5438, 5439, 5440, 5442, 5446, 5448, 5458, 5459, 5460, 5464, 5465, 5466, 5467, 5471, 5472, 5476, 5477, 5478, 5479, 5480, 5486, 5488, 5491, 5495, 5496, 5497, 5498, 5503, 5504, 5505, 5507, 5508, 5509, 5521, 5522, 5523, 5524, 5528, 5531, 5532, 5533, 5534, 5536, 5540, 5541, 5542, 5546, 5547, 5548, 5549, 5550, 5551, 5552, 5559, 5563, 5565, 5566, 5567, 5571, 5574, 5575, 5576, 5580, 5581, 5582, 5589, 5590, 5591, 5592, 5593, 5594, 5595, 5596, 5597, 5598, 5599, 5600, 5601, 5607, 5608, 5609, 5613, 5616, 5617, 5620, 5621, 5622, 5624, 5626, 5627, 5632, 5635, 5636, 5637, 5639, 5642, 5643, 5644, 5646, 5648, 5651, 5652, 5656, 5657, 5658, 5659, 5661, 5663, 5664, 5667, 5668, 5669, 5671, 5672, 5675, 5680, 5681, 5683, 5684, 5685, 5690, 5691, 5692, 5695, 5698, 5699, 5700, 5704, 5705, 5709, 5711, 5712, 5714, 5715, 5716, 5717, 5718, 5719, 5721, 5722, 5725, 5726, 5727, 5728, 5729, 5731, 5732, 5733, 5736, 5737, 5740, 5741, 5742, 5744, 5745, 5746, 5749, 5750, 5751, 5753, 5755, 5756, 5758, 5759, 5763, 5765, 5766, 5768, 5771, 5773, 5775, 5777, 5778, 5780, 5781, 5783, 5786, 5787, 5789, 5790, 5794, 5795, 5796, 5798, 5801, 5806, 5807, 5810, 5811, 5812, 5813, 5815, 5818, 5820, 5824, 5830, 5832, 5837, 5838, 5839, 5840, 5844, 5845, 5847, 5848, 5850, 5856, 5857, 5858, 5859, 5862, 5865, 5867, 5868, 5870, 5872, 5874, 5875, 5877, 5878, 5883, 5884, 5885, 5888, 5889, 5890, 5895, 5896, 5897, 5898, 5899, 5904, 5905, 5906, 5909, 5913, 5914, 5915, 5916, 5917, 5922, 5923, 5924, 5925, 5926, 5930, 5931, 5932, 5935, 5940, 5941, 5942, 5946, 5947, 5948, 5949, 5952, 5956, 5958, 5960, 5965, 5966, 5967, 5968, 5969, 5971, 5973, 5974, 5975, 5978, 5980, 5985, 5988, 5989, 5993, 5997, 6000, 6001, 6003, 6005, 6006, 6007, 6010, 6016, 6018, 6019, 6021, 6022, 6023, 6024, 6025, 6029, 6031, 6032, 6037, 6039, 6040, 6042, 6043, 6045, 6047, 6049, 6050, 6053, 6054, 6059, 6062, 6064, 6066, 6067, 6068, 6069, 6071, 6072, 6073, 6075, 6079, 6082, 6085, 6086, 6087, 6090, 6093, 6094, 6095, 6096, 6099, 6101, 6102, 6103, 6104, 6105, 6108, 6110, 6111, 6112, 6113, 6117, 6118, 6119, 6120, 6124, 6125, 6126, 6127, 6132, 6133, 6137, 6139, 6140, 6141, 6142, 6143, 6144, 6149, 6150, 6151, 6152, 6154, 6155, 6157, 6158, 6160, 6164, 6165, 6166, 6168, 6170, 6171, 6172, 6173, 6176, 6177, 6179, 6183, 6186, 6190, 6192, 6193, 6194, 6195, 6196, 6198, 6199, 6205, 6206, 6207, 6209, 6211, 6212, 6213, 6216, 6218, 6220, 6224, 6225, 6226, 6229, 6230, 6231, 6236, 6237, 6239, 6240, 6241, 6243, 6244, 6248, 6250, 6251, 6252, 6253, 6255, 6257, 6261, 6262, 6263, 6264, 6268, 6271, 6274, 6276, 6278, 6280, 6281, 6282, 6283, 6286, 6288, 6289, 6296, 6300, 6303, 6304, 6305, 6307, 6315, 6319, 6320, 6321, 6322, 6325, 6326, 6327, 6328, 6330, 6333, 6335, 6337, 6339, 6340, 6341, 6344, 6347, 6348, 6349, 6352, 6353, 6354, 6355, 6362, 6363, 6365, 6366, 6372, 6374, 6375, 6377, 6380, 6382, 6383, 6385, 6386, 6387, 6389, 6390, 6391, 6395, 6397, 6398, 6399, 6401, 6403, 6405, 6407, 6409, 6413, 6415, 6416, 6417, 6418, 6419, 6421, 6422, 6423, 6424, 6426, 6427, 6428, 6432, 6436, 6437, 6438, 6439, 6440, 6442, 6443, 6447, 6448, 6454, 6458, 6460, 6461, 6464, 6468, 6469, 6470, 6471, 6474, 6475, 6477, 6479, 6480, 6482, 6484, 6485, 6488, 6491, 6493, 6494, 6495, 6497, 6498, 6500, 6502, 6504, 6506, 6509, 6510, 6512, 6513, 6514, 6515, 6517, 6518, 6520, 6522, 6523, 6524, 6526, 6528, 6529, 6530, 6531, 6533, 6534, 6538, 6540, 6542, 6544, 6546, 6547, 6551, 6553, 6555, 6558, 6560, 6562, 6563, 6565, 6568, 6570, 6576, 6580, 6581, 6582, 6586, 6588, 6592, 6596, 6600, 6604, 6613, 6617, 6621, 6627, 6628, 6634, 6636, 6640, 6642, 6643, 6644, 6646, 6647, 6648, 6650, 6651, 6652, 6654, 6655, 6659, 6661, 6663, 6667, 6671, 6675, 6679, 6685, 6686, 6687, 6688, 6689, 6691, 6692, 6694, 6696, 6698, 6701, 6702, 6706, 6709, 6711, 6715, 6716, 6718, 6720, 6721, 6722, 6725, 6727, 6729, 6730, 6732, 6733, 6734, 6736, 6740, 6744, 6746, 6748, 6751, 6753, 6756, 6758, 6760, 6763, 6767, 6768, 6772, 6773, 6774, 6776, 6777, 6780, 6781, 6784, 6785, 6787, 6790, 6792, 6793, 6795, 6797, 6800, 6801, 6802, 6804, 6805, 6807, 6808, 6813, 6816, 6819, 6821, 6822, 6824, 6825, 6826, 6828, 6829, 6831, 6833, 6835, 6836, 6838, 6840, 6841, 6843, 6845, 6847, 6848, 6850, 6853, 6856, 6860, 6864, 6866, 6868, 6870, 6873, 6875, 6878, 6880, 6881, 6883, 6884, 6885, 6890, 6892, 6893, 6894, 6896, 6897, 6898, 6901, 6903, 6905, 6907, 6908, 6910, 6913, 6916, 6918, 6921, 6923, 6924, 6927, 6928, 6931, 6932, 6935, 6938, 6942, 6944, 6945, 6947, 6948, 6950, 6953, 6955, 6958, 6960, 6962, 6963, 6965, 6967, 6968, 6971, 6973, 6974, 6976, 6979, 6983, 6986, 6987, 6989, 6990, 6992, 6994, 6995, 6996, 6998, 7002, 7004, 7006, 7008, 7009, 7010, 7013, 7014, 7017, 7020, 7021, 7024, 7026, 7028, 7030, 7033, 7036, 7037, 7039, 7041, 7042, 7044, 7047, 7048, 7050, 7051, 7053, 7054, 7055, 7056, 7057, 7060, 7061, 7062, 7064, 7067, 7068, 7069, 7071, 7072, 7074, 7076, 7077, 7078, 7079, 7080, 7081, 7083, 7084, 7085, 7086, 7093, 7096, 7097, 7098, 7099, 7100, 7105, 7107, 7109, 7111, 7112, 7113, 7114, 7118, 7119, 7120, 7121, 7122, 7123, 7126, 7127, 7128, 7133, 7134, 7135, 7136, 7138, 7145, 7146, 7147, 7149, 7150, 7154, 7155, 7156, 7157, 7160, 7162, 7163, 7165, 7166, 7167, 7170, 7171, 7172, 7175, 7179, 7181, 7183, 7184, 7185, 7187, 7188, 7189, 7191, 7192, 7193, 7194, 7196, 7201, 7203, 7207, 7209, 7210, 7216, 7217, 7218, 7222, 7223, 7225, 7228, 7229, 7230, 7231, 7235, 7238, 7239, 7240, 7243, 7247, 7248, 7249, 7250, 7253, 7254, 7256, 7257, 7262, 7263, 7264, 7266, 7268, 7269, 7271, 7272, 7275, 7276, 7280, 7281, 7282, 7283, 7286, 7287, 7288, 7289, 7291, 7294, 7295, 7299, 7300, 7301, 7302, 7308, 7309, 7310, 7313, 7315, 7317, 7318, 7319, 7323, 7326, 7328, 7330, 7331, 7332, 7333, 7336, 7340, 7346, 7347, 7352, 7353, 7357, 7361, 7366, 7367, 7369, 7370, 7371, 7372, 7373, 7377, 7378, 7379, 7382, 7383, 7384, 7385, 7388, 7389, 7390, 7391, 7395, 7396, 7399, 7401, 7402, 7403, 7404, 7406, 7407, 7410, 7414, 7415, 7416, 7417, 7424, 7426, 7428, 7433, 7434, 7437, 7439, 7440, 7444, 7447, 7449, 7450, 7451, 7453, 7457, 7458, 7462, 7463, 7464, 7465, 7469, 7472, 7473, 7474, 7476, 7481, 7482, 7484, 7485, 7490, 7491, 7492, 7494, 7495, 7499, 7500, 7501, 7502, 7504, 7511, 7512, 7513, 7514, 7515, 7516, 7517, 7518, 7519, 7523, 7524, 7526, 7527, 7528, 7529, 7530, 7531, 7532, 7533, 7540, 7542, 7543, 7545, 7551, 7552, 7554, 7555, 7557, 7559, 7562, 7568, 7570, 7577, 7578, 7580, 7583, 7584, 7588, 7589, 7591, 7592, 7595, 7600, 7602, 7603, 7604, 7606, 7607, 7608, 7609, 7610, 7612, 7614, 7616, 7617, 7618, 7619, 7620, 7622, 7623, 7624, 7625, 7626, 7630, 7631, 7632, 7634, 7636, 7639, 7640, 7642, 7644, 7646, 7648, 7650, 7652, 7654, 7655, 7659, 7660, 7662, 7663, 7664, 7665, 7666, 7670, 7673, 7675, 7681, 7683, 7684, 7689, 7690, 7693, 7694, 7695, 7697, 7702, 7703, 7705, 7706, 7708, 7710, 7713, 7714, 7716, 7717, 7720, 7722, 7723, 7725, 7726, 7727, 7729, 7730, 7735, 7736, 7740, 7741, 7742, 7743, 7744, 7748, 7751, 7752, 7755, 7756, 7757, 7763, 7764, 7765, 7766, 7770, 7771, 7774, 7776, 7777, 7778, 7779, 7780, 7785, 7788, 7789, 7790, 7793, 7795, 7797, 7798, 7800, 7801, 7803, 7804, 7806, 7807, 7811, 7814, 7815, 7817, 7819, 7821, 7823, 7828, 7829, 7830, 7833, 7837, 7838, 7840, 7841, 7842, 7844, 7845, 7846, 7849, 7851, 7854, 7856, 7858, 7859, 7860, 7861, 7863, 7866, 7867, 7868, 7869, 7870, 7873, 7875, 7879, 7882, 7885, 7886, 7888, 7891, 7896, 7897, 7899, 7901, 7902, 7904, 7906, 7907, 7909, 7910, 7911, 7913, 7915, 7918, 7920, 7922, 7923, 7925, 7926, 7928, 7930, 7932, 7933, 7936, 7937, 7940, 7941, 7944, 7945, 7947, 7949, 7950, 7951, 7954, 7955, 7957, 7961, 7962, 7965, 7967, 7968, 7970, 7971, 7972, 7975, 7977, 7979, 7981, 7983, 7985, 7986, 7988, 7989, 7991, 7993, 7996, 7998, 8000, 8002, 8003, 8005, 8006, 8007, 8009, 8012, 8014, 8017, 8019, 8021, 8022, 8023, 8025, 8027, 8030, 8032, 8033, 8035, 8038, 8042, 8043, 8044, 8046, 8048, 8049, 8050, 8052, 8053, 8054, 8056, 8057, 8058, 8060, 8061, 8062, 8064, 8065, 8066, 8069, 8070, 8072, 8073, 8074, 8076, 8077, 8078, 8080, 8081, 8082, 8083, 8086, 8088, 8091, 8093, 8094, 8098, 8099, 8100, 8101, 8102, 8104, 8105, 8106, 8107, 8109, 8110, 8111, 8112, 8114, 8116, 8117, 8119, 8120, 8123, 8125, 8127, 8129, 8131, 8133, 8135, 8137, 8139, 8141, 8142, 8143, 8145, 8147, 8150, 8153, 8154, 8158, 8161, 8162, 8165, 8167, 8168, 8170, 8171, 8175, 8176, 8177, 8181, 8183, 8184, 8185, 8187, 8190, 8191, 8195, 8196, 8197, 8199, 8204, 8206, 8208, 8210, 8211, 8212, 8214, 8218, 8219, 8221, 8224, 8226, 8229, 8232, 8233, 8234, 8236, 8238, 8243, 8244, 8247, 8250, 8251, 8255, 8258, 8260, 8262, 8263, 8265, 8268, 8270, 8271, 8273, 8274, 8276, 8277, 8281, 8283, 8284, 8286, 8287, 8288, 8290, 8291, 8292, 8294, 8297, 8300, 8302, 8305, 8307, 8309, 8311, 8313, 8316, 8318, 8319, 8320, 8322, 8324, 8326, 8329, 8330, 8333, 8336, 8338, 8340, 8342, 8344, 8346, 8350, 8352, 8354, 8356, 8358, 8359, 8361, 8363, 8364, 8366, 8368, 8370, 8371, 8374, 8375, 8376, 8377, 8379, 8380, 8381, 8383, 8385, 8388, 8389, 8392, 8394, 8396, 8398, 8399, 8402, 8406, 8407, 8408, 8409, 8411, 8412, 8413, 8415, 8416, 8417, 8420, 8422, 8424, 8425, 8427, 8428, 8429, 8432, 8433, 8436, 8437, 8439, 8440, 8442, 8444, 8446, 8450, 8454, 8456, 8458, 8462, 8464, 8466, 8470, 8472, 8474, 8475, 8477, 8480, 8482, 8483, 8484, 8486, 8490, 8492, 8493, 8495, 8496, 8497, 8498, 8500, 8503, 8505, 8508, 8512, 8513, 8515, 8517, 8519, 8522, 8524, 8527, 8529, 8530, 8531, 8533, 8535, 8537, 8540, 8541, 8542, 8545, 8547, 8550, 8553, 8556, 8559, 8561, 8563, 8565, 8566, 8569, 8571, 8575, 8578, 8580, 8583, 8585, 8587, 8588, 8590, 8592, 8593, 8595, 8597, 8600, 8602, 8604, 8607, 8609, 8611, 8614, 8615, 8616, 8617, 8618, 8619, 8621, 8622, 8623, 8625, 8626, 8627, 8629, 8630, 8631, 8634, 8638, 8642, 8644, 8646, 8650, 8652, 8654, 8659, 8662, 8664, 8666, 8671, 8673, 8674, 8676, 8679, 8684, 8687, 8689, 8692, 8693, 8696, 8698, 8701, 8705, 8707, 8710, 8713, 8715, 8718, 8720, 8722, 8723, 8726, 8727, 8728, 8730, 8731, 8734, 8735, 8737, 8739, 8740, 8742, 8743, 8745, 8747, 8749, 8751, 8754, 8755, 8756, 8759, 8761, 8763, 8765, 8767, 8769, 8771, 8773, 8774, 8775, 8777, 8779, 8782, 8784, 8787, 8789, 8791, 8792, 8794, 8797, 8800, 8802, 8804, 8806, 8810, 8811, 8812, 8813, 8815, 8816, 8817, 8818, 8820, 8821, 8822, 8824, 8827, 8829, 8830, 8833, 8834, 8836, 8838, 8839, 8842, 8844, 8845, 8846, 8849, 8851, 8852, 8853, 8854, 8857, 8858, 8859, 8862, 8868, 8872, 8874, 8876, 8879, 8881, 8884, 8886, 8887, 8888, 8889, 8893, 8894, 8895, 8901, 8902, 8903, 8904, 8910, 8912, 8913, 8914, 8915, 8916, 8918, 8919, 8920, 8921, 8924, 8925, 8926, 8927, 8929, 8932, 8936, 8938, 8939, 8941, 8942, 8946, 8949, 8950, 8951, 8955, 8956, 8960, 8961, 8962, 8963, 8967, 8970, 8971, 8972, 8973, 8974, 8975, 8979, 8980, 8982, 8983, 8986, 8988, 8989, 8990, 8991, 8995, 8996, 8999, 9004, 9005, 9006, 9007, 9008, 9009, 9013, 9015, 9017, 9018, 9019, 9020, 9021, 9023, 9025, 9030, 9031, 9033, 9035, 9036, 9044, 9045, 9048, 9049, 9050, 9051, 9058, 9059, 9064, 9068, 9069, 9070, 9071, 9073, 9077, 9078, 9080, 9081, 9085, 9086, 9088, 9091, 9096, 9100, 9101, 9102, 9104, 9106, 9108, 9109, 9111, 9112, 9113, 9115, 9116, 9118, 9119, 9120, 9123, 9127, 9129, 9132, 9133, 9134, 9135, 9141, 9142, 9143, 9144, 9145, 9149, 9150, 9154, 9155, 9156, 9157, 9163, 9164, 9165, 9166, 9170, 9171, 9174, 9175, 9176, 9177, 9182, 9183, 9184, 9185, 9188, 9191, 9193, 9198, 9200, 9201, 9203, 9204, 9205, 9208, 9214, 9215, 9216, 9217, 9218, 9221, 9222, 9223, 9224, 9229, 9230, 9232, 9233, 9236, 9237, 9238, 9239, 9240, 9241, 9242, 9243, 9244, 9249, 9250, 9251, 9258, 9260, 9263, 9267, 9268, 9269, 9270, 9271, 9273, 9278, 9282, 9283, 9284, 9285, 9290, 9291, 9292, 9294, 9295, 9298, 9300, 9304, 9307, 9310, 9312, 9313, 9314, 9316, 9317, 9319, 9320, 9321, 9322, 9323, 9324, 9326, 9328, 9330, 9331, 9335, 9337, 9338, 9339, 9341, 9343, 9344, 9347, 9348, 9349, 9351, 9353, 9356, 9357, 9358, 9359, 9360, 9361, 9364, 9367, 9370, 9372, 9373, 9378, 9380, 9384, 9385, 9386, 9387, 9389, 9393, 9395, 9396, 9399, 9403, 9405, 9406, 9407, 9408, 9414, 9415, 9416, 9417, 9421, 9422, 9423, 9424, 9425, 9429, 9430, 9431, 9432, 9436, 9437, 9441, 9442, 9443, 9444, 9448, 9449, 9450, 9452, 9453, 9457, 9459, 9460, 9461, 9462, 9465, 9468, 9469, 9470, 9471, 9475, 9476, 9480, 9481, 9482, 9483, 9487, 9490, 9491, 9492, 9495, 9496, 9497, 9502, 9503, 9504, 9507, 9508, 9509, 9510, 9514, 9515, 9519, 9520, 9521, 9522, 9529, 9531, 9532, 9533, 9534, 9540, 9541, 9542, 9547, 9550, 9551, 9553, 9554, 9555, 9559, 9562, 9565, 9566, 9567, 9573, 9574, 9575, 9576, 9580, 9581, 9582, 9583, 9584, 9589, 9590, 9592, 9593, 9594, 9597, 9599, 9601, 9602, 9603, 9605, 9607, 9608, 9609, 9611, 9612, 9619, 9620, 9623, 9624, 9628, 9629, 9630, 9635, 9636, 9643, 9644, 9645, 9648, 9649, 9650, 9651, 9655, 9656, 9661, 9662, 9663, 9666, 9667, 9668, 9673, 9674, 9675, 9678, 9679, 9680, 9685, 9686, 9687, 9691, 9693, 9696, 9697, 9699, 9700, 9701, 9702, 9706, 9709, 9710, 9714, 9715, 9716, 9717, 9721, 9722, 9725, 9726, 9727, 9729, 9730, 9733, 9735, 9736, 9737, 9739, 9740, 9741, 9742, 9745, 9747, 9749, 9750, 9751, 9752, 9753, 9754, 9755, 9760, 9761, 9763, 9764, 9767, 9768, 9769, 9770, 9774, 9775, 9779, 9780, 9781, 9782, 9786, 9788, 9792, 9795, 9799, 9800, 9801, 9805, 9808, 9809, 9810, 9811, 9812, 9813, 9816, 9817, 9818, 9819, 9824, 9825, 9827, 9828, 9829, 9830, 9835, 9836, 9837, 9838, 9841, 9845, 9846, 9847, 9848, 9850, 9853, 9857, 9858, 9859, 9860, 9866, 9870, 9871, 9876, 9877, 9878, 9880, 9881, 9887, 9888, 9889, 9890, 9891, 9893, 9894, 9896, 9897, 9898, 9899, 9902, 9903, 9904, 9909, 9910, 9911, 9913, 9917, 9918, 9919, 9920, 9922, 9927, 9928, 9929, 9930, 9931, 9937, 9939, 9941, 9942, 9943, 9948, 9952, 9953, 9957, 9958, 9959, 9961, 9962, 9966, 9971, 9974, 9975, 9977, 9978, 9979, 9981, 9986, 9987, 9989, 9995, 9997, 9999, 10001, 10002, 10003, 10004, 10005, 10006, 10019, 10022, 10023, 10024, 10028, 10029, 10033, 10034, 10035, 10040, 10041, 10042, 10043, 10045, 10052, 10053, 10054, 10057, 10058, 10060, 10065, 10067, 10068, 10072, 10075, 10078, 10080, 10081, 10082, 10083, 10084, 10085, 10090, 10091, 10092, 10094, 10095, 10099, 10100, 10102, 10103, 10104, 10107, 10111, 10113, 10114, 10115, 10116, 10120, 10121, 10125, 10126, 10127, 10128, 10132, 10133, 10137, 10138, 10139, 10140, 10146, 10147, 10148, 10149, 10153, 10156, 10157, 10158, 10160, 10161, 10164, 10168, 10169, 10171, 10172, 10173, 10179, 10180, 10181, 10182, 10183, 10184, 10185, 10189, 10191, 10192, 10193, 10194, 10195, 10196, 10198, 10199, 10200, 10202, 10204, 10207, 10208, 10209, 10210, 10211, 10212, 10213, 10214, 10215, 10222, 10225, 10226, 10227, 10231, 10234, 10235, 10236, 10237, 10238, 10239, 10243, 10244, 10245, 10246, 10250, 10251, 10252, 10255, 10256, 10260, 10262, 10263, 10264, 10265, 10266, 10270, 10274, 10277, 10279, 10281, 10286, 10287, 10288, 10289, 10291, 10292, 10293, 10295, 10296, 10297, 10299, 10300, 10303, 10304, 10305, 10312, 10314, 10315, 10318, 10319, 10320, 10321, 10322, 10324, 10331, 10332, 10333, 10339, 10340, 10341, 10342, 10343, 10346, 10347, 10348, 10352, 10353, 10354, 10358, 10360, 10367, 10368, 10370, 10371, 10372, 10373, 10374, 10378, 10379, 10380, 10385, 10386, 10387, 10388, 10389, 10390, 10397, 10398, 10399, 10400, 10401, 10402, 10403, 10404, 10405, 10406, 10407, 10412, 10415, 10416, 10417, 10423, 10432, 10436, 10437, 10439, 10440, 10442, 10447, 10449, 10452, 10453, 10454, 10456, 10459, 10460, 10465, 10466, 10467, 10469, 10470, 10471, 10472, 10473, 10476, 10477, 10478, 10479, 10480, 10481, 10486, 10487, 10492, 10493, 10494, 10497, 10498, 10499, 10500, 10501, 10502, 10503, 10510, 10513, 10515, 10516, 10517, 10518, 10520, 10522, 10525, 10527, 10529, 10532, 10533, 10538, 10539, 10540, 10544, 10545, 10546, 10550, 10551, 10552, 10555, 10556, 10557, 10558, 10559, 10561, 10563, 10565, 10566, 10570, 10572, 10573, 10576, 10577, 10580, 10582, 10585, 10586, 10587, 10588, 10592, 10595, 10596, 10598, 10600, 10604, 10607, 10608, 10610, 10611, 10612, 10613, 10614, 10615, 10618, 10619, 10620, 10627, 10628, 10633, 10634, 10639, 10640, 10641, 10642, 10643, 10646, 10647, 10648, 10650, 10652, 10656, 10657, 10661, 10662, 10663, 10664, 10668, 10670, 10672, 10674, 10676, 10680, 10683, 10687, 10688, 10689, 10690, 10693, 10695, 10697, 10699, 10700, 10701, 10704, 10705, 10708, 10711, 10712, 10715, 10716, 10718, 10720, 10722, 10723, 10724, 10726, 10727, 10732, 10733, 10735, 10736, 10737, 10739, 10740, 10741, 10746, 10747, 10748, 10751, 10752, 10755, 10757, 10764, 10767, 10768, 10770, 10771, 10774, 10776, 10777, 10779, 10781, 10784, 10787, 10790, 10791, 10795, 10799, 10802, 10804, 10806, 10808, 10809, 10811, 10817, 10818, 10820, 10822, 10824, 10826, 10827, 10828, 10830, 10835, 10838, 10839, 10840, 10843, 10845, 10847, 10848, 10849, 10850, 10856, 10857, 10862, 10865, 10868, 10869, 10870, 10872, 10873, 10875, 10876, 10877, 10879, 10880, 10882, 10883, 10884, 10888, 10889, 10890, 10891, 10892, 10895, 10897, 10898, 10902, 10907, 10908, 10909, 10913, 10914, 10919, 10920, 10925, 10928, 10931, 10936, 10940, 10942, 10943, 10945, 10946, 10947, 10948, 10950, 10951, 10952, 10955, 10959, 10960, 10961, 10962, 10964, 10965, 10968, 10969, 10972, 10973, 10976, 10977, 10978, 10980, 10982, 10983, 10984, 10986, 10987, 10988, 10990, 10991, 10993, 10994, 10995, 10998, 11002, 11004, 11007, 11012, 11014, 11018, 11026, 11027, 11030, 11034, 11035, 11036, 11040, 11041, 11042, 11045, 11046, 11047, 11051, 11052, 11053, 11054, 11061, 11062, 11064, 11067, 11068, 11070, 11073, 11074, 11080, 11086, 11087, 11088, 11089, 11092, 11095, 11096, 11097, 11098, 11099, 11101, 11103, 11105, 11106, 11107, 11108, 11109, 11110, 11112, 11113, 11116, 11117, 11118, 11119, 11120, 11121, 11122, 11123, 11124, 11126, 11127, 11131, 11132, 11133, 11134, 11135, 11138, 11139, 11140, 11141, 11143, 11144, 11146, 11150, 11154, 11155, 11156, 11158, 11160, 