USER GUIDE
Command-line arguments
The following arguments are available:
$ ogs --help
--enable-fpe
enables floating point exceptions
--unbuffered-std-out
use unbuffered standard output
--config-warnings-nonfatal
warnings from parsing the configuration file will not trigger program
abortion
-l <LOG_LEVEL>, --log-level <LOG_LEVEL>
the verbosity of logging messages: none, error, warn, info, debug, all
-m <PATH>, --mesh-input-directory <PATH>
the directory where the meshes are read from, default is project file directory
-o <PATH>, --output-directory <PATH>
the output directory to write to
--write-prj
Writes processed project file to output path /
[prj_base_name]_processed.prj.
-p <>, --xml-patch <> (accepted multiple times)
the xml patch file(s) which is (are) applied (in the given order) to
the PROJECT_FILE
-r <PATH>, --reference <PATH>
Run output result comparison after successful simulation comparing to
all files in the given path. This requires test definitions to be
present in the project file.
--, --ignore_rest
--version
-h, --help
<PROJECT_FILE>
(required) Path to the ogs6 project file.This article was written by Lars Bilke. If you are missing something or you find an error please reach out
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
