Once you have submitted a merge request the code review process kicks in which can be summarized as:
For more information on merge requests see the GitLab documentation.
The default label upon creating a merge request is workflow::in development.
To request a code review set the merge request label to workflow::please review!
A merge request reviewer will now have look. If changes are requested the reviewer may change the label
to workflow::needs update indicating that the merge request author is now back in charge
again.
To indicate that you are currently not working on a merge request set it to workflow::paused
(disables also CI – there is also a dedicated label for disabling CI: ci skip).
The following diagram summarises the workflow:
workflow::please review.Draft-flag
(if you have set it previously).On the merge request page in the first box which contains information on the MR author and branch name
there is button labelled Check out branch which will show you instructions on how to locally
checkout this MR:
| Edit
this page on