11161, 11162, 11165, 11168, 11169, 11170, 11171, 11172, 11175, 11176, 11180, 11181, 11182, 11183, 11187, 11188, 11190, 11191, 11192, 11194, 11195, 11197, 11198, 11199, 11201, 11202, 11206, 11207, 11208, 11209, 11210, 11214, 11216, 11217, 11219, 11221, 11223, 11225, 11228, 11229, 11230, 11234, 11235, 11236, 11241, 11244, 11246, 11247, 11248, 11250, 11251, 11253, 11254, 11256, 11257, 11258, 11259, 11263, 11265, 11266, 11268, 11273, 11276, 11283, 11284, 11285, 11294, 11295, 11296, 11300, 11301, 11302, 11303, 11304, 11306, 11308, 11312, 11313, 11314, 11316, 11318, 11320, 11321, 11323, 11325, 11326, 11331, 11332, 11333, 11334, 11336, 11337, 11338, 11340, 11343, 11345, 11348, 11350, 11351, 11353, 11354, 11357, 11359, 11360, 11361, 11362, 11364, 11366, 11369, 11372, 11373, 11376, 11377, 11378, 11380, 11381, 11382, 11383, 11384, 11386, 11389, 11390, 11393, 11395, 11396, 11397, 11400, 11403, 11405, 11407, 11410, 11412, 11414, 11415, 11417, 11418, 11421, 11422, 11425, 11426, 11428, 11429, 11431, 11433, 11434, 11437, 11438, 11441, 11442, 11443, 11445, 11448, 11449, 11451, 11454, 11456, 11457, 11458, 11460, 11461, 11463, 11464, 11465, 11466, 11467, 11468, 11470, 11471, 11472, 11474, 11475, 11476, 11477, 11478, 11480, 11481, 11482, 11483, 11484, 11486, 11487, 11488, 11494, 11495, 11499, 11506, 11508, 11511, 11512, 11513, 11515, 11516, 11517, 11519, 11520, 11521, 11523, 11524, 11526, 11527, 11528, 11530, 11531, 11532, 11534, 11535, 11536, 11538, 11539, 11541, 11542, 11543, 11546, 11547, 11548, 11549, 11550, 11552, 11553, 11556, 11558, 11560, 11565, 11569, 11572, 11573, 11577, 11579, 11581, 11583, 11585, 11587, 11589, 11595, 11596, 11597, 11598, 11600, 11601, 11604, 11607, 11608, 11609, 11611, 11612, 11615, 11617, 11618, 11621, 11622, 11624, 11625, 11628, 11629, 11630, 11631, 11633, 11634, 11637, 11640, 11642, 11643, 11646, 11647, 11648, 11649, 11651, 11653, 11655, 11657, 11658, 11660, 11661, 11665, 11666, 11668, 11670, 11672, 11673, 11676, 11677, 11680, 11686, 11687, 11689, 11690, 11693, 11694, 11696, 11697, 11699, 11701, 11705, 11707, 11708, 11709, 11710, 11711, 11714, 11715, 11716, 11718, 11719, 11721, 11730, 11733, 11740, 11743, 11745, 11750, 11751, 11753, 11754, 11755, 11759, 11761, 11763, 11764, 11765, 11766, 11767, 11768, 11769, 11771, 11772, 11777, 11778, 11782, 11783, 11784, 11785, 11791, 11792, 11793, 11798, 11799, 11800, 11802, 11803, 11807, 11808, 11809, 11813, 11814, 11815, 11816, 11817, 11818, 11821, 11822, 11823, 11824, 11827, 11828, 11829, 11834, 11835, 11836, 11839, 11840, 11841, 11846, 11847, 11848, 11850, 11851, 11859, 11860, 11861, 11862, 11863, 11864, 11865, 11866, 11871, 11872, 11873, 11875, 11876, 11882, 11883, 11884, 11885, 11889, 11890, 11892, 11893, 11898, 11902, 11903, 11904, 11909, 11910, 11911, 11912, 11913, 11916, 11917, 11921, 11922, 11923, 11926, 11927, 11928, 11933, 11934, 11935, 11940, 11942, 11943, 11944, 11947, 11949, 11950, 11955, 11958, 11959, 11960, 11961, 11962, 11963, 11965, 11966, 11971, 11972, 11974, 11976, 11981, 11984, 11985, 11989, 11991, 11992, 11997, 11998, 11999, 12003, 12005, 12008, 12011, 12012, 12013, 12014, 12015, 12016, 12021, 12023, 12024, 12025, 12026, 12029, 12032, 12033, 12034, 12035, 12040, 12041, 12042, 12047, 12048, 12049, 12050, 12053, 12054, 12055, 12059, 12060, 12064, 12065, 12066, 12067, 12072, 12074, 12075, 12076, 12077, 12078, 12079, 12084, 12086, 12087, 12088, 12089, 12092, 12093, 12095, 12096, 12097, 12099, 12105, 12106, 12107, 12112, 12113, 12114, 12115, 12117, 12118, 12120, 12123, 12128, 12129, 12132, 12134, 12135, 12136, 12138, 12141, 12142, 12144, 12146, 12147, 12151, 12153, 12154, 12159, 12163, 12164, 12165, 12166, 12168, 12170, 12172, 12175, 12176, 12178, 12180, 12181, 12183, 12184, 12187, 12191, 12193, 12194, 12199, 12201, 12203, 12208, 12209, 12211, 12213, 12217, 12219, 12220, 12221, 12222, 12224, 12227, 12229, 12230, 12231, 12233, 12235, 12236, 12238, 12239, 12241, 12243, 12246, 12247, 12251, 12252, 12255, 12256, 12257, 12258, 12259, 12260, 12267, 12270, 12271, 12272, 12273, 12274, 12277, 12278, 12281, 12284, 12286, 12287, 12288, 12290, 12292, 12296, 12298, 12300, 12302, 12303, 12305, 12306, 12307, 12310, 12311, 12312, 12313, 12316, 12317, 12318, 12321, 12322, 12325, 12326, 12328, 12329, 12331, 12334, 12335, 12337, 12339, 12341, 12342, 12344, 12346, 12348, 12350, 12353, 12355, 12356, 12359, 12360, 12361, 12367, 12368, 12371, 12372, 12373, 12375, 12378, 12381, 12382, 12383, 12385, 12387, 12390, 12392, 12395, 12398, 12399, 12401, 12405, 12408, 12410, 12411, 12412, 12414, 12415, 12416, 12418, 12419, 12420, 12422, 12423, 12424, 12426, 12427, 12428, 12430, 12431, 12432, 12434, 12435, 12436, 12439, 12441, 12442, 12443, 12444, 12445, 12447, 12448, 12449, 12451, 12452, 12454, 12456, 12457, 12464, 12468, 12471, 12472, 12473, 12475, 12476, 12477, 12478, 12480, 12482, 12483, 12484, 12486, 12487, 12489, 12490, 12491, 12492, 12493, 12495, 12498, 12499, 12500, 12502, 12503, 12505, 12507, 12509, 12510, 12511, 12512, 12514, 12515, 12516, 12517, 12518, 12520, 12521, 12522, 12523, 12526, 12530, 12533, 12536, 12539, 12541, 12542, 12543, 12547, 12550, 12553, 12557, 12560, 12562, 12565, 12567, 12568, 12570, 12571, 12573, 12577, 12578, 12580, 12582, 12584, 12586, 12589, 12590, 12592, 12594, 12596, 12597, 12599, 12601, 12603, 12605, 12606, 12607, 12609, 12610, 12613, 12617, 12618, 12619, 12620, 12621, 12622, 12624, 12627, 12630, 12631, 12635, 12637, 12641, 12642, 12644, 12646, 12648, 12649, 12651, 12653, 12654, 12655, 12656, 12658, 12659, 12661, 12662, 12663, 12664, 12665, 12666, 12670, 12673, 12675, 12679, 12681, 12682, 12684, 12686, 12688, 12689, 12690, 12692, 12693, 12694, 12696, 12697, 12699, 12701, 12702, 12704, 12708, 12709, 12710, 12712, 12713, 12715, 12718, 12720, 12722, 12724, 12728, 12729, 12731, 12733, 12735, 12737, 12741, 12744, 12745, 12748, 12749, 12751, 12754, 12756, 12758, 12759, 12762, 12763, 12765, 12767, 12770, 12772, 12773, 12775, 12777, 12780, 12782, 12784, 12786, 12787, 12790, 12791, 12793, 12795, 12796, 12797, 12802, 12806, 12810, 12812, 12814, 12817, 12819, 12821, 12822, 12824, 12825, 12828, 12831, 12834, 12836, 12838, 12839, 12841, 12843, 12846, 12847, 12852, 12856, 12858, 12860, 12862, 12863, 12865, 12867, 12870, 12871, 12873, 12875, 12880, 12884, 12886, 12888, 12891, 12894, 12895, 12896, 12900, 12904, 12906, 12907, 12909, 12913, 12915, 12916, 12918, 12921, 12924, 12925, 12928, 12930, 12931, 12933, 12934, 12939, 12943, 12947, 12949, 12951, 12952, 12954, 12956, 12957, 12958, 12960, 12963, 12965, 12967, 12970, 12971, 12973, 12974, 12976, 12977, 12981, 12983, 12985, 12986, 12987, 12989, 12990, 12993, 12995, 12996, 12998, 13001, 13003, 13004, 13005, 13007, 13009, 13011, 13012, 13013, 13016, 13017, 13020, 13021, 13023, 13025, 13026, 13027, 13029, 13031, 13032, 13034, 13038, 13039, 13042, 13043, 13045, 13047, 13048, 13050, 13051, 13052, 13053, 13056, 13059, 13062, 13063, 13067, 13069, 13070, 13072, 13075, 13077, 13078, 13080, 13081, 13082, 13083, 13084, 13086, 13087, 13089, 13090, 13094, 13096, 13098, 13100, 13101, 13102, 13103, 13104, 13106, 13109, 13112, 13113, 13114, 13117, 13118, 13120, 13121, 13123, 13125, 13128, 13129, 13130, 13132, 13134, 13135, 13138, 13139, 13140, 13143, 13144, 13148, 13149, 13150, 13154, 13155, 13159, 13160, 13161, 13162, 13166, 13167, 13171, 13172, 13173, 13174, 13178, 13179, 13183, 13184, 13185, 13186, 13189, 13190, 13191, 13192, 13198, 13199, 13200, 13201, 13205, 13206, 13207, 13208, 13209, 13210, 13218, 13219, 13221, 13222, 13228, 13230, 13231, 13232, 13234, 13235, 13239, 13240, 13241, 13242, 13246, 13247, 13251, 13252, 13253, 13258, 13259, 13260, 13261, 13264, 13265, 13266, 13270, 13271, 13272, 13273, 13274, 13275, 13276, 13279, 13281, 13283, 13285, 13292, 13293, 13296, 13298, 13299, 13300, 13303, 13304, 13306, 13311, 13313, 13314, 13315, 13316, 13320, 13321, 13322, 13323, 13324, 13328, 13329, 13332, 13334, 13337, 13340, 13341, 13342, 13344, 13348, 13353, 13354, 13355, 13356, 13357, 13362, 13363, 13364, 13370, 13371, 13372, 13377, 13378, 13379, 13382, 13384, 13386, 13387, 13388, 13390, 13391, 13397, 13401, 13402, 13403, 13404, 13405, 13410, 13412, 13416, 13417, 13418, 13419, 13422, 13424, 13425, 13427, 13431, 13433, 13435, 13438, 13439, 13440, 13441, 13442, 13443, 13444, 13445, 13448, 13454, 13458, 13460, 13464, 13466, 13467, 13469, 13471, 13472, 13473, 13477, 13479, 13480, 13482, 13483, 13484, 13485, 13489, 13490, 13495, 13496, 13498, 13499, 13500, 13506, 13507, 13508, 13509, 13516, 13517, 13518, 13519, 13520, 13522, 13523, 13528, 13529, 13530, 13531, 13533, 13540, 13541, 13542, 13545, 13546, 13547, 13552, 13553, 13554, 13557, 13558, 13559, 13564, 13565, 13569, 13570, 13571, 13572, 13574, 13575, 13579, 13580, 13581, 13582, 13583, 13588, 13589, 13593, 13594, 13595, 13596, 13600, 13601, 13605, 13606, 13607, 13608, 13610, 13616, 13617, 13618, 13620, 13621, 13625, 13626, 13627, 13630, 13631, 13633, 13637, 13639, 13643, 13645, 13646, 13649, 13650, 13651, 13654, 13655, 13656, 13657, 13659, 13661, 13662, 13663, 13664, 13666, 13669, 13670, 13672, 13673, 13674, 13675, 13678, 13679, 13680, 13685, 13686, 13687, 13690, 13691, 13692, 13697, 13698, 13699, 13701, 13702, 13708, 13709, 13710, 13711, 13712, 13715, 13716, 13717, 13718, 13719, 13724, 13725, 13726, 13732, 13734, 13735, 13736, 13737, 13742, 13743, 13746, 13747, 13749, 13750, 13751, 13753, 13754, 13755, 13758, 13760, 13761, 13762, 13763, 13764, 13766, 13769, 13771, 13772, 13773, 13775, 13778, 13781, 13782, 13783, 13784, 13788, 13791, 13792, 13793, 13797, 13798, 13802, 13803, 13804, 13805, 13808, 13809, 13810, 13813, 13814, 13815, 13817, 13818, 13819, 13820, 13825, 13827, 13828, 13830, 13834, 13835, 13836, 13840, 13843, 13844, 13845, 13846, 13848, 13850, 13853, 13855, 13857, 13859, 13860, 13861, 13865, 13870, 13871, 13876, 13877, 13878, 13879, 13880, 13884, 13885, 13886, 13891, 13892, 13893, 13894, 13896, 13900, 13902, 13903, 13906, 13908, 13911, 13913, 13918, 13919, 13920, 13922, 13925, 13926, 13933, 13935, 13936, 13939, 13940, 13941, 13944, 13946, 13948, 13949, 13950, 13952, 13954, 13959, 13961, 13963, 13965, 13966, 13967, 13968, 13970, 13971, 13973, 13974, 13975, 13977, 13982, 13985, 13986, 13987, 13989, 13990, 13994, 13995, 13997, 13998, 13999, 14000, 14002, 14003, 14008, 14011, 14012, 14013, 14017, 14018, 14022, 14023, 14024, 14025, 14026, 14030, 14031, 14035, 14036, 14037, 14038, 14040, 14047, 14048, 14052, 14053, 14054, 14055, 14062, 14064, 14066, 14068, 14070, 14071, 14072, 14073, 14075, 14076, 14078, 14079, 14081, 14083, 14084, 14086, 14089, 14093, 14094, 14095, 14097, 14102, 14103, 14104, 14108, 14110, 14112, 14113, 14115, 14116, 14120, 14121, 14124, 14125, 14129, 14132, 14133, 14134, 14136, 14138, 14141, 14143, 14144, 14145, 14147, 14148, 14150, 14154, 14155, 14156, 14159, 14160, 14161, 14163, 14167, 14168, 14169, 14173, 14176, 14177, 14178, 14179, 14183, 14186, 14187, 14188, 14189, 14190, 14191, 14194, 14200, 14201, 14202, 14203, 14204, 14205, 14207, 14211, 14212, 14213, 14215, 14217, 14218, 14219, 14220, 14224, 14225, 14226, 14228, 14231, 14232, 14233, 14234, 14235, 14239, 14241, 14243, 14247, 14248, 14254, 14259, 14260, 14261, 14262, 14263, 14269, 14271, 14272, 14273, 14277, 14278, 14283, 14284, 14287, 14288, 14291, 14296, 14298, 14300, 14301, 14302, 14303, 14305, 14313, 14314, 14315, 14317, 14320, 14321, 14322, 14323, 14324, 14325, 14326, 14331, 14333, 14334, 14336, 14337, 14340, 14341, 14342, 14346, 14347, 14349, 14350, 14353, 14355, 14356, 14357, 14360, 14361, 14362, 14364, 14369, 14370, 14371, 14375, 14376, 14377, 14384, 14385, 14386, 14387, 14388, 14390, 14394, 14400, 14401, 14405, 14406, 14407, 14408, 14410, 14411, 14413, 14415, 14418, 14422, 14424, 14427, 14428, 14429, 14430, 14431, 14438, 14440, 14441, 14442, 14444, 14446, 14449, 14451, 14452, 14456, 14460, 14465, 14467, 14468, 14470, 14476, 14477, 14478, 14481, 14483, 14485, 14488, 14489, 14491, 14493, 14495, 14498, 14501, 14502, 14504, 14506, 14508, 14509, 14511, 14512, 14513, 14514, 14516, 14521, 14523, 14525, 14527, 14529, 14531, 14532, 14533, 14535, 14536, 14537, 14538, 14541, 14544, 14546, 14547, 14548, 14549, 14550, 14551, 14552, 14557, 14558, 14559, 14560, 14566, 14567, 14568, 14569, 14570, 14571, 14576, 14577, 14581, 14584, 14586, 14589, 14590, 14591, 14593, 14595, 14596, 14597, 14599, 14602, 14603, 14606, 14607, 14609, 14611, 14612, 14614, 14615, 14616, 14617, 14620, 14622, 14623, 14625, 14630, 14631, 14633, 14634, 14635, 14636, 14638, 14639, 14641, 14643, 14645, 14646, 14648, 14651, 14653, 14654, 14655, 14656, 14661, 14663, 14664, 14666, 14669, 14670, 14671, 14674, 14675, 14679, 14682, 14684, 14685, 14687, 14691, 14693, 14695, 14700, 14701, 14702, 14703, 14705, 14706, 14707, 14710, 14712, 14714, 14715, 14716, 14717, 14720, 14721, 14722, 14724, 14726, 14729, 14730, 14734, 14737, 14738, 14739, 14740, 14741, 14742, 14745, 14746, 14749, 14752, 14754, 14756, 14757, 14759, 14762, 14764, 14766, 14768, 14769, 14773, 14774, 14776, 14779, 14782, 14783, 14784, 14785, 14786, 14788, 14789, 14793, 14795, 14796, 14799, 14801, 14802, 14804, 14808, 14809, 14811, 14814, 14816, 14818, 14819, 14820, 14821, 14824, 14825, 14827, 14828, 14830, 14831, 14835, 14836, 14837, 14838, 14839, 14842, 14844, 14845, 14847, 14849, 14850, 14852, 14853, 14856, 14860, 14861, 14862, 14864, 14866, 14869, 14872, 14874, 14876, 14878, 14880, 14882, 14884, 14885, 14886, 14888, 14889, 14891, 14893, 14899, 14901, 14902, 14905, 14906, 14908, 14909, 14911, 14912, 14915, 14917, 14920, 14924, 14928, 14932, 14934, 14936, 14939, 14943, 14946, 14949, 14951, 14955, 14959, 14963, 14965, 14967, 14972, 14976, 14980, 14983, 14987, 14991, 14997, 15000, 15004, 15008, 15010, 15014, 15016, 15020, 15025, 15026, 15027, 15028, 15029, 15030, 15031, 15033, 15035, 15037, 15039, 15040, 15042, 15046, 15047, 15048, 15050, 15051, 15052, 15054, 15055, 15056, 15057, 15060, 15061, 15065, 15067, 15069, 15071, 15073, 15075, 15077, 15079, 15080, 15081, 15083, 15086, 15089, 15091, 15092, 15094, 15096, 15097, 15099, 15101, 15105, 15106, 15110, 15112, 15113, 15115, 15116, 15118, 15119, 15123, 15125, 15126, 15127, 15129, 15131, 15133, 15136, 15137, 15139, 15142, 15144, 15146, 15149, 15151, 15152, 15155, 15158, 15159, 15163, 15166, 15167, 15169, 15171, 15174, 15176, 15178, 15180, 15183, 15185, 15186, 15188, 15190, 15195, 15199, 15202, 15204, 15207, 15210, 15212, 15214, 15216, 15217, 15219, 15222, 15225, 15227, 15229, 15232, 15233, 15234, 15236, 15239, 15240, 15241, 15242, 15246, 15248, 15249, 15254, 15255, 15258, 15261, 15262, 15263, 15265, 15266, 15268, 15272, 15276, 15278, 15279, 15280, 15281, 15282, 15284, 15286, 15287, 15288, 15289, 15290, 15291, 15293, 15295, 15298, 15299, 15300, 15301, 15302, 15303, 15307, 15308, 15312, 15313, 15314, 15317, 15318, 15319, 15324, 15325, 15326, 15328, 15332, 15333, 15334, 15338, 15339, 15340, 15341, 15345, 15346, 15350, 15351, 15352, 15353, 15357, 15358, 15362, 15363, 15364, 15365, 15369, 15372, 15373, 15374, 15376, 15377, 15381, 15382, 15383, 15384, 15387, 15391, 15392, 15394, 15395, 15397, 15402, 15404, 15406, 15407, 15408, 15409, 15410, 15412, 15413, 15414, 15417, 15418, 15419, 15420, 15423, 15424, 15426, 15428, 15429, 15432, 15434, 15435, 15436, 15438, 15445, 15446, 15448, 15453, 15454, 15455, 15457, 15458, 15461, 15464, 15465, 15468, 15469, 15470, 15471, 15472, 15473, 15475, 15476, 15479, 15482, 15484, 15485, 15487, 15488, 15489, 15490, 15493, 15494, 15495, 15496, 15497, 15498, 15501, 15503, 15506, 15508, 15510, 15514, 15516, 15517, 15519, 15520, 15521, 15523, 15524, 15525, 15528, 15532, 15538, 15540, 15541, 15542, 15543, 15546, 15547, 15548, 15549, 15553, 15556, 15557, 15558, 15559, 15560, 15561, 15563, 15564, 15565, 15567, 15568, 15572, 15573, 15574, 15575, 15576, 15580, 15583, 15584, 15585, 15586, 15594, 15596, 15598, 15600, 15601, 15602, 15603, 15606, 15607, 15609, 15613, 15614, 15615, 15617, 15622, 15625, 15628, 15629, 15630, 15634, 15635, 15640, 15641, 15643, 15644, 15647, 15648, 15649, 15652, 15653, 15655, 15657, 15661, 15663, 15664, 15665, 15672, 15674, 15675, 15676, 15677, 15681, 15682, 15683, 15684, 15688, 15692, 15694, 15695, 15696, 15697, 15699, 15701, 15702, 15704, 15706, 15710, 15711, 15715, 15717, 15719, 15723, 15724, 15725, 15726, 15730, 15732, 15733, 15734, 15735, 15737, 15738, 15742, 15743, 15744, 15745, 15746, 15751, 15752, 15753, 15755, 15756, 15763, 15764, 15765, 15768, 15771, 15772, 15773, 15774, 15775, 15777, 15778, 15779, 15781, 15782, 15783, 15785, 15786, 15787, 15789, 15791, 15793, 15795, 15796, 15799, 15802, 15803, 15804, 15808, 15809, 15810, 15813, 15814, 15815, 15816, 15817, 15818, 15822, 15823, 15825, 15826, 15827, 15831, 15833, 15835, 15836, 15837, 15840, 15846, 15847, 15848, 15849, 15851, 15856, 15857, 15858, 15859, 15861, 15863, 15869, 15870, 15872, 15873, 15876, 15878, 15879, 15885, 15888, 15889, 15892, 15893, 15896, 15897, 15899, 15916, 15920, 15922, 15924, 15925, 15928, 15930, 15931, 15935, 15936, 15938, 15941, 15943, 15944, 15946, 15953, 15954, 15955, 15957, 15958, 15959, 15961, 15963, 15965, 15967, 15968, 15970, 15971, 15975, 15977, 15979, 15982, 15984, 15986, 15992, 15996, 16000, 16004, 16008, 16012, 16016, 16022, 16025, 16026, 16027, 16028, 16029, 16030, 16032, 16033, 16034, 16036, 16037, 16040, 16044, 16047, 16051, 16053, 16056, 16060, 16062, 16066, 16070, 16074, 16075, 16076, 16079, 16080, 16081, 16083, 16084, 16085, 16087, 16089, 16090, 16091, 16093, 16094, 16098, 16099, 16101, 16103, 16104, 16105, 16107, 16108, 16109, 16111, 16112, 16113, 16114, 16116, 16118, 16121, 16122, 16124, 16125, 16127, 16129, 16130, 16131, 16134, 16138, 16139, 16141, 16143, 16146, 16148, 16151, 16152, 16153, 16155, 16156, 16157, 16160, 16161, 16162, 16164, 16165, 16168, 16170, 16171, 16172, 16174, 16175, 16176, 16179, 16181, 16184, 