import os…
(click to toggle)
The Liakopoulos experiment was dealing with a sand column which was filled with water first and then drained under gravity. A sketch of the related model set-up including initial and boundary conditions is shown in the above figure. A detailed description of the underlying OGS model is given in Grunwald et al. (2022). Two hydraulic models have been compared; two-phase flow with a mobile and a Richards flow with an immobile gas phase coupled to mechanical processes. Due to the absence of analytical solutions various numerical solutions have been compared in the past (see Grunwald et al., 2022).
The model parameters are given in the below table.
| Parameter | Value | Unit |
| Permeability | $k^0_\textrm{S}$ = 4.5 $\times$ 10$^{-13}$ | m$^2$ |
| Porosity | $\phi$ = 0.2975 | - |
| Young’s modulus | $E$ = 1.3 | MPa |
| Poisson ratio | $\nu$ = 0.4 | - |
| Dynamic viscosity of gas phase | $\mu_\textrm{GR}$ = 1.8 $\times$ 10$^{-5}$ | Pa s |
| Dynamic viscosity of liquid phase | $\mu_\textrm{LR}$ = 1.0 $\times$ 10$^{-3}$ | Pa s |
| Density of liquid phase | $\rho_\textrm{LR}$ = 1.0$\times$ 10$^3$ | kg m$^{-3}$ |
| Density of solid phase | $\rho_\textrm{SR}$ = 2.0$\times$ 10$^3$ | kg m$^{-3}$ |
prj_file = "liakopoulos_TH2M.prj"…
(click to toggle)
model = ot.Project(input_file=prj_file, output_file=prj_file)
model.run_model(logfile=f"{out_dir}/out.txt", args=f"-o {out_dir}")Project file written to output.
Simulation: liakopoulos_TH2M.prj
Execution took 5.137517690658569 s
ms = ot.MeshSeries(f"{out_dir}/result_liakopoulos.pvd")…
(click to toggle)
# plausibility checks
max_vals = {"gas_pressure": 1.02e5, "capillary_pressure": 1e4,
"saturation": 1.0001, "displacement": 0.005} # fmt:skip
def plot_sample(var: ot.variables.Scalar) -> None:
fig, ax = plt.subplots(figsize=[6, 3], dpi=150)
ax.set_xlabel(r"$y$ / m")
ax.set_ylabel(var.get_label())
for mesh, t in zip(ms, ms.timevalues, strict=True):
line_mesh = mesh.sample_over_line([0, 0, 0], [0, 1, 0])
vals = line_mesh.sample(mesh)[var.data_name]
assert np.all(np.abs(vals) <= max_vals[var.data_name]), max(abs(vals))
ax.plot(line_mesh.points[:, 1], var.transform(vals), label=f"{t=}", lw=2.5)
ax.legend()
ax.grid()
fig.tight_layout()plot_sample(ot.variables.Scalar("gas_pressure", "Pa", "MPa"))
plot_sample(ot.variables.Scalar("capillary_pressure", "Pa", "kPa"))
plot_sample(ot.variables.Scalar("saturation", "", "%"))
plot_sample(ot.variables.displacement["y"])
OGS links
Credits
Grunwald, N., Lehmann, C., Maßmann, J., Naumov, D., Kolditz, O., Nagel, T., (2022): Non-isothermal two-phase flow in deformable porous media: systematic open-source implementation and verification procedure. Geomech. Geophys. Geo-Energy Geo-Resour. 8 (3), art. 107 https://doi.org/10.1007/s40948-022-00394-2
Kolditz, O., Görke, U.-J., Shao, H., Wang, W., (eds., 2012): Thermo-hydro-mechanical-chemical processes in porous media: Benchmarks and examples. Lecture Notes in Computational Science and Engineering 86, Springer, Berlin, Heidelberg, 391 pp https://link.springer.com/book/10.1007/978-3-642-27177-9
Lewis RW, Schrefler BA (1998): The finite element method in the static and dynamic deformation and consolidation of porous media. Wiley, New York https://www.wiley.com/en-us/The+Finite+Element+Method+in+the+Static+and+Dynamic+Deformation+and+Consolidation+of+Porous+Media%2C+2nd+Edition-p-9780471928096
Liakopoulos AC (1964): Transient flow through unsaturated porous media. PhD thesis. University of California, Berkeley, USA. sources: OGS BMB1 (sec. 13.2
This article was written by Norbert Grunwald, Olaf Kolditz. If you are missing something or you find an error please let us know.
in CI job 683680
Last revision: August 16, 2022
