F-bar on large deformation problems with locking
F-bar method applied to large deformation problems exhibiting volumetric locking
These benchmarks are taken from [1] but employ a basic Neo-Hookean hyperelastic model as described below. The Neo-Hookean model defines an energy function as the sum of volumetric component $U_{\text{dil}}(\F)$ and deviatoric component $U_{\text{dev}}(\F)$ as
where
with $K$ the bulk modulus, and $G$ the shear modulus.
For each following examples a contour plot of the displacement field in the deformed mesh is shown after the simulation finishes.
class SingleOGSModel:… (click to toggle)
    """An OGS run model"""
    def __init__(self, project_name: str, use_fbar: bool):
        self.prj = ot.Project(
            input_file=Path(project_name) / f"{project_name}.prj",
            output_file=out_dir / "modified.prj",
        self.prj.replace_text(project_name, "./time_loop/output/prefix")
        if not use_fbar:
            self.prj.replace_text("none", "./processes/process/f_bar")
        self.project_name = project_name
        self.use_fbar = use_fbar
    def reset_time_step_size(self, dt: float, n_steps: int):
        xpath = "./time_loop/processes/process[1]/time_stepping/timesteps/pair[1]/"
        self.prj.replace_text(str(dt), xpath + "delta_t")
        self.prj.replace_text(n_steps, xpath + "repeat")
    def run(self) -> ot.MeshSeries:
        self.prj.write_input()
        self.prj.run_model(
            logfile=out_dir / "out.txt", args=f"-o {out_dir} -m {self.project_name}"
        return ot.MeshSeries(out_dir / (self.project_name + ".pvd"))
    def run_benchmark(self, u_max_ref: list[float]):
        results = self.run()
        u_max_pt = np.argmax(ot.variables.displacement.magnitude.transform(results[-1]))
        u_max_num = results[-1]["displacement"][u_max_pt]
        np.testing.assert_allclose(u_max_num, u_max_ref, rtol=1e-4)
        f_bar_info = "With F-bar" if self.use_fbar else "Without F-bar"
        print(
            f"{f_bar_info}, the obtained maximum displacement"
            f" of {self.project_name} is {u_max_num} m."
        self.plot3D(results[-1])
    def plot3D(self, mesh: pv.UnstructuredGrid):
        dim = np.max([cell.dimension for cell in mesh.cell])
        if dim == 2:
            zeros = np.zeros((mesh.n_points, 1))
            mesh["displacement"] = np.hstack((mesh["displacement"], zeros))
        pl = pv.Plotter()
        pl.camera_position = "xy" if dim == 2 else (-0.5, -0.5, 0.4)
        pl.show_axes()
        pl.reset_camera()
        pl.show()
A block under compression
This is a plane strain problem. The domain size is 0.01 m $\times$ 0.01 m. The geometry and boundary conditions are shown in the following figure:
Simple test
The values of Young’s modulus ($E$) and Poisson’s ratio ($\nu$) are calculated from the specified bulk modulus of 400,889.806 MPa and the shear modulus of 80.194 MPa. The calculated Poisson’s ratio is close to 0.5, indicating that the material is nearly incompressible.
Simulation without the F-bar method
ogs_model = SingleOGSModel("RubberIndentation", use_fbar=False)
ogs_model.run_benchmark(u_max_ref=[0, -0.00010428732840299523])
 ogs -o /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking -m RubberIndentation /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking/modified.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking', '-m', 'RubberIndentation', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking/modified.prj']
Without F-bar, the obtained maximum displacement of RubberIndentation is [ 0.         -0.00010429] m.
2026-09-17 15:55:17.398 (   2.284s) [    7F3BA00EF480]vtkXOpenGLRenderWindow.:1460  WARN| bad X server connection. DISPLAY=
Simulation with the F-bar method
ogs_model = SingleOGSModel("RubberIndentation", use_fbar=True)
ogs_model.run_benchmark(u_max_ref=[0, -0.00026707547768988984])
With F-bar, the obtained maximum displacement of RubberIndentation is [ 0.         -0.00026708] m.
3D indentation example
Simple test This example analyzes the deformation of a block ($0.01\times 0.01 \times 0.01\,\text{m}^3$) under indentation. As shown in the figure, a uniformly distributed pressure of 40 MPa is applied to one-quarter of the top surface. On the symmetry surfaces, the displacement in the normal direction is fixed, while on the bottom surface, the vertical displacement is fixed. The material parameters are the same as those used in the previous example.
ogs_model = SingleOGSModel("Indentation3D", use_fbar=False)
ogs_model.run_benchmark(u_max_ref=[0, 0, -1.6534484343296282e-05])
 ogs -o /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking -m Indentation3D /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking/modified.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking', '-m', 'Indentation3D', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking/modified.prj']
Without F-bar, the obtained maximum displacement of Indentation3D is [ 0.00000000e+00  0.00000000e+00 -1.65344843e-05] m.
ogs_model = SingleOGSModel("Indentation3D", use_fbar=True)
ogs_model.run_benchmark(u_max_ref=[0, 0, -0.00010953948059235105])
With F-bar, the obtained maximum displacement of Indentation3D is [ 0.          0.         -0.00010954] m.
Thick cylindrical shell under pressure
Simple test
This example analyzes the deformation of a cylindrical shell (R=$0.01\,\text{m}$, thickness=$0.002\,\text{m}$, H=$0.015\,\text{m}$) under radial pressure. Due to symmetry, only half of the shell is considered. The normal displacement on the symmetry surfaces is fixed. The other boundary conditions are shown in the figure, where the uniformly distributed pressure is 6 MPa/m. The bulk modulus is 240 GPa, and the shear modulus is 6 GPa, corresponding to a Poisson’s ratio of 0.4.
ogs_model = SingleOGSModel("ThickCylindricalShell", use_fbar=False)… (click to toggle)
ogs_model.reset_time_step_size(0.3, 4)
ogs_model.run_benchmark(u_max_ref=[0, -0.01192143, 0.00029815])
 ogs -o /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking -m ThickCylindricalShell /var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking/modified.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking', '-m', 'ThickCylindricalShell', '/var/lib/gitlab-runner/builds/K-X1vcp78/0/ogs/build/release-all/Tests/Data/LargeDeformation/FbarBenchmarksLocking/modified.prj']
Without F-bar, the obtained maximum displacement of ThickCylindricalShell is [ 0.         -0.01192143  0.00029815] m.
ogs_model = SingleOGSModel("ThickCylindricalShell", use_fbar=True)
ogs_model.run_benchmark(u_max_ref=[0, -0.01510393, 0.00022727])
With F-bar, the obtained maximum displacement of ThickCylindricalShell is [ 0.         -0.01510393  0.00022727] m.
Reference
  1. T. Elguedj, Y. Bazilevs, V.M. Calo, T.J.R. Hughes (2008), $\bar\B$ and $\bar{\text F}$ projection methods for nearly incompressible linear and non-linear elasticity and plasticity using higher-order NURBS elements, Computer Methods in Applied Mechanics and Engineering, 197(33–40), 2732-2762.
This article was written by Wenqing Wang. If you are missing something or you find an error please reach out to us on our forum.
Generated with Hugo 0.164.0 in CI job 825193 | Last revision: November 26, 2024