16185, 16187, 16188, 16189, 16192, 16193, 16195, 16198, 16200, 16201, 16205, 16209, 16210, 16212, 16213, 16215, 16216, 16217, 16219, 16220, 16223, 16224, 16226, 16228, 16229, 16230, 16232, 16233, 16234, 16236, 16238, 16240, 16241, 16242, 16244, 16245, 16246, 16248, 16249, 16251, 16252, 16254, 16255, 16257, 16261, 16262, 16265, 16267, 16269, 16270, 16272, 16273, 16275, 16278, 16279, 16280, 16282, 16283, 16284, 16286, 16289, 16292, 16294, 16296, 16297, 16300, 16301, 16304, 16306, 16308, 16310, 16313, 16315, 16316, 16319, 16322, 16326, 16327, 16329, 16332, 16337, 16338, 16341, 16345, 16346, 16348, 16350, 16354, 16356, 16359, 16360, 16361, 16363, 16365, 16368, 16370, 16372, 16375, 16376, 16377, 16378, 16380, 16382, 16383, 16387, 16389, 16390, 16392, 16393, 16395, 16397, 16399, 16401, 16405, 16408, 16409, 16412, 16414, 16416, 16418, 16419, 16422, 16424, 16425, 16426, 16429, 16431, 16432, 16434, 16435, 16438, 16444, 16445, 16446, 16450, 16451, 16452, 16456, 16457, 16461, 16462, 16463, 16464, 16468, 16469, 16470, 16471, 16472, 16473, 16476, 16477, 16478, 16483, 16484, 16485, 16487, 16488, 16489, 16491, 16492, 16494, 16495, 16496, 16497, 16498, 16501, 16502, 16503, 16507, 16508, 16509, 16510, 16513, 16517, 16520, 16521, 16524, 16525, 16526, 16527, 16531, 16532, 16534, 16535, 16536, 16540, 16541, 16542, 16544, 16548, 16549, 16550, 16551, 16555, 16556, 16561, 16562, 16563, 16564, 16566, 16573, 16574, 16575, 16576, 16577, 16579, 16580, 16582, 16584, 16588, 16591, 16592, 16593, 16595, 16596, 16603, 16605, 16612, 16613, 16614, 16615, 16616, 16620, 16621, 16622, 16623, 16624, 16625, 16630, 16631, 16634, 16636, 16637, 16638, 16641, 16646, 16648, 16649, 16650, 16651, 16653, 16654, 16655, 16656, 16657, 16659, 16664, 16665, 16667, 16668, 16672, 16673, 16674, 16679, 16680, 16681, 16683, 16684, 16686, 16687, 16690, 16691, 16693, 16696, 16699, 16700, 16701, 16706, 16707, 16708, 16709, 16711, 16718, 16719, 16721, 16722, 16723, 16729, 16730, 16731, 16732, 16736, 16737, 16739, 16740, 16745, 16746, 16747, 16748, 16752, 16754, 16755, 16757, 16760, 16762, 16767, 16769, 16771, 16773, 16774, 16777, 16778, 16781, 16782, 16785, 16786, 16788, 16789, 16791, 16792, 16793, 16795, 16796, 16797, 16799, 16804, 16807, 16808, 16809, 16810, 16812, 16814, 16815, 16816, 16818, 16820, 16826, 16827, 16832, 16833, 16838, 16839, 16841, 16842, 16847, 16848, 16849, 16853, 16856, 16857, 16858, 16859, 16860, 16861, 16865, 16866, 16869, 16871, 16872, 16873, 16874, 16880, 16881, 16884, 16889, 16890, 16892, 16894, 16898, 16899, 16900, 16901, 16902, 16903, 16905, 16909, 16910, 16911, 16912, 16914, 16917, 16918, 16920, 16921, 16922, 16925, 16927, 16930, 16933, 16934, 16935, 16938, 16940, 16941, 16942, 16944, 16947, 16948, 16951, 16953, 16954, 16960, 16961, 16962, 16963, 16965, 16966, 16968, 16970, 16974, 16977, 16979, 16982, 16983, 16987, 16989, 16991, 16993, 16994, 16995, 17000, 17001, 17004, 17005, 17007, 17011, 17012, 17013, 17017, 17018, 17022, 17023, 17026, 17030, 17032, 17033, 17035, 17036, 17038, 17041, 17046, 17047, 17051, 17055, 17059, 17060, 17062, 17064, 17066, 17067, 17069, 17076, 17077, 17078, 17082, 17083, 17084, 17086, 17089, 17090, 17092, 17093, 17096, 17098, 17099, 17101, 17103, 17104, 17106, 17107, 17109, 17110, 17111, 17114, 17117, 17123, 17125, 17126, 17128, 17131, 17132, 17138, 17141, 17143, 17144, 17145, 17147, 17149, 17151, 17152, 17154, 17155, 17157, 17159, 17162, 17163, 17165, 17167, 17168, 17169, 17171, 17173, 17175, 17177, 17179, 17181, 17184, 17186, 17189, 17191, 17194, 17196, 17199, 17200, 17203, 17204, 17206, 17207, 17209, 17210, 17211, 17214, 17216, 17219, 17220, 17222, 17225, 17227, 17228, 17229, 17230, 17232, 17233, 17234, 17236, 17237, 17238, 17239, 17240, 17242, 17243, 17244, 17248, 17252, 17254, 17256, 17258, 17259, 17262, 17267, 17271, 17275, 17277, 17279, 17280, 17281, 17282, 17283, 17285, 17286, 17287, 17289, 17290, 17291, 17293, 17295, 17296, 17297, 17299, 17300, 17301, 17303, 17304, 17307, 17313, 17317, 17321, 17323, 17327, 17329, 17330, 17336, 17341, 17342, 17343, 17345, 17346, 17348, 17350, 17352, 17353, 17355, 17357, 17358, 17363, 17364, 17366, 17368, 17370, 17376, 17380, 17382, 17384, 17386, 17387, 17389, 17391, 17393, 17394, 17395, 17397, 17400, 17403, 17405, 17406, 17407, 17409, 17412, 17415, 17418, 17420, 17421, 17424, 17426, 17428, 17432, 17434, 17435, 17436, 17438, 17440, 17442, 17443, 17444, 17446, 17447, 17449, 17451, 17453, 17454, 17458, 17459, 17460, 17461, 17462, 17463, 17466, 17468, 17470, 17472, 17473, 17475, 17476, 17478, 17480, 17482, 17484, 17488, 17489, 17491, 17493, 17494, 17495, 17496, 17498, 17500, 17502, 17503, 17504, 17507, 17508, 17509, 17510, 17512, 17515, 17517, 17519, 17520, 17521, 17523, 17525, 17528, 17530, 17531, 17533, 17536, 17539, 17541, 17543, 17545, 17547, 17549, 17552, 17554, 17555, 17558, 17560, 17562, 17563, 17566, 17569, 17572, 17575, 17578, 17579, 17582, 17585, 17588, 17590, 17592, 17594, 17596, 17597, 17600, 17603, 17610, 17611, 17612, 17613, 17615, 17617, 17619, 17621, 17623, 17625, 17626, 17627, 17629, 17631, 17632, 17633, 17636, 17638, 17641, 17644, 17647, 17648, 17650, 17654, 17656, 17657, 17659, 17661, 17663, 17664, 17666, 17668, 17669, 17671, 17672, 17674, 17675, 17678, 17680, 17681, 17683, 17686, 17688, 17689, 17691, 17693, 17695, 17696, 17699, 17700, 17701, 17702, 17704, 17705, 17706, 17708, 17710, 17713, 17714, 17716, 17718, 17720, 17723, 17725, 17726, 17728, 17731, 17733, 17734, 17736, 17737, 17739, 17742, 17744, 17746, 17748, 17749, 17750, 17752, 17754, 17756, 17759, 17761, 17763, 17764, 17765, 17766, 17768, 17769, 17770, 17772, 17775, 17777, 17778, 17780, 17783, 17785, 17786, 17788, 17789, 17790, 17791, 17795, 17799, 17801, 17803, 17805, 17806, 17808, 17810, 17811, 17813, 17816, 17818, 17819, 17821, 17823, 17824, 17825, 17827, 17830, 17832, 17833, 17835, 17836, 17837, 17840, 17841, 17843, 17845, 17846, 17848, 17850, 17851, 17852, 17854, 17856, 17858, 17859, 17863, 17867, 17871, 17873, 17877, 17878, 17881, 17884, 17886, 17888, 17890, 17893, 17895, 17897, 17899, 17902, 17905, 17906, 17909, 17910, 17912, 17914, 17915, 17917, 17919, 17920, 17923, 17924, 17926, 17928, 17931, 17932, 17935, 17938, 17941, 17943, 17944, 17948, 17950, 17952, 17954, 17955, 17957, 17958, 17959, 17962, 17963, 17964, 17966, 17969, 17971, 17973, 17975, 17977, 17978, 17980, 17983, 17985, 17986, 17988, 17991, 17993, 17994, 17996, 17997, 17998, 18000, 18004, 18006, 18007, 18009, 18010, 18012, 18013, 18016, 18017, 18019, 18020, 18022, 18025, 18027, 18028, 18030, 18032, 18034, 18039, 18040, 18041, 18042, 18043, 18044, 18045, 18048, 18050, 18052, 18053, 18054, 18056, 18062, 18065, 18066, 18068, 18069, 18071, 18074, 18078, 18079, 18083, 18085, 18086, 18087, 18088, 18089, 18094, 18095, 18096, 18097, 18100, 18102, 18109, 18112, 18113, 18118, 18119, 18120, 18122, 18123, 18124, 18128, 18129, 18130, 18134, 18135, 18136, 18139, 18141, 18146, 18147, 18149, 18150, 18151, 18152, 18154, 18155, 18160, 18164, 18165, 18167, 18169, 18173, 18174, 18175, 18179, 18181, 18182, 18183, 18184, 18189, 18196, 18197, 18198, 18201, 18202, 18203, 18204, 18208, 18209, 18213, 18214, 18215, 18216, 18220, 18221, 18225, 18226, 18227, 18228, 18231, 18232, 18233, 18234, 18238, 18239, 18243, 18244, 18245, 18250, 18251, 18252, 18256, 18257, 18261, 18262, 18263, 18264, 18269, 18270, 18271, 18275, 18278, 18279, 18280, 18284, 18285, 18286, 18290, 18292, 18293, 18296, 18297, 18298, 18299, 18306, 18307, 18309, 18312, 18313, 18314, 18324, 18325, 18326, 18327, 18330, 18331, 18333, 18334, 18335, 18338, 18340, 18341, 18345, 18346, 18347, 18350, 18351, 18352, 18357, 18358, 18359, 18360, 18361, 18365, 18369, 18370, 18371, 18372, 18373, 18374, 18377, 18379, 18380, 18385, 18386, 18388, 18389, 18394, 18396, 18397, 18398, 18399, 18400, 18402, 18403, 18411, 18412, 18413, 18415, 18416, 18417, 18422, 18423, 18427, 18429, 18430, 18431, 18433, 18434, 18441, 18442, 18443, 18444, 18445, 18447, 18449, 18451, 18452, 18453, 18457, 18458, 18459, 18460, 18461, 18467, 18472, 18473, 18474, 18479, 18480, 18481, 18482, 18484, 18489, 18490, 18491, 18492, 18493, 18496, 18497, 18498, 18500, 18503, 18505, 18513, 18514, 18515, 18518, 18519, 18520, 18526, 18527, 18531, 18532, 18534, 18535, 18540, 18541, 18542, 18543, 18544, 18547, 18549, 18550, 18551, 18552, 18555, 18556, 18557, 18560, 18562, 18567, 18568, 18569, 18572, 18573, 18574, 18585, 18586, 18587, 18591, 18592, 18593, 18594, 18595, 18599, 18602, 18603, 18607, 18608, 18609, 18615, 18616, 18617, 18618, 18620, 18621, 18622, 18623, 18626, 18627, 18628, 18629, 18633, 18636, 18637, 18638, 18639, 18640, 18641, 18645, 18646, 18650, 18651, 18652, 18653, 18657, 18658, 18662, 18663, 18664, 18669, 18670, 18671, 18672, 18673, 18677, 18678, 18679, 18684, 18685, 18686, 18687, 18689, 18690, 18691, 18699, 18700, 18701, 18703, 18706, 18708, 18709, 18710, 18712, 18713, 18718, 18722, 18725, 18726, 18727, 18728, 18732, 18733, 18736, 18738, 18739, 18741, 18742, 18748, 18750, 18751, 18752, 18754, 18756, 18758, 18759, 18763, 18767, 18770, 18771, 18772, 18774, 18777, 18778, 18783, 18785, 18788, 18790, 18793, 18795, 18801, 18803, 18804, 18810, 18811, 18812, 18814, 18815, 18817, 18818, 18820, 18821, 18824, 18826, 18827, 18829, 18834, 18835, 18836, 18838, 18841, 18843, 18845, 18846, 18849, 18850, 18851, 18852, 18857, 18859, 18861, 18862, 18863, 18864, 18865, 18867, 18872, 18873, 18876, 18878, 18880, 18886, 18887, 18891, 18892, 18893, 18895, 18897, 18903, 18904, 18905, 18906, 18911, 18912, 18913, 18916, 18917, 18918, 18923, 18924, 18925, 18928, 18929, 18930, 18931, 18935, 18936, 18940, 18941, 18942, 18943, 18947, 18948, 18952, 18953, 18954, 18955, 18959, 18960, 18965, 18966, 18967, 18970, 18971, 18972, 18973, 18977, 18978, 18982, 18983, 18984, 18985, 18989, 18990, 18991, 18996, 18997, 19001, 19002, 19003, 19004, 19008, 19010, 19011, 19012, 19018, 19020, 19021, 19023, 19026, 19027, 19031, 19035, 19037, 19038, 19039, 19040, 19041, 19048, 19050, 19051, 19053, 19054, 19055, 19060, 19063, 19064, 19065, 19067, 19068, 19070, 19072, 19073, 19077, 19078, 19079, 19080, 19086, 19087, 19088, 19089, 19093, 19094, 19098, 19099, 19100, 19101, 19104, 19106, 19108, 19109, 19110, 19112, 19114, 19116, 19117, 19118, 19119, 19125, 19126, 19127, 19128, 19132, 19133, 19134, 19141, 19142, 19143, 19144, 19145, 19147, 19151, 19153, 19154, 19155, 19156, 19157, 19158, 19162, 19167, 19172, 19173, 19176, 19178, 19179, 19180, 19184, 19187, 19188, 19189, 19190, 19191, 19192, 19196, 19197, 19202, 19203, 19204, 19207, 19211, 19212, 19214, 19215, 19216, 19218, 19219, 19222, 19224, 19225, 19230, 19232, 19236, 19237, 19238, 19241, 19242, 19243, 19248, 19249, 19250, 19254, 19255, 19256, 19257, 19261, 19262, 19267, 19268, 19270, 19273, 19275, 19276, 19277, 19278, 19282, 19283, 19286, 19288, 19289, 19290, 19294, 19295, 19296, 19297, 19301, 19302, 19303, 19308, 19309, 19310, 19313, 19314, 19315, 19320, 19321, 19323, 19325, 19330, 19331, 19332, 19333, 19338, 19339, 19341, 19345, 19346, 19347, 19348, 19352, 19353, 19354, 19360, 19363, 19364, 19366, 19367, 19368, 19369, 19373, 19374, 19378, 19379, 19380, 19381, 19385, 19386, 19391, 19392, 19393, 19396, 19397, 19398, 19403, 19404, 19405, 19406, 19407, 19408, 19410, 19411, 19415, 19416, 19417, 19418, 19419, 19420, 19421, 19422, 19424, 19425, 19428, 19430, 19431, 19432, 19436, 19437, 19438, 19442, 19445, 19446, 19447, 19456, 19460, 19462, 19463, 19464, 19465, 19466, 19467, 19469, 19470, 19473, 19475, 19476, 19478, 19479, 19482, 19483, 19484, 19485, 19488, 19489, 19491, 19493, 19496, 19499, 19500, 19501, 19505, 19507, 19509, 19513, 19514, 19515, 19516, 19517, 19518, 19522, 19524, 19525, 19529, 19530, 19533, 19536, 19538, 19541, 19544, 19545, 19546, 19548, 19552, 19553, 19555, 19556, 19557, 19559, 19560, 19561, 19562, 19565, 19567, 19572, 19577, 19579, 19580, 19581, 19583, 19584, 19585, 19586, 19589, 19592, 19594, 19599, 19603, 19604, 19612, 19613, 19614, 19615, 19617, 19618, 19619, 19620, 19621, 19622, 19628, 19630, 19633, 19636, 19637, 19638, 19641, 19643, 19644, 19645, 19648, 19649, 19651, 19654, 19655, 19656, 19657, 19658, 19659, 19664, 19666, 19669, 19670, 19674, 19675, 19676, 19677, 19679, 19680, 19683, 19684, 19686, 19689, 19690, 19692, 19693, 19695, 19696, 19697, 19698, 19702, 19703, 19704, 19707, 19708, 19709, 19714, 19715, 19716, 19718, 19719, 19723, 19725, 19726, 19727, 19728, 19734, 19735, 19736, 19737, 19741, 19742, 19743, 19746, 19747, 19748, 19753, 19754, 19755, 19756, 19757, 19758, 19760, 19761, 19765, 19766, 19771, 19772, 19773, 19776, 19777, 19779, 19781, 19783, 19784, 19785, 19790, 19791, 19798, 19799, 19800, 19801, 19802, 19803, 19804, 19806, 19812, 19819, 19820, 19821, 19822, 19824, 19829, 19830, 19832, 19833, 19834, 19835, 19836, 19837, 19838, 19843, 19844, 19845, 19847, 19852, 19853, 19854, 19857, 19858, 19861, 19862, 19865, 19866, 19868, 19869, 19871, 19872, 19874, 19879, 19880, 19881, 19885, 19888, 19889, 19890, 19892, 19895, 19897, 19899, 19902, 19904, 19906, 19910, 19911, 19914, 19916, 19917, 19918, 19919, 19920, 19922, 19924, 19925, 19927, 19932, 19933, 19937, 19941, 19942, 19943, 19944, 19945, 19946, 19947, 19949, 19954, 19955, 19956, 19959, 19964, 19965, 19967, 19968, 19970, 19972, 19975, 19976, 19977, 19978, 19979, 19980, 19981, 19983, 19986, 19988, 19989, 19990, 19993, 19995, 19996, 19997, 19998, 20000, 20002, 20004, 20007, 20008, 20009, 20011, 20012, 20013, 20015, 20017, 20021, 20022, 20024, 20027, 20029, 20032, 20033, 20035, 20037, 20039, 20040, 20042, 20043, 20044, 20046, 20049, 20050, 20051, 20052, 20053, 20055, 20058, 20059, 20060, 20062, 20066, 20068, 20071, 20073, 20074, 20076, 20078, 20079, 20080, 20081, 20082, 20083, 20087, 20089, 20090, 20091, 20093, 20095, 20097, 20106, 20111, 20113, 20117, 20120, 20121, 20123, 20124, 20125, 20126, 20128, 20129, 20130, 20131, 20132, 20133, 20136, 20137, 20138, 20139, 20140, 20142, 20144, 20146, 20148, 20150, 20153, 20155, 20157, 20159, 20160, 20162, 20163, 20165, 20166, 20168, 20169, 20170, 20174, 20177, 20178, 20179, 20180, 20183, 20189, 20190, 20194, 20195, 20197, 20198, 20199, 20201, 20202, 20203, 20204, 20208, 20209, 20210, 20211, 20215, 20216, 20218, 20219, 20221, 20223, 20224, 20225, 20228, 20229, 20230, 20235, 20237, 20240, 20241, 20243, 20245, 20246, 20247, 20248, 20252, 20254, 20255, 20256, 20259, 20260, 20262, 20263, 20264, 20266, 20269, 20270, 20272, 20273, 20274, 20276, 20279, 20281, 20286, 20287, 20289, 20292, 20297, 20298, 20301, 20302, 20303, 20306, 20307, 20308, 20310, 20311, 20315, 20316, 20318, 20319, 20321, 20322, 20325, 20327, 20329, 20331, 20332, 20335, 20336, 20337, 20338, 20339, 20340, 20341, 20342, 20343, 20344, 20345, 20346, 20349, 20351, 20352, 20353, 20354, 20355, 20357, 20358, 20359, 20360, 20361, 20362, 20363, 20364, 20365, 20366, 20367, 20369, 20370, 20371, 20372, 20373, 20374, 20375, 20376, 20377, 20378, 20379, 20380, 20381, 20382, 20383, 20384, 20385, 20386, 20387, 20388, 20389, 20390, 20391, 20392, 20393, 20394, 20395, 20396, 20397, 20398, 20399, 20400, 20401, 20402, 20403, 20404, 20405, 20406, 20407, 20408, 20409, 20410, 20411, 20412, 20413, 20414, 20415, 20416, 20417, 20418, 20419, 20420, 20421, 20422, 20423, 20424, 20425, 20426, 20456, 20457, 20458, 20459, 20460, 20461, 20462, 20463, 20464, 20465, 20466, 20467, 20468, 20475, 20476, 20477, 20478, 20479, 20480, 20481, 20482, 20483, 20484, 20485, 20486, 20487, 20488, 20489, 20490, 20491, 20492, 20503, 20504, 20505, 20506, 20507, 20508, 20509, 20510, 20511, 20512, 20513, 20514, 20515, 20516, 20517, 20518, 20519, 20520, 20521, 20522, 20523, 20524, 20525, 20526, 20527, 20528, 20529, 20530, 20531, 20532, 20533, 20534, 20536, 20537, 20538, 20539, 20540, 20541, 20542, 20543, 20544, 20545, 20546, 20547, 20548, 20549, 20550, 20551, 20552, 20553, 20554, 20555, 20556, 20557, 20558, 20559, 20560, 20561, 20562, 20563, 20564, 20565, 20566, 20567, 20568, 20569, 20570, 20571, 20572, 20574, 20575, 20576, 20577, 20578, 20579, 20580, 20581, 20582, 20583, 20584, 20585, 20586, 20587, 20588, 20589, 20590, 20591, 20592, 20593, 20594, 20595, 20596, 20597, 20598, 20599, 20600, 20601, 20602, 20603, 20604, 20605, 20606, 20607, 20608, 20609, 20610, 20611, 20613, 20616, 20619, 20622, 20625, 20628, 20631, 20634, 20637, 20640, 20656, 20657, 20658, 20659, 20660, 20661,
warning: Skipping property vector 'PointMergeMap' - not defined on cells or nodes.
info: 1 property vectors copied, 1 vectors skipped.
info: 16 hole(s) detected within the mesh
0
ogs.cli.reviseMesh(i="mixed_dimensional_grid_2.vtu", o="temp.vtu")… (click to toggle)
ogs.cli.NodeReordering(
    i="mixed_dimensional_grid_2.vtu", o="mixed_dimensional_grid_2.vtu"
ogs.cli.checkMesh("mixed_dimensional_grid_2.vtu", v=True)
info: Mesh read: 10340 nodes, 20662 elements.
info: Simplifying the mesh...
warning: Property MaterialIDs exists but does not have the requested mesh item type node.
warning: Property MaterialIDs exists but does not have the requested type f.
warning: Property MaterialIDs exists but does not have the requested type d.
warning: Property PointMergeMap exists but does not have the requested type i.
warning: Property PointMergeMap exists but does not have the requested type f.
warning: Property PointMergeMap exists but does not have the requested type d.
warning: PropertyVector PointMergeMap not being converted.
info: Revised mesh: 10340 nodes, 20662 elements.
info: Reordering nodes...
info: Corrected 0 elements.
info: VTU file written.
info: Memory size: 4 MiB
info: Time for reading: 0.0232141 s
info: Axis aligned bounding box: 	x [-1.77636e-15, 100) (extent 100)
	y [0, 100) (extent 100)
	z [0, 100) (extent 100)
info: Min/max edge lengths: [0.0336252, 6.85976]
info: 	Triangles: 20662
info: Mesh Quality Control:
info: 10360 elements found with wrong node order.
