LIE related processes are not supported to use the parallel FEM scheme with PETSc.
scripts/env/eve/cli.shpartmeshcmake <path_to_source> -DOGS_BUILD_UTILS=ONscripts/env/eve/petsc.shcmake <path_to_source> -DOGS_USE_PETSC=ONmakeIn order to discretize the domain of a unit cube do
bin/generateStructuredMesh -o cube_1x1x1_hex_axbxc.vtu -e hex --lx 1 --ly 1 --lz 1 --nx a --ny b --nz c
where a, b, and c should be chosen according to the needs.
a |
b |
c |
#cells in 10^6 | compute cores | success |
| 150 | 150 | 150 | ~ 3.38 | 20 | yes |
| 175 | 175 | 175 | ~ 5.36 | 20 | yes |
| 190 | 190 | 190 | ~ 6.86 | 20 | yes |
| 196 | 196 | 196 | ~ 7.59 | 20 | no |
| 216 | 216 | 216 | ~ 10.08 | 40 | yes |
| 236 | 236 | 236 | ~ 13.14 | 40 | yes |
| 292 | 292 | 292 | ~ 24.90 | 80 | yes |
| 368 | 368 | 368 | ~ 49.84 | 160 | yes |
| 422 | 422 | 422 | ~ 75.15 | 240 | yes |
| 465 | 465 | 465 | ~ 100.54 | 320 |
For the boundary conditions, if they are simple (i.e. homogeneous), the
simplest .gml file is sufficient for the serial case, but for heterogeneous
boundary conditions and parallelization boundary mesh files are needed. There
are two possibilities to create such files:
.gml file, use constructMeshesFromGeometry
tool which
takes the mesh file and geometry and creates all the boundaries which are
named in the .gml file with the required bulk_node_ids and
bulk_element_ids mappings.identifySubdomains
tool to create or
verify the needed bulk_node_ids and bulk_element_ids mappings.partmeshbin/partmesh -i cube_1x1x1_hex_axbxc.vtu --ogs2metis cube_1x1x1_hex_axbxc.meshbin/partmesh -n number_of_partitions -m -i cube_1x1x1_hex_axbxc.vtu -- boundary_meshes*.vtu .bin files.This article was written by Thomas Fischer. If you are missing something or you find an error please let us know.
in CI job 683680
