In this test, the thermodynamic relationships between gas pressure, temperature and density are tested. For that, a cube-shaped domain consisting of an ideal gas is compressed by 50% of its initial volume over a short period of time, starting from the top surface. The boundaries of that domain are impermeable to fluid flow, therefore gas pressure and density must increase as a result of the decreasing volume. Since energy flow across the boundaries is also prevented, this compression is an adiabatic change of state. No frictional losses are taken into account, so the process can be reversed at any time and the entropy in the overall system remains constant.
The mass balance for such a system can be found by simplifying the mass balance (eq. 44 in Grunwald et al., 2022). With $\phi=s_\mathrm{G}=\alpha_\mathrm{B}=1$ and $\mathrm{A}^\zeta_\alpha=\mathrm{J}^\zeta_\alpha=0$ one obtains
$$ 0=\rho_\mathrm{GR}\mathrm{div}\left(\mathbf{u}_\mathrm{S}\right)'_\mathrm{S}+\left(\rho_\mathrm{GR}\right)'_\mathrm{S} $$With volume strain $e=\text{div}\left(\mathbf{u}_\text{S}\right)'_\text{S}$ we write
$$ \frac{1}{\rho_\text{GR}}\left(\rho_\text{GR}\right)'_\text{S}=-e, $$which can be integrated
$$ \int^{\rho_\text{GR}}_{\rho_{\text{GR},0}}\frac{1}{\rho_\text{GR}}\text{d}\,\rho_\text{GR}=-e $$so that we find
$$ \ln\left(\rho_\text{GR}\right) - \ln\left(\rho_{\text{GR},0}\right) = -e $$or
$$ \rho_\text{GR}=\rho_{\text{GR},0}\exp\left(-e\right). $$The evolution of gas pressure can be found from energy balance equation (eq. 51 in the paper): Starting from
$$ \left(\Sigma_\alpha\rho_\alpha u_\alpha\right)'_\text{S} +\left(\Sigma_\alpha\rho_\alpha h_\alpha\right)\text{div}\left(\mathbf{u}_\text{S}\right)'_\text{S} =0, $$with $u_\text{S}=h_\text{S}$ and $u_\text{G}=h_\text{G}-\frac{p_\text{GR}}{\rho_\text{GR}}$ and with $h_\alpha=c_{p,\alpha}T$. Considering that $\phi_\alpha=\text{const}$ and $c_{p,\text{S}}=0$, we find
$$ \left(\rho_\text{GR}\right)'_\text{S}\left(c_{p,\text{G}}T-p_\text{GR}\rho_\text{GR}^{-1}\right) + \rho_\text{GR}\left(c_{p,\text{G}}T-p_\text{GR}\rho_\text{GR}^{-1}\right)'_\text{S} + \rho_\text{GR}c_{p,\text{G}}Te=0. $$Assuming ideal gas behaviour, we can write $\frac{p_\text{GR}}{\rho_\text{GR}}=\frac{M}{RT}$ and find
$$ \left(\rho_\text{GR}\right)'_\text{S}c_{v,\text{G}}T + \rho_\text{GR}\left(c_{v,\text{G}}T\right)'_\text{S} + \rho_\text{GR}c_{p,\text{G}}Te=0. $$With $c_{v,\text{G}}=\text{const}$ it follows
$$ \frac{\rho_\text{GR}}{p_\text{GR}}\left(p_\text{GR}\right)'_\text{S}c_{v,\text{G}}T + \rho_\text{GR}c_{p,\text{G}}Te=0. $$Density and temperature cancel out so the final equation can be written as
$$ \frac{1}{p_\text{GR}}\left(p_\text{GR}\right)'_\text{S} =-\kappa e $$with the adiabatic index $\kappa = \frac{c_v}{c_p}$. The equation can be integrated to find the solution for the pressure evolution
$$ p_\text{GR}=p_{\text{GR},0}\exp\left(-\kappa e\right) $$The temperature evolution follows Poissons equations for isentropic processes
$$ T=T_0\left(\frac{p_\text{GR}}{p_{\text{GR},0}}\right)^{\frac{\kappa-1}{\kappa}}. $$import os…
(click to toggle)
out_dir.mkdir(parents=True, exist_ok=True)p_0 = 1e6…
(click to toggle)
p_0 = 1e6
T_0 = 270
R = 8.3144621
M = 0.01
c_p = 1000
c_v = c_p - R / M
rho_0 = p_0 * M / R / T_0
kappa = c_p / c_v
def volume_strain(t):
return -t / 100
def gas_density(t):
return rho_0 * np.exp(-volume_strain(t))
def gas_pressure(t):
return p_0 * np.exp(-kappa * volume_strain(t))
def temperature(t):
return gas_pressure(t) * M / R / gas_density(t)# run OGS…
(click to toggle)
# run OGS
cube_compression = ot.Project(
input_file="compression_gas.prj", output_file="compression_gas.prj"
cube_compression.run_model(logfile=f"{out_dir}/out.txt", args=f"-o {out_dir}")Project file written to output.
Simulation: compression_gas.prj
Execution took 0.1932976245880127 s
# read PVD file…
(click to toggle)
# read PVD file
ms = ot.MeshSeries(f"{out_dir}/result_compression_gas.pvd")
time = ms.timevalues
def plot_results_errors(var: ot.variables.Scalar, ref_vals: np.ndarray):
"Plot numerical results, analytical solution and errors."
num_vals = ms.probe([0.0, 1.0, 0.0], var.data_name)
abs_err = ref_vals - num_vals
rel_err = abs_err / ref_vals
assert np.all(np.abs(rel_err) <= 0.002)
fig, (ax1, ax2) = plt.subplots(1, 2, figsize=(10, 4))
ax3 = ax2.twinx()
ax1.set_xlabel(r"$t$ / s")
ax2.set_xlabel(r"$t$ / s")
ax2.set_ylabel("absolute error / " + var.data_unit)
ax3.set_ylabel("relative error")
ax1.plot(time, var.transform(num_vals), "kx", label="numerical")
ax1.plot(time, var.transform(ref_vals), "b", label="analytical")
lns_abs = ax2.plot(time, abs_err, "b", label=r"absolute")
lns_rel = ax3.plot(time, rel_err, "g", label=r"relative")
ax1.legend()
lns = lns_abs + lns_rel
fig.tight_layout()rho_g = ot.variables.Scalar("gas_density", r"kg/$m^3$", r"kg/$m^3$")
plot_results_errors(rho_g, gas_density(ms.timevalues))
p_g = ot.variables.Scalar("gas_pressure_interpolated", "Pa", "MPa")
plot_results_errors(p_g, gas_pressure(ms.timevalues))
plot_results_errors(ot.variables.temperature, temperature(ms.timevalues))
in CI job 683680
Last revision: October 19, 2022