ElementIDs: 0, 2, 5, 6, 8, 9, 13, 14, 15, 17, 18, 20, 22, 24, 26, 27, 28, 30, 33, 35, 37, 39, 41, 42, 43, 45, 47, 50, 51, 53, 57, 59, 62, 63, 66, 67, 70, 72, 73, 77, 80, 83, 85, 86, 88, 92, 95, 97, 98, 100, 101, 104, 105, 107, 109, 110, 113, 115, 117, 119, 120, 124, 128, 132, 138, 142, 146, 151, 152, 154, 155, 156, 158, 159, 160, 161, 162, 164, 166, 167, 168, 170, 171, 178, 181, 185, 188, 193, 196, 198, 200, 202, 203, 204, 206, 208, 212, 214, 216, 220, 223, 226, 230, 232, 235, 237, 245, 249, 253, 257, 261, 267, 269, 273, 276, 277, 278, 279, 281, 282, 283, 284, 286, 287, 288, 291, 292, 293, 295, 296, 297, 299, 301, 303, 304, 307, 309, 311, 313, 315, 317, 319, 321, 322, 325, 326, 328, 330, 331, 333, 335, 337, 339, 343, 346, 347, 349, 351, 354, 355, 359, 360, 363, 366, 367, 369, 370, 372, 373, 375, 377, 380, 384, 386, 387, 389, 391, 392, 395, 398, 401, 402, 405, 406, 409, 410, 412, 413, 417, 420, 424, 428, 431, 433, 434, 435, 436, 437, 439, 440, 441, 444, 446, 449, 451, 454, 456, 459, 461, 464, 465, 467, 469, 471, 472, 473, 475, 478, 480, 481, 483, 486, 488, 490, 493, 495, 497, 501, 505, 508, 510, 511, 512, 513, 515, 516, 517, 519, 520, 521, 523, 525, 527, 528, 530, 532, 534, 536, 539, 541, 542, 544, 547, 548, 550, 552, 553, 556, 558, 559, 560, 562, 564, 566, 568, 570, 571, 572, 573, 576, 580, 582, 585, 586, 588, 589, 592, 593, 596, 597, 598, 599, 601, 603, 608, 609, 612, 613, 615, 616, 617, 620, 621, 625, 628, 629, 631, 634, 635, 637, 638, 639, 641, 642, 643, 647, 649, 651, 653, 655, 657, 658, 659, 660, 662, 664, 666, 668, 671, 673, 675, 676, 678, 680, 681, 682, 683, 685, 686, 688, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 702, 703, 705, 713, 715, 716, 719, 721, 722, 727, 728, 730, 731, 732, 736, 737, 738, 741, 742, 743, 747, 748, 749, 750, 753, 757, 758, 760, 761, 762, 764, 769, 770, 771, 772, 775, 778, 779, 784, 785, 786, 787, 789, 790, 791, 796, 797, 798, 800, 803, 805, 806, 807, 808, 812, 813, 818, 819, 820, 822, 823, 829, 830, 831, 832, 836, 841, 843, 844, 845, 846, 847, 849, 852, 854, 856, 857, 858, 861, 863, 865, 866, 867, 868, 871, 872, 878, 879, 880, 885, 886, 887, 891, 894, 895, 896, 897, 898, 899, 901, 902, 906, 907, 908, 912, 914, 915, 916, 917, 919, 920, 926, 930, 934, 935, 937, 939, 943, 944, 946, 947, 948, 950, 952, 956, 959, 960, 961, 963, 964, 965, 968, 969, 970, 972, 973, 974, 977, 978, 979, 980, 985, 986, 987, 990, 991, 992, 997, 998, 999, 1002, 1003, 1004, 1009, 1010, 1011, 1014, 1015, 1016, 1017, 1021, 1022, 1027, 1028, 1032, 1033, 1034, 1035, 1037, 1038, 1043, 1044, 1045, 1046, 1048, 1049, 1050, 1051, 1053, 1054, 1058, 1059, 1061, 1062, 1063, 1065, 1067, 1071, 1072, 1073, 1074, 1075, 1080, 1081, 1086, 1087, 1088, 1091, 1092, 1093, 1098, 1099, 1103, 1104, 1105, 1106, 1110, 1111, 1115, 1116, 1117, 1118, 1122, 1123, 1124, 1127, 1133, 1134, 1135, 1136, 1141, 1143, 1145, 1147, 1148, 1149, 1150, 1151, 1152, 1153, 1156, 1160, 1163, 1165, 1166, 1169, 1170, 1171, 1175, 1176, 1177, 1181, 1182, 1183, 1186, 1187, 1189, 1191, 1193, 1196, 1197, 1198, 1202, 1203, 1204, 1205, 1206, 1208, 1209, 1210, 1215, 1216, 1217, 1218, 1219, 1220, 1221, 1226, 1227, 1228, 1233, 1235, 1236, 1237, 1238, 1239, 1240, 1245, 1248, 1256, 1258, 1259, 1260, 1261, 1262, 1263, 1264, 1267, 1277, 1278, 1279, 1280, 1281, 1283, 1286, 1287, 1288, 1291, 1292, 1293, 1297, 1298, 1299, 1300, 1301, 1303, 1304, 1305, 1306, 1307, 1308, 1312, 1313, 1317, 1318, 1319, 1320, 1327, 1334, 1335, 1339, 1340, 1342, 1343, 1344, 1350, 1351, 1353, 1354, 1356, 1357, 1359, 1362, 1364, 1367, 1371, 1375, 1376, 1377, 1378, 1383, 1384, 1386, 1387, 1391, 1392, 1393, 1394, 1395, 1397, 1398, 1403, 1404, 1405, 1409, 1410, 1411, 1412, 1413, 1415, 1416, 1420, 1424, 1425, 1426, 1427, 1428, 1430, 1436, 1437, 1438, 1441, 1442, 1443, 1448, 1449, 1450, 1451, 1453, 1454, 1461, 1462, 1463, 1466, 1467, 1468, 1473, 1474, 1475, 1477, 1478, 1482, 1483, 1484, 1487, 1488, 1489, 1490, 1494, 1495, 1496, 1497, 1501, 1504, 1506, 1511, 1512, 1515, 1516, 1517, 1518, 1521, 1522, 1527, 1528, 1529, 1530, 1535, 1537, 1538, 1540, 1541, 1545, 1547, 1548, 1554, 1555, 1558, 1559, 1560, 1561, 1562, 1563, 1565, 1566, 1570, 1571, 1572, 1577, 1578, 1582, 1583, 1584, 1585, 1588, 1589, 1590, 1595, 1597, 1598, 1603, 1604, 1607, 1608, 1611, 1612, 1613, 1617, 1618, 1619, 1622, 1623, 1624, 1625, 1629, 1630, 1635, 1636, 1637, 1638, 1641, 1645, 1647, 1648, 1649, 1650, 1652, 1657, 1658, 1660, 1661, 1662, 1667, 1669, 1670, 1672, 1673, 1674, 1678, 1679, 1680, 1681, 1682, 1685, 1687, 1692, 1694, 1695, 1696, 1697, 1703, 1704, 1705, 1709, 1710, 1715, 1716, 1717, 1718, 1720, 1725, 1726, 1727, 1728, 1729, 1730, 1736, 1737, 1738, 1739, 1743, 1744, 1745, 1746, 1748, 1749, 1750, 1755, 1756, 1757, 1758, 1764, 1765, 1766, 1767, 1771, 1772, 1777, 1778, 1779, 1782, 1786, 1787, 1788, 1789, 1790, 1791, 1793, 1794, 1796, 1801, 1802, 1803, 1805, 1808, 1809, 1813, 1814, 1816, 1819, 1821, 1823, 1824, 1828, 1829, 1833, 1834, 1835, 1836, 1841, 1842, 1843, 1845, 1848, 1852, 1854, 1856, 1859, 1860, 1863, 1865, 1869, 1871, 1874, 1877, 1878, 1880, 1881, 1882, 1887, 1888, 1891, 1894, 1899, 1900, 1901, 1903, 1904, 1905, 1906, 1909, 1910, 1913, 1916, 1918, 1921, 1924, 1926, 1928, 1929, 1934, 1935, 1937, 1939, 1941, 1944, 1947, 1950, 1951, 1952, 1953, 1955, 1960, 1961, 1965, 1966, 1968, 1969, 1972, 1974, 1976, 1978, 1979, 1982, 1984, 1985, 1987, 1990, 1992, 1993, 1997, 2002, 2003, 2004, 2005, 2006, 2007, 2009, 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2020, 2022, 2025, 2026, 2027, 2028, 2029, 2030, 2032, 2033, 2035, 2036, 2037, 2039, 2040, 2043, 2045, 2046, 2049, 2050, 2052, 2059, 2060, 2061, 2062, 2064, 2065, 2071, 2072, 2079, 2080, 2082, 2085, 2090, 2092, 2094, 2095, 2100, 2102, 2106, 2110, 2112, 2114, 2116, 2118, 2120, 2122, 2125, 2128, 2130, 2133, 2135, 2136, 2143, 2145, 2147, 2148, 2149, 2150, 2152, 2155, 2157, 2158, 2159, 2162, 2164, 2166, 2169, 2171, 2173, 2174, 2176, 2177, 2180, 2181, 2182, 2183, 2185, 2190, 2191, 2193, 2194, 2197, 2198, 2199, 2202, 2203, 2204, 2206, 2207, 2208, 2212, 2215, 2216, 2217, 2220, 2221, 2223, 2227, 2228, 2229, 2231, 2232, 2233, 2234, 2235, 2239, 2240, 2241, 2242, 2243, 2246, 2249, 2250, 2251, 2252, 2254, 2258, 2264, 2267, 2268, 2270, 2272, 2273, 2274, 2275, 2276, 2277, 2279, 2284, 2286, 2287, 2288, 2289, 2290, 2294, 2295, 2296, 2298, 2300, 2301, 2305, 2306, 2307, 2308, 2311, 2315, 2317, 2319, 2320, 2324, 2325, 2326, 2327, 2329, 2332, 2334, 2337, 2338, 2339, 2340, 2343, 2344, 2347, 2349, 2352, 2356, 2359, 2360, 2361, 2363, 2364, 2367, 2368, 2371, 2373, 2375, 2379, 2380, 2381, 2384, 2388, 2389, 2393, 2394, 2396, 2397, 2399, 2402, 2405, 2406, 2408, 2409, 2413, 2414, 2417, 2418, 2420, 2422, 2425, 2427, 2428, 2429, 2433, 2436, 2437, 2438, 2440, 2443, 2445, 2446, 2447, 2449, 2451, 2453, 2457, 2458, 2462, 2468, 2472, 2474, 2475, 2476, 2480, 2483, 2485, 2486, 2487, 2489, 2491, 2493, 2495, 2497, 2498, 2500, 2502, 2503, 2505, 2506, 2508, 2509, 2511, 2513, 2514, 2516, 2517, 2524, 2528, 2530, 2534, 2535, 2541, 2545, 2547, 2551, 2553, 2557, 2561, 2562, 2563, 2565, 2567, 2568, 2569, 2570, 2571, 2573, 2574, 2576, 2580, 2582, 2586, 2588, 2592, 2594, 2598, 2604, 2608, 2613, 2616, 2618, 2619, 2620, 2621, 2622, 2624, 2625, 2626, 2628, 2629, 2633, 2636, 2638, 2639, 2644, 2645, 2648, 2649, 2650, 2651, 2653, 2654, 2656, 2659, 2661, 2662, 2663, 2666, 2667, 2668, 2670, 2672, 2674, 2675, 2676, 2678, 2681, 2682, 2685, 2687, 2688, 2689, 2690, 2692, 2695, 2697, 2698, 2700, 2702, 2703, 2705, 2707, 2709, 2710, 2711, 2714, 2716, 2718, 2720, 2722, 2723, 2724, 2726, 2727, 2728, 2732, 2734, 2736, 2738, 2739, 2741, 2743, 2745, 2747, 2749, 2751, 2753, 2755, 2756, 2757, 2759, 2763, 2767, 2769, 2773, 2779, 2781, 2783, 2785, 2787, 2788, 2790, 2793, 2796, 2800, 2802, 2804, 2805, 2806, 2807, 2809, 2811, 2813, 2814, 2815, 2817, 2819, 2820, 2824, 2826, 2827, 2828, 2830, 2831, 2833, 2837, 2839, 2840, 2841, 2843, 2844, 2845, 2848, 2850, 2854, 2855, 2857, 2859, 2861, 2862, 2865, 2867, 2868, 2871, 2873, 2875, 2877, 2878, 2879, 2881, 2882, 2884, 2885, 2886, 2887, 2889, 2890, 2892, 2894, 2895, 2896, 2898, 2900, 2903, 2906, 2908, 2912, 2914, 2917, 2919, 2921, 2923, 2924, 2925, 2928, 2930, 2934, 2935, 2938, 2940, 2941, 2943, 2944, 2945, 2948, 2949, 2952, 2955, 2959, 2960, 2962, 2966, 2968, 2969, 2971, 2975, 2978, 2979, 2980, 2982, 2984, 2987, 2989, 2991, 2993, 2995, 2998, 3004, 3007, 3009, 3010, 3011, 3016, 3017, 3020, 3021, 3023, 3026, 3028, 3029, 3030, 3032, 3034, 3035, 3039, 3041, 3042, 3045, 3050, 3053, 3054, 3058, 3061, 3067, 3069, 3070, 3071, 3072, 3079, 3081, 3083, 3084, 3085, 3088, 3093, 3094, 3095, 3096, 3102, 3103, 3104, 3107, 3111, 3112, 3113, 3114, 3115, 3120, 3121, 3122, 3123, 3126, 3127, 3130, 3131, 3136, 3141, 3142, 3143, 3144, 3145, 3146, 3148, 3149, 3154, 3155, 3162, 3164, 3165, 3166, 3167, 3172, 3173, 3174, 3175, 3176, 3180, 3181, 3182, 3183, 3184, 3185, 3186, 3187, 3192, 3193, 3197, 3198, 3199, 3205, 3211, 3213, 3214, 3217, 3218, 3219, 3223, 3224, 3226, 3227, 3232, 3233, 3234, 3237, 3240, 3241, 3242, 3243, 3247, 3250, 3251, 3252, 3254, 3259, 3261, 3263, 3264, 3265, 3270, 3272, 3273, 3274, 3275, 3276, 3277, 3280, 3284, 3285, 3286, 3287, 3288, 3293, 3294, 3296, 3297, 3299, 3306, 3307, 3308, 3309, 3310, 3311, 3316, 3317, 3318, 3320, 3323, 3325, 3329, 3330, 3331, 3334, 3335, 3336, 3341, 3342, 3344, 3346, 3351, 3355, 3356, 3358, 3360, 3361, 3364, 3366, 3367, 3368, 3371, 3374, 3375, 3377, 3378, 3379, 3380, 3382, 3383, 3385, 3386, 3389, 3390, 3391, 3392, 3393, 3396, 3397, 3398, 3400, 3402, 3403, 3404, 3406, 3412, 3413, 3416, 3417, 3418, 3419, 3423, 3426, 3427, 3429, 3431, 3432, 3433, 3435, 3436, 3438, 3439, 3440, 3442, 3445, 3447, 3448, 3450, 3451, 3452, 3458, 3459, 3460, 3461, 3465, 3466, 3469, 3470, 3471, 3478, 3479, 3480, 3481, 3483, 3484, 3485, 3486, 3492, 3493, 3494, 3495, 3499, 3500, 3501, 3505, 3506, 3507, 3508, 3511, 3512, 3513, 3514, 3515, 3517, 3518, 3520, 3522, 3523, 3524, 3526, 3527, 3530, 3532, 3534, 3535, 3537, 3540, 3544, 3545, 3546, 3548, 3550, 3554, 3555, 3557, 3558, 3560, 3563, 3564, 3566, 3567, 3569, 3570, 3573, 3574, 3577, 3580, 3585, 3588, 3590, 3591, 3594, 3595, 3597, 3599, 3600, 3601, 3602, 3603, 3611, 3614, 3617, 3618, 3621, 3622, 3628, 3629, 3630, 3631, 3632, 3633, 3634, 3638, 3639, 3644, 3645, 3646, 3649, 3650, 3651, 3656, 3657, 3658, 3660, 3661, 3665, 3666, 3668, 3669, 3670, 3673, 3674, 3676, 3681, 3682, 3683, 3684, 3685, 3686, 3687, 3692, 3693, 3694, 3697, 3699, 3701, 3702, 3705, 3709, 3710, 3711, 3716, 3717, 3721, 3722, 3723, 3724, 3725, 3726, 3727, 3728, 3733, 3734, 3735, 3739, 3741, 3743, 3745, 3746, 3747, 3748, 3750, 3751, 3755, 3756, 3757, 3760, 3761, 3762, 3767, 3768, 3769, 3771, 3773, 3774, 3779, 3780, 3781, 3785, 3786, 3787, 3788, 3789, 3792, 3793, 3798, 3799, 3805, 3806, 3808, 3818, 3819, 3820, 3822, 3824, 3825, 3826, 3827, 3829, 3830, 3831, 3832, 3833, 3834, 3835, 3836, 3837, 3838, 3839, 3842, 3843, 3844, 3850, 3852, 3855, 3858, 3859, 3860, 3862, 3863, 3866, 3869, 3873, 3877, 3878, 3880, 3881, 3886, 3887, 3895, 3896, 3901, 3903, 3904, 3907, 3908, 3913, 3914, 3917, 3918, 3920, 3921, 3923, 3924, 3928, 3930, 3931, 3934, 3935, 3938, 3942, 3945, 3946, 3948, 3951, 3953, 3955, 3956, 3957, 3958, 3963, 3964, 3965, 3969, 3970, 3971, 3972, 3975, 3977, 3978, 3979, 3980, 3981, 3982, 3986, 3987, 3988, 3989, 3992, 3994, 3995, 3997, 3998, 3999, 4002, 4003, 4007, 4010, 4011, 4013, 4014, 4017, 4021, 4022, 4026, 4027, 4028, 4035, 4036, 4038, 4040, 4042, 4046, 4047, 4048, 4049, 4051, 4053, 4055, 4057, 4061, 4063, 4067, 4068, 4069, 4071, 4076, 4077, 4079, 4081, 4083, 4085, 4086, 4088, 4089, 4090, 4091, 4092, 4093, 4095, 4096, 4097, 4098, 4101, 4103, 4105, 4106, 4108, 4110, 4111, 4112, 4117, 4118, 4119, 4120, 4122, 4125, 4128, 4129, 4130, 4132, 4136, 4138, 4140, 4142, 4143, 4144, 4145, 4148, 4149, 4151, 4154, 4155, 4158, 4159, 4162, 4163, 4165, 4168, 4170, 4172, 4173, 4174, 4176, 4178, 4182, 4183, 4184, 4185, 4187, 4191, 4195, 4199, 4201, 4202, 4204, 4205, 4207, 4209, 4210, 4212, 4214, 4216, 4218, 4219, 4221, 4225, 4227, 4228, 4232, 4234, 4235, 4237, 4238, 4239, 4240, 4242, 4243, 4245, 4247, 4250, 4251, 4253, 4257, 4259, 4260, 4262, 4263, 4268, 4270, 4272, 4274, 4276, 4279, 4280, 4282, 4284, 4286, 4288, 4294, 4298, 4302, 4306, 4309, 4313, 4317, 4319, 4320, 4321, 4322, 4323, 4324, 4326, 4327, 4328, 4330, 4332, 4338, 4340, 4341, 4345, 4346, 4347, 4349, 4350, 4352, 4353, 4354, 4355, 4356, 4357, 4359, 4360, 4361, 4362, 4365, 4368, 4369, 4370, 4371, 4372, 4374, 4376, 4380, 4383, 4390, 4394, 4396, 4400, 4401, 4402, 4406, 4409, 4410, 4412, 4415, 4417, 4419, 4420, 4422, 4424, 4425, 4426, 4428, 4429, 4430, 4432, 4435, 4436, 4437, 4439, 4442, 4444, 4447, 4450, 4452, 4454, 4455, 4456, 4458, 4459, 4461, 4463, 4464, 4465, 4466, 4468, 4469, 4470, 4472, 4474, 4476, 4477, 4479, 4480, 4483, 4485, 4488, 4490, 4491, 4493, 4494, 4495, 4498, 4505, 4506, 4507, 4509, 4512, 4513, 4517, 4518, 4520, 4522, 4525, 4526, 4528, 4529, 4531, 4533, 4534, 4536, 4537, 4540, 4541, 4542, 4543, 4545, 4548, 4551, 4552, 4553, 4555, 4556, 4558, 4559, 4561, 4563, 4571, 4572, 4577, 4578, 4580, 4581, 4584, 4585, 4586, 4588, 4589, 4591, 4594, 4596, 4598, 4603, 4604, 4606, 4608, 4610, 4612, 4615, 4617, 4619, 4622, 4624, 4626, 4629, 4631, 4633, 4635, 4637, 4640, 4642, 4644, 4646, 4649, 4651, 4654, 4656, 4658, 4660, 4661, 4663, 4665, 4668, 4669, 4671, 4673, 4676, 4677, 4682, 4684, 4685, 4687, 4689, 4692, 4694, 4698, 4700, 4701, 4703, 4706, 4708, 4709, 4711, 4714, 4716, 4718, 4719, 4720, 4722, 4723, 4725, 4727, 4728, 4730, 4732, 4734, 4738, 4740, 4742, 4746, 4754, 4755, 4758, 4759, 4762, 4764, 4767, 4769, 4770, 4771, 4773, 4775, 4777, 4778, 4781, 4784, 4785, 4787, 4788, 4792, 4795, 4798, 4800, 4802, 4805, 4807, 4808, 4810, 4813, 4815, 4818, 4819, 4822, 4823, 4825, 4827, 4829, 4832, 4833, 4835, 4837, 4840, 4843, 4845, 4846, 4847, 4848, 4851, 4857, 4859, 4860, 4861, 4863, 4864, 4865, 4867, 4871, 4872, 4873, 4876, 4878, 4879, 4880, 4882, 4883, 4884, 4886, 4887, 4891, 4896, 4898, 4901, 4902, 4905, 4906, 4908, 4909, 4910, 4911, 4913, 4914, 4917, 4921, 4922, 4924, 4926, 4928, 4929, 4930, 4932, 4933, 4934, 4936, 4938, 4941, 4942, 4945, 4946, 4947, 4951, 4952, 4953, 4955, 4956, 4959, 4960, 4961, 4962, 4965, 4969, 4970, 4972, 4974, 4976, 4978, 4983, 4985, 4988, 4991, 4993, 4996, 4997, 5000, 5005, 5007, 5008, 5009, 5012, 5016, 5018, 5020, 5021, 5023, 5027, 5028, 5029, 5030, 5037, 5038, 5039, 5040, 5041, 5045, 5046, 5047, 5048, 5052, 5053, 5057, 5058, 5059, 5060, 5064, 5065, 5069, 5070, 5071, 5072, 5076, 5077, 5078, 5080, 5081, 5087, 5088, 5089, 5090, 5091, 5092, 5096, 5097, 5098, 5099, 5105, 5111, 5112, 5113, 5117, 5118, 5119, 5120, 5121, 5122, 5123, 5124, 5125, 5126, 5131, 5132, 5136, 5137, 5138, 5139, 5142, 5143, 5144, 5149, 5150, 5151, 5153, 5154, 5158, 5161, 5162, 5163, 5165, 5166, 5170, 5171, 5172, 5175, 5176, 5177, 5178, 5181, 5182, 5183, 5188, 5189, 5190, 5191, 5194, 5198, 5199, 5200, 5201, 5202, 5205, 5206, 5208, 5214, 5216, 5217, 5218, 5219, 5220, 5224, 5225, 5226, 5227, 5233, 5234, 5235, 5239, 5240, 5243, 5244, 5245, 5251, 5252, 5255, 5256, 5257, 5258, 5259, 5261, 5262, 5263, 5267, 5268, 5269, 5273, 5278, 5282, 5283, 5284, 5285, 5286, 5288, 5289, 5290, 5294, 5295, 5296, 5300, 5301, 5302, 5303, 5304, 5305, 5306, 5312, 5319, 5320, 5321, 5322, 5324, 5328, 5331, 5332, 5335, 5336, 5337, 5341, 5344, 5345, 5346, 5351, 5353, 5355, 5356, 5357, 5360, 5362, 5363, 5364, 5367, 5368, 5371, 5372, 5375, 5377, 5378, 5379, 5384, 5385, 5386, 5387, 5388, 5389, 5395, 5396, 5397, 5398, 5401, 5404, 5405, 5406, 5407, 5411, 5412, 5413, 5416, 5418, 5420, 5421, 5423, 5425, 5427, 5430, 5432, 5434, 5435, 5436, 5438, 5439, 5440, 5442, 5446, 5448, 5458, 5459, 5460, 5464, 5465, 5466, 5467, 5471, 5472, 5476, 5477, 5478, 5479, 5480, 5486, 5488, 5491, 5495, 5496, 5497, 5498, 5503, 5504, 5505, 5507, 5508, 5509, 5521, 5522, 5523, 5524, 5528, 5531, 5532, 5533, 5534, 5536, 5540, 5541, 5542, 5546, 5547, 5548, 5549, 5550, 5551, 5552, 5559, 5563, 5565, 5566, 5567, 5571, 5574, 5575, 5576, 5580, 5581, 5582, 5589, 5590, 5591, 5592, 5593, 5594, 5595, 5596, 5597, 5598, 5599, 5600, 5601, 5607, 5608, 5609, 5613, 5616, 5617, 5620, 5621, 5622, 5624, 5626, 5627, 5632, 5635, 5636, 5637, 5639, 5642, 5643, 5644, 5646, 5648, 5651, 5652, 5656, 5657, 5658, 5659, 5661, 5663, 5664, 5667, 5668, 5669, 5671, 5672, 5675, 5680, 5681, 5683, 5684, 5685, 5690, 5691, 5692, 5695, 5698, 5699, 5700, 5704, 5705, 5709, 5711, 5712, 5714, 5715, 5716, 5717, 5718, 5719, 5721, 5722, 5725, 5726, 5727, 5728, 5729, 5731, 5732, 5733, 5736, 5737, 5740, 5741, 5742, 5744, 5745, 5746, 5749, 5750, 5751, 5753, 5755, 5756, 5758, 5759, 5763, 5765, 5766, 5768, 5771, 5773, 5775, 5777, 5778, 5780, 5781, 5783, 5786, 5787, 5789, 5790, 5794, 5795, 5796, 5798, 5801, 5806, 5807, 5810, 5811, 5812, 5813, 5815, 5818, 5820, 5824, 5830, 5832, 5837, 5838, 5839, 5840, 5844, 5845, 5847, 5848, 5850, 5856, 5857, 5858, 5859, 5862, 5865, 5867, 5868, 5870, 5872, 5874, 5875, 5877, 5878, 5883, 5884, 5885, 5888, 5889, 5890, 5895, 5896, 5897, 5898, 5899, 5904, 5905, 5906, 5909, 5913, 5914, 5915, 5916, 5917, 5922, 5923, 5924, 5925, 5926, 5930, 5931, 5932, 5935, 5940, 5941, 5942, 5946, 5947, 5948, 5949, 5952, 5956, 5958, 5960, 5965, 5966, 5967, 5968, 5969, 5971, 5973, 5974, 5975, 5978, 5980, 5985, 5988, 5989, 5993, 5997, 6000, 6001, 6003, 6005, 6006, 6007, 6010, 6016, 6018, 6019, 6021, 6022, 6023, 6024, 6025, 6029, 6031, 6032, 6037, 6039, 6040, 6042, 6043, 6045, 6047, 6049, 6050, 6053, 6054, 6059, 6062, 6064, 6066, 6067, 6068, 6069, 6071, 6072, 6073, 6075, 6079, 6082, 6085, 6086, 6087, 6090, 6093, 6094, 6095, 6096, 6099, 6101, 6102, 6103, 6104, 6105, 6108, 6110, 6111, 6112, 6113, 6117, 6118, 6119, 6120, 6124, 6125, 6126, 6127, 6132, 6133, 6137, 6139, 6140, 6141, 6142, 6143, 6144, 6149, 6150, 6151, 6152, 6154, 6155, 6157, 6158, 6160, 6164, 6165, 6166, 6168, 6170, 6171, 6172, 6173, 6176, 6177, 6179, 6183, 6186, 6190, 6192, 6193, 6194, 6195, 6196, 6198, 6199, 6205, 6206, 6207, 6209, 6211, 6212, 6213, 6216, 6218, 6220, 6224, 6225, 6226, 6229, 6230, 6231, 6236, 6237, 6239, 6240, 6241, 6243, 6244, 6248, 6250, 6251, 6252, 6253, 