Heat conduction with phase change
Test cases
Three tests are presented:
- 1D homogeneous ,
- 1D heterogeneous , and
- 2D heterogeneous .
We simulate the melting of a 1D ice column including the latent heat necessary for this phase change. No solid (porous medium) is involved and the problem can either be homogeneous (volumetric heat source) or heterogeneous (boundary condition as heat input). Further, the heating of fully saturated porous medium with the shape of a disk is simulated including the phase change of pore water to pore ice.
See this PDF for the detailed description.
This article was written by Christian Silbermann, Thomas Nagel. If you are missing something or you find an error please reach out
to us on our forum.
Generated with Hugo 0.164.0
in CI job 825193
Last revision: April 20, 2026
