Modularizing project files
Project files .prj have to be valid XML documents. For information of specific tags see our Doxygen-documentation
Two methods allow you to modularize your project files and avoid repetition:
Option 1: Include XML-content from other files
The <include file="other_file.xml" />-tag allows to include the content of another XML into the current project file.
Limitation: Only one child include-element per (regular) XML-element is allowed.
Tests/Data/Elliptic/circle_radius_1/circle_1e1_axi.prj:
<processes>
<include file="../cube_1x1x1_SteadyStateDiffusion/SteadyStateDiffusion.xml"/>
</processes>Tests/Data/Elliptic/cube_1x1x1_SteadyStateDiffusion/SteadyStateDiffusion.xml:
<process>
<process_variables>
<process_variable>pressure</process_variable>
</process_variables>
<secondary_variables>
<secondary_variable internal_name="darcy_velocity" output_name="v"/>
</secondary_variables>
</process>Note on file encoding
Please do not use UTF-8 with BOM-encoding! The BOM-marker from the included file will be included somewhere in the middle of the final prj-file and this will cause OGS’ ConfigTree to crash. In a text editor you typically can convert a file to other encodings. Please also check your text editor for default encodings on creating new files. In general UTF-8 or ISO 8859-1 should be fine.
Option 2: Apply patch files to the project file
Patch files contain <replace>, <add> and <remove>-elements with XPath
-selectors to modify a specific part of the project file (in-memory during run-time):
Tests/Data/Elliptic/square_1x1_SteadyStateDiffusion/square_neumann.xml:
<OpenGeoSysProjectDiff>
<add sel="/*/time_loop/output/prefix/text()" pos="after">_neumann</add>
<replace sel="/*/parameters/parameter[2]/name/text()">p_neumann</replace>
<replace sel="/*/parameters/parameter[3]/name/text()">p_Dirichlet</replace>
<replace sel="/*/parameters/parameter[3]/value/text()">1</replace>
<replace sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[1]/parameter/text()">p_Dirichlet</replace>
<replace sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[2]/type/text()">Neumann</replace>
<replace sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[2]/parameter/text()">p_neumann</replace>
<add sel="/*/process_variables/process_variable/boundary_conditions/boundary_condition[1]" pos="after">
<boundary_condition>
<geometrical_set>square_1x1_geometry</geometrical_set>
<geometry>bottom</geometry>
<type>Dirichlet</type>
<parameter>p_Dirichlet</parameter>
</boundary_condition>
</add>
</OpenGeoSysProjectDiff>For more examples see this page on the XML Patch Operations Framework .
Option 2a: Supply patch file(s) additionally to the prj-file
ogs -p path/to/square_1e0_neumann.xml [other/optional/patch_file.xml] path/to/square_1e0.prjSupplied patch files are applied in the given order.
Option 2b: Use a patch file directly
If the patch file specifies a base_file:
Tests/Data/Elliptic/cube_1x1x1_SteadyStateDiffusion/cube_1e1.xml:
<OpenGeoSysProjectDiff base_file="cube_1e0.prj">
<replace sel="/*/mesh/text()">cube_1x1x1_hex_1e1.vtu</replace>
<replace sel="/*/time_loop/output/prefix/text()">cube_1e1</replace>
</OpenGeoSysProjectDiff>you can just pass this patch file:
ogs path/to/cube_1e1.xmlIn this case you have just one patch file.
Combination of include and patch method
When both methods are combined the logical order is the following:
- Apply patches
- Insert includes
- Apply patches marked with
after_includes="true"-attribute only.
Example:
<!-- The first line is run before the includes: -->
<!-- The following is evaluated after the includes are run: -->
<replace sel="/*/time_loop/output/prefix/text()" after_includes="true">cube_1e1</replace>
</OpenGeoSysProjectDiff>Check project file syntax with xmllint
You can check the formatting with the xmllint-tool
xmllint --noout myproj.prjInstallation of xmllint
We recommend to install via Chocolatey :
choco install xsltprocAlternative installation
Another method is to use the Windows Subsystem for Linux where you can simply install Linux packages:
sudo apt-get install libxml2-utilssudo apt-get install libxml2-utilsxmllint is part of the Homebrew xmlstarlet package:
brew install xmlstarletThis article was written by Lars Bilke. If you are missing something or you find an error please reach out
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