6255, 6257, 6261, 6262, 6263, 6264, 6268, 6271, 6274, 6276, 6278, 6280, 6281, 6282, 6283, 6286, 6288, 6289, 6296, 6300, 6303, 6304, 6305, 6307, 6315, 6319, 6320, 6321, 6322, 6325, 6326, 6327, 6328, 6330, 6333, 6335, 6337, 6339, 6340, 6341, 6344, 6347, 6348, 6349, 6352, 6353, 6354, 6355, 6362, 6363, 6365, 6366, 6372, 6374, 6375, 6377, 6380, 6382, 6383, 6385, 6386, 6387, 6389, 6390, 6391, 6395, 6397, 6398, 6399, 6401, 6403, 6405, 6407, 6409, 6413, 6415, 6416, 6417, 6418, 6419, 6421, 6422, 6423, 6424, 6426, 6427, 6428, 6432, 6436, 6437, 6438, 6439, 6440, 6442, 6443, 6447, 6448, 6454, 6458, 6460, 6461, 6464, 6468, 6469, 6470, 6471, 6474, 6475, 6477, 6479, 6480, 6482, 6484, 6485, 6488, 6491, 6493, 6494, 6495, 6497, 6498, 6500, 6502, 6504, 6506, 6509, 6510, 6512, 6513, 6514, 6515, 6517, 6518, 6520, 6522, 6523, 6524, 6526, 6528, 6529, 6530, 6531, 6533, 6534, 6538, 6540, 6542, 6544, 6546, 6547, 6551, 6553, 6555, 6558, 6560, 6562, 6563, 6565, 6568, 6570, 6576, 6580, 6581, 6582, 6586, 6588, 6592, 6596, 6600, 6604, 6613, 6617, 6621, 6627, 6628, 6634, 6636, 6640, 6642, 6643, 6644, 6646, 6647, 6648, 6650, 6651, 6652, 6654, 6655, 6659, 6661, 6663, 6667, 6671, 6675, 6679, 6685, 6686, 6687, 6688, 6689, 6691, 6692, 6694, 6696, 6698, 6701, 6702, 6706, 6709, 6711, 6715, 6716, 6718, 6720, 6721, 6722, 6725, 6727, 6729, 6730, 6732, 6733, 6734, 6736, 6740, 6744, 6746, 6748, 6751, 6753, 6756, 6758, 6760, 6763, 6767, 6768, 6772, 6773, 6774, 6776, 6777, 6780, 6781, 6784, 6785, 6787, 6790, 6792, 6793, 6795, 6797, 6800, 6801, 6802, 6804, 6805, 6807, 6808, 6813, 6816, 6819, 6821, 6822, 6824, 6825, 6826, 6828, 6829, 6831, 6833, 6835, 6836, 6838, 6840, 6841, 6843, 6845, 6847, 6848, 6850, 6853, 6856, 6860, 6864, 6866, 6868, 6870, 6873, 6875, 6878, 6880, 6881, 6883, 6884, 6885, 6890, 6892, 6893, 6894, 6896, 6897, 6898, 6901, 6903, 6905, 6907, 6908, 6910, 6913, 6916, 6918, 6921, 6923, 6924, 6927, 6928, 6931, 6932, 6935, 6938, 6942, 6944, 6945, 6947, 6948, 6950, 6953, 6955, 6958, 6960, 6962, 6963, 6965, 6967, 6968, 6971, 6973, 6974, 6976, 6979, 6983, 6986, 6987, 6989, 6990, 6992, 6994, 6995, 6996, 6998, 7002, 7004, 7006, 7008, 7009, 7010, 7013, 7014, 7017, 7020, 7021, 7024, 7026, 7028, 7030, 7033, 7036, 7037, 7039, 7041, 7042, 7044, 7047, 7048, 7050, 7051, 7053, 7054, 7055, 7056, 7057, 7060, 7061, 7062, 7064, 7067, 7068, 7069, 7071, 7072, 7074, 7076, 7077, 7078, 7079, 7080, 7081, 7083, 7084, 7085, 7086, 7093, 7096, 7097, 7098, 7099, 7100, 7105, 7107, 7109, 7111, 7112, 7113, 7114, 7118, 7119, 7120, 7121, 7122, 7123, 7126, 7127, 7128, 7133, 7134, 7135, 7136, 7138, 7145, 7146, 7147, 7149, 7150, 7154, 7155, 7156, 7157, 7160, 7162, 7163, 7165, 7166, 7167, 7170, 7171, 7172, 7175, 7179, 7181, 7183, 7184, 7185, 7187, 7188, 7189, 7191, 7192, 7193, 7194, 7196, 7201, 7203, 7207, 7209, 7210, 7216, 7217, 7218, 7222, 7223, 7225, 7228, 7229, 7230, 7231, 7235, 7238, 7239, 7240, 7243, 7247, 7248, 7249, 7250, 7253, 7254, 7256, 7257, 7262, 7263, 7264, 7266, 7268, 7269, 7271, 7272, 7275, 7276, 7280, 7281, 7282, 7283, 7286, 7287, 7288, 7289, 7291, 7294, 7295, 7299, 7300, 7301, 7302, 7308, 7309, 7310, 7313, 7315, 7317, 7318, 7319, 7323, 7326, 7328, 7330, 7331, 7332, 7333, 7336, 7340, 7346, 7347, 7352, 7353, 7357, 7361, 7366, 7367, 7369, 7370, 7371, 7372, 7373, 7377, 7378, 7379, 7382, 7383, 7384, 7385, 7388, 7389, 7390, 7391, 7395, 7396, 7399, 7401, 7402, 7403, 7404, 7406, 7407, 7410, 7414, 7415, 7416, 7417, 7424, 7426, 7428, 7433, 7434, 7437, 7439, 7440, 7444, 7447, 7449, 7450, 7451, 7453, 7457, 7458, 7462, 7463, 7464, 7465, 7469, 7472, 7473, 7474, 7476, 7481, 7482, 7484, 7485, 7490, 7491, 7492, 7494, 7495, 7499, 7500, 7501, 7502, 7504, 7511, 7512, 7513, 7514, 7515, 7516, 7517, 7518, 7519, 7523, 7524, 7526, 7527, 7528, 7529, 7530, 7531, 7532, 7533, 7540, 7542, 7543, 7545, 7551, 7552, 7554, 7555, 7557, 7559, 7562, 7568, 7570, 7577, 7578, 7580, 7583, 7584, 7588, 7589, 7591, 7592, 7595, 7600, 7602, 7603, 7604, 7606, 7607, 7608, 7609, 7610, 7612, 7614, 7616, 7617, 7618, 7619, 7620, 7622, 7623, 7624, 7625, 7626, 7630, 7631, 7632, 7634, 7636, 7639, 7640, 7642, 7644, 7646, 7648, 7650, 7652, 7654, 7655, 7659, 7660, 7662, 7663, 7664, 7665, 7666, 7670, 7673, 7675, 7681, 7683, 7684, 7689, 7690, 7693, 7694, 7695, 7697, 7702, 7703, 7705, 7706, 7708, 7710, 7713, 7714, 7716, 7717, 7720, 7722, 7723, 7725, 7726, 7727, 7729, 7730, 7735, 7736, 7740, 7741, 7742, 7743, 7744, 7748, 7751, 7752, 7755, 7756, 7757, 7763, 7764, 7765, 7766, 7770, 7771, 7774, 7776, 7777, 7778, 7779, 7780, 7785, 7788, 7789, 7790, 7793, 7795, 7797, 7798, 7800, 7801, 7803, 7804, 7806, 7807, 7811, 7814, 7815, 7817, 7819, 7821, 7823, 7828, 7829, 7830, 7833, 7837, 7838, 7840, 7841, 7842, 7844, 7845, 7846, 7849, 7851, 7854, 7856, 7858, 7859, 7860, 7861, 7863, 7866, 7867, 7868, 7869, 7870, 7873, 7875, 7879, 7882, 7885, 7886, 7888, 7891, 7896, 7897, 7899, 7901, 7902, 7904, 7906, 7907, 7909, 7910, 7911, 7913, 7915, 7918, 7920, 7922, 7923, 7925, 7926, 7928, 7930, 7932, 7933, 7936, 7937, 7940, 7941, 7944, 7945, 7947, 7949, 7950, 7951, 7954, 7955, 7957, 7961, 7962, 7965, 7967, 7968, 7970, 7971, 7972, 7975, 7977, 7979, 7981, 7983, 7985, 7986, 7988, 7989, 7991, 7993, 7996, 7998, 8000, 8002, 8003, 8005, 8006, 8007, 8009, 8012, 8014, 8017, 8019, 8021, 8022, 8023, 8025, 8027, 8030, 8032, 8033, 8035, 8038, 8042, 8043, 8044, 8046, 8048, 8049, 8050, 8052, 8053, 8054, 8056, 8057, 8058, 8060, 8061, 8062, 8064, 8065, 8066, 8069, 8070, 8072, 8073, 8074, 8076, 8077, 8078, 8080, 8081, 8082, 8083, 8086, 8088, 8091, 8093, 8094, 8098, 8099, 8100, 8101, 8102, 8104, 8105, 8106, 8107, 8109, 8110, 8111, 8112, 8114, 8116, 8117, 8119, 8120, 8123, 8125, 8127, 8129, 8131, 8133, 8135, 8137, 8139, 8141, 8142, 8143, 8145, 8147, 8150, 8153, 8154, 8158, 8161, 8162, 8165, 8167, 8168, 8170, 8171, 8175, 8176, 8177, 8181, 8183, 8184, 8185, 8187, 8190, 8191, 8195, 8196, 8197, 8199, 8204, 8206, 8208, 8210, 8211, 8212, 8214, 8218, 8219, 8221, 8224, 8226, 8229, 8232, 8233, 8234, 8236, 8238, 8243, 8244, 8247, 8250, 8251, 8255, 8258, 8260, 8262, 8263, 8265, 8268, 8270, 8271, 8273, 8274, 8276, 8277, 8281, 8283, 8284, 8286, 8287, 8288, 8290, 8291, 8292, 8294, 8297, 8300, 8302, 8305, 8307, 8309, 8311, 8313, 8316, 8318, 8319, 8320, 8322, 8324, 8326, 8329, 8330, 8333, 8336, 8338, 8340, 8342, 8344, 8346, 8350, 8352, 8354, 8356, 8358, 8359, 8361, 8363, 8364, 8366, 8368, 8370, 8371, 8374, 8375, 8376, 8377, 8379, 8380, 8381, 8383, 8385, 8388, 8389, 8392, 8394, 8396, 8398, 8399, 8402, 8406, 8407, 8408, 8409, 8411, 8412, 8413, 8415, 8416, 8417, 8420, 8422, 8424, 8425, 8427, 8428, 8429, 8432, 8433, 8436, 8437, 8439, 8440, 8442, 8444, 8446, 8450, 8454, 8456, 8458, 8462, 8464, 8466, 8470, 8472, 8474, 8475, 8477, 8480, 8482, 8483, 8484, 8486, 8490, 8492, 8493, 8495, 8496, 8497, 8498, 8500, 8503, 8505, 8508, 8512, 8513, 8515, 8517, 8519, 8522, 8524, 8527, 8529, 8530, 8531, 8533, 8535, 8537, 8540, 8541, 8542, 8545, 8547, 8550, 8553, 8556, 8559, 8561, 8563, 8565, 8566, 8569, 8571, 8575, 8578, 8580, 8583, 8585, 8587, 8588, 8590, 8592, 8593, 8595, 8597, 8600, 8602, 8604, 8607, 8609, 8611, 8614, 8615, 8616, 8617, 8618, 8619, 8621, 8622, 8623, 8625, 8626, 8627, 8629, 8630, 8631, 8634, 8638, 8642, 8644, 8646, 8650, 8652, 8654, 8659, 8662, 8664, 8666, 8671, 8673, 8674, 8676, 8679, 8684, 8687, 8689, 8692, 8693, 8696, 8698, 8701, 8705, 8707, 8710, 8713, 8715, 8718, 8720, 8722, 8723, 8726, 8727, 8728, 8730, 8731, 8734, 8735, 8737, 8739, 8740, 8742, 8743, 8745, 8747, 8749, 8751, 8754, 8755, 8756, 8759, 8761, 8763, 8765, 8767, 8769, 8771, 8773, 8774, 8775, 8777, 8779, 8782, 8784, 8787, 8789, 8791, 8792, 8794, 8797, 8800, 8802, 8804, 8806, 8810, 8811, 8812, 8813, 8815, 8816, 8817, 8818, 8820, 8821, 8822, 8824, 8827, 8829, 8830, 8833, 8834, 8836, 8838, 8839, 8842, 8844, 8845, 8846, 8849, 8851, 8852, 8853, 8854, 8857, 8858, 8859, 8862, 8868, 8872, 8874, 8876, 8879, 8881, 8884, 8886, 8887, 8888, 8889, 8893, 8894, 8895, 8901, 8902, 8903, 8904, 8910, 8912, 8913, 8914, 8915, 8916, 8918, 8919, 8920, 8921, 8924, 8925, 8926, 8927, 8929, 8932, 8936, 8938, 8939, 8941, 8942, 8946, 8949, 8950, 8951, 8955, 8956, 8960, 8961, 8962, 8963, 8967, 8970, 8971, 8972, 8973, 8974, 8975, 8979, 8980, 8982, 8983, 8986, 8988, 8989, 8990, 8991, 8995, 8996, 8999, 9004, 9005, 9006, 9007, 9008, 9009, 9013, 9015, 9017, 9018, 9019, 9020, 9021, 9023, 9025, 9030, 9031, 9033, 9035, 9036, 9044, 9045, 9048, 9049, 9050, 9051, 9058, 9059, 9064, 9068, 9069, 9070, 9071, 9073, 9077, 9078, 9080, 9081, 9085, 9086, 9088, 9091, 9096, 9100, 9101, 9102, 9104, 9106, 9108, 9109, 9111, 9112, 9113, 9115, 9116, 9118, 9119, 9120, 9123, 9127, 9129, 9132, 9133, 9134, 9135, 9141, 9142, 9143, 9144, 9145, 9149, 9150, 9154, 9155, 9156, 9157, 9163, 9164, 9165, 9166, 9170, 9171, 9174, 9175, 9176, 9177, 9182, 9183, 9184, 9185, 9188, 9191, 9193, 9198, 9200, 9201, 9203, 9204, 9205, 9208, 9214, 9215, 9216, 9217, 9218, 9221, 9222, 9223, 9224, 9229, 9230, 9232, 9233, 9236, 9237, 9238, 9239, 9240, 9241, 9242, 9243, 9244, 9249, 9250, 9251, 9258, 9260, 9263, 9267, 9268, 9269, 9270, 9271, 9273, 9278, 9282, 9283, 9284, 9285, 9290, 9291, 9292, 9294, 9295, 9298, 9300, 9304, 9307, 9310, 9312, 9313, 9314, 9316, 9317, 9319, 9320, 9321, 9322, 9323, 9324, 9326, 9328, 9330, 9331, 9335, 9337, 9338, 9339, 9341, 9343, 9344, 9347, 9348, 9349, 9351, 9353, 9356, 9357, 9358, 9359, 9360, 9361, 9364, 9367, 9370, 9372, 9373, 9378, 9380, 9384, 9385, 9386, 9387, 9389, 9393, 9395, 9396, 9399, 9403, 9405, 9406, 9407, 9408, 9414, 9415, 9416, 9417, 9421, 9422, 9423, 9424, 9425, 9429, 9430, 9431, 9432, 9436, 9437, 9441, 9442, 9443, 9444, 9448, 9449, 9450, 9452, 9453, 9457, 9459, 9460, 9461, 9462, 9465, 9468, 9469, 9470, 9471, 9475, 9476, 9480, 9481, 9482, 9483, 9487, 9490, 9491, 9492, 9495, 9496, 9497, 9502, 9503, 9504, 9507, 9508, 9509, 9510, 9514, 9515, 9519, 9520, 9521, 9522, 9529, 9531, 9532, 9533, 9534, 9540, 9541, 9542, 9547, 9550, 9551, 9553, 9554, 9555, 9559, 9562, 9565, 9566, 9567, 9573, 9574, 9575, 9576, 9580, 9581, 9582, 9583, 9584, 9589, 9590, 9592, 9593, 9594, 9597, 9599, 9601, 9602, 9603, 9605, 9607, 9608, 9609, 9611, 9612, 9619, 9620, 9623, 9624, 9628, 9629, 9630, 9635, 9636, 9643, 9644, 9645, 9648, 9649, 9650, 9651, 9655, 9656, 9661, 9662, 9663, 9666, 9667, 9668, 9673, 9674, 9675, 9678, 9679, 9680, 9685, 9686, 9687, 9691, 9693, 9696, 9697, 9699, 9700, 9701, 9702, 9706, 9709, 9710, 9714, 9715, 9716, 9717, 9721, 9722, 9725, 9726, 9727, 9729, 9730, 9733, 9735, 9736, 9737, 9739, 9740, 9741, 9742, 9745, 9747, 9749, 9750, 9751, 9752, 9753, 9754, 9755, 9760, 9761, 9763, 9764, 9767, 9768, 9769, 9770, 9774, 9775, 9779, 9780, 9781, 9782, 9786, 9788, 9792, 9795, 9799, 9800, 9801, 9805, 9808, 9809, 9810, 9811, 9812, 9813, 9816, 9817, 9818, 9819, 9824, 9825, 9827, 9828, 9829, 9830, 9835, 9836, 9837, 9838, 9841, 9845, 9846, 9847, 9848, 9850, 9853, 9857, 9858, 9859, 9860, 9866, 9870, 9871, 9876, 9877, 9878, 9880, 9881, 9887, 9888, 9889, 9890, 9891, 9893, 9894, 9896, 9897, 9898, 9899, 9902, 9903, 9904, 9909, 9910, 9911, 9913, 9917, 9918, 9919, 9920, 9922, 9927, 9928, 9929, 9930, 9931, 9937, 9939, 9941, 9942, 9943, 9948, 9952, 9953, 9957, 9958, 9959, 9961, 9962, 9966, 9971, 9974, 9975, 9977, 9978, 9979, 9981, 9986, 9987, 9989, 9995, 9997, 9999, 10001, 10002, 10003, 10004, 10005, 10006, 10019, 10022, 10023, 10024, 10028, 10029, 10033, 10034, 10035, 10040, 10041, 10042, 10043, 10045, 10052, 10053, 10054, 10057, 10058, 10060, 10065, 10067, 10068, 10072, 10075, 10078, 10080, 10081, 10082, 10083, 10084, 10085, 10090, 10091, 10092, 10094, 10095, 10099, 10100, 10102, 10103, 10104, 10107, 10111, 10113, 10114, 10115, 10116, 10120, 10121, 10125, 10126, 10127, 10128, 10132, 10133, 10137, 10138, 10139, 10140, 10146, 10147, 10148, 10149, 10153, 10156, 10157, 10158, 10160, 10161, 10164, 10168, 10169, 10171, 10172, 10173, 10179, 10180, 10181, 10182, 10183, 10184, 10185, 10189, 10191, 10192, 10193, 10194, 10195, 10196, 10198, 10199, 10200, 10202, 10204, 10207, 10208, 10209, 10210, 10211, 10212, 10213, 10214, 10215, 10222, 10225, 10226, 10227, 10231, 10234, 10235, 10236, 10237, 10238, 10239, 10243, 10244, 10245, 10246, 10250, 10251, 10252, 10255, 10256, 10260, 10262, 10263, 10264, 10265, 10266, 10270, 10274, 10277, 10279, 10281, 10286, 10287, 10288, 10289, 10291, 10292, 10293, 10295, 10296, 10297, 10299, 10300, 10303, 10304, 10305, 10312, 10314, 10315, 10318, 10319, 10320, 10321, 10322, 10324, 10331, 10332, 10333, 10339, 10340, 10341, 10342, 10343, 10346, 10347, 10348, 10352, 10353, 10354, 10358, 10360, 10367, 10368, 10370, 10371, 10372, 10373, 10374, 10378, 10379, 10380, 10385, 10386, 10387, 10388, 10389, 10390, 10397, 10398, 10399, 10400, 10401, 10402, 10403, 10404, 10405, 10406, 10407, 10412, 10415, 10416, 10417, 10423, 10432, 10436, 10437, 10439, 10440, 10442, 10447, 10449, 10452, 10453, 10454, 10456, 10459, 10460, 10465, 10466, 10467, 10469, 10470, 10471, 10472, 10473, 10476, 10477, 10478, 10479, 10480, 10481, 10486, 10487, 10492, 10493, 10494, 10497, 10498, 10499, 10500, 10501, 10502, 10503, 10510, 10513, 10515, 10516, 10517, 10518, 10520, 10522, 10525, 10527, 10529, 10532, 10533, 10538, 10539, 10540, 10544, 10545, 10546, 10550, 10551, 10552, 10555, 10556, 10557, 10558, 10559, 10561, 10563, 10565, 10566, 10570, 10572, 10573, 10576, 10577, 10580, 10582, 10585, 10586, 10587, 10588, 10592, 10595, 10596, 10598, 10600, 10604, 10607, 10608, 10610, 10611, 10612, 10613, 10614, 10615, 10618, 10619, 10620, 10627, 10628, 10633, 10634, 10639, 10640, 10641, 10642, 10643, 10646, 10647, 10648, 10650, 10652, 10656, 10657, 10661, 10662, 10663, 10664, 10668, 10670, 10672, 10674, 10676, 10680, 10683, 10687, 10688, 10689, 10690, 10693, 10695, 10697, 10699, 10700, 10701, 10704, 10705, 10708, 10711, 10712, 10715, 10716, 10718, 10720, 10722, 10723, 10724, 10726, 10727, 10732, 10733, 10735, 10736, 10737, 10739, 10740, 10741, 10746, 10747, 10748, 10751, 10752, 10755, 10757, 10764, 10767, 10768, 10770, 10771, 10774, 10776, 10777, 10779, 10781, 10784, 10787, 10790, 10791, 10795, 10799, 10802, 10804, 10806, 10808, 10809, 10811, 10817, 10818, 10820, 10822, 10824, 10826, 10827, 10828, 10830, 10835, 10838, 10839, 10840, 10843, 10845, 10847, 10848, 10849, 10850, 10856, 10857, 10862, 10865, 10868, 10869, 10870, 10872, 10873, 10875, 10876, 10877, 10879, 10880, 10882, 10883, 10884, 10888, 10889, 10890, 10891, 10892, 10895, 10897, 10898, 10902, 10907, 10908, 10909, 10913, 10914, 10919, 10920, 10925, 10928, 10931, 10936, 10940, 10942, 10943, 10945, 10946, 10947, 10948, 10950, 10951, 10952, 10955, 10959, 10960, 10961, 10962, 10964, 10965, 10968, 10969, 10972, 10973, 10976, 10977, 10978, 10980, 10982, 10983, 10984, 10986, 10987, 10988, 10990, 10991, 10993, 10994, 10995, 10998, 11002, 11004, 11007, 11012, 11014, 11018, 11026, 11027, 11030, 11034, 11035, 11036, 11040, 11041, 11042, 11045, 11046, 11047, 11051, 11052, 11053, 11054, 11061, 11062, 11064, 11067, 11068, 11070, 11073, 11074, 11080, 11086, 11087, 11088, 11089, 11092, 11095, 11096, 11097, 11098, 11099, 11101, 11103, 11105, 11106, 11107, 11108, 11109, 11110, 11112, 11113, 11116, 11117, 11118, 11119, 11120, 11121, 11122, 11123, 11124, 11126, 11127, 11131, 11132, 11133, 11134, 11135, 11138, 11139, 11140, 11141, 11143, 11144, 11146, 11150, 11154, 11155, 11156, 11158, 11160, 11161, 11162, 11165, 11168, 11169, 11170, 11171, 11172, 11175, 11176, 11180, 11181, 11182, 11183, 11187, 11188, 11190, 11191, 11192, 11194, 11195, 11197, 11198, 11199, 11201, 11202, 11206, 11207, 11208, 11209, 11210, 11214, 11216, 11217, 11219, 11221, 11223, 11225, 11228, 11229, 11230, 11234, 11235, 11236, 11241, 11244, 11246, 11247, 11248, 11250, 11251, 11253, 11254, 11256, 11257, 11258, 11259, 11263, 11265, 11266, 11268, 11273, 11276, 11283, 11284, 11285, 11294, 11295, 11296, 11300, 11301, 11302, 11303, 11304, 11306, 11308, 11312, 11313, 11314, 11316, 11318, 11320, 11321, 11323, 11325, 11326, 11331, 11332, 11333, 11334, 11336, 11337, 11338, 11340, 11343, 11345, 11348, 11350, 11351, 11353, 11354, 11357, 11359, 11360, 11361, 11362, 11364, 11366, 11369, 11372, 11373, 11376, 11377, 11378, 11380, 11381, 11382, 11383, 11384, 11386, 11389, 11390, 11393, 11395, 11396, 11397, 11400, 11403, 11405, 11407, 11410, 11412, 11414, 11415, 11417, 11418, 11421, 11422, 11425, 11426, 11428, 11429, 11431, 11433, 11434, 11437, 11438, 11441, 11442, 11443, 11445, 11448, 11449, 11451, 11454, 11456, 11457, 11458, 11460, 11461, 11463, 11464, 11465, 11466, 11467, 11468, 11470, 11471, 11472, 11474, 11475, 11476, 11477, 11478, 11480, 11481, 11482, 11483, 11484, 11486, 11487, 11488, 11494, 11495, 11499, 11506, 11508, 11511, 11512, 11513, 11515, 11516, 11517, 11519, 11520, 11521, 11523, 11524, 11526, 11527, 11528, 11530, 11531, 11532, 11534, 11535, 11536, 11538, 11539, 11541, 11542, 11543, 11546, 11547, 11548, 11549, 11550, 11552, 11553, 11556, 11558, 11560, 11565, 11569, 11572, 11573, 11577, 11579, 11581, 11583, 11585, 11587, 11589, 11595, 11596, 11597, 11598, 11600, 11601, 11604, 11607, 11608, 11609, 11611, 11612, 11615, 11617, 11618, 11621, 11622, 11624, 11625, 11628, 11629, 11630, 11631, 11633, 11634, 11637, 11640, 11642, 11643, 11646, 11647, 11648, 11649, 11651, 11653, 11655, 11657, 11658, 11660, 11661, 11665, 11666, 11668, 11670, 11672, 11673, 11676, 11677, 11680, 11686, 11687, 11689, 11690, 11693, 11694, 11696, 11697, 11699, 11701, 11705, 11707, 11708, 11709, 11710, 11711, 11714, 11715, 11716, 11718, 11719, 11721, 11730, 11733, 11740, 11743, 11745, 11750, 11751, 11753, 11754, 11755, 11759, 11761, 11763, 11764, 11765, 11766, 11767, 11768, 11769, 11771, 11772, 11777, 11778, 11782, 11783, 11784, 11785, 11791, 11792, 11793, 11798, 11799, 11800, 11802, 11803, 11807, 11808, 11809, 11813, 11814, 11815, 11816, 11817, 11818, 11821, 11822, 11823, 11824, 11827, 11828, 11829, 11834, 11835, 11836, 11839, 11840, 11841, 11846, 11847, 11848, 11850, 11851, 11859, 11860, 11861, 11862, 11863, 11864, 11865, 11866, 11871, 11872, 11873, 11875, 11876, 11882, 11883, 11884, 11885, 11889, 11890, 11892, 11893, 11898, 11902, 11903, 11904, 11909, 11910, 11911, 11912, 11913, 11916, 11917, 11921, 11922, 11923, 11926, 11927, 11928, 