In the process of incorporating boundary conditions of second type (or Neumann boundary conditions) into the simulation model, the area associated to each surface node is needed for the local assembly. This tool reads a surface mesh (see also ExtractSurface), computes the associated area for each node and writes the information as TXT and CSV data.
ComputeNodeAreasFromSurfaceMesh -i <file name of input mesh>
[-p <output path and base name as one string>]
[--id-prop-name <property name>]
If the option -p is not given the output path is extracted from the input path. The default
value for the --id-prop-name argument is bulk_node_ids. This name is also used
by ExtractSurface for storing the
subsurface node ids.
The following steps were performed to obtain the example data:
generateStructuredMesh -o hex_6x7x3.vtu -e hex --lx 6 --ly 7 --lz 3.ExtractSurface -i hex_6x7x3.vtu -o hex_6x7x3_surface.vtu
The generated surface mesh contains a property bulk_node_ids assigned to the mesh nodes
that contains the original subsurface mesh node ids.
ComputeNodeAreasFromSurfaceMesh -i hex_6x7x3_surface.vtu generates two text files
(hex_6x7x3_surface.txt and hex_6x7x3_surface.csv). The TXT file is usable as
boundary condition input file for OGS-5 simulation. The first column of the text file contains the
original mesh node id (see image above), the second column the associated area. For example to the
corner node 168 an area of 0.25 is associated. The edge node 169 has an area value of 0.5 and the
interior node 176 has an area value of 1.
| Edit
this page on