11933, 11934, 11935, 11940, 11942, 11943, 11944, 11947, 11949, 11950, 11955, 11958, 11959, 11960, 11961, 11962, 11963, 11965, 11966, 11971, 11972, 11974, 11976, 11981, 11984, 11985, 11989, 11991, 11992, 11997, 11998, 11999, 12003, 12005, 12008, 12011, 12012, 12013, 12014, 12015, 12016, 12021, 12023, 12024, 12025, 12026, 12029, 12032, 12033, 12034, 12035, 12040, 12041, 12042, 12047, 12048, 12049, 12050, 12053, 12054, 12055, 12059, 12060, 12064, 12065, 12066, 12067, 12072, 12074, 12075, 12076, 12077, 12078, 12079, 12084, 12086, 12087, 12088, 12089, 12092, 12093, 12095, 12096, 12097, 12099, 12105, 12106, 12107, 12112, 12113, 12114, 12115, 12117, 12118, 12120, 12123, 12128, 12129, 12132, 12134, 12135, 12136, 12138, 12141, 12142, 12144, 12146, 12147, 12151, 12153, 12154, 12159, 12163, 12164, 12165, 12166, 12168, 12170, 12172, 12175, 12176, 12178, 12180, 12181, 12183, 12184, 12187, 12191, 12193, 12194, 12199, 12201, 12203, 12208, 12209, 12211, 12213, 12217, 12219, 12220, 12221, 12222, 12224, 12227, 12229, 12230, 12231, 12233, 12235, 12236, 12238, 12239, 12241, 12243, 12246, 12247, 12251, 12252, 12255, 12256, 12257, 12258, 12259, 12260, 12267, 12270, 12271, 12272, 12273, 12274, 12277, 12278, 12281, 12284, 12286, 12287, 12288, 12290, 12292, 12296, 12298, 12300, 12302, 12303, 12305, 12306, 12307, 12310, 12311, 12312, 12313, 12316, 12317, 12318, 12321, 12322, 12325, 12326, 12328, 12329, 12331, 12334, 12335, 12337, 12339, 12341, 12342, 12344, 12346, 12348, 12350, 12353, 12355, 12356, 12359, 12360, 12361, 12367, 12368, 12371, 12372, 12373, 12375, 12378, 12381, 12382, 12383, 12385, 12387, 12390, 12392, 12395, 12398, 12399, 12401, 12405, 12408, 12410, 12411, 12412, 12414, 12415, 12416, 12418, 12419, 12420, 12422, 12423, 12424, 12426, 12427, 12428, 12430, 12431, 12432, 12434, 12435, 12436, 12439, 12441, 12442, 12443, 12444, 12445, 12447, 12448, 12449, 12451, 12452, 12454, 12456, 12457, 12464, 12468, 12471, 12472, 12473, 12475, 12476, 12477, 12478, 12480, 12482, 12483, 12484, 12486, 12487, 12489, 12490, 12491, 12492, 12493, 12495, 12498, 12499, 12500, 12502, 12503, 12505, 12507, 12509, 12510, 12511, 12512, 12514, 12515, 12516, 12517, 12518, 12520, 12521, 12522, 12523, 12526, 12530, 12533, 12536, 12539, 12541, 12542, 12543, 12547, 12550, 12553, 12557, 12560, 12562, 12565, 12567, 12568, 12570, 12571, 12573, 12577, 12578, 12580, 12582, 12584, 12586, 12589, 12590, 12592, 12594, 12596, 12597, 12599, 12601, 12603, 12605, 12606, 12607, 12609, 12610, 12613, 12617, 12618, 12619, 12620, 12621, 12622, 12624, 12627, 12630, 12631, 12635, 12637, 12641, 12642, 12644, 12646, 12648, 12649, 12651, 12653, 12654, 12655, 12656, 12658, 12659, 12661, 12662, 12663, 12664, 12665, 12666, 12670, 12673, 12675, 12679, 12681, 12682, 12684, 12686, 12688, 12689, 12690, 12692, 12693, 12694, 12696, 12697, 12699, 12701, 12702, 12704, 12708, 12709, 12710, 12712, 12713, 12715, 12718, 12720, 12722, 12724, 12728, 12729, 12731, 12733, 12735, 12737, 12741, 12744, 12745, 12748, 12749, 12751, 12754, 12756, 12758, 12759, 12762, 12763, 12765, 12767, 12770, 12772, 12773, 12775, 12777, 12780, 12782, 12784, 12786, 12787, 12790, 12791, 12793, 12795, 12796, 12797, 12802, 12806, 12810, 12812, 12814, 12817, 12819, 12821, 12822, 12824, 12825, 12828, 12831, 12834, 12836, 12838, 12839, 12841, 12843, 12846, 12847, 12852, 12856, 12858, 12860, 12862, 12863, 12865, 12867, 12870, 12871, 12873, 12875, 12880, 12884, 12886, 12888, 12891, 12894, 12895, 12896, 12900, 12904, 12906, 12907, 12909, 12913, 12915, 12916, 12918, 12921, 12924, 12925, 12928, 12930, 12931, 12933, 12934, 12939, 12943, 12947, 12949, 12951, 12952, 12954, 12956, 12957, 12958, 12960, 12963, 12965, 12967, 12970, 12971, 12973, 12974, 12976, 12977, 12981, 12983, 12985, 12986, 12987, 12989, 12990, 12993, 12995, 12996, 12998, 13001, 13003, 13004, 13005, 13007, 13009, 13011, 13012, 13013, 13016, 13017, 13020, 13021, 13023, 13025, 13026, 13027, 13029, 13031, 13032, 13034, 13038, 13039, 13042, 13043, 13045, 13047, 13048, 13050, 13051, 13052, 13053, 13056, 13059, 13062, 13063, 13067, 13069, 13070, 13072, 13075, 13077, 13078, 13080, 13081, 13082, 13083, 13084, 13086, 13087, 13089, 13090, 13094, 13096, 13098, 13100, 13101, 13102, 13103, 13104, 13106, 13109, 13112, 13113, 13114, 13117, 13118, 13120, 13121, 13123, 13125, 13128, 13129, 13130, 13132, 13134, 13135, 13138, 13139, 13140, 13143, 13144, 13148, 13149, 13150, 13154, 13155, 13159, 13160, 13161, 13162, 13166, 13167, 13171, 13172, 13173, 13174, 13178, 13179, 13183, 13184, 13185, 13186, 13189, 13190, 13191, 13192, 13198, 13199, 13200, 13201, 13205, 13206, 13207, 13208, 13209, 13210, 13218, 13219, 13221, 13222, 13228, 13230, 13231, 13232, 13234, 13235, 13239, 13240, 13241, 13242, 13246, 13247, 13251, 13252, 13253, 13258, 13259, 13260, 13261, 13264, 13265, 13266, 13270, 13271, 13272, 13273, 13274, 13275, 13276, 13279, 13281, 13283, 13285, 13292, 13293, 13296, 13298, 13299, 13300, 13303, 13304, 13306, 13311, 13313, 13314, 13315, 13316, 13320, 13321, 13322, 13323, 13324, 13328, 13329, 13332, 13334, 13337, 13340, 13341, 13342, 13344, 13348, 13353, 13354, 13355, 13356, 13357, 13362, 13363, 13364, 13370, 13371, 13372, 13377, 13378, 13379, 13382, 13384, 13386, 13387, 13388, 13390, 13391, 13397, 13401, 13402, 13403, 13404, 13405, 13410, 13412, 13416, 13417, 13418, 13419, 13422, 13424, 13425, 13427, 13431, 13433, 13435, 13438, 13439, 13440, 13441, 13442, 13443, 13444, 13445, 13448, 13454, 13458, 13460, 13464, 13466, 13467, 13469, 13471, 13472, 13473, 13477, 13479, 13480, 13482, 13483, 13484, 13485, 13489, 13490, 13495, 13496, 13498, 13499, 13500, 13506, 13507, 13508, 13509, 13516, 13517, 13518, 13519, 13520, 13522, 13523, 13528, 13529, 13530, 13531, 13533, 13540, 13541, 13542, 13545, 13546, 13547, 13552, 13553, 13554, 13557, 13558, 13559, 13564, 13565, 13569, 13570, 13571, 13572, 13574, 13575, 13579, 13580, 13581, 13582, 13583, 13588, 13589, 13593, 13594, 13595, 13596, 13600, 13601, 13605, 13606, 13607, 13608, 13610, 13616, 13617, 13618, 13620, 13621, 13625, 13626, 13627, 13630, 13631, 13633, 13637, 13639, 13643, 13645, 13646, 13649, 13650, 13651, 13654, 13655, 13656, 13657, 13659, 13661, 13662, 13663, 13664, 13666, 13669, 13670, 13672, 13673, 13674, 13675, 13678, 13679, 13680, 13685, 13686, 13687, 13690, 13691, 13692, 13697, 13698, 13699, 13701, 13702, 13708, 13709, 13710, 13711, 13712, 13715, 13716, 13717, 13718, 13719, 13724, 13725, 13726, 13732, 13734, 13735, 13736, 13737, 13742, 13743, 13746, 13747, 13749, 13750, 13751, 13753, 13754, 13755, 13758, 13760, 13761, 13762, 13763, 13764, 13766, 13769, 13771, 13772, 13773, 13775, 13778, 13781, 13782, 13783, 13784, 13788, 13791, 13792, 13793, 13797, 13798, 13802, 13803, 13804, 13805, 13808, 13809, 13810, 13813, 13814, 13815, 13817, 13818, 13819, 13820, 13825, 13827, 13828, 13830, 13834, 13835, 13836, 13840, 13843, 13844, 13845, 13846, 13848, 13850, 13853, 13855, 13857, 13859, 13860, 13861, 13865, 13870, 13871, 13876, 13877, 13878, 13879, 13880, 13884, 13885, 13886, 13891, 13892, 13893, 13894, 13896, 13900, 13902, 13903, 13906, 13908, 13911, 13913, 13918, 13919, 13920, 13922, 13925, 13926, 13933, 13935, 13936, 13939, 13940, 13941, 13944, 13946, 13948, 13949, 13950, 13952, 13954, 13959, 13961, 13963, 13965, 13966, 13967, 13968, 13970, 13971, 13973, 13974, 13975, 13977, 13982, 13985, 13986, 13987, 13989, 13990, 13994, 13995, 13997, 13998, 13999, 14000, 14002, 14003, 14008, 14011, 14012, 14013, 14017, 14018, 14022, 14023, 14024, 14025, 14026, 14030, 14031, 14035, 14036, 14037, 14038, 14040, 14047, 14048, 14052, 14053, 14054, 14055, 14062, 14064, 14066, 14068, 14070, 14071, 14072, 14073, 14075, 14076, 14078, 14079, 14081, 14083, 14084, 14086, 14089, 14093, 14094, 14095, 14097, 14102, 14103, 14104, 14108, 14110, 14112, 14113, 14115, 14116, 14120, 14121, 14124, 14125, 14129, 14132, 14133, 14134, 14136, 14138, 14141, 14143, 14144, 14145, 14147, 14148, 14150, 14154, 14155, 14156, 14159, 14160, 14161, 14163, 14167, 14168, 14169, 14173, 14176, 14177, 14178, 14179, 14183, 14186, 14187, 14188, 14189, 14190, 14191, 14194, 14200, 14201, 14202, 14203, 14204, 14205, 14207, 14211, 14212, 14213, 14215, 14217, 14218, 14219, 14220, 14224, 14225, 14226, 14228, 14231, 14232, 14233, 14234, 14235, 14239, 14241, 14243, 14247, 14248, 14254, 14259, 14260, 14261, 14262, 14263, 14269, 14271, 14272, 14273, 14277, 14278, 14283, 14284, 14287, 14288, 14291, 14296, 14298, 14300, 14301, 14302, 14303, 14305, 14313, 14314, 14315, 14317, 14320, 14321, 14322, 14323, 14324, 14325, 14326, 14331, 14333, 14334, 14336, 14337, 14340, 14341, 14342, 14346, 14347, 14349, 14350, 14353, 14355, 14356, 14357, 14360, 14361, 14362, 14364, 14369, 14370, 14371, 14375, 14376, 14377, 14384, 14385, 14386, 14387, 14388, 14390, 14394, 14400, 14401, 14405, 14406, 14407, 14408, 14410, 14411, 14413, 14415, 14418, 14422, 14424, 14427, 14428, 14429, 14430, 14431, 14438, 14440, 14441, 14442, 14444, 14446, 14449, 14451, 14452, 14456, 14460, 14465, 14467, 14468, 14470, 14476, 14477, 14478, 14481, 14483, 14485, 14488, 14489, 14491, 14493, 14495, 14498, 14501, 14502, 14504, 14506, 14508, 14509, 14511, 14512, 14513, 14514, 14516, 14521, 14523, 14525, 14527, 14529, 14531, 14532, 14533, 14535, 14536, 14537, 14538, 14541, 14544, 14546, 14547, 14548, 14549, 14550, 14551, 14552, 14557, 14558, 14559, 14560, 14566, 14567, 14568, 14569, 14570, 14571, 14576, 14577, 14581, 14584, 14586, 14589, 14590, 14591, 14593, 14595, 14596, 14597, 14599, 14602, 14603, 14606, 14607, 14609, 14611, 14612, 14614, 14615, 14616, 14617, 14620, 14622, 14623, 14625, 14630, 14631, 14633, 14634, 14635, 14636, 14638, 14639, 14641, 14643, 14645, 14646, 14648, 14651, 14653, 14654, 14655, 14656, 14661, 14663, 14664, 14666, 14669, 14670, 14671, 14674, 14675, 14679, 14682, 14684, 14685, 14687, 14691, 14693, 14695, 14700, 14701, 14702, 14703, 14705, 14706, 14707, 14710, 14712, 14714, 14715, 14716, 14717, 14720, 14721, 14722, 14724, 14726, 14729, 14730, 14734, 14737, 14738, 14739, 14740, 14741, 14742, 14745, 14746, 14749, 14752, 14754, 14756, 14757, 14759, 14762, 14764, 14766, 14768, 14769, 14773, 14774, 14776, 14779, 14782, 14783, 14784, 14785, 14786, 14788, 14789, 14793, 14795, 14796, 14799, 14801, 14802, 14804, 14808, 14809, 14811, 14814, 14816, 14818, 14819, 14820, 14821, 14824, 14825, 14827, 14828, 14830, 14831, 14835, 14836, 14837, 14838, 14839, 14842, 14844, 14845, 14847, 14849, 14850, 14852, 14853, 14856, 14860, 14861, 14862, 14864, 14866, 14869, 14872, 14874, 14876, 14878, 14880, 14882, 14884, 14885, 14886, 14888, 14889, 14891, 14893, 14899, 14901, 14902, 14905, 14906, 14908, 14909, 14911, 14912, 14915, 14917, 14920, 14924, 14928, 14932, 14934, 14936, 14939, 14943, 14946, 14949, 14951, 14955, 14959, 14963, 14965, 14967, 14972, 14976, 14980, 14983, 14987, 14991, 14997, 15000, 15004, 15008, 15010, 15014, 15016, 15020, 15025, 15026, 15027, 15028, 15029, 15030, 15031, 15033, 15035, 15037, 15039, 15040, 15042, 15046, 15047, 15048, 15050, 15051, 15052, 15054, 15055, 15056, 15057, 15060, 15061, 15065, 15067, 15069, 15071, 15073, 15075, 15077, 15079, 15080, 15081, 15083, 15086, 15089, 15091, 15092, 15094, 15096, 15097, 15099, 15101, 15105, 15106, 15110, 15112, 15113, 15115, 15116, 15118, 15119, 15123, 15125, 15126, 15127, 15129, 15131, 15133, 15136, 15137, 15139, 15142, 15144, 15146, 15149, 15151, 15152, 15155, 15158, 15159, 15163, 15166, 15167, 15169, 15171, 15174, 15176, 15178, 15180, 15183, 15185, 15186, 15188, 15190, 15195, 15199, 15202, 15204, 15207, 15210, 15212, 15214, 15216, 15217, 15219, 15222, 15225, 15227, 15229, 15232, 15233, 15234, 15236, 15239, 15240, 15241, 15242, 15246, 15248, 15249, 15254, 15255, 15258, 15261, 15262, 15263, 15265, 15266, 15268, 15272, 15276, 15278, 15279, 15280, 15281, 15282, 15284, 15286, 15287, 15288, 15289, 15290, 15291, 15293, 15295, 15298, 15299, 15300, 15301, 15302, 15303, 15307, 15308, 15312, 15313, 15314, 15317, 15318, 15319, 15324, 15325, 15326, 15328, 15332, 15333, 15334, 15338, 15339, 15340, 15341, 15345, 15346, 15350, 15351, 15352, 15353, 15357, 15358, 15362, 15363, 15364, 15365, 15369, 15372, 15373, 15374, 15376, 15377, 15381, 15382, 15383, 15384, 15387, 15391, 15392, 15394, 15395, 15397, 15402, 15404, 15406, 15407, 15408, 15409, 15410, 15412, 15413, 15414, 15417, 15418, 15419, 15420, 15423, 15424, 15426, 15428, 15429, 15432, 15434, 15435, 15436, 15438, 15445, 15446, 15448, 15453, 15454, 15455, 15457, 15458, 15461, 15464, 15465, 15468, 15469, 15470, 15471, 15472, 15473, 15475, 15476, 15479, 15482, 15484, 15485, 15487, 15488, 15489, 15490, 15493, 15494, 15495, 15496, 15497, 15498, 15501, 15503, 15506, 15508, 15510, 15514, 15516, 15517, 15519, 15520, 15521, 15523, 15524, 15525, 15528, 15532, 15538, 15540, 15541, 15542, 15543, 15546, 15547, 15548, 15549, 15553, 15556, 15557, 15558, 15559, 15560, 15561, 15563, 15564, 15565, 15567, 15568, 15572, 15573, 15574, 15575, 15576, 15580, 15583, 15584, 15585, 15586, 15594, 15596, 15598, 15600, 15601, 15602, 15603, 15606, 15607, 15609, 15613, 15614, 15615, 15617, 15622, 15625, 15628, 15629, 15630, 15634, 15635, 15640, 15641, 15643, 15644, 15647, 15648, 15649, 15652, 15653, 15655, 15657, 15661, 15663, 15664, 15665, 15672, 15674, 15675, 15676, 15677, 15681, 15682, 15683, 15684, 15688, 15692, 15694, 15695, 15696, 15697, 15699, 15701, 15702, 15704, 15706, 15710, 15711, 15715, 15717, 15719, 15723, 15724, 15725, 15726, 15730, 15732, 15733, 15734, 15735, 15737, 15738, 15742, 15743, 15744, 15745, 15746, 15751, 15752, 15753, 15755, 15756, 15763, 15764, 15765, 15768, 15771, 15772, 15773, 15774, 15775, 15777, 15778, 15779, 15781, 15782, 15783, 15785, 15786, 15787, 15789, 15791, 15793, 15795, 15796, 15799, 15802, 15803, 15804, 15808, 15809, 15810, 15813, 15814, 15815, 15816, 15817, 15818, 15822, 15823, 15825, 15826, 15827, 15831, 15833, 15835, 15836, 15837, 15840, 15846, 15847, 15848, 15849, 15851, 15856, 15857, 15858, 15859, 15861, 15863, 15869, 15870, 15872, 15873, 15876, 15878, 15879, 15885, 15888, 15889, 15892, 15893, 15896, 15897, 15899, 15916, 15920, 15922, 15924, 15925, 15928, 15930, 15931, 15935, 15936, 15938, 15941, 15943, 15944, 15946, 15953, 15954, 15955, 15957, 15958, 15959, 15961, 15963, 15965, 15967, 15968, 15970, 15971, 15975, 15977, 15979, 15982, 15984, 15986, 15992, 15996, 16000, 16004, 16008, 16012, 16016, 16022, 16025, 16026, 16027, 16028, 16029, 16030, 16032, 16033, 16034, 16036, 16037, 16040, 16044, 16047, 16051, 16053, 16056, 16060, 16062, 16066, 16070, 16074, 16075, 16076, 16079, 16080, 16081, 16083, 16084, 16085, 16087, 16089, 16090, 16091, 16093, 16094, 16098, 16099, 16101, 16103, 16104, 16105, 16107, 16108, 16109, 16111, 16112, 16113, 16114, 16116, 16118, 16121, 16122, 16124, 16125, 16127, 16129, 16130, 16131, 16134, 16138, 16139, 16141, 16143, 16146, 16148, 16151, 16152, 16153, 16155, 16156, 16157, 16160, 16161, 16162, 16164, 16165, 16168, 16170, 16171, 16172, 16174, 16175, 16176, 16179, 16181, 16184, 16185, 16187, 16188, 16189, 16192, 16193, 16195, 16198, 16200, 16201, 16205, 16209, 16210, 16212, 16213, 16215, 16216, 16217, 16219, 16220, 16223, 16224, 16226, 16228, 16229, 16230, 16232, 16233, 16234, 16236, 16238, 16240, 16241, 16242, 16244, 16245, 16246, 16248, 16249, 16251, 16252, 16254, 16255, 16257, 16261, 16262, 16265, 16267, 16269, 16270, 16272, 16273, 16275, 16278, 16279, 16280, 16282, 16283, 16284, 16286, 16289, 16292, 16294, 16296, 16297, 16300, 16301, 16304, 16306, 16308, 16310, 16313, 16315, 16316, 16319, 16322, 16326, 16327, 16329, 16332, 16337, 16338, 16341, 16345, 16346, 16348, 16350, 16354, 16356, 16359, 16360, 16361, 16363, 16365, 16368, 16370, 16372, 16375, 16376, 16377, 16378, 16380, 16382, 16383, 16387, 16389, 16390, 16392, 16393, 16395, 16397, 16399, 16401, 16405, 16408, 16409, 16412, 16414, 16416, 16418, 16419, 16422, 16424, 16425, 16426, 16429, 16431, 16432, 16434, 16435, 16438, 16444, 16445, 16446, 16450, 16451, 16452, 16456, 16457, 16461, 16462, 16463, 16464, 16468, 16469, 16470, 16471, 16472, 16473, 16476, 16477, 16478, 16483, 16484, 16485, 16487, 16488, 16489, 16491, 16492, 16494, 16495, 16496, 16497, 16498, 16501, 16502, 16503, 16507, 16508, 16509, 16510, 16513, 16517, 16520, 16521, 16524, 16525, 16526, 16527, 16531, 16532, 16534, 16535, 16536, 16540, 16541, 16542, 16544, 16548, 16549, 16550, 16551, 16555, 16556, 16561, 16562, 16563, 16564, 16566, 16573, 16574, 16575, 16576, 16577, 16579, 16580, 16582, 16584, 16588, 16591, 16592, 16593, 16595, 16596, 16603, 16605, 16612, 16613, 16614, 16615, 16616, 16620, 16621, 16622, 16623, 16624, 16625, 16630, 16631, 16634, 16636, 16637, 16638, 16641, 16646, 16648, 16649, 16650, 16651, 16653, 16654, 16655, 16656, 16657, 16659, 16664, 16665, 16667, 16668, 16672, 16673, 16674, 16679, 16680, 16681, 16683, 16684, 16686, 16687, 16690, 16691, 16693, 16696, 16699, 16700, 16701, 16706, 16707, 16708, 16709, 16711, 16718, 16719, 16721, 16722, 16723, 16729, 16730, 16731, 16732, 16736, 16737, 16739, 16740, 16745, 16746, 16747, 16748, 16752, 16754, 16755, 16757, 16760, 16762, 16767, 16769, 16771, 16773, 16774, 16777, 16778, 16781, 16782, 16785, 16786, 16788, 16789, 16791, 16792, 16793, 16795, 16796, 16797, 16799, 16804, 16807, 16808, 16809, 16810, 16812, 16814, 16815, 16816, 16818, 16820, 16826, 16827, 16832, 16833, 16838, 16839, 16841, 16842, 16847, 16848, 16849, 16853, 16856, 16857, 16858, 16859, 16860, 16861, 16865, 16866, 16869, 16871, 16872, 16873, 16874, 16880, 16881, 16884, 16889, 16890, 16892, 16894, 16898, 16899, 16900, 16901, 16902, 16903, 16905, 16909, 16910, 16911, 16912, 16914, 16917, 16918, 16920, 16921, 16922, 16925, 16927, 16930, 16933, 16934, 16935, 16938, 16940, 16941, 16942, 16944, 16947, 16948, 16951, 16953, 16954, 16960, 16961, 16962, 16963, 16965, 16966, 16968, 16970, 16974, 16977, 16979, 16982, 16983, 16987, 16989, 16991, 16993, 16994, 16995, 17000, 17001, 17004, 17005, 17007, 17011, 17012, 17013, 17017, 17018, 17022, 17023, 17026, 17030, 17032, 17033, 17035, 17036, 17038, 17041, 17046, 17047, 17051, 17055, 17059, 17060, 17062, 17064, 17066, 17067, 17069, 17076, 17077, 17078, 17082, 17083, 17084, 17086, 17089, 17090, 17092, 17093, 17096, 17098, 17099, 17101, 17103, 17104, 17106, 17107, 17109, 17110, 17111, 17114, 17117, 17123, 17125, 17126, 17128, 17131, 17132, 17138, 17141, 17143, 17144, 17145, 17147, 17149, 17151, 17152, 17154, 17155, 17157, 17159, 17162, 17163, 17165, 17167, 17168, 17169, 17171, 17173, 17175, 17177, 17179, 17181, 17184, 17186, 17189, 17191, 17194, 17196, 17199, 17200, 17203, 17204, 17206, 17207, 17209, 17210, 17211, 17214, 17216, 17219, 17220, 17222, 17225, 17227, 17228, 17229, 17230, 17232, 17233, 17234, 17236, 17237, 17238, 17239, 17240, 17242, 17243, 17244, 17248, 17252, 17254, 17256, 17258, 17259, 17262, 17267, 17271, 17275, 17277, 17279, 17280, 17281, 17282, 17283, 17285, 17286, 17287, 17289, 17290, 17291, 17293, 17295, 17296, 17297, 17299, 17300, 17301, 17303, 17304, 17307, 17313, 17317, 17321, 17323, 17327, 17329, 17330, 17336, 17341, 17342, 17343, 17345, 17346, 17348, 17350, 17352, 17353, 17355, 17357, 17358, 17363, 17364, 17366, 17368, 17370, 17376, 17380, 17382, 17384, 17386, 17387, 17389, 17391, 17393, 17394, 17395, 17397, 17400, 17403, 17405, 17406, 17407, 17409, 17412, 17415, 17418, 17420, 17421, 17424, 17426, 17428, 17432, 17434, 17435, 17436, 17438, 17440, 17442, 17443, 17444, 17446, 17447, 17449, 17451, 17453, 17454, 17458, 17459, 17460, 17461, 17462, 17463, 17466, 17468, 17470, 17472, 17473, 17475, 17476, 17478, 17480, 17482, 17484, 17488, 17489, 17491, 17493, 17494, 17495, 17496, 17498, 17500, 17502, 17503, 17504, 17507, 17508, 17509, 17510, 17512, 17515, 17517, 17519, 17520, 17521, 17523, 17525, 17528, 17530, 17531, 17533, 17536, 17539, 17541, 17543, 17545, 17547, 17549, 17552, 17554, 17555, 17558, 17560, 17562, 17563, 17566, 17569, 17572, 17575, 17578, 17579, 17582, 17585, 17588, 17590, 17592, 17594, 17596, 17597, 17600, 17603, 17610, 17611, 17612, 17613, 17615, 17617, 17619, 17621, 17623, 17625, 17626, 17627, 17629, 17631, 17632, 17633, 17636, 17638, 17641, 17644, 17647, 17648, 17650, 17654, 17656, 17657, 17659, 17661, 17663, 17664, 17666, 17668, 17669, 17671, 17672, 17674, 17675, 17678, 17680, 17681, 17683, 17686, 17688, 17689, 17691, 17693, 17695, 17696, 17699, 17700, 17701, 17702, 17704, 17705, 17706, 17708, 17710, 17713, 17714, 17716, 17718, 17720, 17723, 17725, 17726, 17728, 17731, 17733, 17734, 17736, 17737, 17739, 17742, 17744, 17746, 17748, 17749, 17750, 17752, 17754, 17756, 17759, 17761, 17763, 17764, 17765, 17766, 17768, 17769, 17770, 17772, 17775, 17777, 17778, 17780, 17783, 17785, 17786, 17788, 17789, 17790, 17791, 17795, 17799, 17801, 17803, 17805, 17806, 17808, 17810, 17811, 17813, 17816, 17818, 17819, 17821, 17823, 17824, 17825, 17827, 17830, 17832, 17833, 17835, 17836, 17837, 17840, 17841, 17843, 17845, 17846, 17848, 17850, 17851, 17852, 17854, 17856, 17858, 17859, 17863, 17867, 17871, 17873, 17877, 17878, 17881, 17884, 17886, 17888, 17890, 17893, 17895, 17897, 17899, 17902, 17905, 17906, 17909, 17910, 17912, 17914, 17915, 17917, 17919, 17920, 17923, 17924, 17926, 17928, 17931, 17932, 17935, 17938, 17941, 17943, 17944, 17948, 17950, 17952, 17954, 17955, 17957, 17958, 17959, 17962, 17963, 17964, 17966, 17969, 17971, 17973, 17975, 17977, 17978, 17980, 17983, 17985, 17986, 17988, 17991, 17993, 17994, 17996, 17997, 17998, 18000, 18004, 18006, 18007, 18009, 18010, 18012, 18013, 18016, 18017, 18019, 18020, 18022, 18025, 18027, 18028, 18030, 18032, 18034, 18039, 18040, 18041, 18042, 18043, 18044, 18045, 18048, 18050, 18052, 18053, 18054, 18056, 18062, 18065, 18066, 18068, 18069, 18071, 18074, 18078, 18079, 18083, 18085, 18086, 18087, 18088, 18089, 18094, 18095, 18096, 18097, 18100, 18102, 18109, 18112, 18113, 18118, 18119, 18120, 18122, 18123, 18124, 18128, 18129, 18130, 18134, 18135, 18136, 18139, 18141, 18146, 18147, 18149, 18150, 18151, 18152, 18154, 18155, 18160, 18164, 18165, 18167, 18169, 18173, 18174, 18175, 18179, 18181, 18182, 18183, 18184, 18189, 18196, 18197, 18198, 18201, 18202, 18203, 18204, 18208, 18209, 18213, 18214, 18215, 18216, 18220, 18221, 18225, 18226, 18227, 18228, 18231, 18232, 18233, 18234, 18238, 18239, 18243, 18244, 18245, 18250, 18251, 18252, 18256, 18257, 18261, 18262, 18263, 18264, 18269, 18270, 18271, 18275, 18278, 18279, 18280, 18284, 18285, 18286, 18290, 18292, 18293, 18296, 18297, 18298, 18299, 18306, 18307, 18309, 18312, 18313, 18314, 18324, 18325, 18326, 18327, 18330, 18331, 18333, 18334, 18335, 18338, 18340, 18341, 18345, 18346, 18347, 18350, 18351, 18352, 18357, 18358, 18359, 18360, 18361, 18365, 18369, 18370, 18371, 18372, 18373, 18374, 18377, 18379, 18380, 18385, 18386, 18388, 18389, 18394, 18396, 18397, 18398, 18399, 18400, 18402, 18403, 18411, 18412, 18413, 18415, 18416, 18417, 18422, 18423, 18427, 18429, 18430, 18431, 18433, 18434, 18441, 18442, 18443, 18444, 18445, 18447, 18449, 18451, 18452, 18453, 18457, 18458, 18459, 18460, 18461, 18467, 18472, 18473, 18474, 18479, 18480, 18481, 18482, 18484, 18489, 18490, 18491, 18492, 18493, 18496, 18497, 18498, 18500, 18503, 18505, 18513, 18514, 18515, 18518, 18519, 18520, 18526, 18527, 18531, 18532, 18534, 18535, 18540, 18541, 18542, 18543, 18544, 18547, 18549, 18550, 18551, 18552, 18555, 18556, 18557, 18560, 18562, 18567, 18568, 18569, 18572, 18573, 18574, 18585, 18586, 18587, 18591, 18592, 18593, 18594, 18595, 18599, 18602, 18603, 18607, 18608, 18609, 18615, 18616, 18617, 18618, 18620, 18621, 18622, 18623, 18626, 18627, 18628, 18629, 18633, 18636, 18637, 18638, 18639, 18640, 18641, 18645, 18646, 18650, 18651, 18652, 18653, 18657, 18658, 18662, 18663, 18664, 18669, 18670, 18671, 18672, 18673, 18677, 18678, 18679, 18684, 18685, 18686, 18687, 18689, 18690, 18691, 18699, 18700, 18701, 18703, 18706, 18708, 18709, 18710, 18712, 18713, 18718, 18722, 18725, 18726, 18727, 18728, 18732, 18733, 18736, 18738, 18739, 18741, 18742, 18748, 18750, 18751, 18752, 18754, 18756, 18758, 18759, 18763, 18767, 18770, 18771, 18772, 18774, 18777, 18778, 18783, 18785, 18788, 18790, 18793, 18795, 18801, 18803, 18804, 18810, 18811, 18812, 18814, 18815, 18817, 18818, 18820, 18821, 18824, 18826, 18827, 18829, 18834, 18835, 18836, 18838, 18841, 18843, 18845, 18846, 18849, 18850, 18851, 18852, 18857, 18859, 18861, 18862, 18863, 18864, 18865, 18867, 18872, 18873, 18876, 18878, 18880, 18886, 18887, 18891, 18892, 18893, 18895, 18897, 18903, 18904, 18905, 18906, 18911, 18912, 18913, 18916, 18917, 18918, 18923, 18924, 18925, 18928, 18929, 18930, 18931, 18935, 18936, 18940, 18941, 18942, 18943, 18947, 18948, 18952, 18953, 18954, 18955, 18959, 18960, 18965, 18966, 18967, 18970, 18971, 18972, 18973, 18977, 18978, 18982, 18983, 18984, 18985, 18989, 18990, 18991, 18996, 18997, 19001, 19002, 19003, 19004, 19008, 19010, 19011, 19012, 19018, 19020, 19021, 19023, 19026, 19027, 19031, 19035, 19037, 19038, 19039, 19040, 19041, 19048, 19050, 19051, 19053, 19054, 19055, 19060, 19063, 19064, 19065, 19067, 19068, 19070, 19072, 19073, 19077, 19078, 19079, 19080, 19086, 19087, 19088, 19089, 19093, 19094, 19098, 19099, 19100, 19101, 19104, 19106, 19108, 19109, 19110, 19112, 19114, 19116, 19117, 19118, 19119, 19125, 19126, 19127, 19128, 19132, 19133, 19134, 19141, 19142, 19143, 19144, 19145, 19147, 19151, 19153, 19154, 19155, 19156, 19157, 19158, 19162, 19167, 19172, 19173, 19176, 19178, 19179, 19180, 19184, 19187, 19188, 19189, 19190, 19191, 19192, 19196, 19197, 19202, 19203, 19204, 19207, 19211, 19212, 19214, 19215, 19216, 19218, 19219, 19222, 19224, 19225, 19230, 19232, 19236, 19237, 19238, 19241, 19242, 19243, 19248, 19249, 19250, 19254, 19255, 19256, 19257, 19261, 19262, 19267, 19268, 19270, 19273, 19275, 19276, 19277, 19278, 19282, 19283, 19286, 19288, 19289, 19290, 19294, 19295, 19296, 19297, 19301, 19302, 19303, 19308, 19309, 19310, 19313, 19314, 19315, 19320, 19321, 19323, 19325, 19330, 19331, 19332, 19333, 19338, 19339, 19341, 19345, 19346, 19347, 19348, 19352, 19353, 19354, 19360, 19363, 19364, 19366, 19367, 19368, 19369, 19373, 19374, 19378, 19379, 19380, 19381, 19385, 19386, 19391, 19392, 19393, 19396, 19397, 19398, 19403, 19404, 19405, 19406, 19407, 19408, 19410, 19411, 19415, 19416, 19417, 19418, 19419, 19420, 19421, 19422, 19424, 19425, 19428, 19430, 19431, 19432, 19436, 19437, 19438, 19442, 19445, 19446, 19447, 19456, 19460, 19462, 19463, 19464, 19465, 19466, 19467, 19469, 19470, 19473, 19475, 19476, 19478, 19479, 19482, 19483, 19484, 19485, 19488, 19489, 19491, 19493, 19496, 19499, 19500, 19501, 19505, 19507, 19509, 19513, 19514, 19515, 19516, 19517, 19518, 19522, 19524, 19525, 19529, 19530, 19533, 19536, 19538, 19541, 19544, 19545, 19546, 19548, 19552, 19553, 19555, 19556, 19557, 19559, 19560, 19561, 19562, 19565, 19567, 19572, 19577, 19579, 19580, 19581, 19583, 19584, 19585, 19586, 19589, 19592, 19594, 19599, 19603, 19604, 19612, 19613, 19614, 19615, 19617, 19618, 19619, 19620, 19621, 19622, 19628, 19630, 19633, 19636, 19637, 19638, 19641, 19643, 19644, 19645, 19648, 19649, 19651, 19654, 19655, 19656, 19657, 19658, 19659, 19664, 19666, 19669, 19670, 19674, 19675, 19676, 19677, 19679, 19680, 19683, 19684, 19686, 19689, 19690, 19692, 19693, 19695, 19696, 19697, 19698, 19702, 19703, 19704, 19707, 19708, 19709, 19714, 19715, 19716, 19718, 19719, 19723, 19725, 19726, 19727, 19728, 19734, 19735, 19736, 19737, 19741, 19742, 19743, 19746, 19747, 19748, 19753, 19754, 19755, 19756, 19757, 19758, 19760, 19761, 19765, 19766, 19771, 19772, 19773, 19776, 19777, 19779, 19781, 19783, 19784, 19785, 19790, 19791, 19798, 19799, 19800, 19801, 19802, 19803, 19804, 19806, 19812, 19819, 19820, 19821, 19822, 19824, 19829, 19830, 19832, 19833, 19834, 19835, 19836, 19837, 19838, 19843, 19844, 19845, 19847, 19852, 19853, 19854, 19857, 19858, 19861, 19862, 19865, 19866, 19868, 19869, 19871, 19872, 19874, 19879, 19880, 19881, 19885, 19888, 19889, 19890, 19892, 19895, 19897, 19899, 19902, 19904, 19906, 19910, 19911, 19914, 19916, 19917, 19918, 19919, 19920, 19922, 19924, 19925, 19927, 19932, 19933, 19937, 19941, 19942, 19943, 19944, 19945, 19946, 19947, 19949, 19954, 19955, 19956, 19959, 19964, 19965, 19967, 19968, 19970, 19972, 19975, 19976, 19977, 19978, 19979, 19980, 19981, 19983, 19986, 19988, 19989, 19990, 19993, 19995, 19996, 19997, 19998, 20000, 20002, 20004, 20007, 20008, 20009, 20011, 20012, 20013, 20015, 20017, 20021, 20022, 20024, 20027, 20029, 20032, 20033, 20035, 20037, 20039, 20040, 20042, 20043, 20044, 20046, 20049, 20050, 20051, 20052, 20053, 20055, 20058, 20059, 20060, 20062, 20066, 20068, 20071, 20073, 20074, 20076, 20078, 20079, 20080, 20081, 20082, 20083, 20087, 20089, 20090, 20091, 20093, 20095, 20097, 20106, 20111, 20113, 20117, 20120, 20121, 20123, 20124, 20125, 20126, 20128, 20129, 20130, 20131, 20132, 20133, 20136, 20137, 20138, 20139, 20140, 20142, 20144, 20146, 20148, 20150, 20153, 20155, 20157, 20159, 20160, 20162, 20163, 20165, 20166, 20168, 20169, 20170, 20174, 20177, 20178, 20179, 20180, 20183, 20189, 20190, 20194, 20195, 20197, 20198, 20199, 20201, 20202, 20203, 20204, 20208, 20209, 20210, 20211, 20215, 20216, 20218, 20219, 20221, 20223, 20224, 20225, 20228, 20229, 20230, 20235, 20237, 20240, 20241, 20243, 20245, 20246, 20247, 20248, 20252, 20254, 20255, 20256, 20259, 20260, 20262, 20263, 20264, 20266, 20269, 20270, 20272, 20273, 20274, 20276, 20279, 20281, 20286, 20287, 20289, 20292, 20297, 20298, 20301, 20302, 20303, 20306, 20307, 20308, 20310, 20311, 20315, 20316, 20318, 20319, 20321, 20322, 20325, 20327, 20329, 20331, 20332, 20335, 20336, 20337, 20338, 20339, 20340, 20341, 20342, 20343, 20344, 20345, 20346, 20349, 20351, 20352, 20353, 20354, 20355, 20357, 20358, 20359, 20360, 20361, 20362, 20363, 20364, 20365, 20366, 20367, 20369, 20370, 20371, 20372, 20373, 20374, 20375, 20376, 20377, 20378, 20379, 20380, 20381, 20382, 20383, 20384, 20385, 20386, 20387, 20388, 20389, 20390, 20391, 20392, 20393, 20394, 20395, 20396, 20397, 20398, 20399, 20400, 20401, 20402, 20403, 20404, 20405, 20406, 20407, 20408, 20409, 20410, 20411, 20412, 20413, 20414, 20415, 20416, 20417, 20418, 20419, 20420, 20421, 20422, 20423, 20424, 20425, 20426, 20456, 20457, 20458, 20459, 20460, 20461, 20462, 20463, 20464, 20465, 20466, 20467, 20468, 20475, 20476, 20477, 20478, 20479, 20480, 20481, 20482, 20483, 20484, 20485, 20486, 20487, 20488, 20489, 20490, 20491, 20492, 20503, 20504, 20505, 20506, 20507, 20508, 20509, 20510, 20511, 20512, 20513, 20514, 20515, 20516, 20517, 20518, 20519, 20520, 20521, 20522, 20523, 20524, 20525, 20526, 20527, 20528, 20529, 20530, 20531, 20532, 20533, 20534, 20536, 20537, 20538, 20539, 20540, 20541, 20542, 20543, 20544, 20545, 20546, 20547, 20548, 20549, 20550, 20551, 20552, 20553, 20554, 20555, 20556, 20557, 20558, 20559, 20560, 20561, 20562, 20563, 20564, 20565, 20566, 20567, 20568, 20569, 20570, 20571, 20572, 20574, 20575, 20576, 20577, 20578, 20579, 20580, 20581, 20582, 20583, 20584, 20585, 20586, 20587, 20588, 20589, 20590, 20591, 20592, 20593, 20594, 20595, 20596, 20597, 20598, 20599, 20600, 20601, 20602, 20603, 20604, 20605, 20606, 20607, 20608, 20609, 20610, 20611, 20613, 20616, 20619, 20622, 20625, 20628, 20631, 20634, 20637, 20640, 20656, 20657, 20658, 20659, 20660, 20661,
warning: Skipping property vector 'PointMergeMap' - not defined on cells or nodes.
info: 1 property vectors copied, 1 vectors skipped.
info: 16 hole(s) detected within the mesh
0
Boundary and materials extraction using OpenGeoSys tools
  • ExtractBoundary Extracts all outer surface faces from a 3D mesh and creates a boundary-only mesh. Useful for defining where boundary conditions will be applied.
  • RemoveMeshElements Removes elements based on coordinate filters (e.g., x-min, x-max). Used to isolate specific boundary patches for inflow/outflow or other localized conditions.
  • ExtractMaterials Extracts submeshes from a mesh by selecting elements with specific material IDs, enabling features such as boreholes, fractures, or layers to be used for boundary conditions.
boundary_tol_fraction = 1e-6 # Tolerance for boundary selection… (click to toggle)
boundary_tol = boundary_tol_fraction * domain_size
x_outlet = maxs[0] - boundary_tol
x_inlet = mins[0] + boundary_tol
ogs.cli.ExtractBoundary(i="mixed_dimensional_grid_2.vtu", o="boundaries.vtu")… (click to toggle)
ogs.cli.removeMeshElements(i="boundaries.vtu", o="x_inlet.vtu", **{"x-min": x_inlet})
    i="boundaries.vtu", o="x_outlet.vtu", **{"x-min": x_outlet, "invert": True}
info: Mesh read: 10340 nodes, 20662 elements.
info: Created surface mesh: 1132 nodes, 1154 elements.
info: Mesh read: 1132 nodes, 1154 elements.
info: Bounding box of "boundaries" is
x = [-0.000000,100.000000]
y = [0.000000,100.000000]
z = [0.000000,100.000000]
info: 988 elements found.
info: Removing total 988 elements...
info: 166 elements remain in mesh.
info: Removing total 967 nodes...
info: 1129 elements found.
info: Removing total 1129 elements...
info: 25 elements remain in mesh.
info: Removing total 1105 nodes...
0
ogs.cli.ExtractMaterials(… (click to toggle)
    i="mixed_dimensional_grid_2.vtu", o="borehole_right.vtu", m=n_fractures
    i="mixed_dimensional_grid_2.vtu", o="borehole_left.vtu", m=n_fractures + 1
ogs.cli.identifySubdomains(
    "-m",
    "-s",
    str(1e-10),
    f"borehole_left_Layer{n_fractures+1}.vtu",
    f"borehole_right_Layer{n_fractures}.vtu",
info: Extracting material group 10...
info: Removing total 20490 elements...
info: 172 elements remain in mesh.
info: Removing total 10192 nodes...
info: Extracting material group 11...
info: Removing total 20512 elements...
info: 150 elements remain in mesh.
info: Removing total 10206 nodes...
info: Mesh reading time: 0.010366 s
info: MeshNodeSearcher construction time: 0.000483415 s
info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.11e-05 s
info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000651781 s
info: identifySubdomainMesh(): identifySubdomainMeshNodes took 2.068e-05 s
info: identifySubdomainMesh(): identifySubdomainMeshElements took 0.000376892 s
info: identifySubdomains time: 0.00109379 s
info: writing time: 0.00150825 s
info: Entire run time: 0.0135707 s
0
Plot DFN and boundaries
%cd $orig_dir… (click to toggle)
%cd $orig_dir
try:
except Exception as e:
    print("PyVista backend not set:", e)
DFN_2D = pv.read(f"{out_dir}/mixed_dimensional_grid_2.vtu")
x_inlet = pv.read(f"{out_dir}/x_inlet.vtu")
x_outlet = pv.read(f"{out_dir}/x_outlet.vtu")
plotter.add_mesh(
    DFN_2D,
    scalars="MaterialIDs",
    cmap="tab20",
    opacity=0.4,
    show_edges=True,
    scalar_bar_args={"title": "MaterialIDs", "vertical": True},
plotter.add_mesh(DFN_2D.outline(), color="black", line_width=2)
plotter.add_mesh(
    x_inlet,
    color="blue",
    opacity=1.0,
    show_edges=True,
    line_width=5,
    render_lines_as_tubes=True,
plotter.add_mesh(
    x_outlet,
    color="red",
    opacity=1.0,
    show_edges=True,
    line_width=5,
plotter.show_axes()
plotter.enable_parallel_projection()
plotter.view_isometric()
# plotter.window_size = [500, 500]
output_path = out_dir.joinpath("Concentration.png")
plotter.screenshot(str(output_path))
/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/ogs/Tests/Data/Parabolic/ComponentTransport/DFN_PorePy
2025-10-30 14:41:14.968 (  14.696s) [    7FB9317AA400]vtkXOpenGLRenderWindow.:1416  WARN| bad X server connection. DISPLAY=
/var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-all/.venv/lib/python3.13/site-packages/pyvista/plotting/plotter.py:3487: UserWarning: `show_edges=True` not supported when `render_lines_as_tubes=True`. Ignoring `show_edges`.
  warnings.warn(
Generate and assign random fracture properties with Gaussian distributions
We assign random fracture properties (e.g., width and permeability) by calculating each mean value, $\mu$, from one of three user-defined distributions: Uniform, clipped Gaussian, or truncated Gaussian, constrained within specified bounds. The standard deviation is then calculated as $\sigma = \mathrm{rel_{std}} \times \mu$, with $\mathrm{rel_{std}}$ fixed at 30%, and cell values are subsequently sampled from a Gaussian distribution $\bigl(\mu, \sigma\bigr)$ and mapped to the mesh. Permeability can be configured as either isotropic or anisotropic.
Remark: Random fields with spatial correlation would be a more suitable representation of fracture heterogeneity. In the context of OGS see [8,9].
def sample_truncnorm(a, b, mu, sigma, rng, size=None):… (click to toggle)
    if size is None:
        # scalar
        while True:
            x = rng.normal(mu, sigma)
            if a <= x <= b:
                return x
    size = int(size)
    out = np.empty(size)
    filled = 0
    batch = max(1024, size)
    while filled < size:
        x = rng.normal(mu, sigma, batch)
        x = x[(x >= a) & (x <= b)]
        take = min(size - filled, x.size)
        if take:
            out[filled : filled + take] = x[:take]
            filled += take
    return out
def sample_mean(a, b, rng, method="uniform"):
    if method == "uniform":
        return rng.uniform(a, b)
    if method == "constant":
        return 0.5 * (a + b)
    mu = 0.5 * (a + b)
    sigma = (b - a) / 6.0
    if method == "gaussian":
        return np.clip(rng.normal(mu, sigma), a, b)
    if method == "truncated":
        return sample_truncnorm(a, b, mu, sigma, rng)
    msg = "Unknown sampling method"
    raise ValueError(msg)
def generate_random_fracture_stats(
    fracture_ids,
    width_range=(5e-6, 1e-5),
    k_range=(1e-14, 1e-12),
    rel_std=0.3,
    mean_dist="uniform",
    rng=None,
    rng = rng or default_rng()
    stats = {}
    for mat_id in fracture_ids:
        w_min, w_max = width_range
        width_mean = sample_mean(w_min, w_max, rng, method=mean_dist)
        k_min, k_max = k_range
        k_mean = sample_mean(k_min, k_max, rng, method=mean_dist)
        stats[mat_id] = {
            "width_mean": width_mean,
            "width_std": rel_std * width_mean,
            "width_range": (w_min, w_max),
            "k_mean": k_mean,
            "k_std": rel_std * k_mean,
            "k_range": (k_min, k_max),
            "method": mean_dist,
    return stats
def assign_cellwise_random_props(mesh, stats_dict, clip_min=1e-20, seed=42):
    rng = default_rng(seed)
    MaterialIDs = mesh.cell_data["MaterialIDs"]
    n_cells = len(MaterialIDs)
    width_ic = np.zeros(n_cells)
    permeability = np.zeros(n_cells)
    for mat_id, stats in stats_dict.items():
        idx = np.where(MaterialIDs == mat_id)[0]
        n = len(idx)
        method = stats.get("method", "uniform")
        w_min, w_max = stats["width_range"]
        w_mean, w_std = stats["width_mean"], stats["width_std"]
        k_min, k_max = stats["k_range"]
        k_mean, k_std = stats["k_mean"], stats["k_std"]
            width_vals = rng.uniform(w_min, w_max, n)
            k_vals = rng.uniform(k_min, k_max, n)
        elif method == "constant":
            width_vals = np.full(n, w_mean)
            k_vals = np.full(n, k_mean)
        elif method == "truncated":
            width_vals = sample_truncnorm(w_min, w_max, w_mean, w_std, rng, size=n)
            k_vals = sample_truncnorm(k_min, k_max, k_mean, k_std, rng, size=n)
        elif method == "gaussian":
            width_vals = np.clip(rng.normal(w_mean, w_std, n), w_min, w_max)
            k_vals = np.clip(rng.normal(k_mean, k_std, n), k_min, k_max)
        width_ic[idx] = np.clip(width_vals, clip_min, None)
        permeability[idx] = k_vals
    mesh.cell_data["width_ic"] = width_ic
    mesh.cell_data["permeability_ic"] = permeability
input_mesh = "mixed_dimensional_grid_2.vtu"… (click to toggle)
output_mesh = "mixed_dimensional_grid_2_updated.vtu"
use_isotropic_perm = False
mesh = pv.read(Path(out_dir, input_mesh))
material_ids = np.unique(mesh.cell_data["MaterialIDs"])
fracture_ids = list(material_ids)
SEED = 20250818… (click to toggle)
SEED = 20250818
rng = default_rng(SEED)
fracture_stats = generate_random_fracture_stats(
    fracture_ids,
    width_range=(1e-6, 1e-5),
    k_range=(1e-16, 1e-14),
    rel_std=0.3,  # standard deviation is 30 % of mean value.
    mean_dist="gaussian",  # constant, uniform, gaussian, or truncated
    rng=rng,
assign_cellwise_random_props(mesh, fracture_stats, seed=SEED)
mesh.save(Path(out_dir, output_mesh), binary=False)
base_scalar_bar_args = {… (click to toggle)
    "vertical": True,
    "position_x": 0.9,
    "position_y": 0.2,
    "width": 0.03,
    "height": 0.6,
    "title_font_size": 20,
    "label_font_size": 16,
    "n_labels": 4,
    "color": "black",
    "fmt": "%.1f",
try:… (click to toggle)
try:
DFN_2D = pv.read(Path(out_dir, output_mesh))
x_inlet = pv.read(Path(out_dir, "x_inlet.vtu"))
x_outlet = pv.read(Path(out_dir, "x_outlet.vtu"))
def plot_scalar_field(mesh, inlet, outlet, scalar_data, title, cmap, filename):
    scalar_bar_args = base_scalar_bar_args.copy()
    scalar_bar_args["title"] = title
    scalar_bar_args.update(
            "fmt": "%.1e",  # Scientific notation
            "n_labels": 5,  # More labels to show range
    plotter.add_mesh(
        mesh,
        scalars=scalar_data,
        cmap=cmap,
        show_edges=False,
        scalar_bar_args=scalar_bar_args,
    plotter.add_mesh(mesh.outline(), color="black", line_width=2)
    plotter.add_mesh(inlet, color="blue", line_width=5, render_lines_as_tubes=True)
    plotter.add_mesh(outlet, color="red", line_width=5, render_lines_as_tubes=True)
    plotter.show_axes()
    plotter.screenshot(Path(out_dir, filename))
def plot_isotropic_permeability(
    mesh,
    inlet,
    outlet,
    out_dir,
    cmap="viridis",
    image_name="permeability_isotropic.png",
    k_iso = mesh.cell_data["permeability_ic"]  # [:, 0]
    k_log = np.log10(np.clip(k_iso, 1e-20, None))
    mesh.cell_data["log_k_iso"] = k_log
    scalar_bar_args["title"] = "log₁₀(Permeability) [log₁₀(m²)]"
    plotter.add_mesh(
        mesh,
        scalars="log_k_iso",
        cmap=cmap,
        show_edges=False,
    plotter.add_mesh(inlet, color="blue", line_width=6, render_lines_as_tubes=True)
    plotter.add_mesh(outlet, color="red", line_width=6, render_lines_as_tubes=True)
    plotter.show_axes()
    plotter.screenshot(Path(out_dir, image_name))
    mesh=DFN_2D,
    inlet=x_inlet,
    outlet=x_outlet,
    out_dir=out_dir,
plot_scalar_field(
    mesh=DFN_2D,
    inlet=x_inlet,
    outlet=x_outlet,
    scalar_data="width_ic",
    title="Fracture Width (m)",
    cmap="plasma",
    filename="width_ic.png",
Project file preparation
def add_component_to_model(… (click to toggle)
    model, name, pore_diff="1e-9", retardation="1.0", decay="0.0"
    # Add <component>
    model.add_element(".//media/medium/phases/phase/components", "component")
    component_xpath = ".//media/medium/phases/phase/components/component[last()]"
    model.add_element(component_xpath, "name", name)
    model.add_element(component_xpath, "properties")
    for prop, param in {
        "pore_diffusion": f"pore_diff_{name}",
        "retardation_factor": f"retard_{name}",
        "decay_rate": f"decay_{name}",
    }.items():
        model.add_element(f"{component_xpath}/properties", "property")
        prop_xpath = f"{component_xpath}/properties/property[last()]"
        model.add_element(prop_xpath, "name", prop)
        model.add_element(prop_xpath, "type", "Parameter")
        model.add_element(prop_xpath, "parameter_name", param)
    # Add <process_variable>
    model.add_element("./process_variables", "process_variable")
    pv_xpath = "./process_variables/process_variable[last()]"
    model.add_element(pv_xpath, "name", name)
    model.add_element(pv_xpath, "components", "1")
    model.add_element(pv_xpath, "order", "1")
    model.add_element(pv_xpath, "initial_condition", "c0")
    model.add_element(pv_xpath, "boundary_conditions")
    model.add_element(f"{pv_xpath}/boundary_conditions", "boundary_condition")
    bc_xpath = f"{pv_xpath}/boundary_conditions/boundary_condition[last()]"
    model.add_element(bc_xpath, "type", "Dirichlet")
    mesh_name_bc = f"borehole_right_Layer{n_fractures}"
    model.add_element(bc_xpath, "mesh", mesh_name_bc)
    model.add_element(bc_xpath, "parameter", "c_bottom")
    # Add <concentration> in <process_variables>
    model.add_element(".//processes/process/process_variables", "concentration", name)
    # Add <parameter> entries
    for pname, val in {
        f"pore_diff_{name}": pore_diff,
        f"retard_{name}": retardation,
        f"decay_{name}": decay,
    }.items():
        model.add_element(".//parameters", "parameter")
        p_xpath = ".//parameters/parameter[last()]"
        model.add_element(p_xpath, "name", pname)
        model.add_element(p_xpath, "type", "Constant")
        model.add_element(p_xpath, "value", val)
def update_reltols_for_components(model, total_components, tol="1e-12"):
    reltols_xpath = ".//time_loop/processes/process/convergence_criterion/reltols"
    reltol_values = " ".join([tol] * total_components)
    model.replace_text(reltol_values, xpath=reltols_xpath)
def update_project_parameters(project: ot.Project, params: dict):
    update_map = {
        "prefix": ".//time_loop/output/prefix",
        "initial_pressure_expression": ".//parameters/parameter[name='p0']/expression",
        "inlet_pressure_expression": ".//parameters/parameter[name='pinlet']/expression",
        "outlet_pressure_expression": ".//parameters/parameter[name='poutlet']/expression",
        "inlet_concentration_value": ".//parameters/parameter[name='c_bottom']/value",
        "porosity_value": ".//parameters/parameter[name='porosity_parameter']/value",
        "fracture_thickness_value": ".//parameters/parameter[name='fracture_thickness_const']/value",
        "decay_Si_value": ".//parameters/parameter[name='decay']/value",
        "t_end": ".//time_loop/processes/process/time_stepping/t_end",
    for key, xpath in update_map.items():
        if key in params:
            try:
                project.replace_text(params[key], xpath=xpath)
                display(
                    Markdown(
                        f"**Success:** Parameter `{key}` updated to **{params[key]}**"
                msg = f"Failed to update parameter `{key}`: {e}"
                display(Markdown(f"**Error:** {msg}"))
                raise RuntimeError(msg) from e
    if "fracture_permeability_values" in params:
        try:
                params["fracture_permeability_values"].strip(),
                xpath=".//parameters/parameter[name='kappa1_frac']/values",
            display(
                Markdown(
                    "**Success:** Fracture permeability values updated successfully."
            msg = f"Failed to update fracture permeability: {e}"
    main_proc_xpath = "processes/process[1]"
    project.remove_element(f"{main_proc_xpath}/numerical_stabilization")
    if "numerical_stabilization" in params:
        stab = params["numerical_stabilization"]
        stype = stab.get("type")
        if not stype:
            error_msg = "'type' is required in numerical_stabilization"
            raise ValueError(error_msg)
        project.add_element(main_proc_xpath, "numerical_stabilization")
        ns_xpath = f"{main_proc_xpath}/numerical_stabilization[last()]"
        project.add_element(ns_xpath, "type", stype)
        if stype == "FullUpwind":
            cutoff = stab.get("cutoff_velocity", "0.0")
            project.add_element(ns_xpath, "cutoff_velocity", cutoff)
        elif stype == "IsotropicDiffusion":
            tuning = stab.get("tuning_parameter")
            cutoff = stab.get("cutoff_velocity")
            if tuning is None or cutoff is None:
                error_msg = "'tuning_parameter' and 'cutoff_velocity' required for IsotropicDiffusion"
            project.add_element(ns_xpath, "tuning_parameter", tuning)
        elif stype == "FluxCorrectedTransport":
            pass
            error_msg = f"Unsupported stabilization type: {stype}"
        display(
            Markdown(
                f"**Success:** Configured numerical stabilization in main processes with type `{stype}`"
        n = params["n_fractures"]
        target_var_name = "Si"
        bc_mesh_xpath = f".//process_variables/process_variable[name='{target_var_name}']/boundary_conditions/boundary_condition/mesh"
        project.replace_text(f"borehole_right_Layer{n}", xpath=bc_mesh_xpath)
        display(
            Markdown(
                f"**Success:** Updated BC mesh for `{target_var_name}` to `borehole_right_Layer{n}`"
        left_mesh = f"borehole_left_Layer{n + 1}.vtu"
        right_mesh = f"borehole_right_Layer{n}.vtu"
        mesh_base_xpath = ".//meshes/mesh"
        project.replace_text(left_mesh, xpath=f"{mesh_base_xpath}[last()-1]")
        project.replace_text(right_mesh, xpath=f"{mesh_base_xpath}[last()]")
        display(
            Markdown(
                f"**Success:** Updated borehole meshes: `{left_mesh}`, `{right_mesh}`"
user_parameters = {… (click to toggle)
user_parameters = {
    "prefix": "DFN_HC",
    "initial_pressure_expression": "1000*9.81*(500-z)",
    "inlet_pressure_expression": "1000*9.81*(500-z)+2.943e5",
    "outlet_pressure_expression": "1000*9.81*(500-z)",
    "inlet_concentration_value": "1",
    "porosity_value": "0.05",
    "decay_Si_value": "1e-12",
    "t_end": "1e11",
    "maximum_dt": "5e9",
    "numerical_stabilization": {
        "type": "FluxCorrectedTransport",
    "n_fractures": n_fractures,
project_file = Path("DFN_HC.prj")… (click to toggle)
project = ot.Project(
    input_file=project_file, output_file=Path(f"{out_dir}/DFN_HC_final.prj")
    project, "Cs", pore_diff="1e-9", retardation="1.", decay="1.e-10"
    project, total_components=3
)  # total = 1 pressure + 2 components
update_project_parameters(project, user_parameters)
project.write_input()
Success: Parameter prefix updated to DFN_HC
Success: Parameter initial_pressure_expression updated to 10009.81(500-z)
Success: Parameter inlet_pressure_expression updated to 10009.81(500-z)+2.943e5
Success: Parameter outlet_pressure_expression updated to 10009.81(500-z)
Success: Parameter inlet_concentration_value updated to 1
Success: Parameter porosity_value updated to 0.05
Success: Parameter decay_Si_value updated to 1e-12
Success: Parameter t_end updated to 1e11
Success: Configured numerical stabilization in main processes with type FluxCorrectedTransport
Success: Updated BC mesh for Si to borehole_right_Layer10
Success: Updated borehole meshes: borehole_left_Layer11.vtu, borehole_right_Layer10.vtu
Run simulations
project.run_model(args=f"-o {out_dir} -m {out_dir}", logfile=Path(out_dir, "run.log"))
Simulation: /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-all/Tests/Data/Parabolic/ComponentTransport/DFN_PorePy/DFNbyPorePy_to_OGS/DFN_HC_final.prj
Execution took 50.43521857261658 s
Post-processing
ms = ot.MeshSeries(f'{out_dir}/{user_parameters["prefix"]}.pvd')
mesh = ms[-1]
plotter = pv.Plotter(off_screen=True)… (click to toggle)
scalar_bar_args["title"] = "Pressure [Pa]"
plotter.add_mesh(
    mesh,
    scalars="pressure",
    cmap="Blues",
    show_edges=True,
    opacity=1.0,
plotter.show_axes()
output_path = out_dir.joinpath("pressure.png")
magnitude = np.linalg.norm(mesh["darcy_velocity"], axis=1)… (click to toggle)
magnitude[magnitude <= 0] = 1e-12
log_magnitude = np.log10(magnitude)
mesh["darcy_velocity_magnitude"] = magnitude
mesh["log_darcy_velocity_magnitude"] = log_magnitude
mesh.set_active_vectors("darcy_velocity")
vmax = magnitude.max()
domain_size = max(mesh.bounds[1::2]) - min(mesh.bounds[::2])
scale_factor = domain_size * 0.1 / vmax if vmax > 0 else 1.0
arrows = mesh.glyph(
    scale="darcy_velocity_magnitude", orient="darcy_velocity", factor=scale_factor
scalar_bar_args["title"] = "log₁₀(Darcy Velocity) [m/s]"
plotter.add_mesh(
    mesh,
    scalars="log_darcy_velocity_magnitude",
    cmap="viridis",
    opacity=1.0,
    show_edges=False,
plotter.add_mesh(arrows, color="black", label="Velocity Vectors")
plotter.show_axes()
output_path = out_dir.joinpath("full_mesh_velocity_log_arrows.png")
scalar_bar_args["title"] = "Si Concentration [mol/m³]"
plotter.add_mesh(
    mesh,
    scalars="Si",
    cmap="plasma",
    clim=(0, 1),
    show_edges=False,
    opacity=1.0,
plotter.show_axes()
output_path = out_dir.joinpath("concentration.png")
scalar_bar_args["title"] = "Cs Concentration [mol/m³]"
plotter.add_mesh(
    mesh,
    scalars="Cs",
    clim=(0, 1),
    cmap="cividis",
    show_edges=False,
    opacity=1.0,
plotter.show_axes()
output_path = out_dir.joinpath("concentration_Cs.png")
Breakthrough curve (BTC)
the temporal evolution of tracer concentration at a downstream monitoring point in a flow-through porous medium,
mesh_series = ot.MeshSeries(f'{out_dir}/{user_parameters["prefix"]}.pvd')… (click to toggle)
print("Scalar fields available in mesh:", mesh.array_names)
observation_points = np.array(
        [80, 50, 90],
        [80, 50, 80],
labels = [f"Point {i}: {pt}" for i, pt in enumerate(observation_points)]
ms_days = mesh_series.scale(time=("s", "d"))
var = ot.variables.Scalar("Si")
fig_si = ms_days.plot_probe(points=observation_points, variable=var, labels=labels)
fig_si.axes[0].set_xscale("log")
fig_cs = ms_days.plot_probe(points=observation_points, variable="Cs", labels=labels)
fig_cs.axes[0].set_xscale("log")
Scalar fields available in mesh: ['Cs', 'OGS_VERSION', 'PointMergeMap', 'CsFlowRate', 'LiquidMassFlowRate', 'Si', 'SiFlowRate', 'darcy_velocity', 'pressure', 'darcy_velocity_magnitude', 'log_darcy_velocity_magnitude', 'MaterialIDs', 'permeability_ic', 'porosity_avg', 'velocity', 'width_ic']
/tmp/ipykernel_1069056/2640689875.py:16: DeprecationWarning: Call to a deprecated function plot_probe.
    Please use the following code instead:
        ms_pts = ot.MeshSeries.extract_probe(mesh_series, pts)
        fig = ot.plot.line(ms_pts, "time", variable_of_interest)
/tmp/ipykernel_1069056/2640689875.py:19: DeprecationWarning: Call to a deprecated function plot_probe.
def _ensure_point_pressure(m):… (click to toggle)
    if "pressure" in m.point_data:
        return m
    if "pressure" in m.cell_data:
        return m.cell_data_to_point_data()
    msg = "pressure not found in point_data or cell_data"
    raise KeyError(msg)
def _nn_fill(masked_vals, valid_mask, tgt_pts, src_pts, src_vals):
    nan_idx = ~valid_mask
    if not np.any(nan_idx):
        return masked_vals
    tree = cKDTree(src_pts)
    _, j = tree.query(tgt_pts[nan_idx], k=1)
    masked_vals[nan_idx] = src_vals[j]
    return masked_vals
last_mesh = mesh_series[-1]
pressure_last = np.asarray(last_mesh.point_data["pressure"])
system_name = platform.system()
if system_name == "Darwin":
    ref_mesh_path = "DFN_HC_ts_39_t_100000000000.000000_mac.vtu"
elif system_name == "Linux":
    ref_mesh_path = "DFN_HC_ts_39_t_100000000000.000000_linux.vtu"
    msg = f"Unsupported OS: {system_name}"
ref_mesh = _ensure_point_pressure(pv.read(ref_mesh_path))
print(f"Original points: {mesh_c.n_points}, Cleaned points: {clean_mesh.n_points}")
print("pressure_last shape:", pressure_last.shape, "size:", pressure_last.size)
print(
    "pressure_ref  shape:",
    ref_mesh.point_data["pressure"].shape,
    "size:",
    ref_mesh.point_data["pressure"].size,
sampled = last_mesh.sample(ref_mesh)
pressure_ref_on_last = np.asarray(sampled.point_data["pressure"])
mask = sampled.point_data.get("vtkValidPointMask", None)
if mask is not None:
    mask = np.asarray(mask).astype(bool)
    if not mask.all():
        pressure_ref_on_last = _nn_fill(
            pressure_ref_on_last,
            mask,
            last_mesh.points,
            ref_mesh.points,
            np.asarray(ref_mesh.point_data["pressure"]),
abs_diff = np.abs(pressure_last - pressure_ref_on_last)
print(f"max|delta_p|={abs_diff.max():.6g}, mean|delta_p|={abs_diff.mean():.6g}")
np.testing.assert_allclose(
    actual=pressure_last,
    desired=pressure_ref_on_last,
    rtol=5e-6,
    atol=1e-8,
    equal_nan=False,
print("Pressure fields match")
Original points: 12110, Cleaned points: 10340
pressure_last shape: (10340,) size: 10340
pressure_ref  shape: (10340,) size: 10340
max|delta_p|=3.39933e-07, mean|delta_p|=1.7032e-08
NOTE: PorePy produces slightly different number of mesh nodes on macOS vs. Linux. This causes small variations in the output arrays. To avoid flaky test failures, we accept either platform’s expected results until the root cause is resolved.
  1. PorePy – An open-source simulation tool for fractured and porous media. Available at: https://github.com/pmgbergen/porepy
  2. Keilegavlen, E., Berre, I., Fumagalli, A., Stefansson, I., and Edwards, M.G. (2021). PorePy: An open-source simulation tool for flow and transport in deformable fractured rocks. Computational Geosciences, 25, 165–187.
  3. Buchwald, J., Kolditz, O., & Nagel, T. (2021). ogs6py and VTUinterface: streamlining OpenGeoSys workflows in Python. Journal of Open Source Software, 6(67), 3673.
  4. Cvetkovic, V., & Frampton, A. (2010). Transport and retention from single to multiple fractures in crystalline rock at Äspö (Sweden): Fracture network simulations and generic retention model. Water Resources Research, 46, W05506.
  5. Watanabe, N., & Kolditz, O. (2015). Numerical stability analysis of two-dimensional solute transport along a discrete fracture in a porous rock matrix. Water Resources Research, 51(7), 5855-5868.
  6. Chen, C., Binder, M., Oppelt, L., Hu, Y., Engelmann, C., Arab, A., Xu, W., Scheytt, T., & Nagel, T. (2024). Modeling of heat and solute transport in a fracture-matrix mine thermal energy storage system and energy storage performance evaluation. Journal of Hydrology, 636(May), 131335.
  7. Chen, R., Xu, W., Chen, Y., Nagel, T., Chen, C., Hu, Y., Li, J., & Zhuang, D. (2024). Influence of heterogeneity on dissolved CO2 migration in a fractured reservoir. Environmental Earth Sciences, 83(16), 463.
  8. Chaudhry, A. A., Zhang, C., Ernst, O. G., & Nagel, T. (2025). Effects of inhomogeneity and statistical and material anisotropy on THM simulations. Reliability Engineering & System Safety, 110921.
  9. Zheng, Z., Wang, X., Flügge, J., & Nagel, T. (2025). A stochastic modeling framework for radionuclide migration from deep geological repositories considering spatial variability. Advances in Water Resources, 203, 105003.
This article was written by Mostafa Mollaali, Thomas Nagel. If you are missing something or you find an error please let us know.
Generated with Hugo 0.147.9 in CI job 639840 | Last revision: April 28, 2025
